how do I use startup_default_middle_hook in my program
jrdarrah
I think I have a slow power supply problem with my Teensy 3.1 when running it via 2 AA batteries and a 5V up converter. I want to see how far into the startup code it gets before it hangs. I have a blue and a red led available so my plan was to add a startup_default_middle_hook in my program to turn on the LED. I'm using blink to keep things simple. Since I have to have the USB connected to upload the program I expected no issues. In my code I'd expect the Red LED to come on but it doesn't. The orange LED on pin 13 works.
pins_teensy.c has this definition:
static void startup_default_middle_hook(void) {
void startup_middle_hook(void)	__attribute__ ((weak, alias("startup_default_middle_hook")));
I'm using Arduino IDE 1.8.19 and Teensy loader 1.56.
How do I get the startup process to call my startup_default_middle_hook routine? I also tried defining a startup_middle_hook instead. Got the same result -- no red led.
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
// Pin 13 has an LED connected on most Arduino boards.
// Pin 11 has the LED on Teensy 2.0
// Pin 6  has the LED on Teensy++ 2.0
// Pin 13 has the LED on Teensy 3.0
// give it a name:
#define BlueLED 16               // indicator when MIDI is enabled, only used with USB connection so no power drain
#define RedLED 17                // redLED
int led = 13;
// the setup routine runs once when you press reset
void startup_default_middle_hook()
    pinMode(BlueLED, OUTPUT);               //port to drive LED
  digitalWrite(BlueLED, LOW);             // LED off to start
  pinMode(RedLED, OUTPUT);               //port to drive LED
   digitalWrite(RedLED, HIGH);
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
 digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
Use it like this.
extern "C" void startup_middle_hook(void);
void startup_middle_hook() {
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);
extern definition got the program working, but still not via battery
Use it like this.
Thanks for the help. The hook now gets called when using USB to power but not when running via battery even though I see 4.67V at VIN. I have a scope coming next week to look at the power supply rise time. I'll open a new topic when I gather additional data points.
