Results 1 to 9 of 9
Thread: Audio shield wiring
    May 2022
    11
    Audio shield wiring
    I just got the audio shield for the teensy 4.0 and I'm having trouble getting sound out of it. My project requires that I have the shield separate from the teensy so I have them both mounted to a breadboard and I'm trying to wire it up just to the pins on the teensy needed to get sound out of the headphone jack. According to the docs on the I2S interface I need to have pins 7, 20, 21, and 23 connected. I connected these from the teensy to the corresponding pin numbers on the audio shield. I of course have the 3v, 5v and ground connected as well. When I run my code I don't hear anything. My sketch is just an oscillator connected straight to the audio out. Here is the sketch I'm trying to run:
    AudioSynthWaveform       waveform1;      //xy=255,276
    AudioOutputI2S           i2s1;           //xy=505,274
    AudioConnection          patchCord1(waveform1, 0, i2s1, 0);
    AudioConnection          patchCord2(waveform1, 0, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=511,326
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.5);
      waveform1.amplitude(0.5);
      waveform1.frequency(220);
      waveform1.pulseWidth(0.15);
    What am I doing wrong here?
    Senior Member houtson's Avatar
    Aug 2015
    Scotland
    254
    Hi @Pkore,
    In your sketch you need to give it some audio memory in setup (try AudioMemory(10); ).
    In general for hardware testing you'd be better using one of the examples (File>Examples>Audio>HardwareTesting in Arduino) where at least the code is known to work.
    Also a picture of your wiring would help (you need to keep the cables fairly short) if it is still not working.
    Cheers, Paul
    Senior Member h4yn0nnym0u5e's Avatar
    Apr 2021
    Cambridgeshire, UK
    737
    You also need the I²C control pins (18 and 19) connected, or the sgtl5000_1 commands won't work. I also seem to recall you need both the Gnd pins wired, not 100% sure about that.
    May 2022
    11
    Thanks! Yes I tried one of the examples too. There wasn't any sound there either.
    May 2022
    11
    Quote Originally Posted by h4yn0nnym0u5e View Post
    Thank you! I'll try connecting those and post back the progress.
    May 2022
    11
    Thanks for the advice! It worked! The only thing now is there's a high pitch squeal when I plug it into my mixer. It sounds fine through my headphones. I'm thinking it's the length of the wires on my breadboard. They're about 1.5 to 2.0 inches. How long should they be? Or is something else going on?
    Apr 2021
    Cambridgeshire, UK
    737
    Great news it works! Squeal ... not so good. I've used much longer wires (~20cm) for quick tests, but not connecting to anything much. Could be a ground loop or similar: I'm guessing the mixer is grounded via its power supply, and the Teensy / audio / breadboard via your PC or laptop's USB.
    If you're connecting the audio shield to a mixer, be sure to use the Line Out signals, NOT the headphone jack. The headphone jack ground is not at the same voltage level as the line out ground.
    May 2022
    11
    Thanks for pointing that out. I'm sure that's the issue. I'll try that and report back.
