I'd like to make a quadrature signal simulator. This will be used to test other code, which isn't part of the discussion. A real shaft encoder has two output signals, call them A and B. I'd like the simulator to behave reasonably like the real thing, save for maybe any edge bounce.
Tried using the TeensyTimerTool, and have a waveform, but it isn't close enough. The reason is because delayNanoseconds is blocking. Is there a simple way to create an A waveform of 50% duty factor (with controllable period) and a B waveform that is shifted from A a value that is 25% of the period (or 75% of the period when the direction reverses). There's probably a simple way to do this, but as a new user, it is escaping me.
Maybe I could run the timer at 4x the speed and use logic to set the conditions of A & B?
#include "TeensyTimerTool.h"
using namespace TeensyTimerTool;
Timer t1(TCK); // Tick-Timer does not use any hardware timer (20 32bit channels)
Timer t2(TMR1); // First channel on TMR1 aka QUAD timer module. (TMR1 - TMR4, four 16bit channels each)
Timer t3(GPT1); // GPT1 module (one 32bit channel per module)
Timer t4(TMR1); // Second channel on TMR1
// Callbacks ===================================================================================
void a_ns(uint32_t myns)
digitalWriteFast(1, HIGH);
delayNanoseconds(myns); // seems this is blocking, need a different approach!
digitalWriteFast(1, LOW);
void b_ns(uint32_t myns)
delayNanoseconds(myns/2);
digitalWriteFast(2, HIGH);
digitalWriteFast(2, LOW);
for(unsigned pin=1; pin<=2; pin++) pinMode(pin, OUTPUT);
t1.beginPeriodic( [] { a_ns(500);}, 1); // this works somewhat!
t2.beginPeriodic( [] { b_ns(500);}, 1);
