Results 1 to 4 of 4
Thread: Popping noise coming from teensy when connected to audio board
    I have been working on a pretty big FM synthesizer project for the past couple of months now. I am using a teensy 4.1. I have been limited on pins and have resorted to only using pins 7,8,13,18,19,20,21,23 for the audio board, which has worked just fine on its own. I ran my code with everything connected and encountered humming and popping and terrible electrical noise from the teensy so I turned it off and ran a simple sine wave through it, and now I am getting constant clicks and pops from the board. I tried replacing the audio board but had the same problem. If anyone would happen to have any ideas on how to fix this I’m all ears! (Setting the amplitude of the sine wave lower did not fix it btw)Click image for larger version.
    Jul 2020
    2,013
    Could be a code issue. Perhaps you forgot to up the AudioMemory enough as the system became more complicated?
    Anyway post your code if you want help on this.
    I'd be a little worried by the long wires for the I2S bus to the audio adapter - piggybacking the boards is superior for signal
    integrity particularly of the MCLK line. Make sure both ground pins are connected between Teensy and adapter.
    Apologies for the unusual/sloppy code, just needed something functional for the time being. Thanks for the help!
    #include <LiquidCrystal.h>
    #include "Variables.h"
    #define REDLITE 33
    #define GREENLITE 36
    #define BLUELITE 37
    AudioSynthWaveform       waveform1;      //xy=231,240
    AudioOutputI2S           i2s1;           //xy=390,239
    AudioConnection          patchCord1(waveform1, 0, i2s1, 0);
    AudioConnection          patchCord2(waveform1, 0, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=403,300
    LiquidCrystal lcd (16, 22, 24, 25, 28, 29);
    namespace mux
      byte s0 = 6;
      byte s1 = 9;
      byte s2 = 10;
      int muxIn0 = A2;
      int muxIn1 = A3;
      int muxIn2 = A12;
    namespace shiftReg
      const int dataPin = 12;
      const int clockPin = 14;
      const int latchPin = 11;
      const int numBits = 8;
      byte lastState = LOW;
      unsigned long lastStateChange = 0;
    namespace globEnc
      byte encoder0PinA = 0;
      byte encoder0PinB = 1;
      int encoder0Pos0 = 0;
      int encoder0PinALast0 = LOW;
      int n0 = LOW;
      byte encoder0PinC = 2;
      byte encoder0PinD = 3;
      int encoder0Pos1 = 0;
      int encoder0PinALast1 = LOW;
      int n1 = LOW;
      byte encoder0PinE = 4;
      byte encoder0PinF = 5;
      int encoder0Pos2 = 0;
      int encoder0PinALast2 = LOW;
      int n2 = LOW;
    namespace opCtrl
      float ratioVal[21] = {0.16667,0.1818,0.2,0.2222,0.25,0.2857,0.33333,0.4,0.5,0.25,1.0,1.5,2.0,2.5,3.0,3.5,4.0,4.5,5.0,5.5,6.0};
      float ratio0 = 1.0;
      float ratio1 = 1.0;
      float ratio2 = 1.0;
    namespace ctrls
      byte fmLoc1;
      float amp1;
      float fdbk1;
      byte fdbkLoc1;
      byte fmLoc2;
      float amp2;
      float fdbk2;
      byte fdbkLoc2;
      byte fmLoc3;
      float amp3;
      float fdbk3;
      byte fdbkLoc3;
      float coarse;
      float fine;
      float amp0;
      float fdbk0;
      byte fdbkLoc0;
      int att;
      int hol;
      int dec;
      int sus;
      int rel;
      int fulatt;
      int fulhol;
      int fuldec;
      int fulsus;
      int fulrel;
    void setup ()
      Serial.begin (115200);
      AudioMemory (300);
      AudioNoInterrupts ();
      sgtl5000_1.enable ();
      sgtl5000_1.volume(0.45);
      waveform1.begin (WAVEFORM_SINE);
      waveform1.amplitude (0.45);
      waveform1.frequency (264);
      usbMIDI.setHandleNoteOff (midiNoteOff);
      usbMIDI.setHandleNoteOn (midiNoteOn);
      using namespace globEnc;
      pinMode (encoder0PinA, INPUT);
      pinMode (encoder0PinB, INPUT);
      pinMode (encoder0PinC, INPUT);
      pinMode (encoder0PinD, INPUT);
      pinMode (encoder0PinE, INPUT);
      pinMode (encoder0PinF, INPUT);
      using namespace mux;
      pinMode (s0, OUTPUT);
      pinMode (s1, OUTPUT);
      pinMode (s2, OUTPUT);
      using namespace shiftReg;
      pinMode (dataPin, INPUT);
      pinMode (clockPin, OUTPUT);
      pinMode (latchPin, OUTPUT);
      lcd.begin (20, 4);
      lcd.print ("RGB 20x4 Display  ");
      lcd.setCursor (0,1);
      lcd.print (" Multicolor LCD ");
      pinMode (REDLITE, OUTPUT);
      pinMode (GREENLITE, OUTPUT);
      pinMode (BLUELITE, OUTPUT);
    void loop ()
      usbMIDI.read ();
      updateMux ();
      encoder ();
      sRegister ();
      lcdHello ();
    void updateMux ()
      using namespace ctrls;
      for (byte state = 0; state < 8; state++)
        digitalWrite (s0, HIGH && (state & B00000001));
        digitalWrite (s1, HIGH && (state & B00000010));
        digitalWrite (s2, HIGH && (state & B00000100));
        switch (state)
        case 0: amp2 = analogRead (muxIn0);
                amp3 = analogRead (muxIn1);
                fulatt = analogRead (muxIn2);
        case 1: fdbk1 = analogRead (muxIn0);
                fdbk3 = analogRead (muxIn1);
                fulrel = analogRead (muxIn2);
        case 2: amp1 = analogRead (muxIn0);
                rel = analogRead (muxIn1);
                fuldec = analogRead (muxIn2);
        case 3: fdbk2 = analogRead (muxIn0);
        case 4: amp0 = analogRead (muxIn0);
                sus = analogRead (muxIn1);
        case 5: coarse = analogRead (muxIn0);
        case 6: fdbk0 = analogRead (muxIn0);
                dec = analogRead (muxIn1);
                fulsus = analogRead (muxIn2);
        case 7: fine = analogRead (muxIn0);
                att = analogRead (muxIn1);
    void sRegister ()
      digitalWrite(latchPin, LOW);
      digitalWrite(latchPin, HIGH);
      for (int x = 0; x < numBits; x++) {
        if (millis () - lastStateChange > 100) {
          byte currentState = digitalRead (dataPin);
          if (currentState != lastState) {
            lastStateChange = millis();
            lastState = currentState;
            if (currentState == LOW) {
              Serial.print(x);
              Serial.print(": ON");
        digitalWrite (clockPin, HIGH);
        digitalWrite (clockPin, LOW);
    void encoder ()
      using namespace opCtrl;
      n0 = digitalRead (encoder0PinA);
      if ((encoder0PinALast0 == LOW) && (n0 == HIGH))
        if (digitalRead (encoder0PinB) == LOW)
          encoder0Pos0 = encoder0Pos0 + 1;
          if (encoder0Pos0 > 30)
            encoder0Pos0 = 30;
          encoder0Pos0 = encoder0Pos0 - 1;
          if (encoder0Pos0 < 1)
            encoder0Pos0 = 1;
        if (encoder0Pos0 < 15) {
          float x = encoder0Pos0;
          x = x / 15.0;
          Serial.println(x);
        if (encoder0Pos0 > 15) {
          x = x - 15.0;
          Serial.println(x);
      encoder0PinALast0 = n0;
      n1 = digitalRead (encoder0PinC);
      if ((encoder0PinALast1 == LOW) && (n1 == HIGH))
        if (digitalRead (encoder0PinD) == LOW)
          encoder0Pos1 = encoder0Pos1 + 1;
          if (encoder0Pos1 > 30)
            encoder0Pos1 = 30;
          encoder0Pos1 = encoder0Pos1 - 1;
          if (encoder0Pos1 < 1)
            encoder0Pos1 = 1;
        if (encoder0Pos1 < 15) {
          float x = encoder0Pos1;
          x = x / 15.0;
          Serial.println (x);
        if (encoder0Pos1 > 15) {
          x = x - 15.0;
          Serial.println (x);
      encoder0PinALast1 = n1;
      n2 = digitalRead (encoder0PinE);
      if ((encoder0PinALast2 == LOW) && (n2 == HIGH))
        if (digitalRead (encoder0PinF) == LOW)
          encoder0Pos2 = encoder0Pos2 + 1;
          if (encoder0Pos2 > 30)
            encoder0Pos2 = 30;
          encoder0Pos2 = encoder0Pos2 - 1;
          if (encoder0Pos2 < 1)
            encoder0Pos2 = 1;
        if (encoder0Pos2 < 15) {
          float x = encoder0Pos2;
          x = x / 15.0;
          Serial.println (x);
        if (encoder0Pos2 > 15) {
          x = x - 15.0;
          Serial.println (x);
      encoder0PinALast2 = n2;
    void lcdHello () {
      float brightness = analogRead (A13);
      float r = brightness * 0.2481;
      //float g = brightness * 0.1036;
      float g = brightness * 0.2481;
      float b = brightness * 0.2481;
      //Serial.println(b);
      analogWrite (REDLITE, r);
      analogWrite (GREENLITE, g);
      analogWrite (BLUELITE, b);
    void midiNoteOn (byte channel, byte note, byte velocity)
      Serial.println (note);
      float a = 440;
      float freq = (a / 32) * pow (2, ((note - 9) / 12.0));
      float total = coarse + fine;
      freq = freq * total;
    void midiNoteOff (byte channel, byte note, byte velocity)
      Serial.println ("noteOFF");
    Jul 2020
    2,013
    You call AudioNoInterrupts() and never call AudioInterrupts().
