Results 1 to 24 of 24
Thread: Searching for FTP Server example on Teensy 4.1 with QNEthernet
    Apr 2022
    9
    Hello guys,
    Does anyone have an example of an FTP server running successfully with Teensy 4.1 and QNEthernet
    successful running ?
    I need an working library to upload an download files between the teensy and his sd card and a pc.
    Best greetings..
    electrolyt
    Mar 2021
    Easley, SC USA
    17
    I've been trying for 6 months to get an FTP server working with Teensy 4.1 and Adafruit Airlift Featherwing. Here's the code I have been trying to get to work. Hope this helps.
    #include <SimpleFTPServer.h>
    #include <SdFat.h>
    #include <SdFatConfig.h>
    #include <sdios.h>
    #include <WiFiNINA.h>
        //Define WiFi Connections
        #define SPIWIFI       SPI
        #define SPIWIFI_SS    5
        #define ESP32_RESET   6
        #define SPIWIFI_ACK   9
        #define ESP32_GPIO0  -1
        //Define WiFi Credentials
        const char* ssid = "MATRIX";
        const char* pass = "rpentagon845psilly417";
        int status = WL_IDLE_STATUS;     // the Wifi radio's status
        //Define SD Card Object
        SdFat sd;
        //Define FTP Server Object
        FtpServer ftpSrv;
        #define SDCARD_CS_PIN    BUILTIN_SDCARD
        #define SDCARD_MOSI_PIN  11  // not actually used
        #define SDCARD_SCK_PIN   13  // not actually used
        // IP address of FTP server
        // if set to 0, use DHCP for the routeur to assign IP
        // IPAddress serverIp( 192, 168, 1, 40 );
        IPAddress serverIp( 192, 168, 1, 127 );  //This IP is the same IP given to Teensy by DHCP
        //Initialize serial and wait for port to open:
      while (!Serial) {
        ; // wait for serial port to connect. Needed for native USB port only
        // Set up the pins!
        WiFi.setPins(SPIWIFI_SS, SPIWIFI_ACK, ESP32_RESET, ESP32_GPIO0, &SPIWIFI);
        SPI.begin();
        String fv = WiFi.firmwareVersion();
        Serial.print("Firmware Version is ");
        Serial.println(fv);
      // attempt to connect to Wifi network:
        Serial.println("Wifi Begin");
      while (status != WL_CONNECTED) {
        Serial.print("Attempting to connect to WPA SSID: ");
        Serial.println(ssid);
        // Connect to WPA/WPA2 network:
        status = WiFi.begin(ssid, pass);
        Serial.println("...Connecting");
        // you're connected now, so print out the data:
        Serial.print("You're connected to the network.");
        printCurrentNet();
        printWifiData();
      // Initialize the SD card
        SPI.setMOSI(SDCARD_MOSI_PIN);
        SPI.setSCK(SDCARD_SCK_PIN);
        Serial.println("Preparing to initialize SD Card");
      while (!(SD.begin(SDCARD_CS_PIN))) {
        Serial.println("SD Card Not Initialized");
        Serial.println("SD Card Initialized");
        //Initialize FTP Server
        Serial.println("Initializing FTP Server...");
        ftpSrv.begin("esp8266","esp8266");
        // ftpSrv.init( externalIp );
        //ftpSrv.init( IPAddress( 192, 168, 1, 195 ));
        ftpSrv.handleFTP();
    void printMacAddress(byte mac[]) {
      for (int i = 5; i >= 0; i--) {
        if (mac[i] < 16) {
          Serial.print("0");
        Serial.print(mac[i], HEX);
        if (i > 0) {
          Serial.print(":");
    void printWifiData() {
        // print your board's IP address:
        IPAddress ip = WiFi.localIP();
        Serial.print("IP Address: ");
        Serial.println(ip);
        Serial.println(ip);
        // print your MAC address:
        byte mac[6];
        WiFi.macAddress(mac);
        Serial.print("MAC address: ");
        printMacAddress(mac);
    void printCurrentNet() {
        // print the SSID of the network you're attached to:
        Serial.print("SSID: ");
        Serial.println(WiFi.SSID());
        // print the MAC address of the router you're attached to:
        byte bssid[6];
        WiFi.BSSID(bssid);
        Serial.print("BSSID: ");
        printMacAddress(bssid);
        // print the received signal strength:
        long rssi = WiFi.RSSI();
        Serial.print("signal strength (RSSI):");
        Serial.println(rssi);
        // print the encryption type:
        byte encryption = WiFi.encryptionType();
        Serial.print("Encryption Type:");
        Serial.println(encryption, HEX);
    Mar 2021
    Easley, SC USA
    17
    I've got 2 posts on this forum asking for assistance and both have gotten over 50 views and not a single reply. I guess I'm not one of the cool kids.
    Apr 2022
    9
    Hi jhall0326,
    Thank you for your reply. Your exempel sketch shows a connection for a ftp server via wifi. So the ftp server sketch is running on the Adafruit Airlift Featherwing ?
    I am searching for a exampel that should run on a teensy with the lanport extension. Best case is using the great qnethernet library. All others ethernet libraries are often a little bit buggy.
    Are you sure that your sketch is realistic ? The Featherwing bord in combination with the teensy and your Sketch confused me.
    Greetings
    Elektrolyt
    Jan 2020
    Toronto, Canada
    132
    I've ported and will create a new FTP_Server for Teensy 4.1 QNEthernet, as well as many other boards, using WiFi, Ethernet W5x00, ENC, etc.
    Tested so far OK with QNEthernet, RP2040 W5x00, etc.
    Will try to publish the new library within a week.
    Jan 2020
    Toronto, Canada
    132
    The new FTP_Server_Teensy41 has just been published to support Tensy 4.x using QNEthernet, NativeEthernet or W5x00 using Ethernet_Generic Library
    It's currently supporting SD card, using SDFat. The LittleFS, other FS using (Q)SPI Flash will be added gradually.
    Please check, test and report any issue.
    Starting FTP_Server_SDFAT2 on TEENSY 4.1 with QNEthernet
    FTP_Server_Teensy41 v1.0.0
    Initializing SD card...
    Wiring is correct and a card is present.
    Card type: SDHC
    Volume type is FAT32
    Volume size (Kbytes): 31452672
    Volume size (Mbytes): 30715
    SDCard Initialization : done.
    test.txt                                      1048702    22:42  April 29, 2022
    foo.txt                                            13    00:00  January 1, 1980
    datalog.bin                                  41943040    00:00  January 1, 2022
    index.htm                                        3810    22:50  April 29, 2022
    mydatalog.txt                                      10    22:24  April 9, 2022
    edit.htm.gz                                      4116    20:15  March 13, 2022
    CanadaFlag_1.png                                41214    20:15  March 13, 2022
    CanadaFlag_2.png                                 8311    20:15  March 13, 2022
    CanadaFlag_3.jpg                                11156    20:15  March 13, 2022
    favicon.ico                                      1150    22:54  April 29, 2022
    graphs.js.gz                                     1971    20:15  March 13, 2022
    CanadaFlag_2_1.png                               8311    22:52  April 29, 2022
    ESP_AT_WM_Lite.txt                               1547    22:51  April 29, 2022
    done!
    =========== USE_QN_ETHERNET ===========
    Initialize Ethernet using static IP => IP Address = 192.168.2.241
    FTP Server Credentials => account = teensy4x, password = ftp_test
    [FTP]  Ftp server waiting for connection on port  21
    [FTP]  Client connected!
    USER teensy4x
    PASS ftp_test
    [FTP]  Authentication Ok. Waiting for commands.
    SYST
    DELE test.txt
    PORT 192,168,2,30,169,133
    [FTP]  Data IP set to  192.168.2.30 , Data port set to  43397
    LIST
    DELE datalog.bin
    PORT 192,168,2,30,135,195
    [FTP]  Data IP set to  192.168.2.30 , Data port set to  34755
    LIST
    PORT 192,168,2,30,165,55
    [FTP]  Data IP set to  192.168.2.30 , Data port set to  42295
    LIST
    PORT 192,168,2,30,206,193
    [FTP]  Data IP set to  192.168.2.30 , Data port set to  52929
    RETR index.htm
    [FTP]  Sending  index.htm
    PORT 192,168,2,30,182,29
    [FTP]  Data IP set to  192.168.2.30 , Data port set to  46621
    STOR index1.htm
    [FTP]  Receiving  index1.htm
    [FTP]  Transfer completed in (ms)  250 , Speed (kbytes/s)  15
    QUIT
    [FTP]  Disconnecting client
    Apr 2022
    9
    Dear khoih-prog,
    wow, that is a great work.
    That`s exactly what i need.
    I will test it, and will give you an report.
    Thanks very much.
    Apr 2022
    9
    Dear khoih-prog,
    i did some test and will report the situation. I am using the example sketch "FTP_Server_SDFAT2" with FileZilla V3.59.0 as FTP-Client. When the client connect the server in active transfer mode, is the sdcard with fileacess working. But when i configure the ftp-client to connect in passive mode, FileZilla is reporting that directory could not be received and the connection will be disconnected by Error "ECONNABORTED".
    It would be great if both transfer modes where working.
    Was it planed to be ?
    I have a temporary start issue:
    Sometimes i got only a small logging after restart of the teensy.
    The example sketch, didn`t loggs always the files from the sdcard.
    When i disconnect the usbcabel -> power off and connect the teensy again,
    a new logg appers with the full logging including the files from the sd card.
    See logg 2.
    1. Logging:
    Card type: SDHC
    Volume size (Kbytes): 30639104
    Volume size (Mbytes): 29921
    System Volume Information/
    2. Logging:
    Card type: SDHC
    WPSettings.dat 12 13:40 December 28, 2021
    IndexerVolumeGuid 76 23:16 December 28, 2021
    Konfig.ini 699 17:49 December 22, 2021
    PAGE2.HTM 18384 18:51 April 14, 2022
    Para.ini 868 00:00 January 1, 2022
    Bilder/
    Schaltung.gif 7137 13:19 January 29, 2022
    Backup/
    SPS1/
    SPS2/
    INDEX.HTM 22102 23:33 April 29, 2022
    done!
    Initialize Ethernet using static IP => IP Address = 192.168.0.59
    FTP Server Credentials => account = admin, password = pass
    Best greetings,
    Electrolyt
    Jan 2020
    Toronto, Canada
    132
    Hi Electrolyt
    Thanks for testing.
    The passive mode is working OK here. I'm testing using Ubuntu pftp or ftp -p. The default data port is default at 55600 in passive mode, instead of 20 in active mode. But you can change the passive data port via the following command in the example
    // Object for FtpServer
    //  Command port and Data port in passive mode can be defined here
    FtpServer ftpSrv( 221, 25000 );
    // FtpServer ftpSrv( 421 ); // Default data port in passive mode is 55600
    //FtpServer ftpSrv; // Default command port is 21 ( !! without parenthesis !! )
    For the SD card, I just take from the example listfiles of Teensy SD Library and have no issue here. Can you test listfiles or add some delay, etc. to fix the issue.
    That file-listing feature is only optional.
    Jan 2020
    Toronto, Canada
    132
    I'm testing now using FileZilla v3.46.3 and OK in passive mode
    Starting FTP_Server_SDFAT2 on TEENSY 4.1 with using QNEthernet
    Card type: SDHC
    index1.htm                                       3810    23:14  April 29, 2022
    done!
    USER teensy4x
    PASS ftp_test
    [FTP]  Connection management set to passive
    [FTP]  Listening at  192.168.2.241 : 55600
    PORT 192,168,2,30,128,77
    [FTP]  Data IP set to  192.168.2.30 , Data port set to  32845
    RETR favicon.ico
    [FTP]  Sending  favicon.ico
    Apr 2022
    9
    Hi khoih-prog,
    i didn't realize the different FTP initializations for the transfer mode.
    I changed that for my understanding like this:
    #define FTP_Active					// Set transfer mode to active
    #ifndef FTP_Active
      // FTP-Server-object for passive mode can be defined here
      //FtpServer ftpSrv( 221, 55600 ); // Define command port 221 and data port 55600 in passive transfer mode
      FtpServer ftpSrv( 221 );          // Define command port 221 and the default data port in passive transfer mode is 55600
    #else
      // FTP-Server-object for active mode is defined here
      FtpServer ftpSrv;                 // Default command port 21 in active transfer mode ( !! without parenthesis !! )
    With these different initializations modes, i got it succsefully working in passive and active transfer mode.
    Response: 220--- Welcome to FTP_Server_Teensy41 ---
    Response: 220 -- FTP_Server_Teensy41 v1.0.0 --
    Status: Plain FTP is insecure. Please switch to FTP over TLS.
    Command: USER admin
    Response: 331 Ok. Password required
    Command: PASS ****
    Response: 230 Ok
    Status: Logged in
    Status: Retrieving directory listing...
    Command: PWD
    Response: 257 "/" is your current directory
    Status: Directory listing of "/" successful
    Status: Disconnected from server: ECONNABORTED - Connection aborted
    I havent seen an issue at the moment for the listfiles again.
    I will integrate the ftp server in my mainsketch and test the ftp library then more.
    I will write an responce if there are some news.
    cheers
    May 2022
    18
    Hi khoih-prog
    Sorry to ask a stupid question, I am using Filezilla as a FTP client and a Teensy 4.1 as the FTP server.
    So once I set up the Teensy as the FTP server and connect Filezilla(running on my pc) to it, I should be able to see all the files on the Teensy SD card on Filezilla right?. If I then choose to download a file from the Teensy SD card to my PC through FileZilla, then do I have to add any additional code to your FTP_Server_Teensy41 to download the files( like does there need to be code on the Teensy that will start sending the file)
    or does FileZilla take care of downloading from the Teensy?
    Jan 2020
    Toronto, Canada
    132
    I'm in the process of porting / rewriting the new FTPClient_Generic, to support all boards (including Teensy, Portenta, SAMD, RP2040, etc), using Ethernet, WiFi.
    I'll publish the new library within several days.
    Some preliminary test results hereafter. The server is Teensy4.1 using QNEthernet and FTP_Server_Teensy41 library
    Please wait.
    FTPClient_UploadImage on MBED RASPBERRY_PI_PICO with W5x00 using Ethernet_Generic Library on SPI0/SPI
    Starting FTPClient_UploadImage on MBED RASPBERRY_PI_PICO with W5x00 using Ethernet_Generic Library on SPI0/SPI
    FTPCLIENT_GENERIC v1.0.0
    [EWS] =========== USE_ETHERNET_GENERIC ===========
    [EWS] Default SPI pinout:
    [EWS] MOSI: 19
    [EWS] MISO: 16
    [EWS] SCK: 18
    [EWS] SS: 17
    [EWS] =========================
    [EWS] RPIPICO setCsPin: 17
    [ETG] W5100 init, using SS_PIN_DEFAULT = 17 , new ss_pin =  10 , W5100Class::ss_pin =  17
    [ETG] Chip is W5100S
    [ETG] W5100::init: W5100S, SSIZE = 4096
    [EWS] Currently Used SPI pinout:
    [EWS] MOSI: 19
    [EWS] MISO: 16
    [EWS] SCK: 18
    [EWS] SS: 17
    Using mac index = 4
    Connected! IP address: 192.168.2.101
    [FTP] Connecting to:  192.168.2.241
    [FTP] Command connected
    [FTP] Send USER =  teensy4x
    [FTP] Send PASSWORD =  ftp_test
    [FTP] Send TYPE Type A
    [FTP] Send PASV
    [FTP] outBuf = 227 Entering Passive Mode (4043483328, port 55600)
    [FTP] _dataAddress:  192.168.2.241 , Data port:  55600
    [FTP] Data connection established
    [FTP] Send CWD
    [FTP] Send MLSD
    [FTP] Result start
    [FTP] Result:  150 Accepted data connection to port 55600
    226-options: -a -l
    226 18 matches total
    [FTP] Result end
    Directory info:
    Type=file;Modify=20220429231446;Size=3810; index1.htm
    Type=file;Modify=19800101000000;Size=13; foo.txt
    Type=file;Modify=20190101003904;Size=3714; index2.htm
    Type=file;Modify=20220429225004;Size=3810; index.htm
    Type=file;Modify=20220409222458;Size=10; mydatalog.txt
    Type=file;Modify=20220313201514;Size=4116; edit.htm.gz
    Type=file;Modify=20190101003834;Size=1150; favicon.ico
    Type=file;Modify=20220313201514;Size=1971; graphs.js.gz
    Type=file;Modify=20220429225138;Size=1547; ESP_AT_WM_Lite.txt
    Type=file;Modify=20190101023514;Size=18; helloworld.txt
    Type=dir;Modify=20190101000020;Size=0; myNewDir
    Type=dir;Modify=20190101001150;Size=0; my_new_dir
    Type=file;Modify=20190101023748;Size=11; hello_world.txt
    [FTP] Send TYPE Type I
    [FTP] Send PASV
    [FTP] Send STOR
    [FTP] Writing
    [FTP] Close File
    Writing hello_world.txt
    [FTP] Send PASV
    [FTP] Send STOR
    [FTP] Write File
    [FTP] Close File
    [FTP] Connection closed
    FTPClient_DownloadFile on MBED RASPBERRY_PI_PICO with W5x00 using Ethernet_Generic Library on SPI0/SPI
    Starting FTPClient_DownloadFile on MBED RASPBERRY_PI_PICO with W5x00 using Ethernet_Generic Library on SPI0/SPI
    [EWS] MOSI: 19
    [EWS] MISO: 16
    [EWS] SCK: 18
    [EWS] SS: 17
    [EWS] MOSI: 19
    [EWS] MISO: 16
    [EWS] SCK: 18
    [EWS] SS: 17
    Using mac index = 19
    Connected! IP address: 192.168.2.114
    [FTP] Send CWD
    Creating new file helloworld.txt
    [FTP] Send PASV
    [FTP] Send STOR
    [FTP] Write File
    [FTP] Close File
    [FTP] Send PASV
    [FTP] Send RETR
    [FTP] Result start
    [FTP] Result:  150-Connected to port 55600
    150 18 bytes to download
    226 File successfully transferred
    [FTP] Result end
    The file content is: Hi, I'm a new file
    [FTP] Send PASV
    [FTP] Send MLSD
    [FTP] Result start
    226-options: -a -l
    [FTP] Result end
    type=file;modify=20220429231446;size=3810; index1.htm
    type=file;modify=19800101000000;size=13; foo.txt
    type=file;modify=20190101003904;size=3714; index2.htm
    type=file;modify=20220429225004;size=3810; index.htm
    type=file;modify=20220409222458;size=10; mydatalog.txt
    type=file;modify=20220313201514;size=4116; edit.htm.gz
    type=file;modify=20190101003834;size=1150; favicon.ico
    type=file;modify=20220313201514;size=1971; graphs.js.gz
    type=file;modify=20220429225138;size=1547; esp_at_wm_lite.txt
    type=file;modify=20190101024026;size=18; helloworld.txt
    type=dir;modify=20190101000020;size=0; mynewdir
    type=dir;modify=20190101001150;size=0; my_new_dir
    type=file;modify=20190101023930;size=11; hello_world.txt
    File size is: 18
    [FTP] Send PASV
    [FTP] Send RETR
    [FTP] Result start
    [FTP] Result end
    [FTP] Send PASV
    [FTP] Send MKD
    [FTP] FTP error:  521 "myNewDir" directory already exists
    [FTP] Send CWD
    [FTP] Send STOR
    [FTP] Writing
    [FTP] Close File
    CloseConnection
    Apr 2022
    9
    Hi Maher,
    you should see the files on the sd card with the filezilla connection.
    You don't need to write special code for upload / download files.
    The FTP server managed the filehandling with the call from ftpSrv.service(); in the loop.
    So if you use filezilla like the windows explorer, you are manuelley able to transfer files to or from the teensy per drag & drop.
    Greetings..
    May 2022
    18
    Hi Electrolyt,
    thanks for the response, this clears it up a lot for me!!
    Jan 2020
    Toronto, Canada
    132
    HI @Maher
    Check the new FTPClient_Generic library at FTPClient_Generic Library
    May 2022
    18
    Hi khoih-prog
    thanks for this library
    i initialized the FTP server object as FtpServer ftpSrv
    I am running the FTP_Server_SDFAT2 example
    and I am trying to connect to this server using FileZilla
    however I get this error in FileZilla
Name:	Screenshot 2022-06-02 124226.png
    this is the arduino serial monitor
    Starting FTP_Server_SDFAT2 on TEENSY 4.1 with NativeEthernet
    FTP_Server_Teensy41 v1.1.0
    Card type: SDHC
    Volume size (Kbytes): 30522368
    Volume size (Mbytes): 29807
      IndexerVolumeGuid                                76    14:22  June 1, 2022
    WS01.csv                                         1032    16:32  June 1, 2022
    mtpindex.dat                                        0
    SensorData/
      WS0.csv                                        3119    13:56  June 2, 2022
      WS1.csv                                        8562    13:47  June 2, 2022
      WS2.csv                                        8564    13:53  June 2, 2022
    done!
    ======== USE_NATIVE_ETHERNET ========
    Using mac index = 9
    Connected! IP address: 142.66.212.127
    [FTP]  Listening at  142.66.212.127 : 20
    Hi khoih-prog
    Hi Maher,
    Get exactly the same problem, (only with Native ethernet).
    Quote Originally Posted by Maher View Post
    Hi khoih-prog
    May 2022
    18
    Hi microguy
    so with other ethernet libraries you were not seeing this issue? if so is it the QNEthernet library that works with this?
    I tired with the older filezilla 3.46.3 version also but still get the same error
    thanks
    Yes, I tried with QNethernet, and it's working. work in active or passive transfer. for passive transfer, if you use Filezilla on windows, you need to be careful with firewall! (I tried FTPRush too)
    But as I have other part of my software that run with nativeEthernet, I think I can't easily use Qnethernet .
    I use Filezilla 3.60.1.
    Hi microguy
    thanks
    Mar 2017
    Oakland, CA, USA
    482
    QNEthernet is mostly a drop-in replacement, but there are additional features that I think make the library easier to use, more robust, and more functional, once you learn how to use it. But at the end of the day, use what you think works best. As the author, I may or may not be a little biased.
    May 2022
    18
    Hi microguy,
    could you share how you setup your filezilla and firewall?
    I am using windows 10 and Teensy 4.1
    I have filezilla 3.60.1 for ftp client and using QNEthernet now
    I set up filezilla in active mode( edit -> setting -> passive mode -> fall back to active mode) i believe this should switch filezilla to active mode
    but I get ECONABORTED error now. Do you know what might be going wrong here?
    May 2022
    18
    Hi microguy,
    I got the FTP to work with NativeEthernet in active mode
    in filezilla i went to file->site manager->under general use FTP protocol and plain FTP encryption and then under transfer setings use Active mode and check the box to limit number of simultaneous connections to 1
    and also under edit->settings->passive mode->check fall back to active mode
    hope this works for you
    also another issue i ntoiced was that filezilla is unable to open a folder on the teensy SD card that is larger than 3MB, have you encountered this issue before?
    don't know if its a filezilla issue or an issue with the teensy FTP server
    Hi Maher,
    Hi microguy,
    OK, I tried with Native Ethernet and it seems that the problem is not exactly the file or folder size but the number of file, you can't have more than 14 files in your root directory.
    I'm setting up Filezilla like you, so I Think the problem is only the firewall config. On mine, I deactivate it for all private network (but my test computer is only connected to Teensy).
