* This is a simple library to control the Boss MS-3.
* Check README.md or visit https://github.com/MrHaroldA/MS3 for more information.
* Debug information:
* - Define MS3_DEBUG_MODE in your sketch before including this library.
* Dependencies
* - An Arduino with a USB Host Shield
* - https://github.com/felis/USB_Host_Shield_2.0
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#ifndef MS3_h
#define MS3_h
#include "Arduino.h"
* Overridable config.
* MS3_WRITE_INTERVAL_MSEC: The delay before a new message is sent after a write action.
* MS3_READ_INTERVAL_MSEC: The delay before a new message is sent after a read action.
* MS3_RECEIVE_INTERVAL_MSEC: The delay after receiving data from the MS-3.
* MS3_HEADER: The manufacturer and device id header. Define MS3_CUSTOM_HEADER to override this.
* MS3_QUEUE_SIZE: The maximum number of items in the send queue.
#ifndef MS3_WRITE_INTERVAL_MSEC
#define MS3_WRITE_INTERVAL_MSEC 4
#ifndef MS3_READ_INTERVAL_MSEC
#define MS3_READ_INTERVAL_MSEC 25
#ifndef MS3_RECEIVE_INTERVAL_MSEC
#define MS3_RECEIVE_INTERVAL_MSEC 4
#ifndef MS3_CUSTOM_HEADER
const byte MS3_HEADER[6] = {0x41, 0x00, 0x00, 0x00, 0x00, 0x3B};
#ifndef MS3_CUSTOM_HANDSHAKE
const byte HANDSHAKE[15] = {0xF0, 0x7E, 0x00, 0x06, 0x02, 0x41, 0x3B, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF7};
#ifndef MS3_QUEUE_SIZE
#define MS3_QUEUE_SIZE 20
* The configuration options below are internal and should not be changed.
#ifdef MS3_DEBUG_MODE
#define MS3_DEBUG(x) Serial.print(x)
#define MS3_DEBUGLN(x) Serial.println(x)
#define MS3_DEBUG_AS(x, y) Serial.print(x, y)
#else
#define MS3_DEBUG(x) (void)(x)
#define MS3_DEBUGLN(x) (void)(x)
#define MS3_DEBUG_AS(x, y) (void)(x)
#include "usbh_midi.h"
#include "Queue.h"
// General configuration.
const unsigned int INIT_DELAY_MSEC = 100;
const byte MS3_WRITE = 0x12;
const byte MS3_READ = 0x11;
// Return values.
const int8_t MS3_NOT_READY = 0;
const int8_t MS3_READY = 1;
const int8_t MS3_DATA_SENT = 2;
const int8_t MS3_DATA_RECEIVED = 3;
const int8_t MS3_NOTHING_HAPPENED = 4;
const int8_t MS3_ALMOST_IDLE = 5;
const int8_t MS3_IDLE = 6;
// Fixed data.
const byte SYSEX_START = 0xF0;
const byte SYSEX_END = 0xF7;
const unsigned long P_EDIT = 0x7F000001;
// Load the Queue class.
Queue Queue;
class MS3 : public USBH_MIDI {
private:
USB Usb;
byte lastState = 0;
bool ready = false;
unsigned long nextMessage = 0;
* The last bit of the data sent to the MS-3 contains a checksum of the parameter and data.
byte checksum(byte const *data, byte dataLength) {
byte sum = 0, i;
for (i = 8; i < 12 + dataLength; i++) {
sum = (sum + data[i]) & (byte) 0x7F;
return ((byte) 128 - sum) & (byte) 0x7F;
* Construct and send a full SysEx message.
void send(const unsigned long address, byte *data, byte dataLength, byte action) {
byte sysex[14 + dataLength] = {0};
memcpy(sysex + 1, MS3_HEADER, 7);
sysex[8] = (byte) (address >> 24);
sysex[9] = (byte) (address >> 16);
sysex[10] = (byte) (address >> 8);
sysex[11] = (byte) (address);
memcpy(sysex + 12, data, dataLength);
sysex[0] = SYSEX_START;
sysex[7] = action;
sysex[12 + dataLength] = checksum(sysex, dataLength);
sysex[13 + dataLength] = SYSEX_END;
MS3::send(sysex);
* Send the data to the MS-3.
void send(byte *data) {
byte result, dataLength = (byte) MS3::countSysExDataSize(data);
MS3_DEBUG(F("TX:"));
MS3::printSysEx(data, dataLength);
if ((result = MS3::SendSysEx(data, dataLength)) != 0) {
MS3_DEBUG(F(" *** Transfer error: "));
MS3_DEBUG(result);
MS3_DEBUGLN(F("."));
* MS3_DEBUG printer for the received SysEx data.
void printSysEx(byte *data, byte dataLength) {
char buf[10];
for (byte i = 0; i < dataLength; i++) {
sprintf(buf, " %02X", data[i]);
MS3_DEBUG(buf);
MS3_DEBUG(F(" ("));
MS3_DEBUG(dataLength);
MS3_DEBUG(F(")"));
* Check if we've received any data.
bool receive(unsigned long ¶meter, int &dataOut) {
byte
incoming[MIDI_EVENT_PACKET_SIZE] = {0},
data[MIDI_EVENT_PACKET_SIZE] = {0},
dataLength = 0,
i;
uint16_t rcvd;
if (MS3::RecvData(&rcvd, incoming) == 0) {
if (rcvd == 0) {
return false;
byte *p = incoming;
for (i = 0; i < MIDI_EVENT_PACKET_SIZE; i += 4) {
if (*p == 0 && *(p + 1) == 0) {
byte chunk[3] = {0};
if (MS3::extractSysExData(p, chunk) != 0) {
for (byte part : chunk) {
data[dataLength] = part;
dataLength++;
if (part == SYSEX_END) {
p += 4;
MS3_DEBUG(F("RX:"));
// Return values.
parameter = 0;
for (i = 0; i < 4; i++) {
parameter += (unsigned long) data[8 + i] << (3 - i) * 8;
dataOut = (byte) data[dataLength - 3];
// If the data is one byte longer, add x times 128 to the return value for a full integer range.
if (dataLength == 16) {
dataOut += data[dataLength - 4] * 128;
return true;
return false;
* Check if the USB layer is ready.
bool isReady() {
Usb.Task();
if (Usb.getUsbTaskState() == USB_STATE_RUNNING) {
return true;
} else if (MS3::lastState != Usb.getUsbTaskState()) {
MS3_DEBUG(F("*** USB task state: "));
MS3_DEBUG_AS(MS3::lastState = Usb.getUsbTaskState(), HEX);
MS3::ready = false;
return false;
public:
* Constructor.
MS3() : USBH_MIDI(&Usb) {}
* Set up the USB layer.
bool begin() {
if (Usb.Init() == -1) {
MS3_DEBUG(F("*** USB init error! ***"));
return false;
return true;
* Init the editor mode.
void setEditorMode(bool active = true) {
MS3::send((byte *) HANDSHAKE);
delay(MS3_WRITE_INTERVAL_MSEC);
byte data[1] = {(active) ? (byte) 0x01 : (byte) 0x00};
MS3::send(P_EDIT, data, 1, MS3_WRITE);
delay(INIT_DELAY_MSEC);
MS3_DEBUGLN(F("*** Up and ready!"));
* This is the main function for both receiving and sending data when
* there's nothing to receive.
byte update(unsigned long ¶meter, int &data) {
// Are we ready?
if (MS3::isReady()) {
if (!MS3::ready) {
MS3::ready = true;
return MS3_READY;
return MS3_NOT_READY;
// Is there data waiting to be picked up?
if (MS3::receive(parameter, data)) {
MS3::nextMessage = millis() + MS3_RECEIVE_INTERVAL_MSEC;
return MS3_DATA_RECEIVED;
// Check if we need to send out a queued item.
queueItem item = {};
if (MS3::nextMessage <= millis() && Queue.read(item)) {
// Construct the data to send to the MS-3.
byte input[item.dataLength] = {0};
input[item.dataLength - 1] = item.data % (byte) 128;
if (item.dataLength >= 2) {
input[item.dataLength - 2] = (item.data >= 128) ? (byte) 1 : (byte) 0;
// Send the queue item to the MS-3.
MS3::send(
item.address,
input,
item.dataLength,
item.operation
// Store when the next message may be sent.
MS3::nextMessage = millis() + (item.operation == MS3_READ ? MS3_READ_INTERVAL_MSEC : MS3_WRITE_INTERVAL_MSEC);
return MS3_DATA_SENT;
// Are we done? Did we wait for the last message to finish?
if (Queue.isEmpty()) {
return (MS3::nextMessage > millis()) ? MS3_ALMOST_IDLE : MS3_IDLE;
// Nothing interesting happened.
return MS3_NOTHING_HAPPENED;
* Set this single byte parameter on the MS-3. Optionally pad it with leading zero-bytes with a dataLength >= 1.
void write(const unsigned long address, byte data, byte dataLength = 1) {
Queue.write(address, data, dataLength, MS3_WRITE);
* Tell the MS-3 to send us the value of this parameter.
void read(const unsigned long address, byte data) {
Queue.write(address, data, 4, MS3_READ);
* Flush the queue if it's not empty.
void flushQueue() {
if (!Queue.isEmpty()) {
Queue.flush();
