Originally Posted by
bugi74
Would probably be easier (and less work) to implement a proper version of amplitude/gain control block that does the gradual amplitude change at the output sample rate (can't get smoother than that), since such component would have all the needed information easily available to it.
Indeed, I did a little something starting from the mixer object, might need some tweaking but it works, no more noise and adjustable slew:
#ifndef audiosmoothamplifer_h_
#define audiosmoothamplifer_h_
#include "Arduino.h"
#include "AudioStream.h"
#include "utility/dspinst.h"
class AudioSmoothAmplifier : public AudioStream
public:
AudioSmoothAmplifier(void) : AudioStream(1, inputQueueArray), multiplierTarget(65536) {
virtual void update(void);
void gain(float n, float s) {
if (n > 32767.0f) n = 32767.0f;
else if (n < -32767.0f) n = -32767.0f;
multiplierTarget = n * 65536.0f;
smoothness = map((float)constrain(s, 0, 1), 0, 1, 1, 0.01);
private:
int32_t multiplierTarget;
float multiplier;
float smoothness = 1;
void applyGain(int16_t *data);
#if defined(__ARM_ARCH_7EM__)
#define MULTI_UNITYGAIN 65536
inline void AudioSmoothAmplifier::applyGain(int16_t *data)
uint32_t *p = (uint32_t *)data;
const uint32_t *end = (uint32_t *)(data + AUDIO_BLOCK_SAMPLES);
do {
multiplier += (smoothness * (multiplierTarget - multiplier)) / 1000;
uint32_t tmp32 = *p; // read 2 samples from *data
int32_t val1 = signed_multiply_32x16b(multiplier, tmp32);
int32_t val2 = signed_multiply_32x16t(multiplier, tmp32);
val1 = signed_saturate_rshift(val1, 16, 0);
val2 = signed_saturate_rshift(val2, 16, 0);
*p++ = pack_16b_16b(val2, val1);
} while (p < end);
#elif defined(KINETISL)
#define MULTI_UNITYGAIN 256
const int16_t *end = data + AUDIO_BLOCK_SAMPLES;
do {
int32_t val = *data * multiplier;
*data++ = signed_saturate_rshift(val, 16, 0);
} while (data < end);
inline void AudioSmoothAmplifier::update(void)
audio_block_t *block;
if (multiplier == 0 && multiplierTarget == 0) {
// zero gain, discard any input and transmit nothing
block = receiveReadOnly(0);
if (block) release(block);
} else if (multiplier == MULTI_UNITYGAIN && multiplierTarget == MULTI_UNITYGAIN) {
// unity gain, pass input to output without any change
if (block) {
transmit(block);
release(block);
// apply gain to signal
block = receiveWritable(0);
if (block) {
applyGain(block->data);
transmit(block);
release(block);
// Example.ino
#include "AudioSmoothAmplifier.h"
AudioOutputI2S i2s2;
AudioSynthWaveformSine sine; //xy=243,108
AudioSmoothAmplifier amp;
AudioConnection patchCord1(sine, 0, amp, 0);
AudioConnection patchCord2(amp, 0, i2s2, 0);
AudioConnection patchCord3(amp, 0, i2s2, 1);
AudioControlSGTL5000 audioBoard;
elapsedMillis counter;
byte i=1;
while (!Serial && millis() < 5000); // wait for serial monitor
// Audio connections require memory to work.
AudioMemory(48);
audioBoard.enable();
audioBoard.volume(0.4);
sine.frequency(1);
sine.amplitude(1);
if(counter >= 2000){
i++;
i = i %2;
counter = 0;
amp.gain(i, 0);
