uint32_t rTime;
uint32_t rTCnt = 0;
extern "C" uint8_t external_psram_size;
bool memory_ok = false;
uint32_t *memory_begin, *memory_end;
bool check_fixed_pattern(uint32_t pattern);
bool check_lfsr_pattern(uint32_t seed);
while (!Serial) ; // wait
pinMode(13, OUTPUT);
uint8_t size = external_psram_size;
Serial.printf("EXTMEM Memory Test, %d Mbyte\n", size);
if (size == 0) return;
const float clocks[4] = {396.0f, 720.0f, 664.62f, 528.0f};
const float frequency = clocks[(CCM_CBCMR >> 8) & 3] / (float)(((CCM_CBCMR >> 29) & 7) + 1);
Serial.printf(" CCM_CBCMR=%08X (%.1f MHz)\n", CCM_CBCMR, frequency);
memory_begin = (uint32_t *)(0x70000000);
memory_end = (uint32_t *)(0x70000000 + size * 1048576);
elapsedMillis msec = 0;
if (!check_fixed_pattern(0x5A698421)) return;
if (!check_lfsr_pattern(2976674124ul)) return;
if (!check_lfsr_pattern(1438200953ul)) return;
if (!check_lfsr_pattern(3413783263ul)) return;
if (!check_lfsr_pattern(1900517911ul)) return;
if (!check_lfsr_pattern(1227909400ul)) return;
if (!check_lfsr_pattern(276562754ul)) return;
if (!check_lfsr_pattern(146878114ul)) return;
if (!check_lfsr_pattern(615545407ul)) return;
if (!check_lfsr_pattern(110497896ul)) return;
if (!check_lfsr_pattern(74539250ul)) return;
if (!check_lfsr_pattern(4197336575ul)) return;
if (!check_lfsr_pattern(2280382233ul)) return;
if (!check_lfsr_pattern(542894183ul)) return;
if (!check_lfsr_pattern(3978544245ul)) return;
if (!check_lfsr_pattern(2315909796ul)) return;
if (!check_lfsr_pattern(3736286001ul)) return;
if (!check_lfsr_pattern(2876690683ul)) return;
if (!check_lfsr_pattern(215559886ul)) return;
if (!check_lfsr_pattern(539179291ul)) return;
if (!check_lfsr_pattern(537678650ul)) return;
if (!check_lfsr_pattern(4001405270ul)) return;
if (!check_lfsr_pattern(2169216599ul)) return;
if (!check_lfsr_pattern(4036891097ul)) return;
if (!check_lfsr_pattern(1535452389ul)) return;
if (!check_lfsr_pattern(2959727213ul)) return;
if (!check_lfsr_pattern(4219363395ul)) return;
if (!check_lfsr_pattern(1036929753ul)) return;
if (!check_lfsr_pattern(2125248865ul)) return;
if (!check_lfsr_pattern(3177905864ul)) return;
if (!check_lfsr_pattern(2399307098ul)) return;
if (!check_lfsr_pattern(3847634607ul)) return;
if (!check_lfsr_pattern(27467969ul)) return;
if (!check_lfsr_pattern(520563506ul)) return;
if (!check_lfsr_pattern(381313790ul)) return;
if (!check_lfsr_pattern(4174769276ul)) return;
if (!check_lfsr_pattern(3932189449ul)) return;
if (!check_lfsr_pattern(4079717394ul)) return;
if (!check_lfsr_pattern(868357076ul)) return;
if (!check_lfsr_pattern(2474062993ul)) return;
if (!check_lfsr_pattern(1502682190ul)) return;
if (!check_lfsr_pattern(2471230478ul)) return;
if (!check_lfsr_pattern(85016565ul)) return;
if (!check_lfsr_pattern(1427530695ul)) return;
if (!check_lfsr_pattern(1100533073ul)) return;
if (!check_fixed_pattern(0x55555555)) return;
if (!check_fixed_pattern(0x33333333)) return;
if (!check_fixed_pattern(0x0F0F0F0F)) return;
if (!check_fixed_pattern(0x00FF00FF)) return;
if (!check_fixed_pattern(0x0000FFFF)) return;
if (!check_fixed_pattern(0xAAAAAAAA)) return;
if (!check_fixed_pattern(0xCCCCCCCC)) return;
if (!check_fixed_pattern(0xF0F0F0F0)) return;
if (!check_fixed_pattern(0xFF00FF00)) return;
if (!check_fixed_pattern(0xFFFF0000)) return;
if (!check_fixed_pattern(0xFFFFFFFF)) return;
if (!check_fixed_pattern(0x00000000)) return;
Serial.printf(" test ran for %.2f seconds\n", (float)msec / 1000.0f);
Serial.printf(" %d MB's test ran at %.2f MB/sec overall\n", 2 * rTCnt * external_psram_size, 2 * rTCnt * external_psram_size * 1024.0 / (float)msec);
Serial.println("All memory tests passed :-)");
memory_ok = true;
bool fail_message(volatile uint32_t *location, uint32_t actual, uint32_t expected)
Serial.printf(" Error at %08X, read %08X but expected %08X\n",
(uint32_t)location, actual, expected);
return false;
// fill the entire RAM with a fixed pattern, then check it
volatile uint32_t *p;
Serial.printf("testing with fixed pattern %08X\t", pattern);
rTime = micros();
for (p = memory_begin; p < memory_end; p++) {
*p = pattern;
rTime = micros() - rTime;
Serial.printf( "\tfill us:%d MB/s:%.2f\t", rTime, external_psram_size * 1024 * 1024.0 / rTime );
arm_dcache_flush_delete((void *)memory_begin,
(uint32_t)memory_end - (uint32_t)memory_begin);
rTime = micros();
uint32_t actual = *p;
if (actual != pattern) return fail_message(p, actual, pattern);
Serial.printf( "\ttest us:%d MB/s:%.2f\n", rTime, external_psram_size * 1024 * 1024.0 / rTime );
rTCnt++;
return true;
// fill the entire RAM with a pseudo-random sequence, then check it
uint32_t reg;
Serial.printf("testing with pseudo-random sequence, seed=%u\t", seed);
reg = seed;
uint32_t rTime;
rTime = micros();
*p = reg;
for (int i = 0; i < 3; i++) {
if (reg & 1) {
reg >>= 1;
reg ^= 0x7A5BC2E3;
reg >>= 1;
reg = seed;
rTime = micros();
if (actual != reg) return fail_message(p, actual, reg);
//Serial.printf(" reg=%08X\n", reg);
if (reg & 1) {
reg >>= 1;
reg ^= 0x7A5BC2E3;
reg >>= 1;
rTCnt++;
return true;
digitalWrite(13, HIGH);
if (!memory_ok) digitalWrite(13, LOW); // rapid blink if any test fails
