Results 1 to 5 of 5
Thread: Noise in morse signal
    May 2017
    Netherlands
    152
    Hi all,
    My project for the new binary CW decoder is nearly finished however I like to add a noise filter.
    Used here a Teensy 4.1 so is there away to remove the noise from my signal listen to
    https://mega.nz/file/DvxiXKjT#rUPTJD...jdsLR9qWUyUwQU
    The tone is approx 350 Hz.
    Best regards,
    Johan
    Dec 2016
    183
    That noise sounds like mostly Gaussian-like noise. For this, spectral filtering reduces the noise power in proportion to the bandwidth. I suggest FIR filtering as ringing is greater for IIR (biquad) filtering. These components are available in the Audio Libraries.
    If the noise is impulsive, the noise blanking can be very effective. This is available in the floating point audio library.
    Also, if you know the speed of the CW, the "matched" filter is very effective. In a FIR implementation, this consists of enough samples of a 350 Hz sine wave to occupy a dot length. The 350 Hz is your center frequency, I believe. This ends up with a sine(f)/f type of response, which seems strange, but provides the maximum S/N on a dot.
    May 2017
    Netherlands
    152
    Hi Bob,
    I did some filtering listen to the results....
    https://mega.nz/file/KnA1FaLa#-1FnML...G6Nn2pMCvIQDjI
    Thanks for your suggestion!
    Best,
    Johan
    1,885
    What sort of filtering did you use?
    Pete
    May 2017
    Netherlands
    152
    I used. Low pass filer.
    Best,
    Johan
