I'm trying to run the "Add TFT Display" tutorial and all I get is a white screen and no sound when playing from the 4.1 SD card. The sound board and hardware work when running the tutorial playing a wav file from the 4.1 SD card. I wired the TFT to my teensy using the wiring instructions in the 3-3 tutorial step. I'm guessing I have a conflict or missed a step. Any suggestions would be greatly appreciated.
// Advanced Microcontroller-based Audio Workshop
// http://www.pjrc.com/store/audio_tutorial_kit.html
// https://hackaday.io/project/8292-microcontroller-audio-workshop-had-supercon-2015
// Part 3-3: Add a TFT Display
#include <ILI9341_t3.h>
#include <font_Arial.h> // from ILI9341_t3
// copy the Design Tool code here
AudioPlaySdWav playSdWav1; //xy=110,183
AudioOutputI2S i2s1; //xy=484,135
AudioAnalyzePeak peak1; //xy=492,183
AudioAnalyzePeak peak2; //xy=493,242
AudioConnection patchCord1(playSdWav1, 0, i2s1, 0);
AudioConnection patchCord2(playSdWav1, 0, peak1, 0);
AudioConnection patchCord3(playSdWav1, 1, i2s1, 1);
AudioConnection patchCord4(playSdWav1, 1, peak2, 0);
AudioControlSGTL5000 sgtl5000_1; //xy=243,340
#define TFT_DC 20
#define TFT_CS 21
#define TFT_RST 255 // 255 = unused, connect to 3.3V
#define TFT_MOSI 7
#define TFT_SCLK 14
#define TFT_MISO 12
ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
//#define SDCARD_CS_PIN 10
//#define SDCARD_MOSI_PIN 7
//#define SDCARD_SCK_PIN 14
#define SDCARD_CS_PIN BUILTIN_SDCARD
#define SDCARD_MOSI_PIN 11 // not actually used
#define SDCARD_SCK_PIN 13 // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN 4
//#define SDCARD_MOSI_PIN 11
//#define SDCARD_SCK_PIN 13
SPI.setMOSI(7);
SPI.setSCK(14);
tft.begin();
// read diagnostics (optional but can help debug problems)
uint8_t x = tft.readcommand8(ILI9341_RDMODE);
Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDMADCTL);
Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDPIXFMT);
Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDIMGFMT);
Serial.print("Image Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(ILI9341_RDSELFDIAG);
Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
tft.setTextColor(ILI9341_YELLOW);
tft.setFont(Arial_24);
//tft.setTextSize(3);
tft.setCursor(40, 8);
tft.println("Peak Meter");
AudioMemory(10);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1) {
elapsedMillis msecs;
if (playSdWav1.isPlaying() == false) {
Serial.println("Start playing");
//playSdWav1.play("SDTEST1.WAV");
//playSdWav1.play("SDTEST2.WAV");
playSdWav1.play("SDTEST3.WAV");
//playSdWav1.play("SDTEST4.WAV");
delay(10); // wait for library to parse WAV info
if (msecs > 15) {
if (peak1.available() && peak2.available()) {
msecs = 0;
float leftNumber = peak1.read();
float rightNumber = peak2.read();
// Serial.print(leftNumber);
// Serial.print(", ");
// Serial.print(rightNumber);
// Serial.println();
// draw the verticle bars
int height = leftNumber * 240;
tft.fillRect(60, 280 - height, 40, height, ILI9341_GREEN);
tft.fillRect(60, 280 - 240, 40, 240 - height, ILI9341_BLACK);
height = rightNumber * 240;
tft.fillRect(140, 280 - height, 40, height, ILI9341_GREEN);
tft.fillRect(140, 280 - 240, 40, 240 - height, ILI9341_BLACK);
// a smarter approach would redraw only the changed portion...
// draw numbers underneath each bar
tft.setFont(Arial_14);
tft.fillRect(60, 284, 40, 16, ILI9341_BLACK);
tft.setCursor(60, 284);
tft.print(leftNumber);
tft.fillRect(140, 284, 40, 16, ILI9341_BLACK);
tft.setCursor(140, 284);
tft.print(rightNumber);
