I've put midi on a accordion with a arduino mega. I've changed to a teensy 4.1 for the native midi on usb.
Now I have a strange behavior on the keyboard matrix.
I have a 12 row 4 column matrix for the right hand. It worked fine with the Mega.
Now I get a constant midi output. Even if I don't attach any wires. Just a bare Teensy. I changed the pin (11) in the sketch, but the problem consists.
If I remove the last row on pin 11 it works fine. I can use the keyboard. But add the last row the constant output is back. I get the same note. D#
keypad.h has 12 rows as maximum.
I have to work out other issues to, but want to sort this out before wasting time on a broken teensy if that would be the case.
Could sombody give me a hint, I can't find anything.
#include <Keypad.h>
static const bool UseRunningStatus = false;
int val = 0;
int lastVal = 0;
unsigned long time_to_Measure = 0;
const int Measure_Period = 2000; // Update measurement every 2000 msec.
//MIDI_CREATE_DEFAULT_INSTANCE();
const byte ROWS = 11;
const byte COLS = 4;
//define the cymbols on the buttons of the keypads
char keys[ROWS][COLS] = {
{0,76,88,100},//E 22
{65,77,89,101},//F 23
{66,78,90,102},//F# 24
{67,79,91,103},//G 25
{68,80,92,104},//G# 26
{69,81,93,105},//A 27
{70,82,94,0},//A# 28
{71,83,95,0},//B 31
{72,84,96,0},//C 29
{73,85,97,0},//C# 30
{74,86,98,0}//,//D 32
{75,87,99,0}//D# 33
byte rowPins[ROWS] = {0,1,2,3,4,5,6,7,8,9,10,11}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {26,25,24,12}; //connect to the column pinouts of the keypad
const byte ROWSBAS = 6;
const byte COLSBAS = 4;
char keys2[ROWSBAS][COLSBAS] = {
{38,44}, //D,G#
{37,39}, //C#,D#
{42,46}, //F#,A#
{47,41}, //B,F
{40,36}, //E,C
{45,43} //A,G
byte rowPins2[ROWSBAS] = {27,28,29,30,31,32}; //connect to the row pinouts of the keypad
byte colPins2[COLSBAS] = {34,33}; //connect to the column pinouts of the keypad
const byte ROWSBASAK = 6;
const byte COLSBASAK = 2;
char keysAK[ROWSBASAK][COLSBASAK] = {
{45,39}, //A,D#,
{44,38}, //G#,D,
{43,37}, //G,C#,
{42,36}, //F#,C,
{41,47}, //F,B,
{40,46} //E,A#,
byte rowPinsAK[ROWSBASAK] = {27,28,29,30,31,32}; //connect to the row pinouts of the keypad
byte colPinsAK[COLSBASAK] = {36,35}; //connect to the column pinouts of the keypad
// registerdeel
const byte ROWSREG = 7;
const byte COLSREG = 2;
char keys3[ROWSREG][COLSREG] = {
{48,54},
{49},
{50},
{51},
{52},
{53}
//{54}
byte rowPins3[ROWSREG] = {13,37,38,39,40,41};
byte colPins3[COLSREG] = {14,15};
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
Keypad kpd2 = Keypad( makeKeymap(keys2), rowPins2, colPins2, ROWSBAS, COLSBAS);
Keypad kpd3 = Keypad( makeKeymap(keys3), rowPins3, colPins3, ROWSREG, COLSREG);
Keypad kpdAK = Keypad( makeKeymap(keysAK), rowPinsAK, colPinsAK, ROWSBASAK, COLSBASAK);
String msg; //for debugging
// master volume part //
byte analogPin = A2;
kpd.setDebounceTime(100); //debounce 50 miliceconde
//kpd2.setDebounceTime(50); //debounce 50 miliceconde
//kpdAK.setDebounceTime(50); //debounce 50 miliceconde
//kpd.setHoldTime(50);
volumepod();
diskant();
baskant();
regdiskant();
// volume
void volumepod(){
if ((millis() - time_to_Measure) > Measure_Period) {
val = analogRead(A2)/8; // Divide by 8 to get range of 0-127 for midi
if (val != lastVal) // If the value does not = the last value the following command is made. This is because the pot has been turned. Otherwise the pot remains the same and no midi message is output.
usbMIDI.sendControlChange(7, val, 1);
usbMIDI.sendControlChange(7, val, 2);
usbMIDI.sendControlChange(7, val, 3);
usbMIDI.sendControlChange(7, val, 4);
usbMIDI.sendControlChange(7, val, 5);
usbMIDI.sendControlChange(7, val, 6);
usbMIDI.sendControlChange(7, val, 7);
usbMIDI.sendControlChange(7, val, 8);
usbMIDI.sendControlChange(7, val, 9);
usbMIDI.sendControlChange(7, val, 10);
usbMIDI.sendControlChange(7, val, 11);
usbMIDI.sendControlChange(7, val, 12);
usbMIDI.sendControlChange(7, val, 13);
usbMIDI.sendControlChange(7, val, 13);} // cc control nummer (7 volume), waarde, kanaal
lastVal = val;
time_to_Measure = millis();
//delay(10); //here we add a short delay to help prevent slight fluctuations, knocks on the pots etc. Adding this helped to prevent my pots from jumpin up or down a value when slightly touched or knocked.
// diskant knoppen
void diskant(){
// Fills kpd.key[ ] array with up-to 10 active keys.
// Returns true if there are ANY active keys.
if (kpd.getKeys())
for (int i=0; i<LIST_MAX; i++) // Scan the whole key list.
if ( kpd.key[i].stateChanged ) // Only find keys that have changed state.
int midinote = kpd.key[i].kchar; //convert the midi note to int from char
switch (kpd.key[i].kstate) { // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
case PRESSED: //this messages are for debugging so they are not necessary.
//msg = " PRESSED.";
usbMIDI.sendNoteOn(midinote, 127, 1); //12 is an octave shift (I developed all the code so C1 was the lowest note. With this, it is C2 instead).
usbMIDI.sendNoteOn(midinote, 127, 4);
usbMIDI.sendNoteOn(midinote, 127, 5);
usbMIDI.sendNoteOn(midinote, 127, 6);
usbMIDI.sendNoteOn(midinote, 127, 7);
usbMIDI.sendNoteOn(midinote, 127, 8);
usbMIDI.sendNoteOn(midinote, 127, 9);
usbMIDI.sendNoteOn(midinote, 127, 10);
usbMIDI.sendNoteOn(midinote, 127, 11);
usbMIDI.sendNoteOn(midinote, 127, 12);
usbMIDI.sendPitchBend(-300,4); //musset midden riet op toon
usbMIDI.sendPitchBend(-1035,5); //Frans musette -18cent
usbMIDI.sendPitchBend(+448,6); //Frans musette +18cent
usbMIDI.sendPitchBend(-820,7); //Italiaans musette -13cent
usbMIDI.sendPitchBend(+245,8); //Italiaans musette +13cent
usbMIDI.sendPitchBend(-770,9); //Bayan musette -12cent
usbMIDI.sendPitchBend(+330,10); //Bayan musette +15cent
usbMIDI.sendPitchBend(-610,11); //Amerikaans musette -8cent
usbMIDI.sendPitchBend(+80,12); //Amerikaans musette +8cent
case RELEASED:
//msg = " RELEASED.";
usbMIDI.sendNoteOff(midinote, 127, 1);
usbMIDI.sendNoteOff(midinote, 127, 4);
usbMIDI.sendNoteOff(midinote, 127, 5);
usbMIDI.sendNoteOff(midinote, 127, 6);
usbMIDI.sendNoteOff(midinote, 127, 7);
usbMIDI.sendNoteOff(midinote, 127, 8);
usbMIDI.sendNoteOff(midinote, 127, 9);
usbMIDI.sendNoteOff(midinote, 127, 10);
usbMIDI.sendNoteOff(midinote, 127, 11);
usbMIDI.sendNoteOff(midinote, 127, 12);
case HOLD:
case IDLE:
// einde diskant
// bas knoppen
void baskant (){
if (kpd2.getKeys())
if ( kpd2.key[i].stateChanged ) // Only find keys that have changed state.
int midinote = kpd2.key[i].kchar; //convert the midi note to int from char
switch (kpd2.key[i].kstate) { // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
usbMIDI.sendNoteOn(midinote, 127, 2); //(midinote+12, 127, 1)
case RELEASED:
// usbMIDI.sendControlChange(123,0,2);
usbMIDI.sendNoteOff(midinote, 120, 2);
case HOLD:
case IDLE:
//usbMIDI.sendControlChange(123,0,2);
usbMIDI.sendNoteOff(midinote+12, 120, 2);
delay(30);
if (kpdAK.getKeys())
if ( kpdAK.key[i].stateChanged ) // Only find keys that have changed state.
int midinote = kpdAK.key[i].kchar; //convert the midi note to int from char
switch (kpdAK.key[i].kstate) { // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
usbMIDI.sendNoteOn(midinote, 127, 3); //(midinote+12, 127, 1)
// usbMIDI.sendNoteOn(midinote+12, 120, 2);
case RELEASED:
// usbMIDI.sendControlChange(123,0,3);
usbMIDI.sendNoteOff(midinote+12, 120, 2);//(midinote+12, 127, 1)
case HOLD:
case IDLE:
//usbMIDI.sendControlChange(123,0,3);
delay(30);
// einde bas
// disregister
void regdiskant(){
if (kpd3.getKeys())
if ( kpd3.key[i].stateChanged ) // Only find keys that have changed state.
int midinote = kpd3.key[i].kchar; //convert the midi note to int from char
switch (kpd3.key[i].kstate) { // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
case RELEASED:
usbMIDI.sendNoteOff(midinote, 127, 1); //(midinote+12, 127, 1)
case HOLD:
case IDLE:
//einde disregister
