Teensy 3.5 serial message pauses
neurochen
I am trying to use teensy for data acquisition, mostly reading analog inputs and controlling digital outputs. Below is my test environment:
teensy board: 3.5
arduino: 1.8.19
teensyduino: 1.56
USB type: serial
CPU speed: 120Mhz
optimize: faster
python: 3.9.7
pyfirmata: 1.1.0
When I try to use pyfirmata or pyfirmata2 to sample analog reads, the serial messages got periodic pauses every 1-2 seconds. It's worth noting that all the serial messages are finally sent to the computer, but it's highly delayed. It looks like the transmission of serial messages is paused for ~1.5 seconds.
See below for the ino code and python code.
  Firmata is a generic protocol for communicating with microcontrollers
  from software on a host computer. It is intended to work with
  any host computer software package.
  To download a host software package, please click on the following link
  to open the list of Firmata client libraries in your default browser.
  https://github.com/firmata/arduino#firmata-client-libraries
  Copyright (C) 2006-2008 Hans-Christoph Steiner.  All rights reserved.
  Copyright (C) 2010-2011 Paul Stoffregen.  All rights reserved.
  Copyright (C) 2009 Shigeru Kobayashi.  All rights reserved.
  Copyright (C) 2009-2016 Jeff Hoefs.  All rights reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  See file LICENSE.txt for further informations on licensing terms.
  Last updated August 17th, 2017
#include <Servo.h>
#include <Firmata.h>
#define I2C_WRITE                   B00000000
#define I2C_READ                    B00001000
#define I2C_READ_CONTINUOUSLY       B00010000
#define I2C_STOP_READING            B00011000
#define I2C_READ_WRITE_MODE_MASK    B00011000
#define I2C_10BIT_ADDRESS_MODE_MASK B00100000
#define I2C_END_TX_MASK             B01000000
#define I2C_STOP_TX                 1
#define I2C_RESTART_TX              0
#define I2C_MAX_QUERIES             8
#define I2C_REGISTER_NOT_SPECIFIED  -1
// the minimum interval for sampling analog input
#define MINIMUM_SAMPLING_INTERVAL   1
 * GLOBAL VARIABLES
#ifdef FIRMATA_SERIAL_FEATURE
SerialFirmata serialFeature;
/* analog inputs */
int analogInputsToReport = 0; // bitwise array to store pin reporting
/* digital input ports */
byte reportPINs[TOTAL_PORTS];       // 1 = report this port, 0 = silence
byte previousPINs[TOTAL_PORTS];     // previous 8 bits sent
/* pins configuration */
byte portConfigInputs[TOTAL_PORTS]; // each bit: 1 = pin in INPUT, 0 = anything else
/* timer variables */
unsigned long currentMillis;        // store the current value from millis()
unsigned long previousMillis;       // for comparison with currentMillis
unsigned int samplingInterval = 19; // how often to run the main loop (in ms)
/* i2c data */
struct i2c_device_info {
  byte addr;
  int reg;
  byte bytes;
  byte stopTX;
/* for i2c read continuous more */
i2c_device_info query[I2C_MAX_QUERIES];
byte i2cRxData[64];
boolean isI2CEnabled = false;
signed char queryIndex = -1;
// default delay time between i2c read request and Wire.requestFrom()
unsigned int i2cReadDelayTime = 0;
Servo servos[MAX_SERVOS];
byte servoPinMap[TOTAL_PINS];
byte detachedServos[MAX_SERVOS];
byte detachedServoCount = 0;
byte servoCount = 0;
boolean isResetting = false;
// Forward declare a few functions to avoid compiler errors with older versions
// of the Arduino IDE.
void setPinModeCallback(byte, int);
void reportAnalogCallback(byte analogPin, int value);
void sysexCallback(byte, byte, byte*);
/* utility functions */
void wireWrite(byte data)
#if ARDUINO >= 100
  Wire.write((byte)data);
#else
  Wire.send(data);
byte wireRead(void)
#if ARDUINO >= 100
  return Wire.read();
#else
  return Wire.receive();
 * FUNCTIONS
void attachServo(byte pin, int minPulse, int maxPulse)
  if (servoCount < MAX_SERVOS) {
    // reuse indexes of detached servos until all have been reallocated
    if (detachedServoCount > 0) {
      servoPinMap[pin] = detachedServos[detachedServoCount - 1];
      if (detachedServoCount > 0) detachedServoCount--;
      servoPinMap[pin] = servoCount;
      servoCount++;
    if (minPulse > 0 && maxPulse > 0) {
      servos[servoPinMap[pin]].attach(PIN_TO_DIGITAL(pin), minPulse, maxPulse);
      servos[servoPinMap[pin]].attach(PIN_TO_DIGITAL(pin));
    Firmata.sendString("Max servos attached");
void detachServo(byte pin)
  servos[servoPinMap[pin]].detach();
  // if we're detaching the last servo, decrement the count
  // otherwise store the index of the detached servo
  if (servoPinMap[pin] == servoCount && servoCount > 0) {
    servoCount--;
  } else if (servoCount > 0) {
    // keep track of detached servos because we want to reuse their indexes
    // before incrementing the count of attached servos
    detachedServoCount++;
    detachedServos[detachedServoCount - 1] = servoPinMap[pin];
  servoPinMap[pin] = 255;
void enableI2CPins()
  byte i;
  // is there a faster way to do this? would probaby require importing
  // Arduino.h to get SCL and SDA pins
  for (i = 0; i < TOTAL_PINS; i++) {
    if (IS_PIN_I2C(i)) {
      // mark pins as i2c so they are ignore in non i2c data requests
      setPinModeCallback(i, PIN_MODE_I2C);
  isI2CEnabled = true;
  Wire.begin();
/* disable the i2c pins so they can be used for other functions */
void disableI2CPins() {
  // disable read continuous mode for all devices
  queryIndex = -1;
void readAndReportData(byte address, int theRegister, byte numBytes, byte stopTX) {
  // allow I2C requests that don't require a register read
  // for example, some devices using an interrupt pin to signify new data available
  // do not always require the register read so upon interrupt you call Wire.requestFrom()
  if (theRegister != I2C_REGISTER_NOT_SPECIFIED) {
    Wire.beginTransmission(address);
    wireWrite((byte)theRegister);
    Wire.endTransmission(stopTX); // default = true
    // do not set a value of 0
    if (i2cReadDelayTime > 0) {
      // delay is necessary for some devices such as WiiNunchuck
      delayMicroseconds(i2cReadDelayTime);
    theRegister = 0;  // fill the register with a dummy value
  Wire.requestFrom(address, numBytes);  // all bytes are returned in requestFrom
  // check to be sure correct number of bytes were returned by slave
  if (numBytes < Wire.available()) {
    Firmata.sendString("I2C: Too many bytes received");
  } else if (numBytes > Wire.available()) {
    Firmata.sendString("I2C: Too few bytes received");
  i2cRxData[0] = address;
  i2cRxData[1] = theRegister;
  for (int i = 0; i < numBytes && Wire.available(); i++) {
    i2cRxData[2 + i] = wireRead();
  // send slave address, register and received bytes
  Firmata.sendSysex(SYSEX_I2C_REPLY, numBytes + 2, i2cRxData);
void outputPort(byte portNumber, byte portValue, byte forceSend)
  // pins not configured as INPUT are cleared to zeros
  portValue = portValue & portConfigInputs[portNumber];
  // only send if the value is different than previously sent
  if (forceSend || previousPINs[portNumber] != portValue) {
    Firmata.sendDigitalPort(portNumber, portValue);
    previousPINs[portNumber] = portValue;
 * check all the active digital inputs for change of state, then add any events
 * to the Serial output queue using Serial.print() */
void checkDigitalInputs(void)
  /* Using non-looping code allows constants to be given to readPort().
   * The compiler will apply substantial optimizations if the inputs
   * to readPort() are compile-time constants. */
  if (TOTAL_PORTS > 0 && reportPINs[0]) outputPort(0, readPort(0, portConfigInputs[0]), false);
  if (TOTAL_PORTS > 1 && reportPINs[1]) outputPort(1, readPort(1, portConfigInputs[1]), false);
  if (TOTAL_PORTS > 2 && reportPINs[2]) outputPort(2, readPort(2, portConfigInputs[2]), false);
  if (TOTAL_PORTS > 3 && reportPINs[3]) outputPort(3, readPort(3, portConfigInputs[3]), false);
  if (TOTAL_PORTS > 4 && reportPINs[4]) outputPort(4, readPort(4, portConfigInputs[4]), false);
  if (TOTAL_PORTS > 5 && reportPINs[5]) outputPort(5, readPort(5, portConfigInputs[5]), false);
  if (TOTAL_PORTS > 6 && reportPINs[6]) outputPort(6, readPort(6, portConfigInputs[6]), false);
  if (TOTAL_PORTS > 7 && reportPINs[7]) outputPort(7, readPort(7, portConfigInputs[7]), false);
  if (TOTAL_PORTS > 8 && reportPINs[8]) outputPort(8, readPort(8, portConfigInputs[8]), false);
  if (TOTAL_PORTS > 9 && reportPINs[9]) outputPort(9, readPort(9, portConfigInputs[9]), false);
  if (TOTAL_PORTS > 10 && reportPINs[10]) outputPort(10, readPort(10, portConfigInputs[10]), false);
  if (TOTAL_PORTS > 11 && reportPINs[11]) outputPort(11, readPort(11, portConfigInputs[11]), false);
  if (TOTAL_PORTS > 12 && reportPINs[12]) outputPort(12, readPort(12, portConfigInputs[12]), false);
  if (TOTAL_PORTS > 13 && reportPINs[13]) outputPort(13, readPort(13, portConfigInputs[13]), false);
  if (TOTAL_PORTS > 14 && reportPINs[14]) outputPort(14, readPort(14, portConfigInputs[14]), false);
  if (TOTAL_PORTS > 15 && reportPINs[15]) outputPort(15, readPort(15, portConfigInputs[15]), false);
/* sets the pin mode to the correct state and sets the relevant bits in the
 * two bit-arrays that track Digital I/O and PWM status
void setPinModeCallback(byte pin, int mode)
  if (Firmata.getPinMode(pin) == PIN_MODE_IGNORE)
    return;
  if (Firmata.getPinMode(pin) == PIN_MODE_I2C && isI2CEnabled && mode != PIN_MODE_I2C) {
    // disable i2c so pins can be used for other functions
    // the following if statements should reconfigure the pins properly
    disableI2CPins();
  if (IS_PIN_DIGITAL(pin) && mode != PIN_MODE_SERVO) {
    if (servoPinMap[pin] < MAX_SERVOS && servos[servoPinMap[pin]].attached()) {
      detachServo(pin);
  if (IS_PIN_ANALOG(pin)) {
    reportAnalogCallback(PIN_TO_ANALOG(pin), mode == PIN_MODE_ANALOG ? 1 : 0); // turn on/off reporting
  if (IS_PIN_DIGITAL(pin)) {
    if (mode == INPUT || mode == PIN_MODE_PULLUP) {
      portConfigInputs[pin / 8] |= (1 << (pin & 7));
      portConfigInputs[pin / 8] &= ~(1 << (pin & 7));
  Firmata.setPinState(pin, 0);
  switch (mode) {
    case PIN_MODE_ANALOG:
          pinMode(PIN_TO_DIGITAL(pin), INPUT);    // disable output driver
#if ARDUINO <= 100
          // deprecated since Arduino 1.0.1 - TODO: drop support in Firmata 2.6
          digitalWrite(PIN_TO_DIGITAL(pin), LOW); // disable internal pull-ups
        Firmata.setPinMode(pin, PIN_MODE_ANALOG);
    case INPUT:
#if ARDUINO <= 100
        Firmata.setPinMode(pin, INPUT);
    case PIN_MODE_PULLUP:
        pinMode(PIN_TO_DIGITAL(pin), INPUT_PULLUP);
        Firmata.setPinMode(pin, PIN_MODE_PULLUP);
        Firmata.setPinState(pin, 1);
    case OUTPUT:
        if (Firmata.getPinMode(pin) == PIN_MODE_PWM) {
          // Disable PWM if pin mode was previously set to PWM.
        pinMode(PIN_TO_DIGITAL(pin), OUTPUT);
        Firmata.setPinMode(pin, OUTPUT);
    case PIN_MODE_PWM:
      if (IS_PIN_PWM(pin)) {
        pinMode(PIN_TO_PWM(pin), OUTPUT);
        analogWrite(PIN_TO_PWM(pin), 0);
        Firmata.setPinMode(pin, PIN_MODE_PWM);
    case PIN_MODE_SERVO:
        Firmata.setPinMode(pin, PIN_MODE_SERVO);
        if (servoPinMap[pin] == 255 || !servos[servoPinMap[pin]].attached()) {
          // pass -1 for min and max pulse values to use default values set
          // by Servo library
          attachServo(pin, -1, -1);
    case PIN_MODE_I2C:
      if (IS_PIN_I2C(pin)) {
        // mark the pin as i2c
        // the user must call I2C_CONFIG to enable I2C for a device
        Firmata.setPinMode(pin, PIN_MODE_I2C);
    case PIN_MODE_SERIAL:
      serialFeature.handlePinMode(pin, PIN_MODE_SERIAL);
    default:
      Firmata.sendString("Unknown pin mode"); // TODO: put error msgs in EEPROM
  // TODO: save status to EEPROM here, if changed
 * Sets the value of an individual pin. Useful if you want to set a pin value but
 * are not tracking the digital port state.
 * Can only be used on pins configured as OUTPUT.
 * Cannot be used to enable pull-ups on Digital INPUT pins.
void setPinValueCallback(byte pin, int value)
  if (pin < TOTAL_PINS && IS_PIN_DIGITAL(pin)) {
    if (Firmata.getPinMode(pin) == OUTPUT) {
      Firmata.setPinState(pin, value);
      digitalWrite(PIN_TO_DIGITAL(pin), value);
void analogWriteCallback(byte pin, int value)
  if (pin < TOTAL_PINS) {
    switch (Firmata.getPinMode(pin)) {
          servos[servoPinMap[pin]].write(value);
      case PIN_MODE_PWM:
          analogWrite(PIN_TO_PWM(pin), value);
void digitalWriteCallback(byte port, int value)
  byte pin, lastPin, pinValue, mask = 1, pinWriteMask = 0;
  if (port < TOTAL_PORTS) {
    // create a mask of the pins on this port that are writable.
    lastPin = port * 8 + 8;
    if (lastPin > TOTAL_PINS) lastPin = TOTAL_PINS;
    for (pin = port * 8; pin < lastPin; pin++) {
      // do not disturb non-digital pins (eg, Rx & Tx)
        // do not touch pins in PWM, ANALOG, SERVO or other modes
        if (Firmata.getPinMode(pin) == OUTPUT || Firmata.getPinMode(pin) == INPUT) {
          pinValue = ((byte)value & mask) ? 1 : 0;
            pinWriteMask |= mask;
          } else if (Firmata.getPinMode(pin) == INPUT && pinValue == 1 && Firmata.getPinState(pin) != 1) {
            // only handle INPUT here for backwards compatibility
#if ARDUINO > 100
            pinMode(pin, INPUT_PULLUP);
#else
            // only write to the INPUT pin to enable pullups if Arduino v1.0.0 or earlier
          Firmata.setPinState(pin, pinValue);
      mask = mask << 1;
    writePort(port, (byte)value, pinWriteMask);
/* sets bits in a bit array (int) to toggle the reporting of the analogIns
//void FirmataClass::setAnalogPinReporting(byte pin, byte state) {
  if (analogPin < TOTAL_ANALOG_PINS) {
    if (value == 0) {
      analogInputsToReport = analogInputsToReport & ~ (1 << analogPin);
      analogInputsToReport = analogInputsToReport | (1 << analogPin);
      // prevent during system reset or all analog pin values will be reported
      // which may report noise for unconnected analog pins
      if (!isResetting) {
        // Send pin value immediately. This is helpful when connected via
        // ethernet, wi-fi or bluetooth so pin states can be known upon
        // reconnecting.
        Firmata.sendAnalog(analogPin, analogRead(analogPin));
void reportDigitalCallback(byte port, int value)
    reportPINs[port] = (byte)value;
    // Send port value immediately. This is helpful when connected via
    // reconnecting.
    if (value) outputPort(port, readPort(port, portConfigInputs[port]), true);
  // do not disable analog reporting on these 8 pins, to allow some
  // pins used for digital, others analog.  Instead, allow both types
  // of reporting to be enabled, but check if the pin is configured
  // as analog when sampling the analog inputs.  Likewise, while
  // scanning digital pins, portConfigInputs will mask off values from any
  // pins configured as analog
 * SYSEX-BASED commands
void sysexCallback(byte command, byte argc, byte *argv)
  byte mode;
  byte stopTX;
  byte slaveAddress;
  byte data;
  int slaveRegister;
  unsigned int delayTime;
  switch (command) {
    case I2C_REQUEST:
      mode = argv[1] & I2C_READ_WRITE_MODE_MASK;
      if (argv[1] & I2C_10BIT_ADDRESS_MODE_MASK) {
        Firmata.sendString("10-bit addressing not supported");
        return;
      else {
        slaveAddress = argv[0];
      // need to invert the logic here since 0 will be default for client
      // libraries that have not updated to add support for restart tx
      if (argv[1] & I2C_END_TX_MASK) {
        stopTX = I2C_RESTART_TX;
      else {
        stopTX = I2C_STOP_TX; // default
      switch (mode) {
        case I2C_WRITE:
          Wire.beginTransmission(slaveAddress);
          for (byte i = 2; i < argc; i += 2) {
            data = argv[i] + (argv[i + 1] << 7);
            wireWrite(data);
          Wire.endTransmission();
          delayMicroseconds(70);
        case I2C_READ:
          if (argc == 6) {
            // a slave register is specified
            slaveRegister = argv[2] + (argv[3] << 7);
            data = argv[4] + (argv[5] << 7);  // bytes to read
          else {
            // a slave register is NOT specified
            slaveRegister = I2C_REGISTER_NOT_SPECIFIED;
            data = argv[2] + (argv[3] << 7);  // bytes to read
          readAndReportData(slaveAddress, (int)slaveRegister, data, stopTX);
        case I2C_READ_CONTINUOUSLY:
          if ((queryIndex + 1) >= I2C_MAX_QUERIES) {
            // too many queries, just ignore
            Firmata.sendString("too many queries");
          if (argc == 6) {
          else {
            slaveRegister = (int)I2C_REGISTER_NOT_SPECIFIED;
          queryIndex++;
          query[queryIndex].addr = slaveAddress;
          query[queryIndex].reg = slaveRegister;
          query[queryIndex].bytes = data;
          query[queryIndex].stopTX = stopTX;
        case I2C_STOP_READING:
          byte queryIndexToSkip;
          // if read continuous mode is enabled for only 1 i2c device, disable
          // read continuous reporting for that device
          if (queryIndex <= 0) {
            queryIndex = -1;
            queryIndexToSkip = 0;
            // if read continuous mode is enabled for multiple devices,
            // determine which device to stop reading and remove it's data from
            // the array, shifiting other array data to fill the space
            for (byte i = 0; i < queryIndex + 1; i++) {
              if (query[i].addr == slaveAddress) {
                queryIndexToSkip = i;
            for (byte i = queryIndexToSkip; i < queryIndex + 1; i++) {
              if (i < I2C_MAX_QUERIES) {
                query[i].addr = query[i + 1].addr;
                query[i].reg = query[i + 1].reg;
                query[i].bytes = query[i + 1].bytes;
                query[i].stopTX = query[i + 1].stopTX;
            queryIndex--;
        default:
    case I2C_CONFIG:
      delayTime = (argv[0] + (argv[1] << 7));
      if (argc > 1 && delayTime > 0) {
        i2cReadDelayTime = delayTime;
      if (!isI2CEnabled) {
        enableI2CPins();
    case SERVO_CONFIG:
      if (argc > 4) {
        // these vars are here for clarity, they'll optimized away by the compiler
        byte pin = argv[0];
        int minPulse = argv[1] + (argv[2] << 7);
        int maxPulse = argv[3] + (argv[4] << 7);
            detachServo(pin);
          attachServo(pin, minPulse, maxPulse);
          setPinModeCallback(pin, PIN_MODE_SERVO);
    case SAMPLING_INTERVAL:
      if (argc > 1) {
        samplingInterval = argv[0] + (argv[1] << 7);
        if (samplingInterval < MINIMUM_SAMPLING_INTERVAL) {
          samplingInterval = MINIMUM_SAMPLING_INTERVAL;
        //Firmata.sendString("Not enough data");
    case EXTENDED_ANALOG:
      if (argc > 1) {
        int val = argv[1];
        if (argc > 2) val |= (argv[2] << 7);
        if (argc > 3) val |= (argv[3] << 14);
        analogWriteCallback(argv[0], val);
    case CAPABILITY_QUERY:
      Firmata.write(START_SYSEX);
      Firmata.write(CAPABILITY_RESPONSE);
      for (byte pin = 0; pin < TOTAL_PINS; pin++) {
          Firmata.write((byte)INPUT);
          Firmata.write(1);
          Firmata.write((byte)PIN_MODE_PULLUP);
          Firmata.write(1);
          Firmata.write((byte)OUTPUT);
          Firmata.write(1);
          Firmata.write(PIN_MODE_ANALOG);
          Firmata.write(10); // 10 = 10-bit resolution
          Firmata.write(PIN_MODE_PWM);
          Firmata.write(DEFAULT_PWM_RESOLUTION);
          Firmata.write(PIN_MODE_SERVO);
          Firmata.write(14);
          Firmata.write(PIN_MODE_I2C);
          Firmata.write(1);  // TODO: could assign a number to map to SCL or SDA
        serialFeature.handleCapability(pin);
        Firmata.write(127);
      Firmata.write(END_SYSEX);
    case PIN_STATE_QUERY:
      if (argc > 0) {
        byte pin = argv[0];
        Firmata.write(PIN_STATE_RESPONSE);
        Firmata.write(pin);
          Firmata.write(Firmata.getPinMode(pin));
          Firmata.write((byte)Firmata.getPinState(pin) & 0x7F);
          if (Firmata.getPinState(pin) & 0xFF80) Firmata.write((byte)(Firmata.getPinState(pin) >> 7) & 0x7F);
          if (Firmata.getPinState(pin) & 0xC000) Firmata.write((byte)(Firmata.getPinState(pin) >> 14) & 0x7F);
    case ANALOG_MAPPING_QUERY:
      Firmata.write(ANALOG_MAPPING_RESPONSE);
        Firmata.write(IS_PIN_ANALOG(pin) ? PIN_TO_ANALOG(pin) : 127);
    case SERIAL_MESSAGE:
      serialFeature.handleSysex(command, argc, argv);
 * SETUP()
void systemResetCallback()
  isResetting = true;
  // initialize a defalt state
  // TODO: option to load config from EEPROM instead of default
  serialFeature.reset();
  if (isI2CEnabled) {
    disableI2CPins();
  for (byte i = 0; i < TOTAL_PORTS; i++) {
    reportPINs[i] = false;    // by default, reporting off
    portConfigInputs[i] = 0;  // until activated
    previousPINs[i] = 0;
  for (byte i = 0; i < TOTAL_PINS; i++) {
    // pins with analog capability default to analog input
    // otherwise, pins default to digital output
    if (IS_PIN_ANALOG(i)) {
      // turns off pullup, configures everything
      setPinModeCallback(i, PIN_MODE_ANALOG);
    } else if (IS_PIN_DIGITAL(i)) {
      // sets the output to 0, configures portConfigInputs
      setPinModeCallback(i, OUTPUT);
    servoPinMap[i] = 255;
  // by default, do not report any analog inputs
  servoCount = 0;
  /* send digital inputs to set the initial state on the host computer,
   * since once in the loop(), this firmware will only send on change */
  TODO: this can never execute, since no pins default to digital input
        but it will be needed when/if we support EEPROM stored config
  for (byte i=0; i < TOTAL_PORTS; i++) {
    outputPort(i, readPort(i, portConfigInputs[i]), true);
  Firmata.setFirmwareVersion(FIRMATA_FIRMWARE_MAJOR_VERSION, FIRMATA_FIRMWARE_MINOR_VERSION);
  Firmata.attach(ANALOG_MESSAGE, analogWriteCallback);
  Firmata.attach(DIGITAL_MESSAGE, digitalWriteCallback);
  Firmata.attach(REPORT_ANALOG, reportAnalogCallback);
  Firmata.attach(REPORT_DIGITAL, reportDigitalCallback);
  Firmata.attach(SET_PIN_MODE, setPinModeCallback);
  Firmata.attach(SET_DIGITAL_PIN_VALUE, setPinValueCallback);
  Firmata.attach(START_SYSEX, sysexCallback);
  Firmata.attach(SYSTEM_RESET, systemResetCallback);
  // to use a port other than Serial, such as Serial1 on an Arduino Leonardo or Mega,
  // Call begin(baud) on the alternate serial port and pass it to Firmata to begin like this:
  // Serial1.begin(57600);
  // Firmata.begin(Serial1);
  // However do not do this if you are using SERIAL_MESSAGE
  Firmata.begin(57600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for ATmega32u4-based boards and Arduino 101
  systemResetCallback();  // reset to default config
 * LOOP()
  byte pin, analogPin;
  /* DIGITALREAD - as fast as possible, check for changes and output them to the
   * FTDI buffer using Serial.print()  */
  checkDigitalInputs();
  /* STREAMREAD - processing incoming messagse as soon as possible, while still
   * checking digital inputs.  */
  while (Firmata.available())
    Firmata.processInput();
  // TODO - ensure that Stream buffer doesn't go over 60 bytes
  samplingInterval = 1;
  currentMillis = millis();
  if (currentMillis - previousMillis > samplingInterval) {
    previousMillis += samplingInterval;
    /* ANALOGREAD - do all analogReads() at the configured sampling interval */
    for (pin = 0; pin < TOTAL_PINS; pin++) {
      if (IS_PIN_ANALOG(pin) && Firmata.getPinMode(pin) == PIN_MODE_ANALOG) {
        analogPin = PIN_TO_ANALOG(pin);
        if (analogInputsToReport & (1 << analogPin)) {
          analogRead(analogPin);
    // report i2c data for all device with read continuous mode enabled
    if (queryIndex > -1) {
        readAndReportData(query[i].addr, query[i].reg, query[i].bytes, query[i].stopTX);
  serialFeature.update();
python code:
import time
import matplotlib as mpl
mpl.use('Qt5Agg')
import matplotlib.pyplot as plt
from pyfirmata import Arduino
board = Arduino('COM6')
board.analog[0].enable_reporting()
stamps = []
t0 = time.perf_counter()
while time.perf_counter()-t0 < 10:
    while board.bytes_available():
        board.iterate()
        stamps.append(time.perf_counter())
plt.plot(stamps, '*')
plt.title('Serial message stamps')
The ino code is the same as examples/standardFirmata, but I hardcoded the sampling interval to be 1 ms. And the python code here simply wait for the serial message, timestamp it, and then reads it. If you plot the time stamps of serial messages, you will see clear gaps between chunks of messages, but the total number of messages is correct. So, we didn't lost serial packages, but it's just got chunked and delayed.
This issue is not present for Arduino Uno at 1 Khz, and it's for Teensy at higher sampling rates (>200 hz.)
Just checked the "hardware" stamps sampled in Teensy and then set to python vis serial communication, all the stamps are precise enough. At 1 Khz, samples are indeed sampled in teensy exactly at 1Khz with a little jitter (~~0.1 ms.) So, all samples were collected in teensy hardware correctly, meaning that the bug is due to serial communication delays/lockup.
More observations with oscilloscopes.
Arduino TX pin output standard 5V digital signals, but teensy TX (pin digital 1) generate signals around 0.02v. Is this normal, or do we need to somehow configure teensy in the software or strip some of the hardware connectors?
Arduino TX sends data periodically at 1 ms interval at 1Khz, but teensy TX signals look very irregular. In some period of time, packets are chunked together; there are also long intervals without any serial TX signals.
After python connects the serial port, all the TX serial signals disappeared, at least to a level unnoticeable with my oscilloscope Tektronix TBS1032B.
I do not know what is causing the delays on receiving. At this moment my Windows test machine in unavailable, so can't try to reproduce it at this moment.
But I can answer this question right now.
Yes, this is normal behavior.
On Arduino Uno, Serial.print() transmits hardware serial on pin 1. A separate USB-Serial chip receives the serial data and sends it over USB.
On Teensy, there is no separate USB-Serial chip. Using Serial transmits directly on USB virtual serial. It does NOT use pins 0 & 1. To communicate with hardware serial on pins 0 & 1, you would use Serail1 on Teensy.
Documentation is here:
https://www.pjrc.com/teensy/td_serial.html
https://www.pjrc.com/teensy/td_uart.html
Many of Arduino's newer boards, like MKR1000, work this way too. Serial is USB virtual serial and does not communicate on any normal pins. Only the oldest boards like Arduino Uno & Mega work this way, with a separate USB-Serial chip.
Pretty sure I can't run this here without Matlab, right?
mpl.use('Qt5Agg')
I tried just running the program on a Teensy 3.5 and opening the Arduino Serial Monitor. But it seems Firmata is waiting for the PC to configure transmission, probably due to this line in the Python code?
I did try running the firmata_test program on Linux, while Teensy 3.5 was running your program. It shows all the analog pins changing at extreme speed.
I don't know why you're seeing those 1.5 second delays, but it's very likely on the PC side since your program responds at a very high rate with firmata_test.
Maybe these Python and graphics libraries are too slow?
This sort of problem has been a consistent theme with Firmata throughout the life of Teensy, where the receiving software just can't keep up with the vastly faster rate Teensy is able to transmit. One case in particular happened in the very early days of Teensy 2.0, or maybe it was even Teensy 1.0 (hard to recall now) where a guy was intensely angry that Teensy transmitted too fast. He was using a Puredata plugin for Firmata which parsed the incoming serial data 1 byte at a time and caused the entire Pd GUI to refresh for each Firmata message. His older Power-PC Macintosh just couldn't keep up and the whole thing lagged terribly.
I see the code is limiting itself to 1000 updates per second, so it's not the worst case of only limited by USB bandwidth. Seems like any modern PC ought to be able to keep up with that.
Thanks for the quick responses. I don't know teensy and newer Arduino boards use virtual serial. Just checked the links and some google search results, it seems that I can't use hardware serial (pin0/1) if I want to transmit data via USB cable, right?
The hanging serial event issue is not due to the receiver software on the PC, as the same code runs flawlessly for Arduino Uno. And both oscilloscope and time stamps on the receiver PC side confirmed Arduino samples are collected and transmitted on time. Note that we don't visualize the received data in real time; we only check them after collecting all the data in 10 seconds. Based on the above observations, I believe this is actually on the teensy board and sketch side. Another piece of evidence is from the oscilloscope check for teensy outputs (connected to pin 1). In this configuration, I indeed saw some data packets. And details of these packets are actually consistent with serial port settings, in terms of length of the packet (related to baud rate) and intervals between packets (related to sampling rate, 1Khz here.) Although teensy is supposed to be a virtual serial, this small amplitude (~0.02v) might be leakages in the circuit?
To reproduce my issue, you could configure teensy to simply output a serial event at 1Khz. Now, board.analog[0].enable_reporting() is not needed anymore. To receive the serial data, you could use any code you like for firmata; it doesn't need to be python. I believe you will also see it in ubuntu.
  [url]https://github.com/firmata/arduino#firmata-client-libraries[/url]
#include <Servo.h>
 * GLOBAL VARIABLES
/* analog inputs */
/* i2c data */
  byte addr;
  int reg;
  byte bytes;
  byte stopTX;
byte i2cRxData[64];
#if ARDUINO >= 100
#else
  Wire.send(data);
byte wireRead(void)
#if ARDUINO >= 100
  return Wire.read();
#else
 * FUNCTIONS
      servoCount++;
    servoCount--;
  byte i;
  Wire.begin();
  queryIndex = -1;
    return;
    disableI2CPins();
      detachServo(pin);
  switch (mode) {
#if ARDUINO <= 100
    case INPUT:
#if ARDUINO <= 100
    case OUTPUT:
    case PIN_MODE_PWM:
          // by Servo library
    case PIN_MODE_I2C:
    default:
      case PIN_MODE_PWM:
#if ARDUINO > 100
#else
      mask = mask << 1;
    if (value == 0) {
      if (!isResetting) {
        // reconnecting.
    // reconnecting.
  byte mode;
  byte stopTX;
  byte slaveAddress;
  byte data;
  int slaveRegister;
  switch (command) {
    case I2C_REQUEST:
        return;
      else {
      else {
      switch (mode) {
        case I2C_WRITE:
            wireWrite(data);
        case I2C_READ:
          if (argc == 6) {
          else {
          if (argc == 6) {
          else {
          queryIndex++;
            queryIndex = -1;
            queryIndex--;
        default:
    case I2C_CONFIG:
        enableI2CPins();
    case SERVO_CONFIG:
      if (argc > 4) {
        byte pin = argv[0];
            detachServo(pin);
      if (argc > 1) {
      if (argc > 1) {
        int val = argv[1];
          Firmata.write(1);
          Firmata.write(1);
          Firmata.write(1);
          Firmata.write(14);
        Firmata.write(127);
      if (argc > 0) {
        byte pin = argv[0];
        Firmata.write(pin);
 * SETUP()
  isResetting = true;
  if (isI2CEnabled) {
    disableI2CPins();
  servoCount = 0;
//   Serial1.begin(9600);
//  while (!Serial) {
//    ; // wait for serial port to connect. Needed for ATmega32u4-based boards and Arduino 101
 * LOOP()
//  /* DIGITALREAD - as fast as possible, check for changes and output them to the
//   * FTDI buffer using Serial.print()  */
//  checkDigitalInputs();
//  /* STREAMREAD - processing incoming messagse as soon as possible, while still
//   * checking digital inputs.  */
//  while (Firmata.available())
//    Firmata.processInput();
    pin = 0;
    Firmata.sendAnalog(analogPin, 0);
//    /* ANALOGREAD - do all analogReads() at the configured sampling interval */
//    for (pin = 0; pin < TOTAL_PINS; pin++) {
//      if (IS_PIN_ANALOG(pin) && Firmata.getPinMode(pin) == PIN_MODE_ANALOG) {
//        analogPin = PIN_TO_ANALOG(pin);
//        if (analogInputsToReport & (1 << analogPin)) {
//          Firmata.sendAnalog(analogPin, analogRead(analogPin));
More results on ubuntu here. The delay is still there, but it's much less than windows (25 ms vs. 1500 ms). Could you please take a look at ubuntu? I tested the code with arduino and national instruments DAQ boards; both of them are working normally (processed every millisecond) in windows at 1 Khz.
