I have a Spektrum SRXL2 Serial Receiver that I want to connect to a Teensy 4. I have an example for arduino that I want to convert to one-wire communication. How do I take this Serial communication code and use the OneWire Library instead.
This is the documentation for SRXL2 https://github.com/SpektrumRC/SRXL2
I'm using this example code to communicate with the receiver.
https://github.com/AndersHoglund/Ard...oPwmBridge.ino
* Spektrum SRXL2 to PWM Bridge
//#define USE_SOFTWARE_SERIAL
#include <Servo.h>
#ifdef USE_SOFTWARE_SERIAL
#include <SoftwareSerial.h>
#include "spm_srxl.h"
// Select SRXL2 input and output pins (need to be combined into one halfduplex line with a diod)
#define SRXL2_INPUT_PIN 2 // -------o--------- SRXL2_DATA
#define SRXL2_OUTPUT_PIN 3 // ---<|---
#else
//Hardware UART might also need some pullup
// VCC +--|===|--
#define SRXL2_INPUT_PIN 1 // ------------o--------- SRXL2_DATA
#define SRXL2_OUTPUT_PIN 0 // ---<|--------
#define SRXL2_PORT_BAUDRATE_DEFAULT 115200
#define SRXL2_FRAME_TIMEOUT 22
// Spektrum channel order
#define THRO 0
#define AILE 1
#define ELEV 2
#define YAW 3
#define GEAR 4
#define AUX1 5
#define AUX2 6
#define AUX3 7
#define AUX4 8
#define AUX5 9
// Only available at 22ms frame rate.
#define AUX6 10
#define AUX7 11
// Select the PWM output pins
#define PWM_THRO_PIN 9
#define PWM_AUX2_PIN 8
#define PWM_AUX3_PIN 7
#define PWM_AUX4_PIN 6
#define PWM_AUX5_PIN 5
typedef struct
int channel;
int pin;
int value;
unsigned long prevTime;
Servo device;
} pwm_t;
pwm_t pwms[] =
{THRO, PWM_THRO_PIN, 1000, 0},
{AUX2, PWM_AUX2_PIN, 1500, 0},
{AUX3, PWM_AUX3_PIN, 1500, 0},
{AUX4, PWM_AUX4_PIN, 1500, 0},
{AUX5, PWM_AUX5_PIN, 1500, 0}
SoftwareSerial srxl2port(SRXL2_INPUT_PIN, SRXL2_OUTPUT_PIN); // RX, TX
#else
#define srxl2port Serial
unsigned long currentTime;
unsigned long prevPwmTime = 0;
const long pwmInterval = 22;
srxl2port.begin(SRXL2_PORT_BAUDRATE_DEFAULT);
srxlInitDevice(SRXL_DEVICE_ID, SRXL_DEVICE_PRIORITY, SRXL_DEVICE_INFO, 0x01000001);// // Init the local SRXL device with the unique ID 32 bit 0x01000001 hexadezimal.
srxlInitBus(0, 1, SRXL_SUPPORTED_BAUD_RATES);// Init the SRXL bus: The bus index must always be < SRXL_NUM_OF_BUSES -- in this case, it can only be 0 since we have only 1 bus.
for (int i=0; i < sizeof(pwms)/sizeof(pwm_t); i++ )
pwms[i].device.attach(pwms[i].pin);
currentTime = millis();
static unsigned long prevSerialRxTime = 0;
// UART receive buffer
static uint8_t rxBuffer[2 * SRXL_MAX_BUFFER_SIZE];
static uint8_t rxBufferIndex = 0;
if (currentTime - prevSerialRxTime > SRXL2_FRAME_TIMEOUT)
prevSerialRxTime = currentTime;
rxBufferIndex = 0;
srxlRun(0, SRXL2_FRAME_TIMEOUT);
if ( srxl2port.available() )
unsigned char c = srxl2port.read(); //
rxBuffer[rxBufferIndex++] = c;
if (rxBufferIndex >= 5)
if(rxBuffer[0] == SPEKTRUM_SRXL_ID)
uint8_t packetLength = rxBuffer[2];
if (rxBufferIndex >= packetLength)
// Try to parse SRXL packet -- this internally calls srxlRun() after packet is parsed and reset timeout
if (srxlParsePacket(0, rxBuffer, packetLength))
// Move any remaining bytes to beginning of buffer (usually 0)
rxBufferIndex -= packetLength;
memmove(rxBuffer, &rxBuffer[packetLength], rxBufferIndex);
rxBufferIndex = 0;
if (currentTime - pwms[i].prevTime >= pwmInterval)
pwms[i].prevTime = currentTime;
pwms[i].device.writeMicroseconds(pwms[i].value);
///////////////////////// SRXL2 channel interface //////////////////////////////
void userProvidedReceivedChannelData(SrxlChannelData* pChannelData, bool isFailsafe)
// Get channel value and convert to 988 - 1500 - 2011 pwm range
pwms[i].value = 988 + srxlChData.values[pwms[i].channel] >> 6; // 16-bit to 10-bit range (0 - 1023)
void uartSetBaud(uint8_t uart, uint32_t baudRate) // Automatic adjust SRXL2 baudrate.
// Not supported yet
void uartTransmit(uint8_t uart, uint8_t* pBuffer, uint8_t length)
for (uint8_t i=0; i < length; i++)
srxl2port.write(pBuffer[i]);
srxl2port.flush();
