HI!
I'm planning on building an Eurorack module for basic midi control of other modules ( such as Es-9 and Hermod )
8 knobs that send some cc messages over midi.
I have some initial ideas of how to do it but for sure I'm missing a big part of how to do it
Could someone point me out or help me? Would others be interested in something like that?
Thanks so much in advance!
Mockup
Format
Features
Connectivity -> MIDI out via:
My main goal for this module
Inspiration
Not needing the CV out control, but MIdi wise that's the inspiration
BOM / build parts
I would like to understand the needed building parts, some initial approach
Teensy libraries neeed?
- https://www.pjrc.com/teensy/td_midi.html
Mockup
Format
- Would like to be Eurorack ( so powered by normal eurorack power )
- Size 8hp or 10hp
Features
- 8 knobs to send cc's via midi
- 1 button so i can switch between some programs ( every programa would map different cc's to the previous knobs and buttons )
- 1 jack midi out trs type b
- - Would like to be able to **easily configure which CC are mapped to every knob ( ideally web based without unracking the device )
- back of module via pins
- on frontal ( trs type b ideally.. )
- Control via midi some [HERMOD](https://squarp.net/hermod/) params ( so from the type b to the midi in in hermod )
- Control via midi [ES-9](https://www.expert-sleepers.co.uk/es9.html) in standalone mode _( mainly for volume mixing duties via the back of the module )_ , here some reference to ES-9 manual:
Inspiration
- [Tesseract Sweet sixteen](https://www.modulargrid.net/e/tesseract-modular-sweet-sixteen-alternative-silver-panel )
- [Some livids](https://www.gear4music.es/es/PA-DJ-and-Iluminacion/OFFLINE-Livid-Instruments-Elements-Module-16K/SSY)..
BOM / build parts
- The teensy ( which one? )
- 8 pots ( which type? )
- 8 knobs
- Resistors?
- A 8hp blank panel ( frontal )
- A panel to mount the teensy on
- Some separators for the panel
- Something for regulating power coming from eurorack to teensy?
- Something to connect the jack on the frontal for the midi type be ( the connector and the thing holding the connector to the front panel )
