#include <Arduino_GFX_Library.h>
#include <MPU6050_light.h> // Gyro library
File root; // SD card root directory
MPU6050 mpu(Wire); // MPU6050 Gyro = 0x68
#if defined(__IMXRT1052__) || defined(__IMXRT1062__)
// PJRC Teensy 4.x
#define TFT_CS 10 // Used to be pin 39 // GFX_NOT_DEFINED for display without CS pin
#define TFT_DC 9 // Used to be pin 41
#define TFT_RST 8 // Used to be pin 40
#define TFT_BL 7 // Used to be pin 22
#define ledring 6
#define piezo 21
#define sidelights 20
#define rota 15
#define rotb 16
#define rotsw 17
// SD card CS = 5
#define PNG_FILENAME "/TG2.png" // Temp PNG file to load
Arduino_DataBus *bus = new Arduino_HWSPI(TFT_DC, TFT_CS);
// GC9A01 IPS LCD 240x240
//Arduino_GFX *gfx = new Arduino_GC9A01(bus, TFT_RST, 0 /* rotation */, true /* IPS */);
Arduino_GFX *gfx = new Arduino_GC9A01(bus, 7 /* RST */, 0 /* rotation */, true /* IPS */);
//---------------- Set up the PNG display variables -------------------
#include <PNGdec.h>
PNG png;
int16_t wi, hi, xOffset, yOffset; // Offset not required for the round screen
File pngFile; // File to access a PNG image on the SD card
//----------------- Graphics variables --------------------------------
int32_t w, h, n, n1, cx, cy, cx1, cy1, cn, cn1;
uint8_t tsa, tsb, tsc, ds;
//----------------------- Gyro ----------------------------------------
int TestGyroTimer; // Timer to test the gyro at boot
int GyroPitch; // Data from the Gyro
int GyroRoll;
//--------------------------------- Accessing a PNG file from the SD card ----------------------------------------------
void *myOpen(const char *filename, int32_t *size)
pngFile = SD.open(filename, FILE_READ);
if (!pngFile || pngFile.isDirectory())
Serial.println(F("ERROR: Failed to open " PNG_FILENAME " file for reading"));
gfx->println(F("ERROR: Failed to open " PNG_FILENAME " file for reading"));
*size = pngFile.size();
Serial.printf("Opened '%s', size: %d\n", filename, *size);
return &pngFile;
void myClose(void *handle)
if (pngFile)
pngFile.close();
int32_t myRead(PNGFILE *handle, uint8_t *buffer, int32_t length)
if (!pngFile)
return 0;
return pngFile.read(buffer, length);
int32_t mySeek(PNGFILE *handle, int32_t position)
if (!pngFile)
return 0;
return pngFile.seek(position);
static inline uint32_t micros_start() __attribute__((always_inline));
uint8_t oms = millis();
while ((uint8_t)millis() == oms)
return micros();
// Function to draw pixels to the display
void PNGDraw(PNGDRAW *pDraw)
uint16_t usPixels[320];
uint8_t usMask[320];
png.getLineAsRGB565(pDraw, usPixels, PNG_RGB565_LITTLE_ENDIAN, 0x00000000);
png.getAlphaMask(pDraw, usMask, 1);
gfx->draw16bitRGBBitmap(xOffset, yOffset + pDraw->y, usPixels, usMask, pDraw->iWidth, 1);
//##################### SETUP ###############################################################################################################################################################
Wire.begin(); // Set this as master I2c device
//--------------------------------- MPU6050 Gyro -----------------------------------------------
byte status = mpu.begin(); // Stop everything if could not connect to MPU6050
Serial.print(F("MPU6050 status: "));
Serial.println(status);
while (status != 0) {
TestGyroTimer++;
delay(10000);
if (TestGyroTimer > 1000) {
Serial.print(F("GYRO ERROR"));
Serial.println(F("Calculating offsets, do not move MPU6050")); // Gyro and accelerometer calibration
mpu.setAccConfig(3); // 0 = 2g, 1= 4g, 2 = 8g, 3 = 16g SET THE ACCELEROMETER FORCE
mpu.calcOffsets(true, true);
Serial.println("Calibration complete!\n");
GyroPitch = mpu.getAccAngleY(); // Get the submarines angle at boot
GyroRoll = mpu.getAccAngleX();
Serial.print(F("Vehicle initial pitch: ")); Serial.println(GyroPitch);
Serial.print(F("Vehicle initial roll: ")); Serial.println(GyroRoll);
//------------------------------------ SD CARD -----------------------------------------------------
if (!SD.begin(5)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
root = SD.open("/");
printDirectory(root, 0);
Serial.println("done!");
//-------------------------------------- GFX -------------------------------------------------------
// while(!Serial);
Serial.println("Arduino_GFX library Test!");
gfx->begin();
w = gfx->width();
h = gfx->height();
n = min(w, h);
n1 = n - 1;
cx = w / 2;
cy = h / 2;
cx1 = cx - 1;
cy1 = cy - 1;
cn = min(cx1, cy1);
cn1 = cn - 1;
tsa = ((w <= 176) || (h <= 160)) ? 1 : (((w <= 240) || (h <= 240)) ? 2 : 3); // text size A
tsb = ((w <= 240) || (h <= 220)) ? 1 : 2; // text size B
tsc = ((w <= 220) || (h <= 220)) ? 1 : 2; // text size C
ds = (w <= 160) ? 9 : 12; // digit size
#ifdef TFT_BL
pinMode(TFT_BL, OUTPUT);
digitalWrite(TFT_BL, HIGH);
// ------------------- Draw a PNG gauge ------------------
unsigned long start = millis();
int rc;
rc = png.open(PNG_FILENAME, myOpen, myClose, myRead, mySeek, PNGDraw);
if (rc == PNG_SUCCESS)
int16_t pw = png.getWidth();
int16_t ph = png.getHeight();
Serial.print("Image width: "); Serial.println(pw);
Serial.print("Image height: "); Serial.println(ph);
xOffset = 0;
yOffset = 0;
rc = png.decode(NULL, 0);
Serial.printf("Draw offset: (%d, %d), time used: %lu\n", xOffset, yOffset, millis() - start);
Serial.printf("image specs: (%d x %d), %d bpp, pixel type: %d\n", png.getWidth(), png.getHeight(), png.getBpp(), png.getPixelType());
png.close();
delay(5000);
//##################### MAIN LOOP ##########################################################################################################################################################
void loop(void)
mpu.update();
GyroPitch = mpu.getAccAngleY(); // Get the vehicles angle
Serial.println(F("Benchmark\tmicro-secs"));
int32_t usecFillScreen = testFillScreen();
serialOut(F("Screen fill\t"), usecFillScreen, 100, true);
int32_t usecText = testText();
serialOut(F("Text\t"), usecText, 3000, true);
int32_t usecPixels = testPixels();
serialOut(F("Pixels\t"), usecPixels, 100, true);
int32_t usecLines = testLines();
serialOut(F("Lines\t"), usecLines, 100, true);
int32_t usecFastLines = testFastLines();
serialOut(F("Horiz/Vert Lines\t"), usecFastLines, 100, true);
int32_t usecFilledRects = testFilledRects();
serialOut(F("Rectangles (filled)\t"), usecFilledRects, 100, false);
int32_t usecRects = testRects();
serialOut(F("Rectangles (outline)\t"), usecRects, 100, true);
int32_t usecFilledTrangles = testFilledTriangles();
serialOut(F("Triangles (filled)\t"), usecFilledTrangles, 100, false);
int32_t usecTriangles = testTriangles();
serialOut(F("Triangles (outline)\t"), usecTriangles, 100, true);
int32_t usecFilledCircles = testFilledCircles(10);
serialOut(F("Circles (filled)\t"), usecFilledCircles, 100, false);
int32_t usecCircles = testCircles(10);
serialOut(F("Circles (outline)\t"), usecCircles, 100, true);
int32_t usecFilledArcs = testFillArcs();
serialOut(F("Arcs (filled)\t"), usecFilledArcs, 100, false);
int32_t usecArcs = testArcs();
serialOut(F("Arcs (outline)\t"), usecArcs, 100, true);
int32_t usecFilledRoundRects = testFilledRoundRects();
serialOut(F("Rounded rects (filled)\t"), usecFilledRoundRects, 100, false);
int32_t usecRoundRects = testRoundRects();
serialOut(F("Rounded rects (outline)\t"), usecRoundRects, 100, true);
#ifdef CANVAS
uint32_t start = micros_start();
gfx->flush();
int32_t usecFlush = micros() - start;
serialOut(F("flush (Canvas only)\t"), usecFlush, 0, false);
Serial.println(F("Done!"));
uint16_t c = 4;
int8_t d = 1;
for (int32_t i = 0; i < h; i++)
gfx->drawFastHLine(0, i, w, c);
c += d;
if (c <= 4 || c >= 11)
d = -d;
gfx->setCursor(0, 0);
gfx->setTextSize(tsa);
gfx->setTextColor(MAGENTA);
gfx->println(F("Arduino GFX PDQ"));
if (h > w)
gfx->setTextSize(tsb);
gfx->setTextColor(GREEN);
gfx->print(F("\nBenchmark "));
gfx->setTextSize(tsc);
if (ds == 12)
gfx->print(F(" "));
gfx->println(F("micro-secs"));
gfx->setTextSize(1);
printnice(F("Screen fill "), usecFillScreen);
printnice(F("Text "), usecText);
printnice(F("Pixels "), usecPixels);
printnice(F("Lines "), usecLines);
printnice(F("H/V Lines "), usecFastLines);
printnice(F("Rectangles F"), usecFilledRects);
printnice(F("Rectangles "), usecRects);
printnice(F("Triangles F "), usecFilledTrangles);
printnice(F("Triangles "), usecTriangles);
printnice(F("Circles F "), usecFilledCircles);
printnice(F("Circles "), usecCircles);
printnice(F("Arcs F "), usecFilledArcs);
printnice(F("Arcs "), usecArcs);
printnice(F("RoundRects F"), usecFilledRoundRects);
printnice(F("RoundRects "), usecRoundRects);
if ((h > w) || (h > 240))
gfx->print(F("\nBenchmark Complete!"));
#ifdef CANVAS
gfx->flush();
delay(60 * 1000L);
void serialOut(const __FlashStringHelper *item, int32_t v, uint32_t d, bool clear)
#ifdef CANVAS
gfx->flush();
Serial.print(item);
if (v < 0)
Serial.println(F("N/A"));
Serial.println(v);
delay(d);
if (clear)
gfx->fillScreen(BLACK);
void printnice(const __FlashStringHelper *item, long int v)
gfx->setTextColor(CYAN);
gfx->print(item);
gfx->setTextColor(YELLOW);
if (v < 0)
gfx->println(F(" N / A"));
char str[32] = {0};
#ifdef RTL8722DM
sprintf(str, "%d", (int)v);
#else
sprintf(str, "%ld", v);
for (char *p = (str + strlen(str)) - 3; p > str; p -= 3)
memmove(p + 1, p, strlen(p) + 1);
*p = ',';
while (strlen(str) < ds)
memmove(str + 1, str, strlen(str) + 1);
*str = ' ';
gfx->println(str);
int32_t testFillScreen()
// Shortened this tedious test!
gfx->fillScreen(WHITE);
gfx->fillScreen(RED);
gfx->fillScreen(GREEN);
gfx->fillScreen(BLUE);
return micros() - start;
int32_t testText()
gfx->setTextColor(WHITE, BLACK);
gfx->println(F("Hello World!"));
gfx->setTextSize(2);
gfx->setTextColor(gfx->color565(0xff, 0x00, 0x00));
gfx->print(F("RED "));
gfx->setTextColor(gfx->color565(0x00, 0xff, 0x00));
gfx->print(F("GREEN "));
gfx->setTextColor(gfx->color565(0x00, 0x00, 0xff));
gfx->println(F("BLUE"));
gfx->println(1234.56);
gfx->setTextColor(WHITE);
gfx->println((w > 128) ? 0xDEADBEEF : 0xDEADBEE, HEX);
gfx->setTextColor(CYAN, WHITE);
gfx->println(F("Groop,"));
gfx->setTextColor(MAGENTA, WHITE);
gfx->println(F("I implore thee,"));
gfx->setTextColor(NAVY, WHITE);
gfx->println(F("my foonting turlingdromes."));
gfx->setTextColor(DARKGREEN, WHITE);
gfx->println(F("And hooptiously drangle me"));
gfx->setTextColor(DARKCYAN, WHITE);
gfx->println(F("with crinkly bindlewurdles,"));
gfx->setTextColor(MAROON, WHITE);
gfx->println(F("Or I will rend thee"));
gfx->setTextColor(PURPLE, WHITE);
gfx->println(F("in the gobberwartsb"));
gfx->setTextColor(OLIVE, WHITE);
gfx->println(F("with my blurglecruncheon,"));
gfx->setTextColor(DARKGREY, WHITE);
gfx->println(F("see if I don't!"));
gfx->setTextColor(RED);
gfx->println(F("Size 2"));
gfx->setTextSize(3);
gfx->setTextColor(ORANGE);
gfx->println(F("Size 3"));
gfx->setTextSize(4);
gfx->println(F("Size 4"));
gfx->setTextSize(5);
gfx->setTextColor(GREENYELLOW);
gfx->println(F("Size 5"));
gfx->setTextSize(6);
gfx->println(F("Size 6"));
gfx->setTextSize(7);
gfx->setTextColor(BLUE);
gfx->println(F("Size 7"));
gfx->setTextSize(8);
gfx->setTextColor(PURPLE);
gfx->println(F("Size 8"));
gfx->setTextSize(9);
gfx->setTextColor(PINK);
gfx->println(F("Size 9"));
int32_t testPixels()
for (int16_t y = 0; y < h; y++)
for (int16_t x = 0; x < w; x++)
gfx->drawPixel(x, y, gfx->color565(x << 3, y << 3, x * y));
#ifdef ESP8266
yield(); // avoid long run triggered ESP8266 WDT restart
int32_t testLines()
uint32_t start;
int32_t x1, y1, x2, y2;
x1 = y1 = 0;
y2 = h - 1;
for (x2 = 0; x2 < w; x2 += 6)
gfx->drawLine(x1, y1, x2, y2, BLUE);
#ifdef ESP8266
x2 = w - 1;
for (y2 = 0; y2 < h; y2 += 6)
#ifdef ESP8266
x1 = w - 1;
y1 = 0;
y2 = h - 1;
#ifdef ESP8266
x2 = 0;
#ifdef ESP8266
x1 = 0;
y1 = h - 1;
y2 = 0;
#ifdef ESP8266
x2 = w - 1;
#ifdef ESP8266
x1 = w - 1;
y1 = h - 1;
y2 = 0;
#ifdef ESP8266
x2 = 0;
#ifdef ESP8266
int32_t testFastLines()
uint32_t start;
int32_t x, y;
for (y = 0; y < h; y += 5)
gfx->drawFastHLine(0, y, w, RED);
for (x = 0; x < w; x += 5)
gfx->drawFastVLine(x, 0, h, BLUE);
int32_t testFilledRects()
uint32_t start;
int32_t i, i2;
for (i = n; i > 0; i -= 6)
i2 = i / 2;
gfx->fillRect(cx - i2, cy - i2, i, i, gfx->color565(i, i, 0));
int32_t testRects()
uint32_t start;
int32_t i, i2;
for (i = 2; i < n; i += 6)
i2 = i / 2;
gfx->drawRect(cx - i2, cy - i2, i, i, GREEN);
int32_t testFilledCircles(uint8_t radius)
uint32_t start;
int32_t x, y, r2 = radius * 2;
for (x = radius; x < w; x += r2)
for (y = radius; y < h; y += r2)
gfx->fillCircle(x, y, radius, MAGENTA);
int32_t testCircles(uint8_t radius)
uint32_t start;
int32_t w1 = w + radius;
int32_t h1 = h + radius;
// Screen is not cleared for this one -- this is
// intentional and does not affect the reported time.
for (x = 0; x < w1; x += r2)
for (y = 0; y < h1; y += r2)
gfx->drawCircle(x, y, radius, WHITE);
int32_t testFillArcs()
int16_t i, r = 360 / cn;
for (i = 6; i < cn; i += 6)
gfx->fillArc(cx1, cy1, i, i - 3, 0, i * r, RED);
int32_t testArcs()
gfx->drawArc(cx1, cy1, i, i - 3, 0, i * r, WHITE);
int32_t testFilledTriangles()
uint32_t start;
int32_t i;
for (i = cn1; i > 10; i -= 5)
gfx->fillTriangle(cx1, cy1 - i, cx1 - i, cy1 + i, cx1 + i, cy1 + i,
gfx->color565(0, i, i));
int32_t testTriangles()
uint32_t start;
int32_t i;
for (i = 0; i < cn; i += 5)
gfx->drawTriangle(
cx1, cy1 - i, // peak
cx1 - i, cy1 + i, // bottom left
cx1 + i, cy1 + i, // bottom right
gfx->color565(0, 0, i));
int32_t testFilledRoundRects()
uint32_t start;
int32_t i, i2;
for (i = n1; i > 20; i -= 6)
i2 = i / 2;
gfx->fillRoundRect(cx - i2, cy - i2, i, i, i / 8, gfx->color565(0, i, 0));
int32_t testRoundRects()
uint32_t start;
int32_t i, i2;
for (i = 20; i < n1; i += 6)
i2 = i / 2;
gfx->drawRoundRect(cx - i2, cy - i2, i, i, i / 8, gfx->color565(i, 0, 0));
//-------------------------------------- SD CARD CONTENTS -------------------------------------------------------
void printDirectory(File dir, int numTabs) {
while (true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
for (uint8_t i = 0; i < numTabs; i++) {
Serial.print('\t');
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numTabs + 1);
// files have sizes, directories do not
Serial.print("\t\t");
Serial.println(entry.size(), DEC);
entry.close();
// ---------------------------------------------- Piezo --------------------------------------------------------------
void SFX () {
tone(piezo, 900, 100);
