Bug with AudioOutputSPDIF3
h4yn0nnym0u5e
Hi folks
Been chasing this one for a while, and have got somewhere, though I don't understand the hardware interactions well enough to make a stab at fixing the code :(
Here's a sketch that reproduces the problem:
#include <Arduino.h>
// TestSPDIFout: begin automatically generated code
// Audio Processing Nodes
AudioSynthWaveform              wav1; //xy=120,90
AudioSynthWaveform              wav2; //xy=120,160
AudioMixer4                     mixer4L; //xy=260,85
AudioMixer4                     mixer4R; //xy=255,160
AudioOutputI2S                  i2s; //xy=425,75
AudioOutputSPDIF2               spdif2; //xy=410,130
//AudioOutputSPDIF3               spdif3; //xy=405,195
// Audio Connections (all connections (aka wires or links))
AudioConnection        patchCord1(wav1, 0, mixer4L, 0);
AudioConnection        patchCord2(wav1, 0, mixer4R, 0);
AudioConnection        patchCord3(wav2, 0, mixer4L, 1);
AudioConnection        patchCord4(wav2, 0, mixer4R, 1);
AudioConnection        patchCord5(mixer4L, 0, i2s, 0);
AudioConnection        patchCord6(mixer4L, 0, spdif2, 0);
//AudioConnection        patchCord7(mixer4L, 0, spdif3, 0);
//AudioConnection        patchCord8(mixer4R, 0, spdif3, 1);
AudioConnection        patchCord9(mixer4R, 0, spdif2, 1);
AudioConnection        patchCord10(mixer4R, 0, i2s, 1);
// Control Nodes (all control nodes (no inputs or outputs))
AudioControlSGTL5000     sgtl5000;       //xy=605,100
// TestSPDIFout: end automatically generated code
  float freq = 344.0f * 0.75f;
  AudioMemory(20);
  sgtl5000.enable();
  sgtl5000.volume(0.5f);
  sgtl5000.lineOutLevel(14);
  // allow time for audio engine to start up
  delay(20);
  // start two waveforms of
  // slightly different frequencies
  wav1.begin(0.5f,freq,      0);
  wav2.begin(0.5f,freq+10.0f,0);
void loopWithSPDIF3(void)
  while (true)
    yield();
  delay(10);        // wait then...
  loopWithSPDIF3(); // ...create and connect the SPDIF output
This mixes two slightly differing sine waves to get a helpful waveform, then outputs the result to I2S as a reference (green trace). After a while an AudioOutputSPDIF3 object is created and connected to the same source as the I2S (magenta trace). Here are the results:
You can see that the AudioOutputSPDIF3 is outputting incorrect waveform data for part of each update. Judging by the third image, it's actually what should have been emitted 2 audio engine update cycles previously.
Here are some 'scope traces using AudioOutputSPDIF2 in exactly the same way:
Apart from the rather dodgy start-up, you can see the correct waveform emerging. (EDIT: I realise I mucked up the SPDIF2 test a bit, as it was already in existence, which accounts for the "dodgy start-up".)
I hope someone can make sense of this and figure out a fix!
