Results 1 to 4 of 4
Thread: One Wire Serial Communication using Teensy 4 with SRXL2 Spektrum Receivers
    Jun 2021
    14
    I have a Spektrum SRXL2 Serial Receiver that I want to connect to a Teensy 4. I have an example for arduino that I want to convert to one-wire communication. How do I take this Serial communication code and use the OneWire Library instead.
    This is the documentation for SRXL2 https://github.com/SpektrumRC/SRXL2
    I'm using this example code to communicate with the receiver.
    https://github.com/AndersHoglund/Ard...oPwmBridge.ino
     *  Spektrum SRXL2 to PWM Bridge
    //#define USE_SOFTWARE_SERIAL
    #include <Servo.h>
    #ifdef USE_SOFTWARE_SERIAL
    #include <SoftwareSerial.h>
    #include "spm_srxl.h"
    // Select SRXL2 input and output pins (need to be combined into one halfduplex line with a diod)
    #define SRXL2_INPUT_PIN 2     //  -------o--------- SRXL2_DATA
    #define SRXL2_OUTPUT_PIN 3    //  ---<|---
    #else
    //Hardware UART might also need some pullup
                                  // VCC +--|===|--
    #define SRXL2_INPUT_PIN 1     //  ------------o--------- SRXL2_DATA
    #define SRXL2_OUTPUT_PIN 0    //  ---<|--------
    #define SRXL2_PORT_BAUDRATE_DEFAULT 115200
    #define SRXL2_FRAME_TIMEOUT 22
    // Spektrum channel order
    #define THRO 0
    #define AILE 1
    #define ELEV 2
    #define YAW  3
    #define GEAR 4
    #define AUX1 5
    #define AUX2 6
    #define AUX3 7
    #define AUX4 8
    #define AUX5 9
    // Only available at 22ms frame rate.
    #define AUX6 10
    #define AUX7 11
    // Select the PWM output pins
    #define PWM_THRO_PIN 9
    #define PWM_AUX2_PIN 8
    #define PWM_AUX3_PIN 7
    #define PWM_AUX4_PIN 6
    #define PWM_AUX5_PIN 5
    typedef struct
      int channel;
      int pin;
      int value;
      unsigned long prevTime;
      Servo device;
    } pwm_t;
    pwm_t pwms[] =
      {THRO, PWM_THRO_PIN, 1000, 0},
      {AUX2, PWM_AUX2_PIN, 1500, 0},
      {AUX3, PWM_AUX3_PIN, 1500, 0},
      {AUX4, PWM_AUX4_PIN, 1500, 0},
      {AUX5, PWM_AUX5_PIN, 1500, 0}
    SoftwareSerial srxl2port(SRXL2_INPUT_PIN, SRXL2_OUTPUT_PIN); // RX, TX
    #else
    #define srxl2port Serial
    unsigned long currentTime;
    unsigned long prevPwmTime = 0;
    const long pwmInterval = 22;
      srxl2port.begin(SRXL2_PORT_BAUDRATE_DEFAULT);
      srxlInitDevice(SRXL_DEVICE_ID, SRXL_DEVICE_PRIORITY, SRXL_DEVICE_INFO, 0x01000001);// // Init the local SRXL device with the unique ID 32 bit 0x01000001 hexadezimal.
      srxlInitBus(0, 1, SRXL_SUPPORTED_BAUD_RATES);// Init the SRXL bus: The bus index must always be < SRXL_NUM_OF_BUSES -- in this case, it can only be 0 since we have only 1 bus.
      for (int i=0; i < sizeof(pwms)/sizeof(pwm_t); i++ )
        pwms[i].device.attach(pwms[i].pin);
      currentTime = millis();
      static unsigned long prevSerialRxTime = 0;
      // UART receive buffer
      static uint8_t rxBuffer[2 * SRXL_MAX_BUFFER_SIZE];
      static uint8_t rxBufferIndex = 0;
      if (currentTime - prevSerialRxTime > SRXL2_FRAME_TIMEOUT)
        prevSerialRxTime = currentTime;
        rxBufferIndex = 0;
        srxlRun(0, SRXL2_FRAME_TIMEOUT);
      if ( srxl2port.available() )
        unsigned char c = srxl2port.read(); //
        rxBuffer[rxBufferIndex++] = c;
      if (rxBufferIndex >= 5)
        if(rxBuffer[0] == SPEKTRUM_SRXL_ID)
          uint8_t packetLength = rxBuffer[2];
          if (rxBufferIndex >= packetLength)
            // Try to parse SRXL packet -- this internally calls srxlRun() after packet is parsed and reset timeout
            if (srxlParsePacket(0, rxBuffer, packetLength))
              // Move any remaining bytes to beginning of buffer (usually 0)
              rxBufferIndex -= packetLength;
              memmove(rxBuffer, &rxBuffer[packetLength], rxBufferIndex);
                rxBufferIndex = 0;
        if (currentTime - pwms[i].prevTime >= pwmInterval)
          pwms[i].prevTime = currentTime;
          pwms[i].device.writeMicroseconds(pwms[i].value);
    ///////////////////////// SRXL2 channel interface //////////////////////////////
    void userProvidedReceivedChannelData(SrxlChannelData* pChannelData, bool isFailsafe)
        // Get channel value and convert to 988 - 1500 - 2011 pwm range
        pwms[i].value = 988 + srxlChData.values[pwms[i].channel] >> 6;    // 16-bit to 10-bit range (0 - 1023)
    void uartSetBaud(uint8_t uart, uint32_t baudRate) // Automatic adjust SRXL2 baudrate.
      // Not supported yet
    void uartTransmit(uint8_t uart, uint8_t* pBuffer, uint8_t length)
      for (uint8_t i=0; i < length; i++)
        srxl2port.write(pBuffer[i]);
      srxl2port.flush();
    May 2017
    312
    If you look at the one-wire protocol, you will see it is completely different from half duplex serial ( rs232 type ) communication. You will not be able to use the OneWire Library.
    Jun 2021
    14
    Srlx2 uses one wire, the example code that I posted uses a diode to combine the tx/rx lines of the Arduino. Are you saying that the one wire library is unable to communicate with the receiver using Srlx2 protocol?
    I posted the example code to show the necessary call and response to communicate with SRXL2 receivers. I don't understand why one wire can't be used to listen and respond to the SRXL2 receiver.
    May 2017
    312
    To convert your code to Teensy could be as simple as changing one line:
     Change this line to
    #define srxl2port Serial1
    You would then add the diode circuit to enable the half duplex feature. You would wire to pins 0 and 1 to use Serial1. If your receiver is 5 volt, then you may need logic level converters, you need to check/measure with a voltmeter; but it is probably open collector logic and in that case you would just add a pullup to 3.3 volts.
    OneWire is a completely different protocol from Serial Uarts.
    Edit: took a quick look at the Spec at one of your links, it says the Tx/Rx signal is 3.3 volt with a very weak pullup. So you won't need logic level converters but may need a pullup.
