Hi together, I'm trying to get this running...
I have a Teensy 3.6 (4.0/4.1 was not in stock...) with the audio shield.
I downloaded DD4WH´s code and tried to compile as said in the documentation, but I still get this error message:
Code:In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/Audio.h:129:0, from C:\Users\Admin\Documents\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:32: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/play_serialflash_raw.h:33:25: fatal error: SerialFlash.h: No such file or directory compilation terminated. Fehler beim Kompilieren für das Board Teensy 3.6.
How can I Solve this? I installed everything like it's in the documentation.
I badly need help. I followed all the steps and connected everything. Copy pasted the code (removed Teensy 4.1 part as I am using 4.0), compiled successfully, then nothing. Not even a beep.
Checked the serial monitor and it says "Unable to access the SD card" repeatedly. I understand that this is a printed message to check if there is an SD card. I don't know why it is stuck in this loop.
To check my SD Card, i ran File > Examples > MTP_Teensy > Simplified Examples. My SD card got detected but 0 gb. Not sure if this is purely an SD card problem but at least I should hear a beep, correct?
I have the same problem. Wiring and Pin Settings are correct. Any idea how to fix this? Teensy 4.0 with rev d Audio shield
I was the same problem.
I find the missing data in this website. https://github.com/PaulStoffregen/
All is good after.
Same problem too.
I use teensy 4.0 with audio shield REV D2. I changed too mi SD PIN to 10, 11,13 but the it's the same.
I have this line when I compile. I don't know what is it.
/Users/Jeff/Documents/Teensyduino/libraries/MTP_Teensy-main/src/MTP_Teensy.cpp: In member function 'uint32_t MTP_class::GetObjectInfo(MTP_class::MTPContainer&)':
/Users/Jeff/Documents/Teensyduino/libraries/MTP_Teensy-main/src/MTP_Teensy.cpp:523:34: warning: unknown option after '#pragma GCC diagnostic' kind [-Wpragmas]
#pragma GCC diagnostic ignored "-Wformat-truncation" /* Or "-Wformat-truncation" */
That sample is incredibly quiet, so I'm not surprised the noise level is high. From your third image it looks as if you have the mic ground (black wire) connected to the mic input of the audio card ... though of course, as you don't show the other end, that could be wired backwards too, which would cancel the problem out.
As it's so cheap, it seems a reasonable chance to take to try a different microphone. If it works, do report back.
This isn't very surprising ... if you record a quiet signal with a lot of noise, turning the volume up will just turn the noise up along with the signal. You need to get a better signal into the WAV file.If i increase the volume, the background noise seems to be louder as well.
It's not quite as simple as that, unfortunately. Here's a selection of the MTP enable / disable code, as found in the original repository:So, I think the MTP during records is the source of my problem.
I am newby in code. I woulds like to keep the code of DD4WH because I can record greeting wav directly to the phone, but I would like add MTP disable during record.
Do you know how I will do?
If I add this line "MTP.storage()->set_DeltaDeviceCheckTimeMS((uint32_t) -1);" is enough or it's more difficult.
uint32_t MTPcheckInterval; // default value of device check interval [ms]
// mandatory to begin the MTP session.
MTP.begin();
// Add SD Card
MTP.addFilesystem(SD, "Kais Audio guestbook"); // choose a nice name for the SD card volume to appear in your file explorer
Serial.println("Added SD card via MTP");
MTPcheckInterval = MTP.storage()->get_DeltaDeviceCheckTimeMS();
void setMTPdeviceChecks(bool nable)
if (nable)
MTP.storage()->set_DeltaDeviceCheckTimeMS(MTPcheckInterval);
Serial.print("En");
Serial.print("Dis");
Serial.println("abled MTP storage device checks");
void startRecording() {
setMTPdeviceChecks(false); // disable MTP device checks while recording
void stopRecording() {
setMTPdeviceChecks(true); // enable MTP device checks, recording is finished
Hmm, I cannot reproduce a problem in playing the WAV files recorded with my code, they play correctly and smoothly with different players on different devices.Unrelated to the MTP issue, but worth noting, is that DD4WH's generation of the WAV chunks is incorrect, which is also fixed in the original repository - look at the calculations of the Subchunk2Size and ChunkSize values. Not every application shows a visible error, but it could be that some will appear to play the files but actually emit no audio. Groove Music and Windows Media Player play without complaining, but GoldWave gives two warnings before it'll load such a file.
You may be right that the chunk lengths are inconsistent (I am not a specialist in WAV headers), but the files are playing and sound nicely . . .
As you claim in various threads that there are issues with the code in my repo (which I cannot reproduce, because I built four Audio Guest Books with my code which function flawlessly and I have provided a very detailed Manual how to build the hardware and software !), I will now delete my repo in order for all those people interested in the Audio guest Book to have ONE consistent code source. I am sorry that my code and my manual in the Readme produced problems, but without reproducible issue descriptions, there is no way for me to offer any help. And just claiming that "it could be that some will [...] actually emit no audio" without reproducible facts is just blind guessing/fantasy . . . but from now on it will be easier, no more problems to choose between different code sources.
Have fun with the Teensy !
Update: as noted on another thread, there's already a call to sgtl5000_1.micGain(); in the code, which typically sets the gain very low (somewhere between +5 and +15dB, depending on which repo you start from). This is very low, so more level can be achieved for sure - the default is +52dB, and you can set between 0 and +63. However, depending on your hardware quality, and in particular the shielding of the mic cable, you may just get a louder and very noisy WAV file. But at least it won't be an apparently flatline piece of audio that you can't hear at all...This isn't very surprising ... if you record a quiet signal with a lot of noise, turning the volume up will just turn the noise up along with the signal. You need to get a better signal into the WAV file.
I just looked at the audio library code, and the mic gain defaults to +52dB. It is possible to increase this to +63db, if you put in a line sgtl5000_1.micGain(63); - this must be after sgtl5000_1.inputSelect(AUDIO_INPUT_MIC);. It will at least make your WAV file louder, though it may be just as noisy - from your images, the mic wires are neither twisted together nor shielded. You could try removing the capsule from the phone and connecting it directly to the audio adaptor with very short wires, which would probably reduce noise though it won't boost the signal.
Key points to note:Code:uint32_t MTPcheckInterval; // default value of device check interval [ms] ... void setup() { ... // mandatory to begin the MTP session. MTP.begin(); // Add SD Card MTP.addFilesystem(SD, "Kais Audio guestbook"); // choose a nice name for the SD card volume to appear in your file explorer Serial.println("Added SD card via MTP"); MTPcheckInterval = MTP.storage()->get_DeltaDeviceCheckTimeMS(); ... } ... void setMTPdeviceChecks(bool nable) { if (nable) { MTP.storage()->set_DeltaDeviceCheckTimeMS(MTPcheckInterval); Serial.print("En"); } else { MTP.storage()->set_DeltaDeviceCheckTimeMS((uint32_t) -1); Serial.print("Dis"); } Serial.println("abled MTP storage device checks"); } ... void startRecording() { setMTPdeviceChecks(false); // disable MTP device checks while recording ... } ... void stopRecording() { ... setMTPdeviceChecks(true); // enable MTP device checks, recording is finished }
I can't be 100% sure that's complete, but it's the main idea. Take a look at the changes made in PR#20 if anything doesn't work.
- create storage for the MTP check interval
- in setup(), find the default value for the MTP check interval
- before recording starts, disable MTP checks (set interval to -1)
- after recording finishes, restore checks by setting interval back to the default
In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src/MTP_Storage.h:35,
from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src/MTP_Teensy.h:45,
from C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:30:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:37: warning: "FILE_READ" redefined
37 | #define FILE_READ 0
In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/play_sd_raw.h:32,
from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio/Audio.h:127,
from C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:25:
C:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:23: note: this is the location of the previous definition
23 | #define FILE_READ O_READ
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:38: warning: "FILE_WRITE" redefined
38 | #define FILE_WRITE 1
C:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:24: note: this is the location of the previous definition
24 | #define FILE_WRITE (O_READ | O_WRITE | O_CREAT | O_APPEND)
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:75:17: error: reference to 'File' is ambiguous
75 | virtual File openNextFile(uint8_t mode=0) = 0;
C:\Program Files (x86)\Arduino\libraries\SD\src/SD.h:28:9: note: candidates are: 'class SDLib::File'
28 | class File : public Stream {
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:47:7: note: 'class File'
47 | class File;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h: In member function 'File File::openNextFile(uint8_t)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:216:33: error: 'class FileImpl' has no member named 'openNextFile'
216 | return (f) ? f->openNextFile(mode) : *this;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h: At global scope:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:276:17: error: reference to 'File' is ambiguous
276 | virtual File open(const char *filename, uint8_t mode = FILE_READ) = 0;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:101:7: note: 'class File'
101 | class File final : public Stream {
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/FS.h:290:9: error: reference to 'File' is ambiguous
290 | File open(const String &filepath, uint8_t mode = FILE_READ) {
In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src/MTP_Teensy.h:45,
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src/MTP_Storage.h:178:9: error: reference to 'File' is ambiguous
178 | File open(uint32_t store, const char *filename, uint32_t mode) {
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src/MTP_Storage.h:287:9: error: reference to 'File' is ambiguous
287 | File index_;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src/MTP_Storage.h:288:9: error: reference to 'File' is ambiguous
288 | File file_;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src/MTP_Storage.h:289:9: error: reference to 'File' is ambiguous
289 | File child_;
In file included from C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:30:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src/MTP_Teensy.h: In member function 'uint32_t MTP_class::addFilesystem(SDLib::SDClass&, const char*)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src/MTP_Teensy.h:78:25: error: no matching function for call to 'MTP_class::addFilesystem(SDLib::SDClass&, const char*&, mtp_fstype_t)'
78 | return addFilesystem(disk, diskname, MTP_FSTYPE_SD);
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src/MTP_Teensy.h:76:12: note: candidate: 'uint32_t MTP_class::addFilesystem(SDLib::SDClass&, const char*)'
76 | uint32_t addFilesystem(SDClass &disk, const char *diskname) {
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src/MTP_Teensy.h:76:12: note: candidate expects 2 arguments, 3 provided
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src/MTP_Teensy.h:82:12: note: candidate: 'uint32_t MTP_class::addFilesystem(FS&, const char*, mtp_fstype_t)'
82 | uint32_t addFilesystem(FS &disk, const char *diskname, mtp_fstype_t fstype = MTP_FSTYPE_UNKNOWN);
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src/MTP_Teensy.h:82:30: note: no known conversion for argument 1 from 'SDLib::SDClass' to 'FS&'
In file included from C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:31:
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\play_sd_wav.h: At global scope:
play_sd_wav.h:49: error: reference to 'File' is ambiguous
49 | File wavfile;
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:63:1: error: reference to 'File' is ambiguous
63 | File frec;
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void setup()':
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:158:3: error: 'FsDateTime' has not been declared
158 | FsDateTime::setCallback(dateTime);
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void startRecording()':
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:277:3: error: 'frec' was not declared in this scope; did you mean 'free'?
277 | frec = SD.open(filename, FILE_WRITE);
| free
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void continueRecording()':
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:309:5: error: 'frec' was not declared in this scope; did you mean 'free'?
309 | frec.write(buffer, sizeof buffer);
| free
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void stopRecording()':
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:333:5: error: 'frec' was not declared in this scope; did you mean 'free'?
333 | frec.write((byte*)queue1.readBuffer(), AUDIO_BLOCK_SAMPLES*sizeof(int16_t));
| free
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:339:3: error: 'frec' was not declared in this scope; did you mean 'free'?
339 | frec.close();
| free
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void playAllRecordings()':
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:348:3: error: reference to 'File' is ambiguous
348 | File dir = SD.open("/");
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:351:5: error: reference to 'File' is ambiguous
351 | File entry = dir.openNextFile();
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:352:16: error: 'entry' was not declared in this scope
352 | if (strstr(entry.name(), "greeting"))
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:354:17: error: 'dir' was not declared in this scope; did you mean 'div'?
354 | entry = dir.openNextFile();
| div
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:356:10: error: 'entry' was not declared in this scope
356 | if (!entry) {
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:366:16: error: 'entry' was not declared in this scope
366 | if (strstr(entry.name(), ".wav") || strstr(entry.name(), ".WAV")) {
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:377:5: error: 'entry' was not declared in this scope
377 | entry.close();
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void dateTime(uint16_t*, uint16_t*, uint8_t*)':
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:439:11: error: 'FS_DATE' was not declared in this scope; did you mean 'LS_DATE'?
439 | *date = FS_DATE(year(), month(), day());
| LS_DATE
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:442:11: error: 'FS_TIME' was not declared in this scope; did you mean 'FAT_TIME'?
442 | *time = FS_TIME(hour(), minute(), second());
| FAT_TIME
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void writeOutHeader()':
C:\Users\cassi\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:470:3: error: 'frec' was not declared in this scope; did you mean 'free'?
470 | frec.seek(0);
| free
* Audio Guestbook, Copyright (c) 2022 Playful Technology
* Tested using a Teensy 4.0 with Teensy Audio Shield, although should work
* with minor modifications on other similar hardware
* When handset is lifted, a pre-recorded greeting message is played, followed by a tone.
* Then, recording starts, and continues until the handset is replaced.
* Playback button allows all messages currently saved on SD card through earpiece
* Files are saved on SD card as 44.1kHz, 16-bit, mono signed integer RAW audio format
* --> changed this to WAV recording, DD4WH 2022_07_31
* --> added MTP support, which enables copying WAV files from the SD card via the USB connection, DD4WH 2022_08_01
* Frank DD4WH, August 1st 2022
* for a DBP 611 telephone (closed contact when handheld is lifted) & with recording to WAV file
* contact for switch button 0 is closed when handheld is lifted
* GNU GPL v3.0 license
#include <Bounce.h>
#include <TimeLib.h>
#include <MTP_Teensy.h>
#include "play_sd_wav.h" // local copy with fixes
// DEFINES
// Define pins used by Teensy Audio Shield
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
// And those used for inputs
#define HOOK_PIN 0
#define PLAYBACK_BUTTON_PIN 1
#define noINSTRUMENT_SD_WRITE
// GLOBALS
// Audio initialisation code can be generated using the GUI interface at https://www.pjrc.com/teensy/gui/
// Inputs
AudioSynthWaveform waveform1; // To create the "beep" sfx
AudioInputI2S i2s2; // I2S input from microphone on audio shield
AudioPlaySdWavX playWav1; // Play 44.1kHz 16-bit PCM greeting WAV file
AudioRecordQueue queue1; // Creating an audio buffer in memory before saving to SD
AudioMixer4 mixer; // Allows merging several inputs to same output
AudioOutputI2S i2s1; // I2S interface to Speaker/Line Out on Audio shield
AudioConnection patchCord1(waveform1, 0, mixer, 0); // wave to mixer
AudioConnection patchCord3(playWav1, 0, mixer, 1); // wav file playback mixer
AudioConnection patchCord4(mixer, 0, i2s1, 0); // mixer output to speaker (L)
AudioConnection patchCord6(mixer, 0, i2s1, 1); // mixer output to speaker (R)
AudioConnection patchCord5(i2s2, 0, queue1, 0); // mic input to queue (L)
// Filename to save audio recording on SD card
char filename[15];
// The file object itself
File frec;
// Use long 40ms debounce time on both switches
Bounce buttonRecord = Bounce(HOOK_PIN, 40);
Bounce buttonPlay = Bounce(PLAYBACK_BUTTON_PIN, 40);
// Keep track of current state of the device
enum Mode {Initialising, Ready, Prompting, Recording, Playing};
Mode mode = Mode::Initialising;
float beep_volume = 0.04f; // not too loud :-)
// variables for writing to WAV file
unsigned long ChunkSize = 0L;
unsigned long Subchunk1Size = 16;
unsigned int AudioFormat = 1;
unsigned int numChannels = 1;
unsigned long sampleRate = 44100;
unsigned int bitsPerSample = 16;
unsigned long byteRate = sampleRate*numChannels*(bitsPerSample/8);// samplerate x channels x (bitspersample / 8)
unsigned int blockAlign = numChannels*bitsPerSample/8;
unsigned long Subchunk2Size = 0L;
unsigned long recByteSaved = 0L;
unsigned long NumSamples = 0L;
byte byte1, byte2, byte3, byte4;
while (!Serial && millis() < 5000) {
// wait for serial port to connect.
Serial.println("Serial set up correctly");
Serial.printf("Audio block set to %d samples\n",AUDIO_BLOCK_SAMPLES);
print_mode();
// Configure the input pins
pinMode(HOOK_PIN, INPUT_PULLUP);
pinMode(PLAYBACK_BUTTON_PIN, INPUT_PULLUP);
AudioMemory(60);
sgtl5000_1.enable();
// Define which input on the audio shield to use (AUDIO_INPUT_LINEIN / AUDIO_INPUT_MIC)
//sgtl5000_1.adcHighPassFilterDisable(); //
sgtl5000_1.volume(0.95);
mixer.gain(0, 1.0f);
mixer.gain(1, 1.0f);
// Play a beep to indicate system is online
waveform1.begin(beep_volume, 440, WAVEFORM_SINE);
wait(1000);
waveform1.amplitude(0);
// Initialize the SD card
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
if (!(SD.begin(SDCARD_CS_PIN)))
while (1) {
else Serial.println("SD card correctly initialized");
MTP.begin();
// Add SD Card
// MTP.addFilesystem(SD, "SD Card");
// Value in dB
// sgtl5000_1.micGain(15);
sgtl5000_1.micGain(5); // much lower gain is required for the AOM5024 electret capsule
// Synchronise the Time object used in the program code with the RTC time provider.
// See https://github.com/PaulStoffregen/Time
// Define a callback that will assign the correct datetime for any file system operations
// (i.e. saving a new audio recording onto the SD card)
mode = Mode::Ready; print_mode();
// First, read the buttons
buttonRecord.update();
buttonPlay.update();
switch(mode){
case Mode::Ready:
// Falling edge occurs when the handset is lifted --> 611 telephone
if (buttonRecord.fallingEdge()) {
Serial.println("Handset lifted");
mode = Mode::Prompting; print_mode();
else if(buttonPlay.fallingEdge()) {
//playAllRecordings();
playLastRecording();
case Mode::Prompting:
// Wait a second for users to put the handset to their ear
wait(1000);
// Play the greeting inviting them to record their message
playWav1.play("greeting.wav");
// Wait until the message has finished playing
// while (playWav1.isPlaying()) {
while (!playWav1.isStopped()) {
// Check whether the handset is replaced
// Handset is replaced
if(buttonRecord.risingEdge()) {
playWav1.stop();
return;
playWav1.stop();
return;
// Debug message
Serial.println("Starting Recording");
// Play the tone sound effect
wait(1250);
// Start the recording function
startRecording();
case Mode::Recording:
if(buttonRecord.risingEdge()){
// Debug log
Serial.println("Stopping Recording");
// Stop recording
stopRecording();
// Play audio tone to confirm recording has ended
end_Beep();
else {
continueRecording();
case Mode::Playing: // to make compiler happy
case Mode::Initialising: // to make compiler happy
MTP.loop(); // This is mandatory to be placed in the loop code.
if (nable)
Serial.print("En");
#if defined(INSTRUMENT_SD_WRITE)
static uint32_t worstSDwrite, printNext;
#endif // defined(INSTRUMENT_SD_WRITE)
worstSDwrite = 0;
printNext = 0;
// Find the first available file number
// for (uint8_t i=0; i<9999; i++) { // BUGFIX uint8_t overflows if it reaches 255
for (uint16_t i=0; i<9999; i++) {
// Format the counter as a five-digit number with leading zeroes, followed by file extension
snprintf(filename, 11, " %05d.wav", i);
// Create if does not exist, do not open existing, write, sync after write
if (!SD.exists(filename)) {
Serial.println("Opened file !");
if(frec) {
Serial.print("Recording to ");
Serial.println(filename);
queue1.begin();
mode = Mode::Recording; print_mode();
recByteSaved = 0L;
else {
Serial.println("Couldn't open file to record!");
void continueRecording() {
uint32_t started = micros();
#define NBLOX 16
// Check if there is data in the queue
if (queue1.available() >= NBLOX) {
byte buffer[NBLOX*AUDIO_BLOCK_SAMPLES*sizeof(int16_t)];
// into a 512 byte buffer. The Arduino SD library
// writes are used.
for (int i=0;i<NBLOX;i++)
memcpy(buffer+i*AUDIO_BLOCK_SAMPLES*sizeof(int16_t), queue1.readBuffer(), AUDIO_BLOCK_SAMPLES*sizeof(int16_t));
queue1.freeBuffer();
// Write all 512 bytes to the SD card
recByteSaved += sizeof buffer;
started = micros() - started;
if (started > worstSDwrite)
worstSDwrite = started;
if (millis() >= printNext)
Serial.printf("Worst write took %luus\n",worstSDwrite);
worstSDwrite = 0;
printNext = millis()+250;
// Stop adding any new data to the queue
queue1.end();
// Flush all existing remaining data from the queue
// Save to open file
recByteSaved += AUDIO_BLOCK_SAMPLES*sizeof(int16_t);
writeOutHeader();
// Close the file
frec.close();
Serial.println("Closed file");
void playAllRecordings() {
// Recording files are saved in the root directory
while (true) {
if (!entry) {
// no more files
entry.close();
end_Beep();
//int8_t len = strlen(entry.name()) - 4;
// if (strstr(strlwr(entry.name() + (len - 4)), ".raw")) {
// if (strstr(strlwr(entry.name() + (len - 4)), ".wav")) {
// the lines above throw a warning, so I replace them with this (which is also easier to read):
Serial.print("Now playing ");
Serial.println(entry.name());
// Play a short beep before each message
waveform1.amplitude(beep_volume);
wait(750);
// Play the file
playWav1.play(entry.name());
mode = Mode::Playing; print_mode();
entry.close();
// while (playWav1.isPlaying()) { // strangely enough, this works for playRaw, but it does not work properly for playWav
while (!playWav1.isStopped()) { // this works for playWav
// Button is pressed again
// if(buttonPlay.risingEdge() || buttonRecord.risingEdge()) { // FIX
if(buttonPlay.fallingEdge() || buttonRecord.risingEdge()) {
playWav1.stop();
return;
// All files have been played
void playLastRecording() {
uint16_t idx = 0;
// check, if file with index i exists
idx = i - 1;
// now play file with index idx == last recorded file
snprintf(filename, 11, " %05d.wav", idx);
playWav1.play(filename);
playWav1.stop();
return;
// file has been played
end_Beep();
// Retrieve the current time from Teensy built-in RTC
time_t getTeensy3Time(){
return Teensy3Clock.get();
// Callback to assign timestamps for file system operations
void dateTime(uint16_t* date, uint16_t* time, uint8_t* ms10) {
// Return date using FS_DATE macro to format fields.
// Return time using FS_TIME macro to format fields.
// Return low time bits in units of 10 ms.
*ms10 = second() & 1 ? 100 : 0;
// Non-blocking delay, which pauses execution of main program logic,
// but while still listening for input
void wait(unsigned int milliseconds) {
elapsedMillis msec=0;
while (msec <= milliseconds) {
if (buttonRecord.fallingEdge()) Serial.println("Button (pin 0) Press");
if (buttonPlay.fallingEdge()) Serial.println("Button (pin 1) Press");
if (buttonRecord.risingEdge()) Serial.println("Button (pin 0) Release");
if (buttonPlay.risingEdge()) Serial.println("Button (pin 1) Release");
void writeOutHeader() { // update WAV header with final filesize/datasize
// NumSamples = (recByteSaved*8)/bitsPerSample/numChannels;
// Subchunk2Size = NumSamples*numChannels*bitsPerSample/8; // number of samples x number of channels x number of bytes per sample
Subchunk2Size = recByteSaved - 42; // because we didn't make space for the header to start with! Lose 21 samples...
ChunkSize = Subchunk2Size + 34; // was 36;
frec.seek(0);
frec.write("RIFF");
byte1 = ChunkSize & 0xff;
byte2 = (ChunkSize >> 8) & 0xff;
byte3 = (ChunkSize >> 16) & 0xff;
byte4 = (ChunkSize >> 24) & 0xff;
frec.write(byte1); frec.write(byte2); frec.write(byte3); frec.write(byte4);
frec.write("WAVE");
frec.write("fmt ");
byte1 = Subchunk1Size & 0xff;
byte2 = (Subchunk1Size >> 8) & 0xff;
byte3 = (Subchunk1Size >> 16) & 0xff;
byte4 = (Subchunk1Size >> 24) & 0xff;
byte1 = AudioFormat & 0xff;
byte2 = (AudioFormat >> 8) & 0xff;
byte1 = numChannels & 0xff;
byte2 = (numChannels >> 8) & 0xff;
byte1 = sampleRate & 0xff;
byte2 = (sampleRate >> 8) & 0xff;
byte3 = (sampleRate >> 16) & 0xff;
byte4 = (sampleRate >> 24) & 0xff;
byte1 = byteRate & 0xff;
byte2 = (byteRate >> 8) & 0xff;
byte3 = (byteRate >> 16) & 0xff;
byte4 = (byteRate >> 24) & 0xff;
byte1 = blockAlign & 0xff;
byte2 = (blockAlign >> 8) & 0xff;
byte1 = bitsPerSample & 0xff;
byte2 = (bitsPerSample >> 8) & 0xff;
frec.write("data");
byte1 = Subchunk2Size & 0xff;
byte2 = (Subchunk2Size >> 8) & 0xff;
byte3 = (Subchunk2Size >> 16) & 0xff;
byte4 = (Subchunk2Size >> 24) & 0xff;
frec.close();
Serial.println("header written");
Serial.print("Subchunk2: ");
Serial.println(Subchunk2Size);
void end_Beep(void) {
waveform1.frequency(523.25);
wait(250);
wait(250);
wait(250);
wait(250);
wait(250);
wait(250);
wait(250);
void print_mode(void) { // only for debugging
Serial.print("Mode switched to: ");
// Initialising, Ready, Prompting, Recording, Playing
if(mode == Mode::Ready) Serial.println(" Ready");
else if(mode == Mode::Prompting) Serial.println(" Prompting");
else if(mode == Mode::Recording) Serial.println(" Recording");
else if(mode == Mode::Playing) Serial.println(" Playing");
else if(mode == Mode::Initialising) Serial.println(" Initialising");
else Serial.println(" Undefined");
