Hi All,
Does anyone know how to reset the General Purpose Timer Counter registers? For example, within an interrupt, I want to read the value of GPT1_CNT, and then reset GPT1_CNT to zero. This is def possible with FlexTimers and others, however I cannot determine how to do this with General Purpose Timers.
Any Ideas?
Any Ideas?
const byte pin_LED = 13;
const byte pin_InputSig = 11;
boolean LED_st = 1;
uint32_t TempVal = 0;
pinMode(pin_LED,OUTPUT);
digitalWrite(pin_LED,HIGH);
//Setup General Purpose Timers
Setup_GPT1();
attachInterrupt(digitalPinToInterrupt(pin_InputSig), ISR_GPT1_DSK, FALLING);
t1 = millis();
t2 = t1;
int i;
t1 = millis();
if(((t1-t2) >= 100) || (t2 > t1))
LED_st = !LED_st;
digitalWrite(pin_LED,LED_st);
Serial.print(t1);
Serial.print("\t");
Serial.print(GPT1_CNT);
Serial.print("\t");
Serial.print(TestVal_A);
t2 = t1;
void ISR_GPT1_DSK()
TestVal_A = GPT1_CNT;
GPT1_SR = 0x003F;
//GPT1_CNT = 0;
asm volatile ("dsb"); // wait for clear memory barrier
void Setup_GPT1()
/* Initialize GPT1 */
CCM_CCGR1 |= CCM_CCGR1_GPT1_BUS(CCM_CCGR_ON) | CCM_CCGR1_GPT1_SERIAL(CCM_CCGR_ON);
GPT1_SR = 0x3F; // clear all prior status
GPT1_CR |= GPT_CR_CLKSRC(1); // Set clocksource to Peripheral Clock
GPT1_CR |= GPT_CR_ENMOD; // Set Reset Mode
GPT1_OCR1 = 0x1FFFFFFF;
GPT1_CR |= GPT_CR_EN;
