Results 1 to 16 of 16
Thread: Bourns Encoder for my project help to choice
    Jun 2022
    16
    I need encoder for my midi board.
    Can I use Bourns EAW0J-C24-AE0128L with teensy 3.5 ?
    If anyone can help me on choice of endless encoder I really appreciate.
    If you have tips to connect and use encoder I really enjoy for.
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    821
    Electrically, this absolute endless encoder [datasheet] can be connected to a Teensy 3.5. Just use pinMode(pin, INPUT_PULLUP) for pins P1-P8 and then digitalRead each pin.
    However, be aware that this endless encoder has 128 unique states but it outputs decimal values from 1 to 254 on those 8 pins.
    I rearranged the table on page 2 to show the decimal values incrementing from 1 to 254. You will that decimal values 5, 10, 11, 13, 17, etc are missing.
    That may or may not be cumbersome for your application.
    Ofcourse you can add a look-up table to your code to get position and decimal value re-alligned.
    Pos									Dec
    56	0	0	0	0	0	0	0	1	1
    40	0	0	0	0	0	0	1	0	2
    55	0	0	0	0	0	0	1	1	3
    24	0	0	0	0	0	1	0	0	4
    39	0	0	0	0	0	1	1	0	6
    52	0	0	0	0	0	1	1	1	7
    8	0	0	0	0	1	0	0	0	8
    57	0	0	0	0	1	0	0	1	9
    23	0	0	0	0	1	1	0	0	12
    36	0	0	0	0	1	1	1	0	14
    13	0	0	0	0	1	1	1	1	15
    120	0	0	0	1	0	0	0	0	16
    41	0	0	0	1	0	0	1	0	18
    54	0	0	0	1	0	0	1	1	19
    53	0	0	0	1	0	1	1	1	23
    7	0	0	0	1	1	0	0	0	24
    20	0	0	0	1	1	1	0	0	28
    19	0	0	0	1	1	1	0	1	29
    125	0	0	0	1	1	1	1	0	30
    18	0	0	0	1	1	1	1	1	31
    104	0	0	1	0	0	0	0	0	32
    105	0	0	1	0	0	0	0	1	33
    25	0	0	1	0	0	1	0	0	36
    106	0	0	1	0	0	1	0	1	37
    38	0	0	1	0	0	1	1	0	38
    58	0	0	1	0	1	0	0	1	41
    37	0	0	1	0	1	1	1	0	46
    14	0	0	1	0	1	1	1	1	47
    119	0	0	1	1	0	0	0	0	48
    118	0	0	1	1	0	0	0	1	49
    107	0	0	1	1	0	1	0	1	53
    4	0	0	1	1	1	0	0	0	56
    3	0	0	1	1	1	0	1	0	58
    109	0	0	1	1	1	1	0	0	60
    108	0	0	1	1	1	1	0	1	61
    2	0	0	1	1	1	1	1	0	62
    1	0	0	1	1	1	1	1	1	63
    88	0	1	0	0	0	0	0	0	64
    89	0	1	0	0	0	0	1	0	66
    51	0	1	0	0	0	1	1	1	71
    9	0	1	0	0	1	0	0	0	72
    10	0	1	0	0	1	0	0	1	73
    90	0	1	0	0	1	0	1	0	74
    22	0	1	0	0	1	1	0	0	76
    11	0	1	0	0	1	1	0	1	77
    12	0	1	0	0	1	1	1	1	79
    42	0	1	0	1	0	0	1	0	82
    43	0	1	0	1	0	0	1	1	83
    21	0	1	0	1	1	1	0	0	92
    126	0	1	0	1	1	1	1	0	94
    127	0	1	0	1	1	1	1	1	95
    103	0	1	1	0	0	0	0	0	96
    102	0	1	1	0	0	0	1	0	98
    91	0	1	1	0	1	0	1	0	106
    116	0	1	1	1	0	0	0	0	112
    117	0	1	1	1	0	0	0	1	113
    115	0	1	1	1	0	1	0	0	116
    93	0	1	1	1	1	0	0	0	120
    94	0	1	1	1	1	0	0	1	121
    92	0	1	1	1	1	0	1	0	122
    114	0	1	1	1	1	1	0	0	124
    95	0	1	1	1	1	1	0	1	125
    113	0	1	1	1	1	1	1	0	126
    0	0	1	1	1	1	1	1	1	127
    72	1	0	0	0	0	0	0	0	128
    71	1	0	0	0	0	0	0	1	129
    68	1	0	0	0	0	0	1	1	131
    73	1	0	0	0	0	1	0	0	132
    29	1	0	0	0	0	1	1	1	135
    70	1	0	0	0	1	0	0	1	137
    69	1	0	0	0	1	0	1	1	139
    35	1	0	0	0	1	1	1	0	142
    34	1	0	0	0	1	1	1	1	143
    121	1	0	0	1	0	0	0	0	144
    122	1	0	0	1	0	0	1	0	146
    74	1	0	0	1	0	1	0	0	148
    30	1	0	0	1	0	1	1	1	151
    6	1	0	0	1	1	0	0	0	152
    123	1	0	0	1	1	0	1	0	154
    124	1	0	0	1	1	1	1	0	158
    17	1	0	0	1	1	1	1	1	159
    67	1	0	1	0	0	0	1	1	163
    26	1	0	1	0	0	1	0	0	164
    27	1	0	1	0	0	1	1	0	166
    28	1	0	1	0	0	1	1	1	167
    59	1	0	1	0	1	0	0	1	169
    15	1	0	1	0	1	1	1	1	175
    5	1	0	1	1	1	0	0	0	184
    110	1	0	1	1	1	1	0	0	188
    111	1	0	1	1	1	1	1	0	190
    16	1	0	1	1	1	1	1	1	191
    87	1	1	0	0	0	0	0	0	192
    84	1	1	0	0	0	0	0	1	193
    45	1	1	0	0	0	0	1	1	195
    86	1	1	0	0	0	1	0	0	196
    85	1	1	0	0	0	1	0	1	197
    50	1	1	0	0	0	1	1	1	199
    46	1	1	0	0	1	0	1	1	203
    33	1	1	0	0	1	1	1	1	207
    83	1	1	0	1	0	0	0	1	209
    44	1	1	0	1	0	0	1	1	211
    75	1	1	0	1	0	1	0	0	212
    31	1	1	0	1	0	1	1	1	215
    32	1	1	0	1	1	1	1	1	223
    100	1	1	1	0	0	0	0	0	224
    61	1	1	1	0	0	0	0	1	225
    101	1	1	1	0	0	0	1	0	226
    66	1	1	1	0	0	0	1	1	227
    62	1	1	1	0	0	1	0	1	229
    49	1	1	1	0	0	1	1	1	231
    99	1	1	1	0	1	0	0	0	232
    60	1	1	1	0	1	0	0	1	233
    47	1	1	1	0	1	0	1	1	235
    48	1	1	1	0	1	1	1	1	239
    77	1	1	1	1	0	0	0	0	240
    82	1	1	1	1	0	0	0	1	241
    78	1	1	1	1	0	0	1	0	242
    65	1	1	1	1	0	0	1	1	243
    76	1	1	1	1	0	1	0	0	244
    63	1	1	1	1	0	1	0	1	245
    64	1	1	1	1	0	1	1	1	247
    98	1	1	1	1	1	0	0	0	248
    81	1	1	1	1	1	0	0	1	249
    79	1	1	1	1	1	0	1	0	250
    80	1	1	1	1	1	0	1	1	251
    97	1	1	1	1	1	1	0	0	252
    96	1	1	1	1	1	1	0	1	253
    112	1	1	1	1	1	1	1	0	254
    Do you really need an absolute encoder?
    If not, than you're better off with standard non-absolute encoders. See this page for more info on how to use them.
    Paul
    Jun 2022
    16
    Thanks for your advise, I think you are right, I just need a 24 pulse relative encoder. It s to change the FX Time between multiple FX with MIDI messages (Pioneer Rekordbox) and I don't want fx time change abruptly for each fx when I switch between differents fx.
    Thanks for your help
    Jun 2022
    16
    Another question: the Teensy only have 3.3v pin power supply. Majority of encoder are 5v to work. With only 3.3v it is ok ?. What is the solution if it not work properly ?
    Can I get the 5v from teensy 3.5 vOut to power the encoder (or another components require 5v ) and put 220ohm resitor before each teensy Digital pins ?
    thanks
    Apr 2015
    Netherlands
    821
    Quote Originally Posted by mickael View Post
    Yes, no problem. Better not use 5V as not all Teensy's are 5V tolerant.
    But for those simple rotary encoders, you hook them up differently. No need to use 3V3 or 5V.
    Connect encoder pin Out A to Teensy pin 5, encoder pin Out B to Teensy pin 6 and encoder pin GND to Teensy GND.
    Then run the following code and check the serial monitor output:
    /* Encoder Library - Basic Example
     * http://www.pjrc.com/teensy/td_libs_Encoder.html
     * This example code is in the public domain.
    #include <Encoder.h>
    // Change these two numbers to the pins connected to your encoder.
    //   Best Performance: both pins have interrupt capability
    //   Good Performance: only the first pin has interrupt capability
    //   Low Performance:  neither pin has interrupt capability
    Encoder myEnc(5, 6);
    //   avoid using pins with LEDs attached
      Serial.println("Basic Encoder Test:");
    long oldPosition  = -999;
      long newPosition = myEnc.read();
      if (newPosition != oldPosition) {
        oldPosition = newPosition;
        Serial.println(newPosition);
    Paul
    Jun 2022
    16
    Thanks Paul,
    The test work great with my low cost encoder ec11.
    I have a problem, when I want to send midi message.
    After "oldPosition = newPosition;" I had usbMIDI.sendControlChange(35, 64, 1); to send Control change 35 value 64 on chanel 1.
    After I turn the encodeur few time, midi message is not send anymore and serial console doesn't display value. It seem the teensy crash.
    Apr 2015
    Netherlands
    821
    Is it possible to post your complete code so that we can reproduce the issue? [or, preferably, the smallest code that shows the error].
    Paul
    Jun 2022
    16
    Paul
    for information the code used:
        usbMIDI.sendControlChange(1, 64, 1);
      delay(10);
    midiox capture messages:
    0000199D 4 -- B0 23 48 1 --- Control Change
    00001A0C 4 -- B0 23 48 1 --- Control Change
    00001A16 4 -- B0 23 48 1 --- Control Change
    00002F11 4 -- B0 23 48 1 --- Control Change
    00002F43 4 -- B0 23 48 1 --- Control Change
    00002F4D 4 -- B0 23 48 1 --- Control Change
    000037DB 4 -- B0 23 48 1 --- Control Change
    00003835 4 -- B0 23 48 1 --- Control Change
    00003849 4 -- B0 23 48 1 --- Control Change
    00004203 4 -- B0 23 48 1 --- Control Change
    0000424E 4 -- B0 23 48 1 --- Control Change
    00004259 4 -- B0 23 48 1 --- Control Change
    000049BA 4 -- B0 23 48 1 --- Control Change
    00004A50 4 -- B0 23 48 1 --- Control Change
    000050F6 4 -- B0 23 48 1 --- Control Change
    0000511E 4 -- B0 23 48 1 --- Control Change --> after this teensy doesn't respond.....
    Apr 2015
    Netherlands
    821
    Made a quick setup using a Teensy 3.2 [don't have a Teensy 3.5] and ran your code.
    Here is the setup:
    Set USB type to "Serial+MIDI". Could not get it to fail...both serial monitor and MIDI-OX keep outputting data:
    Using Windows 10, Arduino 1.8.19, Teensyduino 1.56, MIDI-OX 7.0.2.372,
    By the way, your MIDI-OX captured messages are not sent by the code you posted...
    Paul
    Jun 2022
    16
    thank you for the test.
    It is very strange, I have same configuration, only teensy model change.
    When I comment "usbMIDI.sendControlChange(1, 64, 1);" serial display the position of encoder and it work properly (no crash of teensy).
    I will try with another encoder but I doubt that s the cause (encoders are new)
    thanks
    Apr 2015
    Netherlands
    821
    If the serial monitor shows correct counting of the encoder, than the encoder is fine. I see 4 counts per detent of the rotary encoder.
    Is it possible for you to make a photo that shows your wiring of Teensy and encoder? Just for making sure the wiring is OK.
    Do you happen to have another Teensy, like a 3.2?
    Just thinking out loud, could it be that the internal pullups are weaker on a Teensy 3.5 than on a 3.2 and therefor introduce more noise on the encoder outputs [in combination with long wires from the encoder]?
    Paul
    Germany
    1,850
    I have not much experience with MIDI. Just wondering if it is OK to send those messages every 10ms? The encoder library will generate a lot of fast up/down counts if the encoder bounces (which is very likely). So, your if (newPosition != oldPosition) might be true much more often as you expect. A quick check would be to increase the delay to 100ms.
    Apr 2015
    Netherlands
    821
    Replacing the Teensy 3.2 by a Teensy 4.1 and running your exact code gave the same flawless results as in my post #9.
    Paul
    Jun 2022
    16
    Hi Paul,
    my apologizes for my misstake in midi I accidentaly activate the midi output on teensy port after disable output to teensy midi port all work OK.
    For info I write this code to send midi only when +4 or -4 value difference between new and old value.
    Encoder myEnc(6, 5);
      if (oldPosition != newPosition)
        // Serial.println(newPosition);
        int fourStep;
        fourStep = (newPosition - oldPosition) % 4;
        if (fourStep == 0 && newPosition - oldPosition >= 0)
          usbMIDI.sendControlChange(40, 63, 1);
        else if (fourStep == 0 && newPosition - oldPosition <= 0)
          usbMIDI.sendControlChange(40, 65, 1);
      // delay(1);
    thanks and excuse me for this misstake.
    Apr 2015
    Netherlands
    821
    Your code above did not work for me. I had to add delay(10) to the loop.
    But your code can be simpler. Just divide the myEnc.read() by 4. And then check for the difference being positive or negative.
      long newPosition = (myEnc.read() / 4);
        if (newPosition - oldPosition > 0) {
        else if (newPosition - oldPosition < 0) {
      delay(10);
    The program is now much more responsive to a 1 detent rotation.
    Paul
    Jun 2022
    16
    Thanks, you are right it is much more simple and efficient why I don't think to that
