Results 1 to 12 of 12
Thread: ILI9341_t3n and NativeEthernet on teensy 4.1
    I can use NativeEthernet together with the original ILI9341_t3 library, this works well using SPI, not SPI1.
    But now I want to migrate my display to SPI1, because I need SPI for the HighPowerStepperDriver lib from Pololu.
    I tried using ILI9341_t3n, which works fine on SPI1. But not with NativeEthernet.
    In fact also ILI9341_t3n on SPI does not work with NativeEthernet.
    Has anyone been able to successfully use NativeEthernet and ILI9341_t3n in the same sketch?
    Or is it just me?
    Yours,
    Johannes
    10,767
    Sorry, no idea...
    However not sure might help to know what does not work? Does not compile, does not???
    That is I am not sure any reason why if ILI9341_t3 works with SPI and NativeEthernet why _t3n would not.
    Unless there is some issue like conflicting names or?
    Do you have simple setup/sketch which shows the issues?
    Mar 2017
    Oakland, CA, USA
    482
    Do you feel like trying QNEthernet instead of NativeEthernet to see if the issue still exists?
    I am always delighted that there are poeple willing to help in this forum! Thank You!
    The code compiles well. And it works well except in the configuration given below:
    USE_NATIVE_ETHERNET and USE_ILI9341_T3N, this does not work.
    USE_NATIVE_ETHERNET and USE_ILI9341_T3 work well together,
    USE_ILI9341_T3N alone without USE_NATIVE_ETHERNET also works.
    What I mean when I say "it does not work":
    Serial console output stops after printing "initializing ILI9341".
    The teensy is somehow stuck (inside tft.begin()) and I cannot upload another sketch until I press the Teensy-button or disconnect the USB cable.
    #define USE_NATIVE_ETHERNET
    #define USE_ILI9341_T3N
    //#define USE_ILI9341_T3
    #ifdef USE_NATIVE_ETHERNET
    // In NativeEthernet.cpp,EthernetClass::begin(...) you must remove waiting on the link status:
    ///  while(!link_status){
    /// Otherwise the program will block until an ethernet cable is connected.
    #include <NativeEthernet.h>
    const byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
    const IPAddress ip(192, 168, 1, 177);
    const unsigned int local_port = 8888;
    const IPAddress remote_ip(192, 168, 1, 1);
    const uint16_t remote_port = 8888;
    EthernetLinkStatus link_status = Unknown;
    EthernetUDP Udp;
    char packetBuffer[64];
    #if defined(USE_ILI9341_T3) || defined(USE_ILI9341_T3N)
    #if defined(USE_ILI9341_T3N)
    #include "ILI9341_t3n.h"
    ILI9341_t3n
    #else
    #include "ILI9341_t3.h"
    ILI9341_t3
      tft(255, //uint8_t _CS,
          31, // uint8_t _DC,
          255, //uint8_t _RST = 255,
          11, //uint8_t _MOSI=11,
          13, //uint8_t _SCLK=13,
          255); //uint8_t _MISO=12);
      while (!Serial);
      Serial.println("calling Ethernet.begin");
      Ethernet.begin(mac, ip);
      Serial.println("Ethernet.begin finished");
      if (Ethernet.hardwareStatus() == EthernetNoHardware) {
        Serial.println("Ethernet HW not found.");
        while (true);
      Serial.println("Ethernet HW found");
      Udp.begin(local_port);
      Serial.println("initializing ILI9341");
      tft.begin();
      tft.fillScreen(0x0000);
      tft.setTextColor(0xFFFF);
      tft.setTextSize(1);
      tft.setRotation(0);
      Serial.println("ILI9341 initialized");
    unsigned int loop_count = 0;
        EthernetLinkStatus s = Ethernet.linkStatus();
        if (s != link_status) {
          link_status = s;
          switch (link_status) {
            case LinkON:
              Serial.println("Ethernet cable connected.");
            case LinkOFF:
              Serial.println("Ethernet cable disconnected.");
            default:
              Serial.println("weird link status.");
      unsigned int x = loop_count;
      for (int i=9;i>=0;i--) {
        packetBuffer[i] = '0' + (x % 10);
        x /= 10;
      Udp.beginPacket(remote_ip, remote_port);
      Udp.write(packetBuffer,10);
      Udp.endPacket();
      tft.fillRect(0,0,tft.width(),8,0x0000);
      tft.setCursor(0,0);
      tft.print(loop_count);
      Serial.println(loop_count);
      loop_count++;
    Quote Originally Posted by shawn View Post
    I did not realize there is another ethernet library for teensy 4.1, thank you! I will give it a try...
    This is cool! Thank you! I already like it better than NativeEthernet, because the sketch can start without connected ethernet cable.
    In NativeEthernet Ethernet.begin() would block until there is a link. Therefore I had to patch it.
    And it works together with ILI9341_t3n!
    If you know the reason for this, please share your wisdom!
    Below there is the adapted sketch for experimenting with all combinations.
    #define USE_QN_ETHERNET
    //#define USE_NATIVE_ETHERNET
    #if defined(USE_NATIVE_ETHERNET) || defined(USE_QN_ETHERNET)
    #if defined(USE_QN_ETHERNET)
    #include <QNEthernet.h>
    using namespace qindesign;
    using namespace network;
    #else
    EthernetUDP Udp;
    ILI9341_t3n
    #else
    ILI9341_t3
          31, // uint8_t _DC,
      while (!Serial);
        while (true);
      tft.begin();
      tft.setTextSize(1);
      tft.setRotation(0);
          link_status = s;
            case LinkON:
            case LinkOFF:
            default:
        x /= 10;
      Udp.endPacket();
      tft.setCursor(0,0);
      loop_count++;
    Now I just have to try with SPI1 instead of SPI...
    and sure enough it works. Thanks again!
    Being the developer of QNEthernet you might know the reason for the incompatibility beween NativeEthernet and ILI9341_t3n.
    Please give some insight!
    Yours, Johannes
    10,767
    Actually I am surprised it works with passing in 255 for CS...
    My Display has no CS pin. Therefore I cannot connect any other device on this SPI bus together with the display.
    There is a MIS pin, which I leave disconnected. This way it works well with ILI9341_t3n.
    I can also pass 10 for CS, but no difference: NativeEthernet and ILI9341_t3n are incompatible.
    10,767
    I ran your sketch:
    EthernetUDP Udp;
    ILI9341_t3n
    #else
    ILI9341_t3
    tft(10, //uint8_t _CS,
        9, // uint8_t _DC,
        8, //uint8_t _RST = 255,
        12); //uint8_t _MISO=12);
      while (!Serial);
        while (true);
      tft.begin();
      tft.setTextSize(1);
      tft.setRotation(0);
          link_status = s;
            case LinkON:
            case LinkOFF:
            default:
      for (int i = 9; i >= 0; i--) {
        x /= 10;
      Udp.write(packetBuffer, 10);
      Udp.endPacket();
      tft.fillRect(0, 0, tft.width(), 8, 0x0000);
      tft.setCursor(0, 0);
      loop_count++;
    Except I edited to give some default pins...
    Ethernet HW found
    ILI9341 initialized
    0
    1
    2
    3
    I ran your sketch:
        9, // uint8_t _DC,
    Ethernet HW found
    ILI9341 initialized
    0
    1
    2
    3
    I have copy-pasted your entire code into a new sketch, uploaded it, and it makes no difference for me:
    the output stops after "initializing ILI9341" and when I upload another sketch I have to press the Teensy button.
    I also tried
      tft(38,//255, //uint8_t _CS,
          28, // uint8_t _DC,
          40,//255, //uint8_t _RST = 255,
          26, //uint8_t _MOSI=11,
          27, //uint8_t _SCLK=13,
          39);//255); //uint8_t _MISO=12);
    which did not work, too. Strange.
    I even remove all Hardware and the SD-card so that my teensy is just connected to USB and Ethernet. Did not work, either.
    10,767
    EthernetUDP Udp;
    ILI9341_t3n
    #else
    ILI9341_t3
          28, // uint8_t _DC,
          39);//255); //uint8_t _MISO=12);tft(10, //uint8_t _CS,
      while (!Serial);
        while (true);
      tft.begin();
      tft.setTextColor(ILI9341_RED, ILI9341_BLACK);
      tft.setCursor(10, tft.height()/4);
      tft.setTextSize(2);
      tft.setRotation(0);
      tft.print("Initialized");
          link_status = s;
            case LinkON:
            case LinkOFF:
            default:
        x /= 10;
      Udp.endPacket();
    //  tft.fillRect(0, 0, tft.width(), 8, ILI9341_BLACK);
      tft.setCursor(10, (tft.height()*3)/4);
      loop_count++;
    Updated to your new pins. Moved the pins to the display and it works for me...
    Note: I am using Arduino 1.8.19, The current beta release of Teensyduino.
    And using master branch of ILI9341_t3n. You might make sure that yours is up to date. I was also also using a different branch that I did a couple months ago for an issue with DMA, but this is not DMA...
    I also updated your sketch slightly to use opaque text output so did not have to erase..
    I now have upgraded to ILI9341_t3n, but I still have Arduino 1.8.13 and Teensyduino 1.53. This must be the reason why it does not work for me.
    Thanks for the opaque text output, this is much better!
    Until I update and probably also after updating I will use QNEthernet instead of NativeEthernet. Together with ILI9341_t3n.
    Mar 2017
    Oakland, CA, USA
    482
    Here's a version that is designed for QNEthernet. I took out the #ifdefs for readability and added a few notes. (Hopefully I didn't make any mistakes.) There's a few other ways to do things here, this is just one way.
    using namespace qindesign::network;
    const IPAddress subnet_mask(255, 255, 255, 0);
    const IPAddress gateway(192, 168, 1, 1);
    const uint16_t local_port = 8888;  // Note: Changed to uint16_t
    bool link_state = false;
    EthernetUDP udp;
    uint8_t packet_buf[64];  // Note: Changed to uint8_t for use with EthernetUDP::send()
    ILI9341_t3n
    #else
    ILI9341_t3
          31, // uint8_t _DC,
      Serial.begin(115200);  // Note: 115200 is better than 9600
      while (!Serial && millis() < 4000) {
        // Wait for Serial or a timeout
        // Note: You had this before Serial.begin(); it needs to come after
      Serial.print("Initializing Ethernet...");
      if (Ethernet.begin(ip, subnet_mask, gateway)) {
        Serial.println("done.");
        udp.begin(local_port);
        Serial.println("ERROR!");
      tft.begin();
      tft.setTextSize(1);
      tft.setRotation(0);
      // Note: Could also monitor with Ethernet.onLinkState() as a callback; see the examples
      // Note: Ethernet.linkState() is new to QNEthernet
      bool s = Ethernet.linkState();
      if (s != link_state) {
        link_state = s;
        if (s) {
          Serial.println("Ethernet link ON");
          Serial.println("Ethernet link OFF");
      if (link_state) {
          packet_buf[i] = '0' + (x % 10);
          x /= 10;
        // Note: The following is instead of beginPacket()/write()/endPacket()
        udp.send(remote_ip, remote_port, packet_buf, 10);
      tft.setCursor(0,0);
      loop_count++;
