Hi all, im trying to make a audio guestbook for my wedding next week. I have everything wired up correctly in the phone, and am stuck on the coding part. Using teensy 4.0 and arduino 1.8
Here is my code followed by the errors:
Here is the errors: Im completely lost on what to do. Please help!!!
Arduino: 1.8.19 (Windows 10), TD: 1.56, Board: "Teensy 4.0, Serial, 600 MHz, Faster, US English"
* Audio Guestbook, Copyright (c) 2022 Playful Technology
* Tested using a Teensy 4.0 with Teensy Audio Shield, although should work
* with minor modifications on other similar hardware
* When handset is lifted, a pre-recorded greeting message is played, followed by a tone.
* Then, recording starts, and continues until the handset is replaced.
* Playback button allows all messages currently saved on SD card through earpiece
* Files are saved on SD card as 44.1kHz, 16-bit, mono signed integer RAW audio format
* These can be loaded directly into Audacity ([url]https://www.audacityteam.org/[/url]). Or else, converted to WAV/MP3 format using SOX ([url]https://sourceforge.net/projects/sox/[/url])
// INCLUDES
// The default "sketchbook" location in which Arduino IDE installs libraries is:
// C:\Users\alast\Documents\Arduino
// However, the TeensyDuino installer installs libraries in:
// C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries
// To ensure the correct libraries are used when targetting Teensy platform in Arduino IDE, go File->Preferences and change the sketchbook location to avoid conflicts with Arduino libraries.
// When targetting Arduino boards, change it back again to default
#include <Bounce.h>
#include <TimeLib.h>
// DEFINES
// Define pins used by Teensy Audio Shield
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
// And those used for inputs
#define HOOK_PIN 0
#define PLAYBACK_BUTTON_PIN 1
// GLOBALS
// Audio initialisation code can be generated using the GUI interface at [url]https://www.pjrc.com/teensy/gui/[/url]
// Inputs
AudioSynthWaveform waveform1; // To create the "beep" sfx
AudioInputI2S i2s2; // I2S input from microphone on audio shield
AudioPlaySdRaw playRaw1; // Play .RAW audio files saved on SD card
AudioPlaySdWav playWav1; // Play 44.1kHz 16-bit PCM greeting WAV file
// Outputs
AudioRecordQueue queue1; // Creating an audio buffer in memory before saving to SD
AudioMixer4 mixer; // Allows merging several inputs to same output
AudioOutputI2S i2s1; // I2S interface to Speaker/Line Out on Audio shield
// Connections
AudioConnection patchCord1(waveform1, 0, mixer, 0); // wave to mixer
AudioConnection patchCord2(playRaw1, 0, mixer, 1); // raw audio to mixer
AudioConnection patchCord3(playWav1, 0, mixer, 2); // wav file playback mixer
AudioConnection patchCord4(mixer, 0, i2s1, 0); // mixer output to speaker (L)
AudioConnection patchCord5(i2s2, 0, queue1, 0); // mic input to queue (L)
// Filename to save audio recording on SD card
char filename[15];
// The file object itself
File frec;
// Use long 40ms debounce time on hook switch
Bounce buttonRecord = Bounce(HOOK_PIN, 40);
Bounce buttonPlay = Bounce(PLAYBACK_BUTTON_PIN, 8);
// Keep track of current state of the device
enum Mode {Initialising, Ready, Prompting, Recording, Playing};
Mode mode = Mode::Initialising;
// Note that Serial.begin() is not required for Teensy -
// by default it initialises serial communication at full USB speed
// See [url]https://www.pjrc.com/teensy/td_serial.html[/url]
// Serial.begin()
Serial.println(__FILE__ __DATE__);
// Configure the input pins
pinMode(HOOK_PIN, INPUT_PULLUP);
pinMode(PLAYBACK_BUTTON_PIN, INPUT_PULLUP);
AudioMemory(60);
sgtl5000_1.enable();
// Define which input on the audio shield to use (AUDIO_INPUT_LINEIN / AUDIO_INPUT_MIC)
sgtl5000_1.volume(0.5);
// Play a beep to indicate system is online
waveform1.frequency(440);
waveform1.amplitude(0.9);
wait(250);
waveform1.amplitude(0);
// Initialize the SD card
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1) {
// Value in dB
sgtl5000_1.micGain(15);
// Synchronise the Time object used in the program code with the RTC time provider.
// See [url]https://github.com/PaulStoffregen/Time[/url]
// Define a callback that will assign the correct datetime for any file system operations
// (i.e. saving a new audio recording onto the SD card)
FsDateTime::setCallback(dateTime);
mode = Mode::Ready;
// First, read the buttons
buttonRecord.update();
buttonPlay.update();
switch(mode){
case Mode::Ready:
// Rising edge occurs when the handset is lifted
if (buttonRecord.risingEdge()) {
Serial.println("Handset lifted");
mode = Mode::Prompting;
else if(buttonPlay.fallingEdge()) {
playAllRecordings();
case Mode::Prompting:
// Wait a second for users to put the handset to their ear
wait(1000);
// Play the greeting inviting them to record their message
playWav1.play("greeting.wav");
// Wait until the message has finished playing
while (playWav1.isPlaying()) {
// Check whether the handset is replaced
// Handset is replaced
if(buttonRecord.fallingEdge()) {
playWav1.stop();
mode = Mode::Ready;
return;
// Debug message
Serial.println("Starting Recording");
// Play the tone sound effect
wait(250);
// Start the recording function
startRecording();
case Mode::Recording:
if(buttonRecord.fallingEdge()){
// Debug log
Serial.println("Stopping Recording");
// Stop recording
stopRecording();
// Play audio tone to confirm recording has ended
waveform1.frequency(523.25);
wait(50);
wait(50);
wait(50);
else {
continueRecording();
case Mode::Playing:
void startRecording() {
// Find the first available file number
for (uint8_t i=0; i<9999; i++) {
// Format the counter as a five-digit number with leading zeroes, followed by file extension
snprintf(filename, 11, " %05d.RAW", i);
// Create if does not exist, do not open existing, write, sync after write
if (!SD.exists(filename)) {
frec = SD.open(filename, FILE_WRITE);
if(frec) {
Serial.print("Recording to ");
Serial.println(filename);
queue1.begin();
mode = Mode::Recording;
else {
Serial.println("Couldn't open file to record!");
void continueRecording() {
// Check if there is data in the queue
if (queue1.available() >= 2) {
byte buffer[512];
// into a 512 byte buffer. The Arduino SD library
// writes are used.
memcpy(buffer, queue1.readBuffer(), 256);
queue1.freeBuffer();
memcpy(buffer+256, queue1.readBuffer(), 256);
// Write all 512 bytes to the SD card
frec.write(buffer, 512);
void stopRecording() {
// Stop adding any new data to the queue
queue1.end();
// Flush all existing remaining data from the queue
// Save to open file
frec.write((byte*)queue1.readBuffer(), 256);
// Close the file
frec.close();
mode = Mode::Ready;
void playAllRecordings() {
// Recording files are saved in the root directory
File dir = SD.open("/");
while (true) {
File entry = dir.openNextFile();
if (!entry) {
// no more files
entry.close();
int8_t len = strlen(entry.name());
if (strstr(strlwr(entry.name() + (len - 4)), ".raw")) {
Serial.print("Now playing ");
Serial.println(entry.name());
// Play a short beep before each message
waveform1.amplitude(0.5);
wait(250);
// Play the file
playRaw1.play(entry.name());
mode = Mode::Playing;
entry.close();
while (playRaw1.isPlaying()) {
// Button is pressed again
if(buttonPlay.risingEdge() || buttonRecord.fallingEdge()) {
playRaw1.stop();
mode = Mode::Ready;
return;
// All files have been played
mode = Mode::Ready;
// Retrieve the current time from Teensy built-in RTC
time_t getTeensy3Time(){
return Teensy3Clock.get();
// Callback to assign timestamps for file system operations
void dateTime(uint16_t* date, uint16_t* time, uint8_t* ms10) {
// Return date using FS_DATE macro to format fields.
*date = FS_DATE(year(), month(), day());
// Return time using FS_TIME macro to format fields.
*time = FS_TIME(hour(), minute(), second());
// Return low time bits in units of 10 ms.
*ms10 = second() & 1 ? 100 : 0;
// Non-blocking delay, which pauses execution of main program logic,
// but while still listening for input
void wait(unsigned int milliseconds) {
elapsedMillis msec=0;
while (msec <= milliseconds) {
if (buttonRecord.fallingEdge()) Serial.println("Button (pin 0) Press");
if (buttonPlay.fallingEdge()) Serial.println("Button (pin 1) Press");
if (buttonRecord.risingEdge()) Serial.println("Button (pin 0) Release");
if (buttonPlay.risingEdge()) Serial.println("Button (pin 1) Release");
C:\Users\t_lun\Desktop\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\t_lun\Desktop\Arduino\hardware -hardware C:\Users\t_lun\AppData\Local\Arduino15\packages -tools C:\Users\t_lun\Desktop\Arduino\tools-builder -tools C:\Users\t_lun\Desktop\Arduino\hardware\tools\avr -tools C:\Users\t_lun\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\t_lun\Desktop\Arduino\libraries -libraries C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr\libraries\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10819 -build-path C:\Users\t_lun\AppData\Local\Temp\arduino_build_912611 -warnings=none -build-cache C:\Users\t_lun\AppData\Local\Temp\arduino_cache_280408 -verbose C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr\libraries\sketch_jun04a\sketch_jun04a.ino
C:\Users\t_lun\Desktop\Arduino\arduino-builder -compile -logger=machine -hardware C:\Users\t_lun\Desktop\Arduino\hardware -hardware C:\Users\t_lun\AppData\Local\Arduino15\packages -tools C:\Users\t_lun\Desktop\Arduino\tools-builder -tools C:\Users\t_lun\Desktop\Arduino\hardware\tools\avr -tools C:\Users\t_lun\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\t_lun\Desktop\Arduino\libraries -libraries C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr\libraries\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10819 -build-path C:\Users\t_lun\AppData\Local\Temp\arduino_build_912611 -warnings=none -build-cache C:\Users\t_lun\AppData\Local\Temp\arduino_cache_280408 -verbose C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr\libraries\sketch_jun04a\sketch_jun04a.ino
Using board 'teensy40' from platform in folder: C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr
Using core 'teensy4' from platform in folder: C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Users\\t_lun\\AppData\\Local\\Temp\\arduino_build_912611\\sketch\\sketch_jun04a.ino.cpp" -o nul
Alternatives for Bounce.h: [Bounce]
ResolveLibrary(Bounce.h)
-> candidates: [Bounce]
"C:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "C:\\Users\\t_lun\\AppData\\Local\\Temp\\arduino_build_912611\\sketch\\sketch_jun04a.ino.cpp" -o nul
Alternatives for Audio.h: [Audio@1.3]
ResolveLibrary(Audio.h)
-> candidates: [Audio@1.3]
"C:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "C:\\Users\\t_lun\\AppData\\Local\\Temp\\arduino_build_912611\\sketch\\sketch_jun04a.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "C:\\Users\\t_lun\\AppData\\Local\\Temp\\arduino_build_912611\\sketch\\sketch_jun04a.ino.cpp" -o nul
Alternatives for SD.h: [SD@1.2.4 SD@2.0.0]
ResolveLibrary(SD.h)
-> candidates: [SD@1.2.4 SD@2.0.0]
"C:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\src" "C:\\Users\\t_lun\\AppData\\Local\\Temp\\arduino_build_912611\\sketch\\sketch_jun04a.ino.cpp" -o nul
Alternatives for SdFat.h: [SdFat@2.1.0]
ResolveLibrary(SdFat.h)
-> candidates: [SdFat@2.1.0]
"C:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=156 -DARDUINO=10819 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\src" "-IC:\\Users\\t_lun\\Desktop\\Arduino\\hardware\\teensy\\avr\\libraries\\SdFat\\src" "C:\\Users\\t_lun\\AppData\\Local\\Temp\\arduino_build_912611\\sketch\\sketch_jun04a.ino.cpp" -o nul
Alternatives for SerialFlash.h: []In file included from C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr\libraries\Audio/Audio.h:129:0,
from C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr\libraries\sketch_jun04a\sketch_jun04a.ino:32:
ResolveLibrary(SerialFlash.h)C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr\libraries\Audio/play_serialflash_raw.h:33:25: fatal error: SerialFlash.h: No such file or directory
-> candidates: []compilation terminated.
Used: C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr\libraries\SD
Not used: C:\Users\t_lun\Desktop\Arduino\libraries\SD
Using library Bounce in folder: C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr\libraries\Bounce (legacy)
Using library Audio at version 1.3 in folder: C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr\libraries\Audio
Using library SPI at version 1.0 in folder: C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr\libraries\SPI
Using library SD at version 2.0.0 in folder: C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr\libraries\SD
Using library SdFat at version 2.1.0 in folder: C:\Users\t_lun\Desktop\Arduino\hardware\teensy\avr\libraries\SdFat
Error compiling for board Teensy 4.0.
