I think I have a slow power supply problem with my Teensy 3.1 when running it via 2 AA batteries and a 5V up converter. I want to see how far into the startup code it gets before it hangs. I have a blue and a red led available so my plan was to add a startup_default_middle_hook in my program to turn on the LED. I'm using blink to keep things simple. Since I have to have the USB connected to upload the program I expected no issues. In my code I'd expect the Red LED to come on but it doesn't. The orange LED on pin 13 works.
pins_teensy.c has this definition:
I'm using Arduino IDE 1.8.19 and Teensy loader 1.56.
How do I get the startup process to call my startup_default_middle_hook routine? I also tried defining a startup_middle_hook instead. Got the same result -- no red led.
static void startup_default_middle_hook(void) {
void startup_middle_hook(void) __attribute__ ((weak, alias("startup_default_middle_hook")));
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
// Pin 13 has an LED connected on most Arduino boards.
// Pin 11 has the LED on Teensy 2.0
// Pin 6 has the LED on Teensy++ 2.0
// Pin 13 has the LED on Teensy 3.0
// give it a name:
#define BlueLED 16 // indicator when MIDI is enabled, only used with USB connection so no power drain
#define RedLED 17 // redLED
int led = 13;
// the setup routine runs once when you press reset
void startup_default_middle_hook()
pinMode(BlueLED, OUTPUT); //port to drive LED
digitalWrite(BlueLED, LOW); // LED off to start
pinMode(RedLED, OUTPUT); //port to drive LED
digitalWrite(RedLED, HIGH);
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
