Teensy 3.2 + Cirque touchpad. Steam controller DIY.
KPollock
Hello everyone. Hope you're all having a great day.
I'm wondering if anyone can point me into the right direction or prior forum for a project I'm working on. I remember seeing a circular touchpad from cirque used as a gaming joystick (360 degree) or alternately implemented into 8 way WASD/ Directional (preferred).
I'm unable to find where I last viewed the discussion. The cirque touchpads I have are the 23mm, 35mm, 40mm all SPI.
Thank you for your help and guidance.
// Copyright (c) 2018 Cirque Corp. Restrictions apply. See: www.cirque.com/sw-license
// ___ Using a Cirque TM0XX0XX w/ Curved Overlay and Arduino ___
// This demonstration application is built to work with a Teensy 3.1/3.2 but it can easily be adapted to
// work with Arduino-based systems.
// When using with DK000013 development kit, connect sensor to the FFC connector
// labeled 'Sensor0'.
// This application connects to a TM0XX0XX circular touch pad via SPI. To verify that your touch pad is configured
// for SPI-mode, make sure that R1 is populated with a 470k resistor (or whichever resistor connects pins 24 & 25 of the 1CA027 IC).
// The pad is configured for Absolute mode tracking. Touch data is sent in text format over USB CDC to
// the host PC. You can open a terminal window on the PC to the USB CDC port and see X, Y, and Z data
// fill the window when you touch the sensor. Tools->Serial Monitor can be used to view touch data.
// NOTE: all config values applied in this sample are meant for a module using REXT = 976kOhm
// Pinnacle TM0XX0XX with Arduino
// Hardware Interface
// GND
// +3.3V
// SCK = Pin 13
// MISO = Pin 12
// MOSI = Pin 11
// SS = Pin 8
// DR = Pin 7
// Hardware pin-number labels
#define SCK_PIN 13
#define DIN_PIN 12
#define DOUT_PIN 11
#define CS_PIN 10
#define DR_PIN 9
#define SDA_PIN 18
#define SCL_PIN 19
#define LED_0 21
#define LED_1 20
// Masks for Cirque Register Access Protocol (RAP)
#define WRITE_MASK 0x80
#define READ_MASK 0xA0
// Register config values for this demo
#define SYSCONFIG_1 0x00
#define FEEDCONFIG_1 0x03
#define FEEDCONFIG_2 0x1F
#define Z_IDLE_COUNT 0x05
// Coordinate scaling values
#define PINNACLE_XMAX 2047 // max value Pinnacle can report for X
#define PINNACLE_YMAX 1535 // max value Pinnacle can report for Y
#define PINNACLE_X_LOWER 127 // min "reachable" X value
#define PINNACLE_X_UPPER 1919 // max "reachable" X value
#define PINNACLE_Y_LOWER 63 // min "reachable" Y value
#define PINNACLE_Y_UPPER 1471 // max "reachable" Y value
#define PINNACLE_X_RANGE (PINNACLE_X_UPPER-PINNACLE_X_LOWER)
#define PINNACLE_Y_RANGE (PINNACLE_Y_UPPER-PINNACLE_Y_LOWER)
#define ZONESCALE 256 // divisor for reducing x,y values to an array index for the LUT
#define ROWS_Y ((PINNACLE_YMAX + 1) / ZONESCALE)
#define COLS_X ((PINNACLE_XMAX + 1) / ZONESCALE)
// ADC-attenuation settings (held in BIT_7 and BIT_6)
// 1X = most sensitive, 4X = least sensitive
#define ADC_ATTENUATE_1X 0x00
#define ADC_ATTENUATE_2X 0x40
#define ADC_ATTENUATE_3X 0x80
#define ADC_ATTENUATE_4X 0xC0
// Convenient way to store and access measurements
typedef struct _absData
uint16_t xValue;
uint16_t yValue;
uint16_t zValue;
uint8_t buttonFlags;
bool touchDown;
bool hovering;
} absData_t;
absData_t touchData;
//const uint16_t ZONESCALE = 256;
//const uint16_t ROWS_Y = 6;
//const uint16_t COLS_X = 8;
// These values require tuning for optimal touch-response
// Each element represents the Z-value below which is considered "hovering" in that XY region of the sensor.
// The values present are not guaranteed to work for all HW configurations.
const uint8_t ZVALUE_MAP[ROWS_Y][COLS_X] =
{0, 0, 0, 0, 0, 0, 0, 0},
{0, 2, 3, 5, 5, 3, 2, 0},
{0, 3, 5, 15, 15, 5, 2, 0},
{0, 3, 5, 15, 15, 5, 3, 0},
// setup() gets called once at power-up, sets up serial debug output and Cirque's Pinnacle ASIC.
while(!Serial); // needed for USB
pinMode(LED_0, OUTPUT);
Pinnacle_Init();
// These functions are required for use with thick overlays (curved)
setAdcAttenuation(ADC_ATTENUATE_2X);
tuneEdgeSensitivity();
Serial.println("X\tY\tZ\tBtn\tData");
Pinnacle_EnableFeed(true);
// loop() continuously checks to see if data-ready (DR) is high. If so, reads and reports touch data to terminal.
if(DR_Asserted())
Pinnacle_GetAbsolute(&touchData);
Pinnacle_CheckValidTouch(&touchData); // Checks for "hover" caused by curved overlays
// ScaleData(&touchData, 1024, 1024); // Scale coordinates to arbitrary X, Y resolution
Serial.print(touchData.xValue);
Serial.print('\t');
Serial.print(touchData.yValue);
Serial.print('\t');
Serial.print(touchData.zValue);
Serial.print('\t');
Serial.print(touchData.buttonFlags);
Serial.print('\t');
if(Pinnacle_zIdlePacket(&touchData))
Serial.println("liftoff");
else if(touchData.hovering)
Serial.println("hovering");
Serial.println("valid");
AssertSensorLED(touchData.touchDown);
/* Pinnacle-based TM0XX0XX Functions */
void Pinnacle_Init()
RAP_Init();
DeAssert_CS();
pinMode(DR_PIN, INPUT);
// Host clears SW_CC flag
Pinnacle_ClearFlags();
// Host configures bits of registers 0x03 and 0x05
RAP_Write(0x03, SYSCONFIG_1);
RAP_Write(0x05, FEEDCONFIG_2);
// Host enables preferred output mode (absolute)
RAP_Write(0x04, FEEDCONFIG_1);
// Host sets z-idle packet count to 5 (default is 30)
RAP_Write(0x0A, Z_IDLE_COUNT);
Serial.println("Pinnacle Initialized...");
// Reads XYZ data from Pinnacle registers 0x14 through 0x17
// Stores result in absData_t struct with xValue, yValue, and zValue members
void Pinnacle_GetAbsolute(absData_t * result)
uint8_t data[6] = { 0,0,0,0,0,0 };
RAP_ReadBytes(0x12, data, 6);
result->buttonFlags = data[0] & 0x3F;
result->xValue = data[2] | ((data[4] & 0x0F) << 8);
result->yValue = data[3] | ((data[4] & 0xF0) << 4);
result->zValue = data[5] & 0x3F;
result->touchDown = result->xValue != 0;
// Checks touch data to see if it is a z-idle packet (all zeros)
bool Pinnacle_zIdlePacket(absData_t * data)
return data->xValue == 0 && data->yValue == 0 && data->zValue == 0;
// Clears Status1 register flags (SW_CC and SW_DR)
void Pinnacle_ClearFlags()
RAP_Write(0x02, 0x00);
delayMicroseconds(50);
// Enables/Disables the feed
void Pinnacle_EnableFeed(bool feedEnable)
uint8_t temp;
RAP_ReadBytes(0x04, &temp, 1); // Store contents of FeedConfig1 register
if(feedEnable)
temp |= 0x01; // Set Feed Enable bit
RAP_Write(0x04, temp);
temp &= ~0x01; // Clear Feed Enable bit
/* Curved Overlay Functions */
// Adjusts the feedback in the ADC, effectively attenuating the finger signal
// By default, the the signal is maximally attenuated (ADC_ATTENUATE_4X for use with thin, flat overlays
void setAdcAttenuation(uint8_t adcGain)
uint8_t temp = 0x00;
Serial.println("Setting ADC gain...");
ERA_ReadBytes(0x0187, &temp, 1);
temp &= 0x3F; // clear top two bits
temp |= adcGain;
ERA_WriteByte(0x0187, temp);
Serial.print("ADC gain set to:\t");
Serial.print(temp &= 0xC0, HEX);
switch(temp)
case ADC_ATTENUATE_1X:
Serial.println(" (X/1)");
case ADC_ATTENUATE_2X:
Serial.println(" (X/2)");
case ADC_ATTENUATE_3X:
Serial.println(" (X/3)");
case ADC_ATTENUATE_4X:
Serial.println(" (X/4)");
default:
// Changes thresholds to improve detection of fingers
void tuneEdgeSensitivity()
Serial.println("Setting xAxis.WideZMin...");
ERA_ReadBytes(0x0149, &temp, 1);
Serial.print("Current value:\t");
Serial.println(temp, HEX);
ERA_WriteByte(0x0149, 0x04);
Serial.print("New value:\t");
Serial.println("Setting yAxis.WideZMin...");
ERA_ReadBytes(0x0168, &temp, 1);
ERA_WriteByte(0x0168, 0x03);
// This function identifies when a finger is "hovering" so your system can choose to ignore them.
// Explanation: Consider the response of the sensor to be flat across it's area. The Z-sensitivity of the sensor projects this area
// a short distance upwards above the surface of the sensor. Imagine it is a solid cylinder (wider than it is tall)
// in which a finger can be detected and tracked. Adding a curved overlay will cause a user's finger to dip deeper in the middle, and higher
// on the perimeter. If the sensitivity is tuned such that the sensing area projects to the highest part of the overlay, the lowest
// point will likely have excessive sensitivity. This means the sensor can detect a finger that isn't actually contacting the overlay in the shallower area.
// ZVALUE_MAP[][] stores a lookup table in which you can define the Z-value and XY position that is considered "hovering". Experimentation/tuning is required.
// NOTE: Z-value output decreases to 0 as you move your finger away from the sensor, and it's maximum value is 0x63 (6-bits).
void Pinnacle_CheckValidTouch(absData_t * touchData)
uint32_t zone_x, zone_y;
//eliminate hovering
zone_x = touchData->xValue / ZONESCALE;
zone_y = touchData->yValue / ZONESCALE;
touchData->hovering = !(touchData->zValue > ZVALUE_MAP[zone_y][zone_x]);
/* ERA (Extended Register Access) Functions */
// Reads <count> bytes from an extended register at <address> (16-bit address),
// stores values in <*data>
void ERA_ReadBytes(uint16_t address, uint8_t * data, uint16_t count)
uint8_t ERAControlValue = 0xFF;
Pinnacle_EnableFeed(false); // Disable feed
RAP_Write(0x1C, (uint8_t)(address >> 8)); // Send upper byte of ERA address
RAP_Write(0x1D, (uint8_t)(address & 0x00FF)); // Send lower byte of ERA address
for(uint16_t i = 0; i < count; i++)
RAP_Write(0x1E, 0x05); // Signal ERA-read (auto-increment) to Pinnacle
// Wait for status register 0x1E to clear
do
RAP_ReadBytes(0x1E, &ERAControlValue, 1);
} while(ERAControlValue != 0x00);
RAP_ReadBytes(0x1B, data + i, 1);
// Writes a byte, <data>, to an extended register at <address> (16-bit address)
void ERA_WriteByte(uint16_t address, uint8_t data)
RAP_Write(0x1B, data); // Send data byte to be written
RAP_Write(0x1C, (uint8_t)(address >> 8)); // Upper byte of ERA address
RAP_Write(0x1D, (uint8_t)(address & 0x00FF)); // Lower byte of ERA address
RAP_Write(0x1E, 0x02); // Signal an ERA-write to Pinnacle
do
/* RAP Functions */
void RAP_Init()
pinMode(CS_PIN, OUTPUT);
SPI.begin();
// Reads <count> Pinnacle registers starting at <address>
void RAP_ReadBytes(byte address, byte * data, byte count)
byte cmdByte = READ_MASK | address; // Form the READ command byte
SPI.beginTransaction(SPISettings(10000000, MSBFIRST, SPI_MODE1));
Assert_CS();
SPI.transfer(cmdByte); // Signal a RAP-read operation starting at <address>
SPI.transfer(0xFC); // Filler byte
for(byte i = 0; i < count; i++)
data = SPI.transfer(0xFC); // Each subsequent SPI transfer gets another register's contents
DeAssert_CS();
SPI.endTransaction();
// Writes single-byte <data> to <address>
void RAP_Write(byte address, byte data)
byte cmdByte = WRITE_MASK | address; // Form the WRITE command byte
Assert_CS();
SPI.transfer(cmdByte); // Signal a write to register at <address>
SPI.transfer(data); // Send <value> to be written to register
DeAssert_CS();
/* Logical Scaling Functions */
// Clips raw coordinates to "reachable" window of sensor
// NOTE: values outside this window can only appear as a result of noise
void ClipCoordinates(absData_t * coordinates)
if(coordinates->xValue < PINNACLE_X_LOWER)
coordinates->xValue = PINNACLE_X_LOWER;
else if(coordinates->xValue > PINNACLE_X_UPPER)
coordinates->xValue = PINNACLE_X_UPPER;
if(coordinates->yValue < PINNACLE_Y_LOWER)
coordinates->yValue = PINNACLE_Y_LOWER;
else if(coordinates->yValue > PINNACLE_Y_UPPER)
coordinates->yValue = PINNACLE_Y_UPPER;
// Scales data to desired X & Y resolution
void ScaleData(absData_t * coordinates, uint16_t xResolution, uint16_t yResolution)
uint32_t xTemp = 0;
uint32_t yTemp = 0;
ClipCoordinates(coordinates);
xTemp = coordinates->xValue;
yTemp = coordinates->yValue;
// translate coordinates to (0, 0) reference by subtracting edge-offset
xTemp -= PINNACLE_X_LOWER;
yTemp -= PINNACLE_Y_LOWER;
// scale coordinates to (xResolution, yResolution) range
coordinates->xValue = (uint16_t)(xTemp * xResolution / PINNACLE_X_RANGE);
coordinates->yValue = (uint16_t)(yTemp * yResolution / PINNACLE_Y_RANGE);
/* I/O Functions */
void Assert_CS()
digitalWrite(CS_PIN, LOW);
void DeAssert_CS()
digitalWrite(CS_PIN, HIGH);
void AssertSensorLED(bool state)
digitalWrite(LED_0, !state);
bool DR_Asserted()
return digitalRead(DR_PIN);
