Raspberry PI Raspbian 64Bit OS support ?
macrosii
I would like to migrate over to Raspian 64bit on my Raspberry PI 4's as after testing performance seems smoother.
Paul, is there any chance you will be supporting this for Teensyduino ?
Thanks and Regards
(and sorry if this has been asked before , I couldn't find in a search!)
Just yesterday I installed Arduino 1.8.19 Arduino + TD 1.57B2 onto an RPI 4 that I install Ubuntu 2204 64 bit.
I mentioned it up at:
https://forum.pjrc.com/threads/70409-Teensyduino-1-57-Beta-2?p=307573&viewfull=1#post307573
Today same machine I installed Arduino 2 RC 7 from: https://github.com/koendv/arduino-ide-raspberrypi
on the same machine and I installed the TD 1.56 install talked about in this thread: https://forum.pjrc.com/threads/53548-Arduino-CLI-Alpha-Release-Teensy-Support
And they appear to work
Edit: Forgot to mention that Arduino IDE 1.x for ARM 64 I would probably try from:
The one marked: Linux Installer (AARCH64 / Jetson TX2)
Likewise from Arduino.cc would download the ARM64 version.
Note: I have not tried the Raspion 64 bit OS in awhile so not sure in that case.
I have Arduino 1.8.19 and Teensyduino 1.56 running on "raspian" 64 ( raspberry pi os 64 bit ) on a 8gb RPI 4 ...and while I haven't done much heavy lifting with it, it does seem to work fine.
As Kurt says grab the ARM64 / AARCH64 - Jetson TX2 versions
