Page 9 of 12 FirstFirst ... 7 8 9 10 11 ... LastLast
Results 201 to 225 of 294
Thread: Teensy 4.0 - based Audio Guestbook
  1. #201
    Dec 2022
    5
    Just downloaded the newest version of both tools.
  2. #202
    Dec 2022
    5
    Anyone an idea?
  3. #203
    Dec 2022
    5
    No one here who can help?
  4. #204
    Senior Member BriComp's Avatar
    Cheltenham, UK
    1,146
    Just downloaded Audio Guestbook, set USB Type to Serial + MTP Disk (Experimental), set cpu to Teensy 3.6 and compiled just fine using TeensyDuino 1.58b3.
    Note that you will have to alter the program to work with Teensy 3.6 as noted at the head of the program.
  5. #205
    Jan 2023
    1
    I have no coding experience, but I'm stumbling along. I need some help. I'm getting these error comments when I try compiling the audio guestbook sketch:
    Arduino: 1.8.19 (Windows 10), TD: 1.57, Board: "Teensy 4.0, Serial + MTP Disk (Experimental), 600 MHz, Faster, US English"
    C:\Users\thebe\AppData\Local\Temp\Temp3_audio-guestbook-main.zip\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:49:1: error: 'AudioPlaySdWavX' does not name a type
    AudioPlaySdWavX playWav1; // Play 44.1kHz 16-bit PCM greeting WAV file
    C:\Users\thebe\AppData\Local\Temp\Temp3_audio-guestbook-main.zip\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:54:28: error: 'playWav1' was not declared in this scope
    AudioConnection patchCord3(playWav1, 0, mixer, 1); // wav file playback mixer
    C:\Users\thebe\AppData\Local\Temp\Temp3_audio-guestbook-main.zip\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void loop()':
    C:\Users\thebe\AppData\Local\Temp\Temp3_audio-guestbook-main.zip\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:185:7: error: 'playWav1' was not declared in this scope
    playWav1.play("greeting.wav");
    C:\Users\thebe\AppData\Local\Temp\Temp3_audio-guestbook-main.zip\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void playAllRecordings()':
    C:\Users\thebe\AppData\Local\Temp\Temp3_audio-guestbook-main.zip\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:374:7: error: 'playWav1' was not declared in this scope
    playWav1.play(entry.name());
    C:\Users\thebe\AppData\Local\Temp\Temp3_audio-guestbook-main.zip\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:380:13: error: 'playWav1' was not declared in this scope
    while (!playWav1.isStopped()) { // this works for playWav
    C:\Users\thebe\AppData\Local\Temp\Temp3_audio-guestbook-main.zip\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void playLastRecording()':
    C:\Users\thebe\AppData\Local\Temp\Temp3_audio-guestbook-main.zip\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:411:7: error: 'playWav1' was not declared in this scope
    playWav1.play(filename);
    Can anyone help guide me through this?
  6. #206
    Senior Member h4yn0nnym0u5e's Avatar
    Apr 2021
    Cambridgeshire, UK
    634
    Quote Originally Posted by lilredmom View Post
    Wow ... not quite sure how you managed this! The emboldened text suggests you've somehow managed to persuade the Arduino IDE to try to compile a sketch directly from the .ZIP you downloaded - I can't do that, though I did try briefly.
    You should unzip the code into a sub-folder in your default sketches folder; it will need to end up looking roughly like this:
Name:	2023-01-11 21_04_42-C__Users_Jonathan_Documents_Arduino_audio-guestbook.png
    Now you need to follow the "Installation method" from the readme.md really carefully, and check that you have an option on the Tools menu called "Audio tweaks". When the sketch is loaded ready to compile, the IDE should look like this:
Name:	2023-01-11 21_11_13-audio-guestbook _ Arduino 1.8.19.png
    Note the two extra files along with the sketch - if these aren't there, then you get the error: 'AudioPlaySdWavX' does not name a type diagnostic. All the other errors you see are a direct result of this, so you can ignore them.
    Assuming it now compiles and uploads, check the serial output that tells you the "Audio tweaks" have worked (again, documented in the readme).
    EDIT: this is really not a great application for someone with "no coding experience, but I'm stumbling along" to be tackling! Too much of it is on the ragged edge of just about working...
  7. #207
    Jan 2023
    5
    Hi there!
    I'm new to all this as many of the new members here, I like the concept of the phone and I hope this is the kickstart to get me into arduino which is something I've been wanting to do for some time.
    I downloaded and installed all the latest versions of the required software, uploaded the code to a 32gb sd card, placed on the sd card reader of the teensy 4.1.
    Managed to find the switch poles of my phone, I have all the wires ready and I can switch them to try different connections, because all I;m doing is trial and error here.
    I have my greeting.wav in the root of the SD card, but I pick up the tube and I hear nothing, move switch the wires to see if anything changes and still nothing.
    My serial monitor displays this :
    Serial set up correctly
    Mode switched to: Initialising
    Button (pin 0) Release
    Button (pin 1) Release
    SD card correctly initialized
    Add **SDClass** file system
    Added SD card via MTP
    Mode switched to: Ready
    &&&&& Dump MTPStorage Loop Data &&&&&
    Callback Data: 0 0x0 0
    1 0xd059 1
    2 0x0 0
    3 0x0 0
    4 0x0 0
    File Systems:
    0 0x200039c8 1
    I was trying to be a smart a*s thinking I know everything, and I bought a phone already made from a guy in Canada. My idea was to have a working unit and reverse engineer it, but this guy says he cannot provide me with the code, and I've been doing some research and is not as easy as I thought it would be to download the code from that teensy so I can copy to mine.
    The phone he sent me is a chinese replica, pure plastic, I bought a nice baquelite vintage phone I want to modify, but I'm hitting a wall here.
  8. #208
    Cheltenham, UK
    1,146
    Any code for the Teensy has to be programmed into the Teensy. You can not just place it onto an SD card.
    I suggest you read this about getting started with Arduino.
    Think of the Teensy as a supercharged Arduino.
    The Arduino is a Model T, the Teensy is a Ferrari.
    They are both cars which do a similar thing but the Ferrari is faster and more complex.
  9. #209
    Jan 2023
    5
    Quote Originally Posted by BriComp View Post
    Hi there!
    I uploaded the code to the board obviously, my libraries are all there, software has the latest updates, those basics I got them covered
  10. #210
    Jan 2023
    5
    well, I finally made it !!!
    Changed a couple of things in the code that I completely missed and now I see action the serial monitor and see the wav files in the card.
    I can't hear anything so far, neither the greeting or the recorded message, but I guess that should be an easy fix compared to the code errors, at least in your first phone.
    Not sure if my old phone was working properly and have no idea how to test parts. The speaker made a lot of noises at some point, but not sure how to test it if it's able to reproduce any sounds.
    Same thing with the mic, not sure how to test besides the most logical (to me) cutting a mic's cable and attach it to the corresponding terminals, but not sure if it's that straight forward or not.
    In case I decide to change speaker and mic, not having access to an electronic store and very limited variety of parts online for fast an easy shippng based on where I live, what would you do? Buy another, newer phone and get some donor parts?
  11. #211
    Nov 2022
    5
    Can someone help me ?... The welcome message is perfect but the recorded messages sound very very reduced on the sd card and when playing them directly from the play button.
    Thank You.
  12. #212
    Nov 2022
    5
    Does anyone have any ideas please ????
  13. #213
    pm sent to you
  14. #214
    Feb 2023
    4
    I installed fresh everything from the original repo. After applying the audio tweak, my recordings sound choppy. I tried several high speed SD cards, all with the same error.
    If in continueRecording() function decreases the NBLOX value from 16, it gets faster, if I increase it gets slower. I can't make it stop. Does anyone have any tips?
    void continueRecording() {
    #if defined(INSTRUMENT_SD_WRITE)
      uint32_t started = micros();
    #endif // defined(INSTRUMENT_SD_WRITE)
    #define NBLOX 16
      // Check if there is data in the queue
      if (queue1.available() >= NBLOX) {
        byte buffer[NBLOX*AUDIO_BLOCK_SAMPLES*sizeof(int16_t)];
        // into a 512 byte buffer.  The Arduino SD library
        // writes are used.
        for (int i=0;i<NBLOX;i++)
          memcpy(buffer+i*AUDIO_BLOCK_SAMPLES*sizeof(int16_t), queue1.readBuffer(), AUDIO_BLOCK_SAMPLES*sizeof(int16_t));
          queue1.freeBuffer();
        // Write all 512 bytes to the SD card
        frec.write(buffer, sizeof buffer);
        recByteSaved += sizeof buffer;
      started = micros() - started;
      if (started > worstSDwrite)
        worstSDwrite = started;
      if (millis() >= printNext)
        Serial.printf("Worst write took %luus\n",worstSDwrite);
        worstSDwrite = 0;
        printNext = millis()+250;
    I use Teensy 4.0
  15. #215
    what card you using a a1 or a2 type card
  16. #216
    Feb 2023
    4
    a1 Sandisk extreme 32GB
    thank you!
  17. #217
    Quote Originally Posted by mtom View Post
    thank you!
    pm sent to you
  18. #218
    what i am using
     * Audio Guestbook, Copyright (c) 2022 Playful Technology
     * Tested using a Teensy 4.0 with Teensy Audio Shield, although should work
     * with minor modifications on other similar hardware
     * When handset is lifted, a pre-recorded greeting message is played, followed by a tone.
     * Then, recording starts, and continues until the handset is replaced.
     * Playback button allows all messages currently saved on SD card through earpiece
     * Files are saved on SD card as 44.1kHz, 16-bit, mono signed integer RAW audio format
     * --> changed this to WAV recording, DD4WH 2022_07_31
     * --> added MTP support, which enables copying WAV files from the SD card via the USB connection, DD4WH 2022_08_01
     * Frank DD4WH, August 1st 2022
     * for a DBP 611 telephone (closed contact when handheld is lifted) & with recording to WAV file
     * contact for switch button 0 is closed when handheld is lifted
     * GNU GPL v3.0 license
    #include <Bounce.h>
    #include <TimeLib.h>
    #include <MTP_Teensy.h>
    #include "play_sd_wav.h" // local copy with fixes
    // DEFINES
    // Define pins used by Teensy Audio Shield
    #define SDCARD_CS_PIN    10
    #define SDCARD_MOSI_PIN  7
    #define SDCARD_SCK_PIN   14
    // And those used for inputs
    #define HOOK_PIN 0
    #define PLAYBACK_BUTTON_PIN 1
    #define noINSTRUMENT_SD_WRITE
    // GLOBALS
    // Audio initialisation code can be generated using the GUI interface at https://www.pjrc.com/teensy/gui/
    // Inputs
    AudioSynthWaveform          waveform1; // To create the "beep" sfx
    AudioInputI2S               i2s2; // I2S input from microphone on audio shield
    AudioRecordQueue            queue1; // Creating an audio buffer in memory before saving to SD
    AudioMixer4                 mixer; // Allows merging several inputs to same output
    AudioOutputI2S              i2s1; // I2S interface to Speaker/Line Out on Audio shield
    AudioConnection patchCord1(waveform1, 0, mixer, 0); // wave to mixer
    AudioConnection patchCord4(mixer, 0, i2s1, 0); // mixer output to speaker (L)
    AudioConnection patchCord6(mixer, 0, i2s1, 1); // mixer output to speaker (R)
    AudioConnection patchCord5(i2s2, 0, queue1, 0); // mic input to queue (L)
    AudioControlSGTL5000      sgtl5000_1;
    // Filename to save audio recording on SD card
    char filename[15];
    // The file object itself
    File frec;
    // Use long 40ms debounce time on both switches
    Bounce buttonRecord = Bounce(HOOK_PIN, 40);
    Bounce buttonPlay = Bounce(PLAYBACK_BUTTON_PIN, 40);
    // Keep track of current state of the device
    enum Mode {Initialising, Ready, Prompting, Recording, Playing};
    Mode mode = Mode::Initialising;
    float beep_volume = 0.04f; // not too loud :-)
    uint32_t MTPcheckInterval; // default value of device check interval [ms]
    // variables for writing to WAV file
    unsigned long ChunkSize = 0L;
    unsigned long Subchunk1Size = 16;
    unsigned int AudioFormat = 1;
    unsigned int numChannels = 1;
    unsigned long sampleRate = 44100;
    unsigned int bitsPerSample = 16;
    unsigned long byteRate = sampleRate*numChannels*(bitsPerSample/8);// samplerate x channels x (bitspersample / 8)
    unsigned int blockAlign = numChannels*bitsPerSample/8;
    unsigned long Subchunk2Size = 0L;
    unsigned long recByteSaved = 0L;
    unsigned long NumSamples = 0L;
    byte byte1, byte2, byte3, byte4;
      while (!Serial && millis() < 5000) {
        // wait for serial port to connect.
      Serial.println("Serial set up correctly");
      Serial.printf("Audio block set to %d samples\n",AUDIO_BLOCK_SAMPLES);
      print_mode();
      // Configure the input pins
      pinMode(HOOK_PIN, INPUT_PULLUP);
      pinMode(PLAYBACK_BUTTON_PIN, INPUT_PULLUP);
      AudioMemory(60);
      sgtl5000_1.enable();
      // Define which input on the audio shield to use (AUDIO_INPUT_LINEIN / AUDIO_INPUT_MIC)
      //sgtl5000_1.adcHighPassFilterDisable(); //
      sgtl5000_1.volume(0.95);
      mixer.gain(0, 1.0f);
      mixer.gain(1, 1.0f);
      // Play a beep to indicate system is online
      waveform1.begin(beep_volume, 440, WAVEFORM_SINE);
      wait(1000);
      waveform1.amplitude(0);
      // Initialize the SD card
      SPI.setMOSI(SDCARD_MOSI_PIN);
      SPI.setSCK(SDCARD_SCK_PIN);
      if (!(SD.begin(SDCARD_CS_PIN)))
        while (1) {
        else Serial.println("SD card correctly initialized");
      // mandatory to begin the MTP session.
        MTP.begin();
      // Add SD Card
    //    MTP.addFilesystem(SD, "SD Card");
        MTP.addFilesystem(SD, "Ian Audio guestbook"); // choose a nice name for the SD card volume to appear in your file explorer
        Serial.println("Added SD card via MTP");
        MTPcheckInterval = MTP.storage()->get_DeltaDeviceCheckTimeMS();
        // Value in dB
    //  sgtl5000_1.micGain(100);
      sgtl5000_1.micGain(35); // much lower gain is required for the AOM5024 electret capsule
      // Synchronise the Time object used in the program code with the RTC time provider.
      // See https://github.com/PaulStoffregen/Time
      // Define a callback that will assign the correct datetime for any file system operations
      // (i.e. saving a new audio recording onto the SD card)
      FsDateTime::setCallback(dateTime);
      mode = Mode::Ready; print_mode();
      // First, read the buttons
      buttonRecord.update();
      buttonPlay.update();
      switch(mode){
        case Mode::Ready:
          // Falling edge occurs when the handset is lifted --> 611 telephone
          if (buttonRecord.fallingEdge()) {
            Serial.println("Handset lifted");
            mode = Mode::Prompting; print_mode();
          else if(buttonPlay.fallingEdge()) {
            //playAllRecordings();
            playLastRecording();
        case Mode::Prompting:
          // Wait a second for users to put the handset to their ear
          wait(1000);
          // Play the greeting inviting them to record their message
          // Wait until the  message has finished playing
    //      while (playWav1.isPlaying()) {
            // Check whether the handset is replaced
            // Handset is replaced
            if(buttonRecord.risingEdge()) {
              playWav1.stop();
              return;
              playWav1.stop();
              return;
          // Debug message
          Serial.println("Starting Recording");
          // Play the tone sound effect
          wait(1250);
          // Start the recording function
          startRecording();
        case Mode::Recording:
          if(buttonRecord.risingEdge()){
            // Debug log
            Serial.println("Stopping Recording");
            // Stop recording
            stopRecording();
            // Play audio tone to confirm recording has ended
            end_Beep();
          else {
            continueRecording();
        case Mode::Playing: // to make compiler happy
        case Mode::Initialising: // to make compiler happy
      MTP.loop();  // This is mandatory to be placed in the loop code.
    void setMTPdeviceChecks(bool nable)
      if (nable)
        MTP.storage()->set_DeltaDeviceCheckTimeMS(MTPcheckInterval);
        Serial.print("En");
        MTP.storage()->set_DeltaDeviceCheckTimeMS((uint32_t) -1);
        Serial.print("Dis");
      Serial.println("abled MTP storage device checks");
    static uint32_t worstSDwrite, printNext;
    void startRecording() {
      setMTPdeviceChecks(false); // disable MTP device checks while recording
      worstSDwrite = 0;
      printNext = 0;
      // Find the first available file number
    //  for (uint8_t i=0; i<9999; i++) { // BUGFIX uint8_t overflows if it reaches 255
      for (uint16_t i=0; i<9999; i++) {
        // Format the counter as a five-digit number with leading zeroes, followed by file extension
        snprintf(filename, 11, " %05d.wav", i);
        // Create if does not exist, do not open existing, write, sync after write
        if (!SD.exists(filename)) {
      frec = SD.open(filename, FILE_WRITE);
      Serial.println("Opened file !");
      if(frec) {
        Serial.print("Recording to ");
        Serial.println(filename);
        queue1.begin();
        mode = Mode::Recording; print_mode();
        recByteSaved = 0L;
      else {
        Serial.println("Couldn't open file to record!");
    #define NBLOX 16
        // writes are used.
        worstSDwrite = 0;
    void stopRecording() {
      // Stop adding any new data to the queue
      queue1.end();
      // Flush all existing remaining data from the queue
        // Save to open file
        frec.write((byte*)queue1.readBuffer(), AUDIO_BLOCK_SAMPLES*sizeof(int16_t));
        recByteSaved += AUDIO_BLOCK_SAMPLES*sizeof(int16_t);
      writeOutHeader();
      // Close the file
      frec.close();
      Serial.println("Closed file");
      setMTPdeviceChecks(true); // enable MTP device checks, recording is finished
    void playAllRecordings() {
      // Recording files are saved in the root directory
      File dir = SD.open("/");
      while (true) {
        File entry =  dir.openNextFile();
        if (strstr(entry.name(), "greeting"))
        if (!entry) {
          // no more files
          entry.close();
          end_Beep();
        //int8_t len = strlen(entry.name()) - 4;
    //    if (strstr(strlwr(entry.name() + (len - 4)), ".raw")) {
    //    if (strstr(strlwr(entry.name() + (len - 4)), ".wav")) {
        // the lines above throw a warning, so I replace them with this (which is also easier to read):
        if (strstr(entry.name(), ".wav") || strstr(entry.name(), ".WAV")) {
          Serial.print("Now playing ");
          Serial.println(entry.name());
          // Play a short beep before each message
          waveform1.amplitude(beep_volume);
          wait(750);
          // Play the file
          mode = Mode::Playing; print_mode();
        entry.close();
    //    while (playWav1.isPlaying()) { // strangely enough, this works for playRaw, but it does not work properly for playWav
          // Button is pressed again
    //      if(buttonPlay.risingEdge() || buttonRecord.risingEdge()) { // FIX
          if(buttonPlay.fallingEdge() || buttonRecord.risingEdge()) {
            playWav1.stop();
            return;
      // All files have been played
    void playLastRecording() {
      uint16_t idx = 0;
        // check, if file with index i exists
         idx = i - 1;
          // now play file with index idx == last recorded file
          snprintf(filename, 11, " %05d.wav", idx);
            playWav1.stop();
            return;
          // file has been played
      end_Beep();
    // Retrieve the current time from Teensy built-in RTC
    time_t getTeensy3Time(){
      return Teensy3Clock.get();
    // Callback to assign timestamps for file system operations
    void dateTime(uint16_t* date, uint16_t* time, uint8_t* ms10) {
      // Return date using FS_DATE macro to format fields.
      *date = FS_DATE(year(), month(), day());
      // Return time using FS_TIME macro to format fields.
      *time = FS_TIME(hour(), minute(), second());
      // Return low time bits in units of 10 ms.
      *ms10 = second() & 1 ? 100 : 0;
    // Non-blocking delay, which pauses execution of main program logic,
    // but while still listening for input
    void wait(unsigned int milliseconds) {
      elapsedMillis msec=0;
      while (msec <= milliseconds) {
        if (buttonRecord.fallingEdge()) Serial.println("Button (pin 0) Press");
        if (buttonPlay.fallingEdge()) Serial.println("Button (pin 1) Press");
        if (buttonRecord.risingEdge()) Serial.println("Button (pin 0) Release");
        if (buttonPlay.risingEdge()) Serial.println("Button (pin 1) Release");
    void writeOutHeader() { // update WAV header with final filesize/datasize
    //  NumSamples = (recByteSaved*8)/bitsPerSample/numChannels;
    //  Subchunk2Size = NumSamples*numChannels*bitsPerSample/8; // number of samples x number of channels x number of bytes per sample
      Subchunk2Size = recByteSaved - 42; // because we didn't make space for the header to start with! Lose 21 samples...
      ChunkSize = Subchunk2Size + 34; // was 36;
      frec.seek(0);
      frec.write("RIFF");
      byte1 = ChunkSize & 0xff;
      byte2 = (ChunkSize >> 8) & 0xff;
      byte3 = (ChunkSize >> 16) & 0xff;
      byte4 = (ChunkSize >> 24) & 0xff;
      frec.write(byte1);  frec.write(byte2);  frec.write(byte3);  frec.write(byte4);
      frec.write("WAVE");
      frec.write("fmt ");
      byte1 = Subchunk1Size & 0xff;
      byte2 = (Subchunk1Size >> 8) & 0xff;
      byte3 = (Subchunk1Size >> 16) & 0xff;
      byte4 = (Subchunk1Size >> 24) & 0xff;
      byte1 = AudioFormat & 0xff;
      byte2 = (AudioFormat >> 8) & 0xff;
      byte1 = numChannels & 0xff;
      byte2 = (numChannels >> 8) & 0xff;
      byte1 = sampleRate & 0xff;
      byte2 = (sampleRate >> 8) & 0xff;
      byte3 = (sampleRate >> 16) & 0xff;
      byte4 = (sampleRate >> 24) & 0xff;
      byte1 = byteRate & 0xff;
      byte2 = (byteRate >> 8) & 0xff;
      byte3 = (byteRate >> 16) & 0xff;
      byte4 = (byteRate >> 24) & 0xff;
      byte1 = blockAlign & 0xff;
      byte2 = (blockAlign >> 8) & 0xff;
      byte1 = bitsPerSample & 0xff;
      byte2 = (bitsPerSample >> 8) & 0xff;
      frec.write("data");
      byte1 = Subchunk2Size & 0xff;
      byte2 = (Subchunk2Size >> 8) & 0xff;
      byte3 = (Subchunk2Size >> 16) & 0xff;
      byte4 = (Subchunk2Size >> 24) & 0xff;
      frec.close();
      Serial.println("header written");
      Serial.print("Subchunk2: ");
      Serial.println(Subchunk2Size);
    void end_Beep(void) {
              waveform1.frequency(523.25);
            wait(250);
            wait(250);
            wait(250);
            wait(250);
            wait(250);
            wait(250);
            wait(250);
    void print_mode(void) { // only for debugging
      Serial.print("Mode switched to: ");
      // Initialising, Ready, Prompting, Recording, Playing
      if(mode == Mode::Ready)           Serial.println(" Ready");
      else if(mode == Mode::Prompting)  Serial.println(" Prompting");
      else if(mode == Mode::Recording)  Serial.println(" Recording");
      else if(mode == Mode::Playing)    Serial.println(" Playing");
      else if(mode == Mode::Initialising)  Serial.println(" Initialising");
      else Serial.println(" Undefined");
  19. #219
    Feb 2023
    4
    clicking noise
    Hi All! I still have a clicking sound, I've tried everything. Anyone have any tips on how to fix it?
    T4.0, A1 SDHC 32gb micros, original repo with "256-sample audio blocks tweak"
    Thank you very much!
    00001.wav.zip
  20. #220
    Feb 2023
    18
    nothing after beep
    Hey Guys, i'm hoping someone can help because i'm losing my mind over here! LOL
    so i finally got everything to compile with the latest code. (Thank you so much to DD4WH for the updated coding). i'm assuming since everything compiled correctly that i have all my libraries and everything in the right spots. My problem is that when i power up, i get the 1 beep, and the nothing. and i'm totally stumped. i've read through this entire thread 3 times already hoping i missed something with an answer but can't find anything.
    i'm using a new phone from amazon in a retro style. i'm assuming since i cant record anything it has something to do with my hook switch, so i temporarily hooked up a momentary switch to act as the hook, but i still get nothing. i originally had the wires soldered to pins ground and 0 on the teensy and now i have the wires soldered to pins ground and zero on the audio shield. not sure there is a difference since they are connected via header pins but i figured i'd try, but still nothing. can anyone help?! i'm at a total loss. =(
    i'm using a t4 with the Rev D audio shield (maybe that's why????) do i have the right components?
  21. #221
    After the 1 long beep try saying something as thats when it records the message if you press the hook switch you would get 4 short beeps if you still got handset to ur ear at momonent i cant get the greeting message to play on mine
  22. #222
    Feb 2023
    18
    Nothing records after the first beep and nothing happens when I hit the hook switch after. I never get any other beeps or anything. I thought the code said 2 short beeps to record initial greeting. I could be wrong though. So I figured it does the 1st beep to "initialize" like ok power on, with the handset down, then pick up, hear the 2 beeps and record greeting.
  23. #223
    look at post 218 thats the code im using cant get greeting message or replay to work at moment but it recording ok
  24. #224
    Feb 2023
    18
    i tried your code but it doesn't compile. i get errors for the playwav1 file.
    Arduino: 1.8.19 (Windows 10), TD: 1.57, Board: "Teensy 4.0, Serial + MTP Disk (Experimental), 150 MHz, Faster, US English, Bigger blocks (256 samples)"
    C:\Users\Tripz\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:49:1: error: 'AudioPlaySdWavX' does not name a type
    C:\Users\Tripz\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:54:28: error: 'playWav1' was not declared in this scope
    C:\Users\Tripz\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void loop()':
    C:\Users\Tripz\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:185:7: error: 'playWav1' was not declared in this scope
    C:\Users\Tripz\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void playAllRecordings()':
    C:\Users\Tripz\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:374:7: error: 'playWav1' was not declared in this scope
    C:\Users\Tripz\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:380:13: error: 'playWav1' was not declared in this scope
    C:\Users\Tripz\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino: In function 'void playLastRecording()':
    C:\Users\Tripz\Downloads\audio-guestbook-main\audio-guestbook-main\audio-guestbook\audio-guestbook.ino:411:7: error: 'playWav1' was not declared in this scope
  25. #225
    one b4 mine
    #include <Bounce.h>
    // DEFINES
    #define HOOK_PIN 0
    // GLOBALS
    // Inputs
    char filename[15];
    File frec;
      print_mode();
      AudioMemory(60);
      wait(1000);
        while (1) {
        MTP.begin();
      // Add SD Card
        // Value in dB
    //  sgtl5000_1.micGain(15);
      sgtl5000_1.micGain(5); // much lower gain is required for the AOM5024 electret capsule
      switch(mode){
        case Mode::Ready:
          wait(1000);
              playWav1.stop();
              return;
              playWav1.stop();
              return;
          // Debug message
          wait(1250);
          startRecording();
            // Debug log
            // Stop recording
            stopRecording();
            end_Beep();
          else {
      if (nable)
        Serial.print("En");
      worstSDwrite = 0;
      printNext = 0;
      if(frec) {
        queue1.begin();
        recByteSaved = 0L;
      else {
    #define NBLOX 16
        // writes are used.
        worstSDwrite = 0;
      queue1.end();
      writeOutHeader();
      // Close the file
      frec.close();
      while (true) {
        if (!entry) {
          // no more files
          entry.close();
          end_Beep();
          wait(750);
          // Play the file
        entry.close();
            playWav1.stop();
            return;
      uint16_t idx = 0;
         idx = i - 1;
            playWav1.stop();
            return;
      end_Beep();
      frec.seek(0);
      frec.write("RIFF");
      frec.write("WAVE");
      frec.write("fmt ");
      frec.write("data");
      frec.close();
            wait(250);
            wait(250);
            wait(250);
            wait(250);
            wait(250);
            wait(250);
            wait(250);
