Hello
I am using Teensy 3.5, Using Arduino compiler 1.8.15.
I am simply setting up an RS232 port (Serial 2) to talk to/from a weather sensor which operates at 1200 baud.
This (standard) code works as expected, no issues on Teensy 3.5:
All reading and writing to and from the port works as expected.
I was unable to get Teensy 3.5's so I started using Teensy 3.6's.
Everything functions as expected, except that I am unable to set the baud rate on the Teensy 3.6 to 1200.
The same code, as above, does not work.
However, I found that the Teensy 3.6 can work if I set the baud rate to 9600:
Does anyone know why the serial port Teensy 3.6 can't be set to 1200 baud?
Gary
WEATHER.begin(1200);WEATHER.setTimeout(5);WEATHER.addMemoryForRead(bufferWs,50);
WEATHER.begin(9600);WEATHER.setTimeout(5);WEATHER.addMemoryForRead(bufferWs,50);
Gary
