Trying to create a class to handle some audio thats running on a teensy 4.1 with the PT8211 chip, however I'm missing something. If I run the waveform example in github everything works. I tried to wrap the waveform example into a C++ class but I can't get any output. Also the SD card test wav's won't play either. I'm guessing I'm missing something with the implementation of the AudioConnection when used inside a class. It does not crash or throw errors, just no playback. Did I miss something in the patchcords again?
SolarAudio.h
SolarAudio.cpp
main.cpp
SolarAudio.h
#include <Sdfat.h>
class SolarAudio {
private:
AudioPlaySdWav playSdWav1;
AudioPlaySdWav playSdWav2;
AudioPlaySdWav playSdWav3;
AudioMixer4 mixer1;
AudioOutputPT8211 pt8211_1;
AudioSynthWaveform waveform1;
public:
void begin();
void testTone(int duration);
void play1();
void play2();
void play3();
SolarAudio.cpp
#include <Sdfat.h>
#include "Pins.h"
#include "SolarAudio.h"
void SolarAudio::begin(){
AudioConnection patchCord1(waveform1, 0, mixer1, 0);
AudioConnection patchCord2(playSdWav1, 0, mixer1, 1);
AudioConnection patchCord3(playSdWav2, 0, mixer1, 2);
AudioConnection patchCord4(playSdWav3, 0, mixer1, 3);
AudioConnection patchCord5(mixer1, 0, pt8211_1, 0);
AudioConnection patchCord6(mixer1, 0, pt8211_1, 1);
mixer1.gain(0, 0.99);
mixer1.gain(1, 0.99);
mixer1.gain(2, 0.99);
mixer1.gain(3, 0.99);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
if (!(SD.begin(BUILTIN_SDCARD))) {
while (1) {
Serial.println("PT8211 Init Complete");
void SolarAudio::play1(){
Serial.println("Play1()");
playSdWav1.play("SDTEST1.WAV");
void SolarAudio::play2(){
Serial.println("Play2()");
playSdWav2.play("SDTEST2.WAV");
void SolarAudio::play3(){
Serial.println("Play3()");
playSdWav3.play("SDTEST3.WAV");
void SolarAudio::testTone(int duration){
Serial.println("Playing Test Tone");
waveform1.frequency(440);
waveform1.amplitude(0.99);
delay(duration);
waveform1.amplitude(0);
main.cpp
#include <Arduino.h>
#include "Pins.h"
SolarAudio audio;
while (!Serial) {
Serial.println("Starting");
AudioMemory(40);
audio.begin();
Serial.println("loop");
audio.testTone(5000);
delay(2000);
audio.play1();
delay(2000);
audio.play2();
delay(2000);
audio.play3();
delay(2000);
