JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
How to compile using Makefile?
Hello all. I am fairly new to Teensy and fairly new to Make as I usually use CMake. I am trying to use a Makefile to compile code into a .HEX file but I keep getting a bunch of errors. I sorted most of them out, but I would like to get some help from people who know what they are doing. I am using the Makefile provided in 'core/teensy4/' Modified to suit my needs. At first I got a bunch of errors about it not being able to find Arduino.h, so I edited the Makefile $(CC) & $(CXX) Parameters to include the Teensy4 directory which had it's own Arduino.h. Then I got an error about it not being able to find 'avr/pgmspace.h' so I added the include path to that into the file as well. The previous errors are probably due to the fact that I copied the Makefile out of the teensy4 directory and into my project directory. I moved it back just in case it was the problem and it got a lot farther, but now it is giving me '/usr/lib/gcc/arm-none-eabi/9.2.1/../../../arm-none-eabi/bin/ld: cannot find -larm_cortexM7lfsp_math' And I am stumped as I cannot find anything online. I will post my Makefile and source file below. (Sorry about not posting in code format, Formatting buttons are not showing up) Any help would be very appreciated!
Hardware: Teensy4.1
Makefile.txt
5.7 KB
TestProg.cpp
88 bytes
It would be important that you also provide a copy of the compiler output (including errors and warnings)
Here is the compiler output:
/usr/bin/arm-none-eabi-gcc -Wall -g -O2 -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -mthumb -MMD -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DUSING_MAKEFILE -D__IMXRT1062__ -DARDU
INO=10813 -DTEENSYDUINO=154 -DARDUINO_TEENSY40 -I. -I /home/thetimbrick/arduino-1.8.19/libraries -ffunction-sections -fdata-sections -I /home/thetimbrick/arduino-1.8.19/hardware/teensy/avr/cor
es/teensy4 -c -o usb_serial.o usb_serial.c
es/teensy4 -c -o sm_calloc.o sm_calloc.c
es/teensy4 -c -o extmem.o extmem.c
es/teensy4 -c -o usb_serial2.o usb_serial2.c
es/teensy4 -c -o keylayouts.o keylayouts.c
es/teensy4 -c -o usb_midi.o usb_midi.c
es/teensy4 -c -o pwm.o pwm.c
es/teensy4 -c -o sm_realloc_i.o sm_realloc_i.c
es/teensy4 -c -o usb_mouse.o usb_mouse.c
es/teensy4 -c -o digital.o digital.c
es/teensy4 -c -o tempmon.o tempmon.c
es/teensy4 -c -o usb_touch.o usb_touch.c
es/teensy4 -c -o usb_rawhid.o usb_rawhid.c
es/teensy4 -c -o sm_realloc_move.o sm_realloc_move.c
es/teensy4 -c -o nonstd.o nonstd.c
es/teensy4 -c -o fuse.o fuse.c
es/teensy4 -c -o sm_zalloc.o sm_zalloc.c
es/teensy4 -c -o sm_realloc.o sm_realloc.c
es/teensy4 -c -o sm_hash.o sm_hash.c
es/teensy4 -c -o rtc.o rtc.c
es/teensy4 -c -o usb_mtp.o usb_mtp.c
es/teensy4 -c -o usb_keyboard.o usb_keyboard.c
es/teensy4 -c -o usb_desc.o usb_desc.c
es/teensy4 -c -o usb_serial3.o usb_serial3.c
es/teensy4 -c -o sm_malloc_stats.o sm_malloc_stats.c
es/teensy4 -c -o usb.o usb.c
es/teensy4 -c -o bootdata.o bootdata.c
es/teensy4 -c -o sm_alloc_valid.o sm_alloc_valid.c
es/teensy4 -c -o sm_pool.o sm_pool.c
es/teensy4 -c -o sm_szalloc.o sm_szalloc.c
es/teensy4 -c -o eeprom.o eeprom.c
es/teensy4 -c -o analog.o analog.c
es/teensy4 -c -o delay.o delay.c
es/teensy4 -c -o usb_joystick.o usb_joystick.c
es/teensy4 -c -o sm_malloc.o sm_malloc.c
es/teensy4 -c -o interrupt.o interrupt.c
es/teensy4 -c -o usb_seremu.o usb_seremu.c
es/teensy4 -c -o sm_free.o sm_free.c
es/teensy4 -c -o startup.o startup.c
es/teensy4 -c -o clockspeed.o clockspeed.c
es/teensy4 -c -o sm_util.o sm_util.c
es/teensy4 -c -o debugprintf.o debugprintf.c
/usr/bin/arm-none-eabi-g++ -std=gnu++14 -felide-constructors -fno-exceptions -fpermissive -fno-rtti -Wno-error=narrowing -I /home/thetimbrick/arduino-1.8.19/libraries -I /home/thetimbrick/ardu
ino-1.8.19/hardware/teensy/avr/cores/teensy4/avr/ -Wall -g -O2 -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -mthumb -MMD -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -DUSING_MAKEFILE
-D__IMXRT1062__ -DARDUINO=10813 -DTEENSYDUINO=154 -DARDUINO_TEENSY40 -I. -I /home/thetimbrick/arduino-1.8.19/libraries -ffunction-sections -fdata-sections -I /home/thetimbrick/arduino-1.8.19/h
ardware/teensy/avr/cores/teensy4 -c -o IPAddress.o IPAddress.cpp
ardware/teensy/avr/cores/teensy4 -c -o AudioStream.o AudioStream.cpp
ardware/teensy/avr/cores/teensy4 -c -o HardwareSerial2.o HardwareSerial2.cpp
ardware/teensy/avr/cores/teensy4 -c -o serialEvent7.o serialEvent7.cpp
ardware/teensy/avr/cores/teensy4 -c -o CrashReport.o CrashReport.cpp
ardware/teensy/avr/cores/teensy4 -c -o Print.o Print.cpp
ardware/teensy/avr/cores/teensy4 -c -o usb_audio.o usb_audio.cpp
ardware/teensy/avr/cores/teensy4 -c -o usb_inst.o usb_inst.cpp
ardware/teensy/avr/cores/teensy4 -c -o HardwareSerial7.o HardwareSerial7.cpp
ardware/teensy/avr/cores/teensy4 -c -o serialEvent1.o serialEvent1.cpp
ardware/teensy/avr/cores/teensy4 -c -o Stream.o Stream.cpp
ardware/teensy/avr/cores/teensy4 -c -o TestProg.o TestProg.cpp
TestProg.cpp: In function ' int function() ':
TestProg.cpp:5:1: warning: no return statement in function returning non-void [ -Wreturn-type ]
5 | }
ardware/teensy/avr/cores/teensy4 -c -o HardwareSerial5.o HardwareSerial5.cpp
ardware/teensy/avr/cores/teensy4 -c -o Time.o Time.cpp
ardware/teensy/avr/cores/teensy4 -c -o serialEvent2.o serialEvent2.cpp
ardware/teensy/avr/cores/teensy4 -c -o new.o new.cpp
ardware/teensy/avr/cores/teensy4 -c -o serialEventUSB2.o serialEventUSB2.cpp
ardware/teensy/avr/cores/teensy4 -c -o yield.o yield.cpp
ardware/teensy/avr/cores/teensy4 -c -o main.o main.cpp
ardware/teensy/avr/cores/teensy4 -c -o HardwareSerial.o HardwareSerial.cpp
ardware/teensy/avr/cores/teensy4 -c -o HardwareSerial4.o HardwareSerial4.cpp
ardware/teensy/avr/cores/teensy4 -c -o serialEvent3.o serialEvent3.cpp
ardware/teensy/avr/cores/teensy4 -c -o HardwareSerial6.o HardwareSerial6.cpp
ardware/teensy/avr/cores/teensy4 -c -o Tone.o Tone.cpp
ardware/teensy/avr/cores/teensy4 -c -o HardwareSerial8.o HardwareSerial8.cpp
ardware/teensy/avr/cores/teensy4 -c -o WString.o WString.cpp
ardware/teensy/avr/cores/teensy4 -c -o serialEvent4.o serialEvent4.cpp
ardware/teensy/avr/cores/teensy4 -c -o usb_flightsim.o usb_flightsim.cpp
ardware/teensy/avr/cores/teensy4 -c -o serialEvent8.o serialEvent8.cpp
ardware/teensy/avr/cores/teensy4 -c -o WMath.o WMath.cpp
ardware/teensy/avr/cores/teensy4 -c -o DMAChannel.o DMAChannel.cpp
ardware/teensy/avr/cores/teensy4 -c -o HardwareSerial1.o HardwareSerial1.cpp
ardware/teensy/avr/cores/teensy4 -c -o EventResponder.o EventResponder.cpp
ardware/teensy/avr/cores/teensy4 -c -o serialEvent5.o serialEvent5.cpp
ardware/teensy/avr/cores/teensy4 -c -o serialEvent6.o serialEvent6.cpp
ardware/teensy/avr/cores/teensy4 -c -o HardwareSerial3.o HardwareSerial3.cpp
ardware/teensy/avr/cores/teensy4 -c -o serialEventUSB1.o serialEventUSB1.cpp
ardware/teensy/avr/cores/teensy4 -c -o IntervalTimer.o IntervalTimer.cpp
ardware/teensy/avr/cores/teensy4 -c -o serialEvent.o serialEvent.cpp
/usr/bin/arm-none-eabi-gcc -Os -Wl,--gc-sections,--relax -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -mthumb -Timxrt1062.ld -o TestProg.elf usb_serial.o sm_calloc.o extmem.o usb_serial2.o
keylayouts.o usb_midi.o pwm.o sm_realloc_i.o usb_mouse.o digital.o tempmon.o usb_touch.o usb_rawhid.o sm_realloc_move.o nonstd.o fuse.o sm_zalloc.o sm_realloc.o sm_hash.o rtc.o usb_mtp.o usb_
keyboard.o usb_desc.o usb_serial3.o sm_malloc_stats.o usb.o bootdata.o sm_alloc_valid.o sm_pool.o sm_szalloc.o eeprom.o analog.o delay.o usb_joystick.o sm_malloc.o interrupt.o usb_seremu.o sm_
free.o startup.o clockspeed.o sm_util.o debugprintf.o IPAddress.o AudioStream.o HardwareSerial2.o serialEvent7.o CrashReport.o Print.o usb_audio.o usb_inst.o HardwareSerial7.o serialEvent1.o S
tream.o TestProg.o HardwareSerial5.o Time.o serialEvent2.o new.o serialEventUSB2.o yield.o main.o HardwareSerial.o HardwareSerial4.o serialEvent3.o HardwareSerial6.o Tone.o HardwareSerial8.o W
String.o serialEvent4.o usb_flightsim.o serialEvent8.o WMath.o DMAChannel.o HardwareSerial1.o EventResponder.o serialEvent5.o serialEvent6.o HardwareSerial3.o serialEventUSB1.o IntervalTimer.o
serialEvent.o -larm_cortexM7lfsp_math -lm -lstdc++
collect2: error: ld returned 1 exit status
make: *** [Makefile:157: TestProg.elf] Error 1
Everything has been tested with gcc 5.4.1, which Teensyduino installs. In theory, newer versions like 9.2.1 should work. But you might run into subtle differences that manifest as difficult to understand bugs.
Hey, if you'd rather use CMake, I have a version of Teensy cores that works with CMake here:
https://github.com/bolderflight/core
The CMakeLists file pulls from this repo to configure the processor and flash the Teensy from the command line:
https://github.com/bolderflight/mcu-support.git
Typically you wouldn't interact with that repo directly, but it does have the CMake files that you might be interested in.
Finally, this repo helps setup the appropriate build environment (either Linux or WSL on Windows) by installing CMake and the required compilers:
https://github.com/bolderflight/build-tools
Supports Teensy 3.x, 4.x, and LC. It's not a one-to-one port of the Teensy cores, my interest are focused on drones and robotics, so I only ported the core files that supported the functionality I was interested in. But should be a good jumping off point if you want to implement a CMake-based build system for your projects.
Thanks! I will have a look!
