Results 1 to 4 of 4
Thread: Thermal Camera using Teensy 4.0 + MLX90640 + ILI9341
    Senior Member manicksan's Avatar
    Jun 2020
    Sweden
    606
    It's time to share my latest project
    https://github.com/manicken/ThermographicCamera
    This started with that I wanted to check the house for heat loss,
    but also be able to check electrical things for pre-failure,
    and bought some MLX90614 to make a sweep-scan
    with two servos, but that method is very slow and the used servos was unreliable
    Meanwhile I was thinking to use better servos/(maybe stepper motors),
    that project was postponed.
    But then I saw this thread
    https://forum.pjrc.com/threads/66816...d-a-Teensy-4-0
    and realized that MLX90640 was cheap, and after a lot of thinkin I did finally buy that sensor
    found a Swedish site that did have them (for almost the same price as from mouser+shipping+import fees)
    https://hitechchain.se/
    Now with the new sensor + a ST7789 (1.3" 240x240) that I already had.
    I first did a Raspberry PI Pico + circuit python
    as it already did exist a working example that was very basic
    but it was as expected very slow (~1fps)
    Did try Teensy 4.0 with the same example but ran into issues as described here
    https://forum.pjrc.com/threads/59040...l=1#post302661
    Just to clarify I use VSCODE + Platform IO
    (as I could not think of using Arduino IDE for anything else than extremely very basic stuff)
    So began to look for examples and both the Adafruit MLX90640 and ST7789 libraries did have examples
    and both worked flawless.
    So it was mostly wasted time of using Python as it don't really make any sense to use it,
    except for small pre-prototype projects just to test things out.
    (but now I have at least tested Python on a microcontroller)
    My resulting code was based on the Display example as I did think it was the mostly 'complicated' of the two.
    After the join I did just use enlarged pixels without any interpolation,
    could do linear interpolation but do not like how that looks
    and wanted to do bicubic interpolation (or at least try)
    So after a lot of searching I did found example code @ Adafruit for another sensor
    https://github.com/adafruit/Adafruit...erpolation.cpp
    that could be run at ~7fps which is fairly impressive (the scale was then 1:7 as I am using a 240x240 TFT)
    But then I was not really happy with the current color palette, think I found it here
    https://github.com/adafruit/Adafruit...nterpolate.ino
    and wanted to try some other
    this was a fairly hard task as there is not really anywhere to find any (except for very blurry images)
    but found finally this other project
    https://github.com/maxritter/DIY-Thermocam
    that did have 18 variants
    but as they do take a lot of space (which makes the reprogramming slower)
    also they do have different sizes and do not fit into the screen size
    so each color palette would had to be remade to fit my particular screen size
    My though was then to generate them from the base colors instead
    then they would not take up so much space and could be generated at runtime
    to fit any display size.
    This lead to that I found code from FastLED (line:106)
    https://github.com/FastLED/FastLED/b...colorutils.cpp
    also used the CRGB structure (or based my own upon it) from FastLED as it's easier to use.
    Did beforehand do a own version of (fill_gradient_RGB),
    but do now use the FastLED version as it generates smoother results
    First I did try the code out in JavaScript (as it's very similar the conversion was no problem)
    https://github.com/manicken/Thermogr.../PaletteEditor
    (not really a Palette Editor yet)
    Where I also printed the color palettes from "DIY-Thermocam"
    to see how they really looked like
    (using 2d context on a canvas + createImageData + putImageData)
    could then save these generated palettes as PNG:s
    so I could use paint to extract the base colors
    these was then put into the JavaScript program
    so I could print both the "original" + the generated version
    and the be able to finetune the percent's used to determine
    how the generated palette would look like.
    here is a example how two palettes could look like (JavaScript)
    var gps = {
        IronBow:[
            {p:0, c:new CRGB(0,0,0)},        // black
            {p:10, c:new CRGB(32,0,140)},    // dark blue
            {p:35, c:new CRGB(204,0,119)},   // magenta red
            {p:70, c:new CRGB(255,165,0)},   // orange
            {p:85, c:new CRGB(255,215,0)},   // gold
            {p:100, c:new CRGB(255,255,255)} // white
        RainBow:[
            {p:0,     c:new CRGB(0,0,0)},      // white
            {p:100/6, c:new CRGB(0,0,255)},    // blue
            {p:200/6, c:new CRGB(0,255,255)},  // cyan
            {p:300/6, c:new CRGB(0,255,0)},    // green
            {p:400/6, c:new CRGB(255,255,0)},  // yellow
            {p:500/6, c:new CRGB(255,0,0)},    // red
    the same but in c++ struct
    here they need to be all in one array,
    and is using a another struct array to store the sizes and names
    const struct GradientPaletteDef Def[] = {
            {"Iron Bow",6},        // 0
            {"Rain Bow 0",9}      // 1
    const struct GradientPaletteItem Data[] = {
            // IronBow // 6
            {0,     {0,0,0}}, // black
            {10.0f, {32,0,140}}, // dark blue
            {35.0f, {204,0,119}}, //magenta red
            {70.0f, {255,165,0}}, // orange
            {85.0f, {255,215,0}}, // gold
            {100.0f,{255,255,255}},  // white
            // RainBow0 // 7
            {100/6, {0,0,255}}, // blue
            {190/6, {0,255,255}}, // cyan
            {220/6, {0,255,255}}, // cyan
            {300/6, {0,255,0}}, // green
            {390/6, {255,255,0}}, // yellow
            {410/6, {255,255,0}}, // yellow
            {500/6, {255,0,0}}, // red
            {100,   {255,255,255}} // white
    Here is the results in from the JavaScript program
    Now I did think that the screen was to small 1.3"
    And because the RoboRemo-app that I'm using for different projects
    can receive and show Images in a so called Image-object
    and do work together with USB OTG CDC.
    First I did think it would be slow, but wanted to try it anyway
    but after I did try it the first time it worked perfect
    at least receiving 224x168(24bit) images
    then I also put in some buttons to direct-select the current color palette
    + one image to show the current color palette
    (updated only when the color palette is changed)
    + three textboxes to show the temperatures
    here is the result
    But I did also wanted to have this size "standalone"
    so I bough a Olimex mod-lcd2.8rtp display (320x240 2.8" ILI9341+AR1021)
    (it also have touch so I can make a settings screen in the future)
    changing the color palette with two buttons at the moment
    (in the current box they are no implemented yet, did exist on the breadboard)
    This bigger display have a bigger resolution so now the framerate is down to ~5fps
    (which is maybe not a big issue)
    but as the MLX work at 1MHz I2C,
    there is much time wasted just by waiting for it to complete the reads.
    Then I was thinking it could do the Interpolation routine while waiting
    To solve this I wanted to use TeensyThreads that run in "Cooperative multitasking"
    "preemptive" did not work as it's hard to set the "time-slices" right.
    Cooperative also is much better while sharing resources/variables
    But do require yield in loops so that the different tasks allow to run.
    I'm "overloading" the yield to
    void yield()
        if (yieldCB != NULL)
            yieldCB();
    which used a function pointer callback that is set after all threads has been started
    this ensure that there is threads to switch to? (had a problem with it enabled direct at startup)
    First the the threading did not work,
    but after a lot of tinkering and finally I did see what parameters the teensy threads have,
    the I was thinking that it did have something to do with the stack size
    and after setting it to 2kbyte it started to work a little, @4kbyte it worked flawless but was slower than the unthreaded version
    After printing the used stack size I could see that the MLX read thread used a lot of memory,
    and because it actually uses dynamically allocated memory to read the raw data this would then be copied onto the stack at task switch
    (which takes a lot of time), so after changing all bigger arrays to static both the used stack size and the speed improved.
    then It did work much faster ~7fps just as I wanted.
    The resulted images now however is still a bit noisy
    and did try Gaussian Interpolation from
    http://blog.dzl.dk/2019/06/08/compac...mall-displays/
    + my own tryout that work like this:
    1. sensor 32x24 pixels "Gaussian interpolation" to 64x48
    2. Bicubic interpolation from 64x48 to 160x120
    3. Bicubic interpolation from 160x120 to 32x24 (maybe unnecessary to run Bicubic here, but easiest at the moment)
    4. Bicubic interpolation from 32x24 to 288x208
    that above decrease the noise but I did was still not really happy with it
    The current version now uses a average method,
    which uses a kind of circular buffer to store the latest read values
    (up to 32 hardcoded, can be changed by a serial command)
    this makes the update more smooth (faded)
    than by just reading a lot of frames and then just print the average out
    I have upgraded the "Tool" to receive and show images in a 'Node'
    It uses the "Web Serial API" to receive the raw images in the "Roboremo-format".
    This makes the "Remote Control (streaming)"-development faster
    as otherwise it needs to be disconnected from my computer to the mobile.
    here is a video showing how it looks like
    here is some pictures
    Is built into a recycled box from old test-equipment for old mobiles (sony ericsson)
    Here the wires are soldered direct onto the display
    this makes some extra space that can be used for a future built in Li-Ion battery + TP4056 charger
    currently powered by a external powerbank which is bulky
    thermal camera "local" (standalone mode)
    https://www.youtube.com/watch?v=3VbFxfoDFB8
    (did have to change it into a url as I could not include more that 2 videos)
    Future TODO:
    * Buttons to change the color palette
    * Built in Li-Ion + charger
    * Touch GUI
    * Maybe upgrade to Flir Lepton 3.5
    (as it's have much better resolution)
    and come with a fair price
    at least if I make the breakout board myself
    Jun 2020
    Sweden
    606
    Forgot to say:
    Did try do a standalone app in "MIT-app inventor"
    but the performance is a disaster, just to update a image took many seconds
    and read data from the USB CDC + some seconds
    the Image update did not work either when it actually printed something
    Could maybe improve the extensions used, but at the time I had already spent to much time on it
    and tried to write a real app instead but then my motivation was very low, and wanted to develop futher on the main
    stuff.
    here is the MIT app inventor project if anyone would see how it looked like
    https://github.com/manicken/Thermogr...rmalCamera.aia
    Feb 2018
    Corvallis, OR
    368
    I spent a couple of months last fall working with a FLIR camera interfaced to a T4.1. I learned a lot about using the CMOS Sensor Interface (CSI) and the Pixel Processing Pipeline (PXP). At about $3500 retail, the camera is out of the hobbyist price range, and I signed an NDA in return for the hardware. However, I am porting a lot of the techniques to my OV7670 Library.
    Here are some key things I learned:
    * The CSI can store VGA-size pixel images in EXTMEM at 30FPS with minimal impact on foreground operations. I set up the CSI to store images in a circular buffer of six frames. That means that I have about 200 milliseconds to process an image before it will be overwritten by the CSI.
    * It takes about 140mSec to compress a VGA image to a 55KB file and write it to SD.
    * The PXP is used to convert the VGA image in YUV422 format to a QVGA image in RGB565 format for an ILI9341. That takes about 100mSec, but it is all background time and doesn't tie up the T4.1 foreground program.
    * The CSI and PXP do not play well together when they are using EXTMEM for the images. You need to use EXTMEM because the 640x480 YUV422 images are too large for DTCM or DMAMEM. When the two hardware systems compete for limited EXTMEM bandwidth, you get glitches in the images. I solved this by shutting down the CSI for exactly one frame time while the PXP processes an image. This results in an effective frame rate of 15FPS,
    * The PXP, CSI, and ILI9341 can generate a 'viewfinder' for the camera that can update the ILI9341 completely in the background as follows:
    CSI EOF interrupt handler stops the CSI and starts the PXP converting VGA YUV422 to QVGA RGB565
    PXP End interrupt handler starts asynchronous background SPI transfer of QVGA buffer to ILI9341
    After 1 frame interval from last EOF, the CSI is restarted by an expiring interval timer
    * While the CSI, PXP, and ILI9341 are working in the background, the foreground loop handles commands that generate JPEG compressed images and either stores them on SD or sends them to a host program for display. Until MTP gets a bit more integrated into TeensyDuino, I send the images to the PC using the second USB serial port in a USB Dual Serial setup on the T4.1. I have host programs in Embarcadero C++ Builder and Python on the PC and a host in Python on the Macintosh.
    My 8GB M1 Mac Mini compiles the T4.1 Arduino program much faster than a mid-level gaming PC. I ascribe this speed to the very fast NVME SSD in the Mac. It reads the source and cached binary libraries and writes the updated cache and output data much faster than the Samsung 970 NVME SSD on my PC.
    Here are a few sample images:
Name:	Warm Puppy.jpg
    Our miniature schnauzer hanging out in the office. Fluorescent lighting.
    The back of the house in the early morning in October.
    Cars in the driveway. Taken near noon in early October.
    Cat on floor in dark office. Camera triggered by motion-capture routine
    The cat gets bored and moves on. Notice the warm spot on the floor and the cold window at upper right.
    Both great projects.
    I'm currently working on interfacing with this camera:https://www.flir.com/products/boson/
    I thought about using the CSI module but I'm trying to get 16bits from the camera's CMOS pins and from what I can tell only 8 bits of the CSI pins are available on the Teensy. I could be wrong, the IMXRT060 manual is incredibly long.
