Following instruction from https://www.pjrc.com/teensy/td_serial.html, I use this code to read data from PC host:
Two observations:
1. by measuring the testpin, I found the data rate is about 5Mbyte/second.
2. the number 128 in bytecount< 128 cannot be too large. If I set it to such as 256, I start to loose data.
I am trying to get fast data throughput. I have tested it is very fast to send data from Teensy to PC, but the direction from PC to Teensy seems to be slower. Is this by design?
unsigned char bytecount = 0;
while (SerialUSB1.available() && bytecount< 128) {
toggle=!toggle;
digitalWriteFast(TESTPin,toggle);
readBuffer[bytecount]= SerialUSB1.read();
//SerialUSB1.readBytes();
bytecount++;
if(bytecount>0){
ProcessInput(readBuffer,bytecount);
Two observations:
