Using analogWriteFrequency on Teensy 4.1 @ ~2 Hz or lower
jonahbsaunders
New member
Hello All,
I'm working on a project using the Teensy 4.1 and I want to use the analogWriteFrequency function to set the frequency to around 2 Hz. Will this cause any issues?
I read on an earlier forum post that there might be issues regarding running the analogWriteFrequency function at a lower clock. I wasn't sure if this was relevant anymore because the post was from years ago. Will it also be able to run consistently at around 1Hz to 0.5 Hz?
My best,
Jonah
