I'm trying to use two Adafruit BNO055 sensors connected to two different I2C ports on a teensy 3.6.
The BNO055 sensor comes with a breakout board: https://learn.adafruit.com/adafruit-bno055-absolute-orientation-sensor
I connected the two sensors to SCL0, SDA0 and SCL1, SDA1 respectively (i.e., pin 7, 8 and 18, 19).
I used the I2C scanner coming with the examples of Wire library (File -> Examples -> Wire -> Scanner) but I can get only the first sensor (on SCL0, SDA0): "Device found at address 0x28 (BNO055,EM7180,CAP1188"
The second sensor is not detected. How can I make the sensor visible to Teensy and get the second I2C address?
