Hi!
I have working project with Teensy 3.5 and Ethernet shield WIZ850io. I use standart SPI port for connection. Now i try to use Teensy 4.1, but unfortunetly i cant starting Ethernet.
How i can see in pinout diagram Teensy 4.1 has the same SPI pins as Teensy 3.5.
Examples from Standart libraries dont work properly, teensy hang up while Ethernet.begin(mac, ip);
I tryed all libraries (Ethernet, NativeEthernet, QNEthernet) with same result.
I read this https://www.pjrc.com/store/wiz820_sd_adaptor.html#init and make reset, how it recomended, but still dont work.
Is it possible to use Ethernet shield WIZ850io with Teensy 4.1?
