Rolfdegen
Hallo..
I use two LFO in my synth project. I want booth LFO with oneshoot function. How can I identify the LFOs in my audio object code?
My solution is a bit cumbersome. I use two waveforms (LFO1 = WAVEFORM_SINE and LFO2 = WAVEFORM_SINE2) with oneshoot function.
Is there a better solution ?
void AudioSynthWaveform::update(void)
audio_block_t *block;
int16_t *bp, *end;
int32_t val1, val2;
int16_t magnitude15;
uint32_t i, ph, index, index2, scale;
const uint32_t inc = phase_increment;
if(syncFlag==1){
phase_accumulator = 0;
syncFlag = 0;
ph = phase_accumulator + phase_offset;
if (magnitude == 0) {
phase_accumulator += inc * AUDIO_BLOCK_SAMPLES;
return;
block = allocate();
if (!block) {
return;
bp = block->data;
switch(tone_type) {
case WAVEFORM_SINE:
for (i=0; i < AUDIO_BLOCK_SAMPLES; i++) {
index = ph >> 24;
val1 = AudioWaveformSine[index];
val2 = AudioWaveformSine[index+1];
scale = (ph >> 8) & 0xFFFF;
val2 *= scale;
val1 *= 0x10000 - scale;
*bp++ = multiply_32x32_rshift32(val1 + val2, magnitude);
uint32_t ph_old = ph;
ph += inc;
if (lfo1oneShoot == true && ph < inc) {
ph = ph_old;
case WAVEFORM_SINE2:
index = ph >> 24;
val2 *= scale;
ph += inc;
if (lfo2oneShoot == true && ph < inc) {
ph = ph_old;
