Results 1 to 8 of 8
Thread: teensy 4.1 esc control
    May 2022
    5
    I am trying to control an esc with the teensy 4.1 board but i am not able to get it to work using the PWM Servo library.
    #include <PWMServo.h>
    int channel[8];
    int PPMin = 23;
    #define TH1 2
    #define TH2 3
    PWMServo throttel1;
    PWMServo throttel2;
    throttel1.attach(TH1);
    throttel2.attach(TH2);
    if(pulseIn(PPMin , HIGH) > 4000)
    for(int i = 1; i <= channumber; i++)
    channel[i-1]=pulseIn(PPMin, HIGH);
    int throttle_input = channel[2];
    Serial.print("CH[3]: "); Serial.print(channel[2]);
    int throttle1_input = map(throttle_input, 1497 ,519 , 0, 180);
    throttel1.write(throttle1_input);
    int throttle2_input = map(throttle_input, 1497 ,519 , 0, 180);
    throttel1.write(throttle2_input);
    I have also tried with analogwrite but i had no luck.
    Any help is appreciated.
    Thanks.
    May 2017
    312
    Some thoughts:
    What gets printed out on serial? Do you read the channel information correctly?
    Many/Most ESC's need to be armed, need to see zero speed for a certain time. Add that to setup.
    Your map looks incorrect to me. Normally it would be 1000 to 2000 mapped to 0 to 180 with the midpoint at 1500 us.
    Senior Member BriComp's Avatar
    Cheltenham, UK
    806
    int channel[8];
    int PPMin = 23;
    #define TH1 2
    #define TH2 3
    PWMServo throttel1;
    PWMServo throttel2;
    	if (pulseIn(PPMin, HIGH) > 4000)
    		for (int i = 1; i <= channumber; i++)
    			channel[i - 1] = pulseIn(PPMin, HIGH);
    		int throttle1_input = map(throttle_input, 1497, 519, 0, 180);
    		int throttle2_input = map(throttle_input, 1497, 519, 0, 180);
    Hi @pilot011, welcome to the Teensy fold.
    Can I request that in future, when you put code into your posting, can you enclose the code between CODE tags using the # button as I have done above for your code.
    It makes it so much easier for someone to read and potentially help solve your problem.
    Incidentally the code that you presented will NOT compile with the following error, error: 'channumber' was not declared in this scope.
    May 2022
    5
    Will do. sorry about that.
    May 2022
    5
    I am able to read the ppm signals. The only issue i am having is getting the motors to run. I am able to run the servos. I have also tried mapping it from 1000 to 2000 but i still have had no luck. the serial print just prints out the throttle value the receiver is getting
    May 2022
    5
    I have added the missing lines.
    #define channumber  8
    int channel[8];
    int PPMin =  23;
    #define TH1          2
    #define TH2          3
    PWMServo throttel1;
    PWMServo throttel2;
    the throttle output range from my transmitter is 1500 to 500.
    May 2017
    312
             throttel1.write(throttle2_input);   You wanted throttel2.write here
    Do your ESC motors combination produce the appropriate beep codes on power up?
    Perhaps you need to calibrate the ESC's to your transmitter. Usually this is done by powering up at full throttle, wait for a beep code, and then reduce throttle to zero, power down.
    May 2022
    5
    Thats a typo. But yea i have tried the power up sequence but that also doesn't seem to work from the teensy
