Hello all
I am tinkering with a project that has a couple of strips of RGB's attached to the OctoWS2811 adapter. Channels 1 and 2 which I believe are pins 2 and 14 on the Teensy.
But, I have an existing project that uses the Fastled library and I would like to use that with the above board for it's isolation and connection ability.
From what I understand, the first channel is 0-300 leds, the second is 301-600 and so on (is that correct?).
So is it possible for me to talk directly to the data pin on the strips through the OctoWS2811 board without using the Octo library? I REALLY don't want to try and have to re-write the code as the lighting effect is very complicated.
If I talk to pin 2 (channel 1) with Fastled, then it appears to work, but the second channel on pin 14 does not and it also flashes all kinds of weird stuff on that second strip, even when I am not talking to it (or even have it enabled).
Any advice would be great.
