Made my own custom PCB following the teensy 4.0 scematic and everything runs pretty darn good. Per Paul's suggestion I used the 4.1 chip as my microcontroller as it's the same pinout and much easier to design traces around and solder that BGA. However... I failed to double check and make sure all the pins were the same. By total luck I have all the pins working well enough except for two. J1 and K1. On 4.0 they're pins 34 and 35, on Teensy 4.1 they're used as the DAT0 and DAT1 connections for the SD card reader.
Instead of redesigning my board, is there a way I can access these pins in software? I just need to drive them high or low for a mosfet configuration, so nothing crazy. I tried to configure the board as a Teensy 4.0 but that obviously didn't work too well.
Thanks for the help!
