Nolan.Decker
New member
Hi all. I'm trying to build a macro pad.
Eventually it will have numerous keys. Hence, I'm planning to implement a keyboard matrix. At this initial stage however, it only has two keys so my matrix is 1 row by 2 columns.
Here are pics of my prototype. I added callouts to assist communication.
Here is my code. It builds and uploads without errors.
The serial monitor is showing the avg loops/second as expected, but when I press the keys there's no output on the serial monitor or in the verbose info panel. I'm not seeing any errors.
When I verify I get this output...
When I upload I get this output...
Here's the serial monitor...
Any insight would be really helpful. Thanks!
(btw I was able to get a 1x1 matrix to work — in other words same code as above with keys defined as
and a single keyswitch wired to the board.)
#include <Keypad.h>
const byte ROWS = 1; // rows
const byte COLS = 2; // columns
//define the symbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
{'a','b'}
byte rowPins[ROWS] = {4}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {7, 6}; //connect to the column pinouts of the keypad
//initialize an instance of class Keypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS );
unsigned long loopCount;
unsigned long startTime;
String msg;
void setup(){
loopCount = 0;
startTime = millis();
msg = "";
void loop(){
loopCount++;
if ( (millis()-startTime)>2000 ) {
Serial.print("Average loops per second = ");
Serial.println(loopCount/5);
loopCount = 0;
char customKey = customKeypad.getKey();
if (customKey){
Serial.println("Keypress occurred");
Serial.println(customKey);
18:35:12.428 (post_compile 58): Begin, version=1.56, high-res time
18:35:12.431 (loader): remote connection 1604 opened
18:35:12.432 (loader): remote cmd from 1604: "comment: Teensyduino 1.56 - WINDOWS (teensy_post_compile)"
18:35:12.432 (post_compile 58): Sending command: comment: Teensyduino 1.56 - WINDOWS (teensy_post_compile)
18:35:12.433 (loader): remote cmd from 1604: "status"
18:35:12.434 (loader): file changed
18:35:12.443 (loader): File "C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\CustomKeypad.ino.hex", 30720 bytes
18:35:12.444 (loader): File "CustomKeypad.ino.hex". 30720 bytes
18:35:12.451 (post_compile 58): Status: 1, 1, 0, 13, 0, 0, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:35:12.451 (post_compile 58): Sending command: dir:C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\
18:35:12.454 (loader): remote cmd from 1604: "dir:C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\"
18:35:12.455 (loader): remote cmd from 1604: "file:CustomKeypad.ino.hex"
18:35:12.455 (post_compile 58): Sending command: file:CustomKeypad.ino.hex
18:35:12.465 (loader): File "C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\CustomKeypad.ino.hex", 30720 bytes
18:35:12.466 (loader): File "CustomKeypad.ino.hex". 30720 bytes
18:35:12.471 (loader): remote cmd from 1604: "status"
18:35:12.478 (post_compile 58): Status: 1, 1, 0, 13, 0, 0, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:35:12.478 (post_compile 58): Disconnect
18:35:12.494 (loader): remote connection 1604 closed
18:35:55.643 (loader): remote connection 1620 closed
18:35:59.544 (loader): file changed
18:35:59.555 (loader): File "C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\CustomKeypad.ino.hex", 30720 bytes
18:35:59.555 (loader): File "CustomKeypad.ino.hex". 30720 bytes
18:35:59.586 (post_compile 59): Begin, version=1.56, high-res time
18:35:59.588 (loader): remote connection 1604 opened
18:35:59.589 (loader): remote cmd from 1604: "comment: Teensyduino 1.56 - WINDOWS (teensy_post_compile)"
18:35:59.590 (post_compile 59): Sending command: comment: Teensyduino 1.56 - WINDOWS (teensy_post_compile)
18:35:59.590 (loader): remote cmd from 1604: "status"
18:35:59.597 (loader): remote cmd from 1604: "dir:C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\"
18:35:59.598 (post_compile 59): Status: 1, 1, 0, 13, 0, 0, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:35:59.598 (post_compile 59): Sending command: dir:C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\
18:35:59.598 (loader): remote cmd from 1604: "file:CustomKeypad.ino.hex"
18:35:59.599 (post_compile 59): Sending command: file:CustomKeypad.ino.hex
18:35:59.607 (loader): File "C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\CustomKeypad.ino.hex", 30720 bytes
18:35:59.609 (loader): File "CustomKeypad.ino.hex". 30720 bytes
18:35:59.617 (loader): remote cmd from 1604: "status"
18:35:59.625 (post_compile 59): Status: 1, 1, 0, 13, 0, 0, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:35:59.625 (post_compile 59): Disconnect
18:35:59.639 (loader): remote connection 1604 closed
18:35:59.920 (post_compile 60): Begin, version=1.56, high-res time
18:35:59.923 (loader): remote connection 1604 opened
18:35:59.925 (loader): remote cmd from 1604: "comment: Teensyduino 1.56 - WINDOWS (teensy_post_compile)"
18:35:59.925 (post_compile 60): Sending command: comment: Teensyduino 1.56 - WINDOWS (teensy_post_compile)
18:35:59.928 (loader): remote cmd from 1604: "status"
18:35:59.935 (loader): remote cmd from 1604: "dir:C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\"
18:35:59.936 (post_compile 60): Status: 1, 1, 0, 13, 0, 0, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:35:59.936 (post_compile 60): Sending command: dir:C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\
18:35:59.938 (loader): remote cmd from 1604: "file:CustomKeypad.ino.hex"
18:35:59.938 (post_compile 60): Sending command: file:CustomKeypad.ino.hex
18:35:59.949 (loader): File "C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\CustomKeypad.ino.hex", 30720 bytes
18:35:59.952 (loader): File "CustomKeypad.ino.hex". 30720 bytes
18:35:59.959 (loader): remote cmd from 1604: "status"
18:35:59.967 (post_compile 60): Status: 1, 1, 0, 13, 0, 0, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:35:59.967 (post_compile 60): Disconnect
18:35:59.981 (loader): remote connection 1604 closed
18:35:59.982 (post_compile 61): Running teensy_reboot: "C:\Program Files (x86)\Arduino\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY41" "-port=usb:70001/3/0/3" "-portlabel=hid#vid_16c0&pid_0478 Bootloader" "-portprotocol=Teensy"
18:35:59.985 (loader): remote connection 1604 opened
18:36:00.004 (reboot 62): Begin, version=1.56, high-res time
18:36:00.004 (reboot 62): location = usb:70001/3/0/3
18:36:00.004 (reboot 62): portprotocol = Teensy
18:36:00.004 (reboot 62): portlabel = hid#vid_16c0&pid_0478 Bootloader
18:36:00.004 (reboot 62): Only location usb:70001/3/0/3 will be tried
18:36:00.004 (reboot 62): LoadLibrary cfgmgr32 ok
18:36:00.004 (reboot 62): LoadLibrary ntdll ok
18:36:00.005 (reboot 62): found_usb_device, id=\\?\usb#vid_16c0&pid_04d0#10996430#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
18:36:00.005 (reboot 62): found_usb_device, loc=usb:70001/3/0/3 Port_#0003.Hub_#0002
18:36:00.005 (reboot 62): found_usb_device, hwid=USB\VID_16C0&PID_04D0&REV_0280
18:36:00.005 (reboot 62): found_usb_device, devinst=00000007
18:36:00.005 (reboot 62): add: loc=usb:70001/3/0/3, class=USB, vid=16C0, pid=04D0, ver=0280, serial=10996430, dev=\\?\usb#vid_16c0&pid_04d0#10996430#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
18:36:00.006 (reboot 62): hiddev_from_devinst_list: iface=1
18:36:00.006 (reboot 62): 0000000E: path=\\?\hid#vid_16c0&pid_04d0&mi_01#8&3ad25e64&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
18:36:00.008 (reboot 62): found_usb_device complete
18:36:00.008 (reboot 62): hid, found devinst=0000000C
18:36:00.008 (reboot 62): hid, found devinst=0000000E
18:36:00.008 (reboot 62): hid, found devinst=00000010
18:36:00.008 (reboot 62): usb scan found 1 devices
18:36:00.010 (loader): remote connection 1740 opened
18:36:00.015 (loader): remote cmd from 1740: "show:arduino_attempt_reboot"
18:36:00.016 (reboot 62): found Teensy Loader, version 1.56
18:36:00.016 (reboot 62): Sending command: show:arduino_attempt_reboot
18:36:00.019 (loader): got request to show arduino rebooting message
18:36:00.025 (loader): remote cmd from 1740: "comment: Teensyduino 1.56 - WINDOWS (teensy_reboot)"
18:36:00.026 (reboot 62): Sending command: comment: Teensyduino 1.56 - WINDOWS (teensy_reboot)
18:36:00.029 (loader): remote cmd from 1740: "status"
18:36:00.044 (reboot 62): Status: 1, 1, 0, 13, 0, 0, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:36:00.044 (reboot 62): hid_send_feature
18:36:00.044 (loader): remote cmd from 1740: "status"
18:36:00.053 (reboot 62): Status: 1, 1, 0, 13, 0, 0, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:36:00.053 (reboot 62): status read, retry 0
18:36:00.154 (loader): remote cmd from 1740: "status"
18:36:00.165 (reboot 62): Status: 1, 1, 0, 13, 0, 0, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:36:00.165 (reboot 62): status read, retry 1
18:36:00.266 (loader): remote cmd from 1740: "status"
18:36:00.277 (reboot 62): Status: 1, 1, 0, 13, 0, 0, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:36:00.277 (reboot 62): status read, retry 2
18:36:00.378 (loader): remote cmd from 1740: "status"
18:36:00.387 (reboot 62): Status: 1, 1, 0, 13, 0, 0, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:36:00.387 (reboot 62): status read, retry 3
18:36:00.489 (loader): remote cmd from 1740: "status"
18:36:00.498 (reboot 62): Status: 1, 1, 0, 13, 0, 0, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:36:00.498 (reboot 62): status read, retry 4
18:36:00.588 (ports 22): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
18:36:00.589 (ports 22): remove: loc=usb:70001/3/0/3
18:36:00.589 (ports 22): usb_remove: usb:70001/3/0/3
18:36:00.589 (ports 22): nothing new, skipping HID & Ports enum
18:36:00.601 (ports 22): WM_DEVICECHANGE DBT_DEVICEARRIVAL
18:36:00.603 (ports 22): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#0010c77b#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
18:36:00.603 (ports 22): found_usb_device, loc=usb:70001/3/0/3 Port_#0003.Hub_#0002
18:36:00.603 (ports 22): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0107
18:36:00.603 (ports 22): found_usb_device, devinst=00000023
18:36:00.603 (ports 22): add: loc=usb:70001/3/0/3, class=HID, vid=16C0, pid=0478, ver=0107, serial=0010c77b, dev=\\?\usb#vid_16c0&pid_0478#0010c77b#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
18:36:00.603 (ports 22): hiddev_from_devinst_list: iface=0
18:36:00.603 (ports 22): found_usb_device complete
18:36:00.604 (ports 22): usb_add: usb:70001/3/0/3 [no_device] (Teensy 4.1) Bootloader
18:36:00.617 (loader): remote cmd from 1740: "status"
18:36:00.628 (loader): secure mode can not be locked: this is Standard Teensy
18:36:00.632 (loader): encryption is possible on this Teensy, but not yet configured
18:36:00.636 (loader): but without secure mode locked, encryption will NOT be secure!
18:36:00.640 (loader): Device came online, code_size = 8126464
18:36:00.644 (loader): Board is: Teensy 4.1 (IMXRT1062), version 1.07
18:36:00.656 (loader): File "C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\CustomKeypad.ino.hex", 30720 bytes
18:36:00.661 (loader): File "CustomKeypad.ino.hex". 30720 bytes, 0% used
18:36:00.688 (loader): set background IMG_ONLINE
18:36:00.702 (loader): File "C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\CustomKeypad.ino.hex", 30720 bytes
18:36:00.706 (loader): File "CustomKeypad.ino.hex". 30720 bytes, 0% used
18:36:00.733 (loader): elf appears to be for Teensy 4.1 (IMXRT1062) (8126464 bytes)
18:36:00.737 (loader): elf binary data matches hex file
18:36:00.741 (loader): elf file is for Teensy 4.1 (IMXRT1062)
18:36:00.745 (loader): using hex file
18:36:00.770 (loader): begin operation
18:36:00.804 (reboot 62): Status: 1, 1, 1, 14, 0, 1, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:36:00.825 (ports 22): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
18:36:00.825 (ports 22): update_usb_device, devinst list change, old had 1, new has 2
18:36:00.825 (ports 22): hiddev_from_devinst_list: iface=0
18:36:00.827 (ports 22): hid, found devinst=00000024
18:36:00.827 (ports 22): hid, path=\\?\hid#vid_16c0&pid_0478#7&fcf674e&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
18:36:00.827 (ports 22): hid, opened handle
18:36:00.827 (ports 22): devinst=00000024, location=usb:70001/3/0/3
18:36:00.827 (ports 22): vid=16C0, pid=0478, ver=0107, usepage=FF9C, use=0025
18:36:00.827 (ports 22): devpath=\\?\hid#vid_16c0&pid_0478#7&fcf674e&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
18:36:00.827 (ports 22): usb_add: usb:70001/3/0/3 hid#vid_16c0&pid_0478 (Teensy 4.1) Bootloader
18:36:00.871 (loader): remote cmd from 1740: "status"
18:36:00.878 (reboot 62): Status: 1, 1, 1, 14, 0, 1, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:36:00.880 (loader): flash, block=0, bs=1024, auto=1
18:36:00.887 (loader): flash, block=1, bs=1024, auto=1
18:36:00.891 (loader): flash, block=2, bs=1024, auto=1
18:36:01.138 (loader): remote cmd from 1740: "status"
18:36:01.144 (loader): flash, block=3, bs=1024, auto=1
18:36:01.144 (reboot 62): Status: 1, 1, 1, 14, 0, 1, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:36:01.148 (loader): flash, block=4, bs=1024, auto=1
18:36:01.157 (loader): flash, block=5, bs=1024, auto=1
18:36:01.166 (loader): flash, block=6, bs=1024, auto=1
18:36:01.174 (loader): flash, block=7, bs=1024, auto=1
18:36:01.192 (loader): flash, block=8, bs=1024, auto=1
18:36:01.199 (loader): flash, block=9, bs=1024, auto=1
18:36:01.205 (loader): remote cmd from 1740: "status"
18:36:01.211 (loader): flash, block=10, bs=1024, auto=1
18:36:01.211 (reboot 62): Status: 1, 1, 1, 14, 0, 1, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:36:01.220 (loader): flash, block=11, bs=1024, auto=1
18:36:01.231 (loader): flash, block=12, bs=1024, auto=1
18:36:01.238 (loader): flash, block=13, bs=1024, auto=1
18:36:01.245 (loader): flash, block=14, bs=1024, auto=1
18:36:01.254 (loader): flash, block=15, bs=1024, auto=1
18:36:01.261 (loader): flash, block=16, bs=1024, auto=1
18:36:01.270 (loader): remote cmd from 1740: "status"
18:36:01.274 (reboot 62): Status: 1, 1, 1, 14, 0, 1, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:36:01.275 (loader): flash, block=17, bs=1024, auto=1
18:36:01.281 (loader): flash, block=18, bs=1024, auto=1
18:36:01.288 (ports 22): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
18:36:01.289 (ports 22): nothing new, skipping HID & Ports enum
18:36:01.311 (loader): flash, block=19, bs=1024, auto=1
18:36:01.319 (loader): flash, block=20, bs=1024, auto=1
18:36:01.324 (loader): flash, block=21, bs=1024, auto=1
18:36:01.331 (loader): remote cmd from 1740: "status"
18:36:01.336 (reboot 62): Status: 1, 1, 1, 14, 0, 1, C:\Users\nolan\AppData\Local\Temp\arduino_build_900335\, CustomKeypad.ino.hex
18:36:01.336 (loader): flash, block=22, bs=1024, auto=1
18:36:01.342 (loader): flash, block=23, bs=1024, auto=1
18:36:01.347 (loader): flash, block=24, bs=1024, auto=1
18:36:01.352 (loader): flash, block=25, bs=1024, auto=1
18:36:01.358 (loader): flash, block=26, bs=1024, auto=1
18:36:01.364 (loader): flash, block=27, bs=1024, auto=1
18:36:01.369 (loader): flash, block=28, bs=1024, auto=1
18:36:01.376 (loader): flash, block=29, bs=1024, auto=1
18:36:01.391 (reboot 62): status read, retry 5
18:36:01.391 (reboot 62): Success
18:36:01.391 (reboot 62): Disconnect
18:36:01.404 (loader): sending reboot
18:36:01.410 (loader): begin wait_until_offline
18:36:01.416 (loader): offline, waited 0
18:36:01.422 (ports 22): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
18:36:01.423 (ports 22): remove: loc=usb:70001/3/0/3
18:36:01.423 (ports 22): usb_remove: usb:70001/3/0/3
18:36:01.423 (ports 22): nothing new, skipping HID & Ports enum
18:36:01.427 (loader): end operation, total time = 0.653 seconds
18:36:01.433 (loader): set background IMG_REBOOT_OK
18:36:01.440 (loader): redraw timer set, image 14 to show for 1200 ms
18:36:01.445 (loader): remote connection 1740 closed
18:36:01.445 (loader): remote connection 1604 closed
18:36:01.455 (serialmon 63): Begin, version=1.56, high-res time
18:36:01.455 (serialmon 63): listening for location: usb:70001/3/0/3
18:36:01.455 (serialmon 63): LoadLibrary cfgmgr32 ok
18:36:01.455 (serialmon 63): LoadLibrary ntdll ok
18:36:01.539 (serialmon 63): callback 0024
18:36:01.539 (serialmon 63): callback 0081
18:36:01.543 (serialmon 63): callback 0083
18:36:01.543 (serialmon 63): hWnd = 853926
18:36:01.543 (serialmon 63): loop stdin, ready=262143
18:36:01.547 (serialmon 63): nothing new, skipping HID & Ports enum
18:36:01.549 (loader): HID/win32: vid:04D9 pid:A0F8 ver:0392 usb:70001/3/0/2/4/4/6
18:36:01.554 (loader): HID/win32: vid:258A pid:0059 ver:1022 usb:70001/3/0/1/4/4/4/4/5
18:36:01.559 (loader): HID/win32: vid:258A pid:0059 ver:1022 usb:70001/3/0/1/4/4/4/4/5
18:36:01.564 (loader): HID/win32: vid:258A pid:0059 ver:1022 usb:70001/3/0/1/4/4/4/4/5
18:36:01.575 (loader): HID/win32: vid:04D9 pid:A0F8 ver:0392 usb:70001/3/0/2/4/4/5
18:36:01.581 (loader): HID/win32: vid:258A pid:0059 ver:1022 usb:70001/3/0/1/4/4/4/4/5
18:36:01.593 (loader): HID/win32: vid:04D9 pid:A0F8 ver:0392 usb:70001/3/0/2/4/4/5
18:36:01.597 (loader): HID/win32: vid:1395 pid:0031 ver:0104 usb:10003/0/0/E/11
18:36:01.607 (loader): HID/win32: vid:046D pid:C24A ver:7702 usb:70001/3/0/1/2/3
18:36:01.611 (loader): HID/win32: vid:054C pid:0CD3 ver:0104 usb:70001/3/0/1/4/4/2
18:36:01.615 (loader): remote connection 1796 opened
18:36:01.631 (serialmon 63): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
18:36:01.632 (serialmon 63): nothing new, skipping HID & Ports enum
18:36:01.660 (ports 22): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
18:36:01.660 (ports 22): nothing new, skipping HID & Ports enum
18:36:01.721 (ports 22): WM_DEVICECHANGE DBT_DEVICEARRIVAL
18:36:01.721 (serialmon 63): WM_DEVICECHANGE DBT_DEVICEARRIVAL
18:36:01.722 (ports 22): found_usb_device, id=\\?\usb#vid_16c0&pid_04d0#10996430#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
18:36:01.722 (ports 22): found_usb_device, loc=usb:70001/3/0/3 Port_#0003.Hub_#0002
18:36:01.722 (ports 22): found_usb_device, hwid=USB\VID_16C0&PID_04D0&REV_0280
18:36:01.722 (ports 22): found_usb_device, devinst=00000007
18:36:01.722 (ports 22): add: loc=usb:70001/3/0/3, class=USB, vid=16C0, pid=04D0, ver=0280, serial=10996430, dev=\\?\usb#vid_16c0&pid_04d0#10996430#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
18:36:01.722 (ports 22): hiddev_from_devinst_list: iface=1
18:36:01.722 (serialmon 63): found_usb_device, id=\\?\usb#vid_16c0&pid_04d0#10996430#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
18:36:01.722 (serialmon 63): found_usb_device, loc=usb:70001/3/0/3 Port_#0003.Hub_#0002
18:36:01.722 (serialmon 63): found_usb_device, hwid=USB\VID_16C0&PID_04D0&REV_0280
18:36:01.722 (serialmon 63): found_usb_device, devinst=00000007
18:36:01.722 (serialmon 63): add: loc=usb:70001/3/0/3, class=USB, vid=16C0, pid=04D0, ver=0280, serial=10996430, dev=\\?\usb#vid_16c0&pid_04d0#10996430#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
18:36:01.722 (serialmon 63): hiddev_from_devinst_list: iface=1
18:36:01.723 (ports 22): found_usb_device complete
18:36:01.723 (serialmon 63): found_usb_device complete
18:36:01.724 (ports 22): usb_add: usb:70001/3/0/3 [no_device] (Teensy 4.1) Keyboard
18:36:01.725 (serialmon 63): usb_add: usb:70001/3/0/3
18:36:01.725 (serialmon 63): ignoring partial USB device discovery (Windows XP issue?)
18:36:01.979 (serialmon 63): retry device discovery (Windows XP workaround)
18:36:01.980 (serialmon 63): update_usb_device, devinst list change, old had 2, new has 7
18:36:01.980 (serialmon 63): hiddev_from_devinst_list: iface=1
18:36:01.980 (serialmon 63): 00000020: path=\\?\hid#vid_16c0&pid_04d0&mi_01#8&3ad25e64&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
18:36:01.981 (serialmon 63): hid, found devinst=0000001E
18:36:01.981 (serialmon 63): hid, found devinst=00000020
18:36:01.981 (serialmon 63): hid, found devinst=00000022
18:36:01.981 (serialmon 63): usb_add: usb:70001/3/0/3
18:36:01.981 (serialmon 63): Opened \\?\hid#vid_16c0&pid_04d0&mi_01#8&3ad25e64&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030} Keyboard
18:36:01.983 (serialmon 63): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
18:36:01.983 (serialmon 63): nothing new, skipping HID & Ports enum
18:36:02.043 (ports 22): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
18:36:02.044 (ports 22): update_usb_device, devinst list change, old had 1, new has 7
18:36:02.044 (ports 22): hiddev_from_devinst_list: iface=1
18:36:02.045 (ports 22): 0000000E: path=\\?\hid#vid_16c0&pid_04d0&mi_01#8&3ad25e64&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
18:36:02.045 (ports 22): hid, found devinst=0000000C
18:36:02.045 (ports 22): hid, found devinst=0000000E
18:36:02.045 (ports 22): hid, found devinst=00000010
18:36:02.046 (ports 22): usb_add: usb:70001/3/0/3 hid#vid_16c0&pid_04d0 (Teensy 4.1) Keyboard
18:36:02.638 (loader): redraw, image 9
{{'a'}}
