Solved - Ethernet kit LED won't flash on T4.1
bicycleguy
This is posted as a FYI for those who may encounter it.
If the ethernet kit cable is plugged in backwards ethernet still works(somehow:eek:) but the led on the ethernet jack does not function. Apparently this upside-down connection for a few hours didn't wreck anything in my case. YRMV.
The phy has auto-MDIX, which will auto detect a crossover cable and swap the signals.
When you plug it in backwards, it will auto correct, but LED won’t work.
Yeah, it usually can work plugged in backwards because Auto-MDIX automatically figures out whether the RX & TX pairs are swapped, and also because the LED when not conducting has enough capacitance between its anode & cathode.
