ATORTeensyMan
I am trying to control a 3-Phase BLDC Blower Fan Motor Controller w/ PWM, then control that PWM "analog" voltage scale with PID. I am not receiving the full duty cycle of the Blower Fan, because 3v3 is the maximum PWM output, while the controller wants a 5v PWM voltage scale. So, in reality on the controller side I'm receiving a 66% Duty Cycle. 66% is just on the cusp of being too slow for my application. If any of you know a good way to convert the entire voltage scale that would be awesome thanks!
P.S.
I bought this and I couldn't get it to work. Based on what I read after I received it and started testing, I don't think it's going to work. However, If I am wrong and it should work, please tell me.
Link: https://www.sparkfun.com/products/1...EmTe_sJ0ggnesloBGAh2orUjzkDCoeXsaAomUEALw_wcB
P.P.S.
I don't understand the frequency side of things very well when it comes to PWM. Should I change the resolution at all? The controller says its 1-20khz, so does that mean that in my code I need to:
Development Board:
Teensy 3.5
3-Phase BLDC Controller:
View attachment JYQD-V6.3E2.pdf
Blower Fan:
View attachment U65ML-024KS-5.pdf
P.S.
P.P.S.
analogWriteFrequency(PWM, 20000);
Development Board:
Teensy 3.5
Blower Fan:
