Quick question . Is this good to power the teensy board ? Or could it burn the board ? https://www.amazon.com/ICV-USB-Wall...lpcontext&ref_=fplfs&psc=1&smid=A4LYBGKZAPPLR
20:13:27.782 (ports 5): Begin, version=1.57, high-res time
20:13:27.782 (ports 5): LoadLibrary cfgmgr32 ok
20:13:27.782 (ports 5): LoadLibrary ntdll ok
20:13:27.786 (ports 5): callback 0024
20:13:27.786 (ports 5): callback 0081
20:13:27.789 (ports 5): callback 0083
20:13:27.789 (ports 5): hWnd = 3475668
20:13:27.792 (ports 5): nothing new, skipping HID & Ports enum
20:14:03.912 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
20:14:03.914 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#0011a9ee#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:14:03.914 (ports 5): found_usb_device, loc=usb:0/140000/0/2 Port_#0002.Hub_#0001
20:14:03.914 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0107
20:14:03.914 (ports 5): found_usb_device, devinst=00000003
20:14:03.914 (ports 5): add: loc=usb:0/140000/0/2, class=HID, vid=16C0, pid=0478, ver=0107, serial=0011a9ee, dev=\\?\usb#vid_16c0&pid_0478#0011a9ee#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:14:03.915 (ports 5): hiddev_from_devinst_list: iface=0
20:14:03.916 (ports 5): found_usb_device complete
20:14:03.918 (ports 5): hid, found devinst=00000007
20:14:03.918 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#6&2bc5e7a5&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
20:14:03.918 (ports 5): hid, opened handle
20:14:03.918 (ports 5): devinst=00000007, location=usb:0/140000/0/2
20:14:03.918 (ports 5): vid=16C0, pid=0478, ver=0107, usepage=FF9C, use=0024
20:14:03.918 (ports 5): devpath=\\?\hid#vid_16c0&pid_0478#6&2bc5e7a5&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
20:14:03.919 (ports 5): usb_add: usb:0/140000/0/2 hid#vid_16c0&pid_0478 (Teensy 4.0) Bootloader
20:14:03.952 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
20:14:03.952 (ports 5): nothing new, skipping HID & Ports enum
20:14:31.461 (post_compile 1): Begin, version=1.57, high-res time
20:14:31.659 (loader): Teensy Loader 1.57, begin program
20:14:31.733 (loader): Listening for remote control on port 3149
20:14:31.733 (loader): initialized, showing main window
20:14:31.767 (loader): remote connection 1268 opened
20:14:31.768 (loader): remote cmd from 1268: "comment: Teensyduino 1.57 - WINDOWS (teensy_post_compile)"
20:14:31.768 (post_compile 1): Sending command: comment: Teensyduino 1.57 - WINDOWS (teensy_post_compile)
20:14:31.769 (loader): remote cmd from 1268: "status"
20:14:31.770 (loader): HID/win32: vid:056A pid:51C5 ver:0002 usb:150001/1
20:14:31.855 (loader): HID/win32: vid:16C0 pid:0478 ver:0107 usb:0/140000/0/2
20:14:31.855 (loader): HID/win32: usage_page:FF9C, usage:0024
20:14:31.856 (loader): secure mode can not be locked: this is Standard Teensy
20:14:31.856 (loader): encryption is possible on this Teensy, but not yet configured
20:14:31.856 (loader): but without secure mode locked, encryption will NOT be secure!
20:14:31.856 (loader): Device came online, code_size = 2031616
20:14:31.857 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.07
20:14:31.858 (loader): set background IMG_ONLINE
20:14:31.862 (post_compile 1): Status: 0, 0, 1, 1, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_577662\, Part_1_02_Hardware_Test.ino.hex
20:14:31.862 (post_compile 1): Sending command: dir:C:\Users\dasau\AppData\Local\Temp\arduino_build_679220\
20:14:31.862 (loader): remote cmd from 1268: "dir:C:\Users\dasau\AppData\Local\Temp\arduino_build_679220\"
20:14:31.862 (loader): remote cmd from 1268: "file:Blink.ino.hex"
20:14:31.862 (post_compile 1): Sending command: file:Blink.ino.hex
20:14:31.869 (loader): File "C:\Users\dasau\AppData\Local\Temp\arduino_build_679220\Blink.ino.hex", 19456 bytes
20:14:31.869 (loader): File "Blink.ino.hex". 19456 bytes, 1% used
20:14:31.920 (loader): remote cmd from 1268: "status"
20:14:31.920 (loader): HID/win32: HidD_GetPreparsedData ok, device still online :-)
20:14:31.921 (post_compile 1): Status: 1, 0, 1, 1, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_679220\, Blink.ino.hex
20:14:31.921 (post_compile 1): Disconnect
20:14:31.932 (loader): remote connection 1268 closed
20:14:32.012 (post_compile 2): Begin, version=1.57, high-res time
20:14:32.013 (loader): remote connection 1268 opened
20:14:32.013 (loader): remote cmd from 1268: "comment: Teensyduino 1.57 - WINDOWS (teensy_post_compile)"
20:14:32.013 (loader): remote cmd from 1268: "status"
20:14:32.014 (post_compile 2): Sending command: comment: Teensyduino 1.57 - WINDOWS (teensy_post_compile)
20:14:32.014 (loader): remote cmd from 1268: "dir:C:\Users\dasau\AppData\Local\Temp\arduino_build_679220\"
20:14:32.014 (loader): remote cmd from 1268: "file:Blink.ino.hex"
20:14:32.015 (post_compile 2): Status: 1, 0, 1, 1, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_679220\, Blink.ino.hex
20:14:32.015 (post_compile 2): Sending command: dir:C:\Users\dasau\AppData\Local\Temp\arduino_build_679220\
20:14:32.015 (post_compile 2): Sending command: file:Blink.ino.hex
20:14:32.021 (loader): File "C:\Users\dasau\AppData\Local\Temp\arduino_build_679220\Blink.ino.hex", 19456 bytes
20:14:32.021 (loader): File "Blink.ino.hex". 19456 bytes, 1% used
20:14:32.068 (loader): remote cmd from 1268: "status"
20:14:32.069 (post_compile 2): Status: 1, 0, 1, 1, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_679220\, Blink.ino.hex
20:14:32.069 (post_compile 2): Disconnect
20:14:32.087 (loader): remote connection 1268 closed
20:14:32.087 (post_compile 3): Running teensy_reboot: "C:\Program Files (x86)\Arduino\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY40" "-port=usb:0/140000/0/2" "-portlabel=hid#vid_16c0&pid_0478 Bootloader" "-portprotocol=Teensy"
20:14:32.088 (loader): remote connection 1268 opened
20:14:32.105 (reboot 4): Begin, version=1.57, high-res time
20:14:32.105 (reboot 4): location = usb:0/140000/0/2
20:14:32.105 (reboot 4): portlabel = hid#vid_16c0&pid_0478 Bootloader
20:14:32.105 (reboot 4): portprotocol = Teensy
20:14:32.105 (reboot 4): Only location usb:0/140000/0/2 will be tried
20:14:32.105 (reboot 4): LoadLibrary cfgmgr32 ok
20:14:32.105 (reboot 4): LoadLibrary ntdll ok
20:14:32.106 (reboot 4): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#0011a9ee#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:14:32.106 (reboot 4): found_usb_device, loc=usb:0/140000/0/2 Port_#0002.Hub_#0001
20:14:32.106 (reboot 4): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0107
20:14:32.106 (reboot 4): found_usb_device, devinst=00000003
20:14:32.106 (reboot 4): add: loc=usb:0/140000/0/2, class=HID, vid=16C0, pid=0478, ver=0107, serial=0011a9ee, dev=\\?\usb#vid_16c0&pid_0478#0011a9ee#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:14:32.106 (reboot 4): hiddev_from_devinst_list: iface=0
20:14:32.108 (reboot 4): found_usb_device complete
20:14:32.108 (reboot 4): hid, found devinst=00000007
20:14:32.109 (reboot 4): usb scan found 1 devices
20:14:32.110 (loader): remote connection 1312 opened
20:14:32.110 (loader): remote cmd from 1312: "show:arduino_attempt_reboot"
20:14:32.110 (loader): got request to show arduino rebooting message
20:14:32.111 (reboot 4): found Teensy Loader, version 1.57
20:14:32.111 (reboot 4): Sending command: show:arduino_attempt_reboot
20:14:32.114 (reboot 4): Sending command: comment: Teensyduino 1.57 - WINDOWS (teensy_reboot)
20:14:32.114 (loader): remote cmd from 1312: "comment: Teensyduino 1.57 - WINDOWS (teensy_reboot)"
20:14:32.114 (loader): remote cmd from 1312: "status"
20:14:32.114 (loader): remote cmd from 1312: "auto:on"
20:14:32.114 (reboot 4): Status: 1, 0, 1, 1, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_679220\, Blink.ino.hex
20:14:32.114 (reboot 4): send: auto:on
20:14:32.114 (reboot 4): Sending command: auto:on
20:14:32.115 (reboot 4): Disconnect
20:14:32.123 (loader): File "C:\Users\dasau\AppData\Local\Temp\arduino_build_679220\Blink.ino.hex", 19456 bytes
20:14:32.123 (loader): File "Blink.ino.hex". 19456 bytes, 1% used
20:14:32.176 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
20:14:32.176 (loader): elf binary data matches hex file
20:14:32.176 (loader): elf file is for Teensy 4.0 (IMXRT1062)
20:14:32.176 (loader): using hex file
20:14:32.227 (loader): begin operation
20:14:32.240 (loader): remote connection 1312 closed
20:14:32.241 (loader): remote connection 1268 closed
20:14:32.247 (loader): flash, block=0, bs=1024, auto=1
20:14:32.248 (loader): flash, block=1, bs=1024, auto=1
20:14:32.248 (loader): flash, block=2, bs=1024, auto=1
20:14:32.570 (loader): flash, block=3, bs=1024, auto=1
20:14:32.570 (loader): flash, block=4, bs=1024, auto=1
20:14:32.574 (loader): flash, block=5, bs=1024, auto=1
20:14:32.575 (loader): flash, block=6, bs=1024, auto=1
20:14:32.577 (loader): flash, block=7, bs=1024, auto=1
20:14:32.579 (loader): flash, block=8, bs=1024, auto=1
20:14:32.579 (loader): flash, block=9, bs=1024, auto=1
20:14:32.581 (loader): flash, block=10, bs=1024, auto=1
20:14:32.582 (loader): flash, block=11, bs=1024, auto=1
20:14:32.584 (loader): flash, block=12, bs=1024, auto=1
20:14:32.585 (loader): flash, block=13, bs=1024, auto=1
20:14:32.586 (loader): flash, block=14, bs=1024, auto=1
20:14:32.588 (loader): flash, block=15, bs=1024, auto=1
20:14:32.589 (loader): flash, block=16, bs=1024, auto=1
20:14:32.591 (loader): flash, block=17, bs=1024, auto=1
20:14:32.592 (loader): flash, block=18, bs=1024, auto=1
20:14:32.604 (loader): sending reboot
20:14:32.604 (loader): begin wait_until_offline
20:14:32.614 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
20:14:32.661 (loader): offline, waited 1
20:14:32.661 (loader): end operation, total time = 0.435 seconds
20:14:32.663 (loader): set background IMG_REBOOT_OK
20:14:32.665 (loader): redraw timer set, image 14 to show for 1200 ms
20:14:32.665 (loader): remote connection 1308 opened
20:14:32.668 (ports 5): remove: loc=usb:0/140000/0/2
20:14:32.668 (ports 5): usb_remove: usb:0/140000/0/2
20:14:32.668 (ports 5): nothing new, skipping HID & Ports enum
20:14:32.670 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
20:14:32.670 (ports 5): nothing new, skipping HID & Ports enum
20:14:32.718 (loader): HID/win32: vid:056A pid:51C5 ver:0002 usb:150001/1
20:14:32.719 (loader): HID/win32: vid:056A pid:51C5 ver:0002 usb:150001/1
20:14:32.719 (loader): HID/win32: vid:06CB pid:7F28 ver:0003 usb:150000/1
20:14:32.998 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
20:14:32.999 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#11576140#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:14:32.999 (ports 5): found_usb_device, loc=usb:0/140000/0/2 Port_#0002.Hub_#0001
20:14:32.999 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
20:14:32.999 (ports 5): found_usb_device, devinst=00000014
20:14:32.999 (ports 5): add: loc=usb:0/140000/0/2, class=USB, vid=16C0, pid=0483, ver=0279, serial=11576140, dev=\\?\usb#vid_16c0&pid_0483#11576140#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:14:32.999 (ports 5): comport_from_devinst_list attempt
20:14:32.999 (ports 5): found Ports in classguid_list at index=1
20:14:32.999 (ports 5): port COM5 found from devnode
20:14:32.999 (ports 5): found_usb_device complete
20:14:33.000 (ports 5): usb_add: usb:0/140000/0/2 COM5 (Teensy 4.0) Serial
20:14:33.020 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
20:14:33.021 (ports 5): nothing new, skipping HID & Ports enum
20:14:33.034 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
20:14:33.035 (ports 5): nothing new, skipping HID & Ports enum
20:14:33.035 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
20:14:33.036 (ports 5): nothing new, skipping HID & Ports enum
20:14:33.861 (loader): redraw, image 9
20:14:40.949 (loader): Verbose Info event
20:15:27.420 (serialmon 6): Begin, version=1.57, high-res time
20:15:27.420 (serialmon 6): listening for location: usb:0/140000/0/2
20:15:27.420 (serialmon 6): LoadLibrary cfgmgr32 ok
20:15:27.420 (serialmon 6): LoadLibrary ntdll ok
20:15:27.423 (serialmon 6): callback 0024
20:15:27.423 (serialmon 6): callback 0081
20:15:27.426 (serialmon 6): callback 0083
20:15:27.426 (serialmon 6): hWnd = 526472
20:15:27.426 (serialmon 6): loop stdin, ready=262143
20:15:27.427 (serialmon 6): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#11576140#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:15:27.427 (serialmon 6): found_usb_device, loc=usb:0/140000/0/2 Port_#0002.Hub_#0001
20:15:27.427 (serialmon 6): found_usb_device, devinst=00000002
20:15:27.427 (serialmon 6): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
20:15:27.427 (serialmon 6): add: loc=usb:0/140000/0/2, class=USB, vid=16C0, pid=0483, ver=0279, serial=11576140, dev=\\?\usb#vid_16c0&pid_0483#11576140#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:15:27.427 (serialmon 6): comport_from_devinst_list attempt
20:15:27.427 (serialmon 6): found Ports in classguid_list at index=1
20:15:27.427 (serialmon 6): port COM5 found from devnode
20:15:27.427 (serialmon 6): found_usb_device complete
20:15:27.429 (serialmon 6): usb_add: usb:0/140000/0/2
20:15:27.429 (serialmon 6): translate "COM5" -> "\\.\COM5"
20:15:27.455 (serialmon 6): GetDefaultCommConfig success
20:15:27.480 (serialmon 6): SetDefaultCommConfig success
20:15:27.480 (serialmon 6): Opened \\.\COM5 Serial
20:15:27.481 (ports 5): callback 001A
20:15:27.509 (loader): remote connection 2028 opened
20:15:29.469 (loader): remote connection 2028 closed
20:17:54.219 (post_compile 7): Begin, version=1.57, high-res time
20:17:54.221 (loader): remote connection 1584 opened
20:17:54.222 (loader): remote cmd from 1584: "comment: Teensyduino 1.57 - WINDOWS (teensy_post_compile)"
20:17:54.222 (loader): remote cmd from 1584: "status"
20:17:54.222 (post_compile 7): Sending command: comment: Teensyduino 1.57 - WINDOWS (teensy_post_compile)
20:17:54.224 (post_compile 7): Status: 1, 1, 0, 1, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_679220\, Blink.ino.hex
20:17:54.224 (post_compile 7): Sending command: dir:C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\
20:17:54.225 (loader): remote cmd from 1584: "dir:C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\"
20:17:54.225 (post_compile 7): Sending command: file:Part_1_02_Hardware_Test.ino.hex
20:17:54.225 (loader): remote cmd from 1584: "file:Part_1_02_Hardware_Test.ino.hex"
20:17:54.239 (loader): File "C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\Part_1_02_Hardware_Test.ino.hex", 73728 bytes
20:17:54.239 (loader): File "Part_1_02_Hardware_Test.ino.hex". 73728 bytes
20:17:54.244 (loader): remote cmd from 1584: "status"
20:17:54.246 (post_compile 7): Status: 1, 1, 0, 1, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\, Part_1_02_Hardware_Test.ino.hex
20:17:54.246 (post_compile 7): Disconnect
20:17:54.271 (loader): remote connection 1584 closed
20:17:54.343 (post_compile 8): Begin, version=1.57, high-res time
20:17:54.344 (loader): remote connection 1560 opened
20:17:54.345 (loader): remote cmd from 1560: "comment: Teensyduino 1.57 - WINDOWS (teensy_post_compile)"
20:17:54.345 (loader): remote cmd from 1560: "status"
20:17:54.345 (post_compile 8): Sending command: comment: Teensyduino 1.57 - WINDOWS (teensy_post_compile)
20:17:54.347 (loader): remote cmd from 1560: "dir:C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\"
20:17:54.347 (loader): remote cmd from 1560: "file:Part_1_02_Hardware_Test.ino.hex"
20:17:54.347 (post_compile 8): Status: 1, 1, 0, 1, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\, Part_1_02_Hardware_Test.ino.hex
20:17:54.347 (post_compile 8): Sending command: dir:C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\
20:17:54.347 (post_compile 8): Sending command: file:Part_1_02_Hardware_Test.ino.hex
20:17:54.361 (loader): File "C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\Part_1_02_Hardware_Test.ino.hex", 73728 bytes
20:17:54.361 (loader): File "Part_1_02_Hardware_Test.ino.hex". 73728 bytes
20:17:54.366 (loader): remote cmd from 1560: "status"
20:17:54.368 (post_compile 8): Status: 1, 1, 0, 1, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\, Part_1_02_Hardware_Test.ino.hex
20:17:54.368 (post_compile 8): Disconnect
20:17:54.380 (loader): remote connection 1560 closed
20:17:54.380 (loader): remote connection 1728 opened
20:17:54.380 (post_compile 9): Running teensy_reboot: "C:\Program Files (x86)\Arduino\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY40" "-port=usb:0/140000/0/2" "-portlabel=hid#vid_16c0&pid_0478 Bootloader" "-portprotocol=Teensy"
20:17:54.391 (reboot 10): Begin, version=1.57, high-res time
20:17:54.391 (reboot 10): location = usb:0/140000/0/2
20:17:54.391 (reboot 10): portlabel = hid#vid_16c0&pid_0478 Bootloader
20:17:54.391 (reboot 10): portprotocol = Teensy
20:17:54.391 (reboot 10): Only location usb:0/140000/0/2 will be tried
20:17:54.391 (reboot 10): LoadLibrary cfgmgr32 ok
20:17:54.391 (reboot 10): LoadLibrary ntdll ok
20:17:54.391 (reboot 10): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#11576140#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:17:54.391 (reboot 10): found_usb_device, loc=usb:0/140000/0/2 Port_#0002.Hub_#0001
20:17:54.391 (reboot 10): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
20:17:54.391 (reboot 10): found_usb_device, devinst=00000002
20:17:54.391 (reboot 10): add: loc=usb:0/140000/0/2, class=USB, vid=16C0, pid=0483, ver=0279, serial=11576140, dev=\\?\usb#vid_16c0&pid_0483#11576140#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:17:54.391 (reboot 10): comport_from_devinst_list attempt
20:17:54.391 (reboot 10): found Ports in classguid_list at index=1
20:17:54.391 (reboot 10): port COM5 found from devnode
20:17:54.391 (reboot 10): found_usb_device complete
20:17:54.393 (reboot 10): usb scan found 1 devices
20:17:54.394 (loader): remote connection 1564 opened
20:17:54.394 (loader): remote cmd from 1564: "show:arduino_attempt_reboot"
20:17:54.394 (loader): got request to show arduino rebooting message
20:17:54.395 (reboot 10): found Teensy Loader, version 1.57
20:17:54.395 (reboot 10): Sending command: show:arduino_attempt_reboot
20:17:54.397 (reboot 10): Sending command: comment: Teensyduino 1.57 - WINDOWS (teensy_reboot)
20:17:54.398 (loader): remote cmd from 1564: "comment: Teensyduino 1.57 - WINDOWS (teensy_reboot)"
20:17:54.398 (loader): remote cmd from 1564: "status"
20:17:54.400 (reboot 10): Status: 1, 1, 0, 1, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\, Part_1_02_Hardware_Test.ino.hex
20:17:54.400 (reboot 10): do_reset (serial) COM5
20:17:54.403 (loader): remote cmd from 1564: "status"
20:17:54.405 (reboot 10): Status: 1, 1, 0, 1, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\, Part_1_02_Hardware_Test.ino.hex
20:17:54.405 (reboot 10): status read, retry 0
20:17:54.441 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
20:17:54.442 (ports 5): remove: loc=usb:0/140000/0/2
20:17:54.442 (ports 5): usb_remove: usb:0/140000/0/2
20:17:54.442 (ports 5): nothing new, skipping HID & Ports enum
20:17:54.450 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
20:17:54.451 (ports 5): nothing new, skipping HID & Ports enum
20:17:54.505 (loader): remote cmd from 1564: "status"
20:17:54.509 (reboot 10): Status: 1, 1, 0, 1, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\, Part_1_02_Hardware_Test.ino.hex
20:17:54.509 (reboot 10): status read, retry 1
20:17:54.611 (loader): remote cmd from 1564: "status"
20:17:54.613 (reboot 10): Status: 1, 1, 0, 1, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\, Part_1_02_Hardware_Test.ino.hex
20:17:54.613 (reboot 10): status read, retry 2
20:17:54.703 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
20:17:54.704 (ports 5): nothing new, skipping HID & Ports enum
20:17:54.711 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
20:17:54.712 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#0011a9ee#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:17:54.712 (ports 5): found_usb_device, loc=usb:0/140000/0/2 Port_#0002.Hub_#0001
20:17:54.712 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0107
20:17:54.712 (ports 5): found_usb_device, devinst=00000003
20:17:54.712 (ports 5): add: loc=usb:0/140000/0/2, class=HID, vid=16C0, pid=0478, ver=0107, serial=0011a9ee, dev=\\?\usb#vid_16c0&pid_0478#0011a9ee#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:17:54.712 (ports 5): hiddev_from_devinst_list: iface=0
20:17:54.713 (ports 5): found_usb_device complete
20:17:54.714 (ports 5): usb_add: usb:0/140000/0/2 [no_device] (Teensy 4.0) Bootloader
20:17:54.714 (loader): remote cmd from 1564: "status"
20:17:54.715 (loader): secure mode can not be locked: this is Standard Teensy
20:17:54.715 (loader): encryption is possible on this Teensy, but not yet configured
20:17:54.715 (loader): but without secure mode locked, encryption will NOT be secure!
20:17:54.715 (loader): Device came online, code_size = 2031616
20:17:54.715 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.07
20:17:54.735 (loader): File "C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\Part_1_02_Hardware_Test.ino.hex", 73728 bytes
20:17:54.735 (loader): File "Part_1_02_Hardware_Test.ino.hex". 73728 bytes, 4% used
20:17:54.786 (loader): set background IMG_ONLINE
20:17:54.802 (loader): File "C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\Part_1_02_Hardware_Test.ino.hex", 73728 bytes
20:17:54.802 (loader): File "Part_1_02_Hardware_Test.ino.hex". 73728 bytes, 4% used
20:17:54.854 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
20:17:54.855 (loader): elf binary data matches hex file
20:17:54.855 (loader): elf file is for Teensy 4.0 (IMXRT1062)
20:17:54.855 (loader): using hex file
20:17:54.902 (loader): begin operation
20:17:54.917 (reboot 10): Status: 1, 1, 1, 2, 0, 1, C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\, Part_1_02_Hardware_Test.ino.hex
20:17:54.924 (loader): flash, block=0, bs=1024, auto=1
20:17:54.925 (loader): flash, block=1, bs=1024, auto=1
20:17:54.925 (loader): flash, block=2, bs=1024, auto=1
20:17:54.925 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
20:17:54.926 (ports 5): hid, found devinst=00000007
20:17:54.926 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#6&2bc5e7a5&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
20:17:54.926 (ports 5): hid, opened handle
20:17:54.926 (ports 5): devinst=00000007, location=usb:0/140000/0/2
20:17:54.926 (ports 5): vid=16C0, pid=0478, ver=0107, usepage=FF9C, use=0024
20:17:54.926 (ports 5): devpath=\\?\hid#vid_16c0&pid_0478#6&2bc5e7a5&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
20:17:54.926 (ports 5): usb_add: usb:0/140000/0/2 hid#vid_16c0&pid_0478 (Teensy 4.0) Bootloader
20:17:55.077 (loader): remote cmd from 1564: "status"
20:17:55.077 (loader): flash, block=3, bs=1024, auto=1
20:17:55.078 (reboot 10): Status: 1, 1, 1, 2, 0, 1, C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\, Part_1_02_Hardware_Test.ino.hex
20:17:55.078 (loader): flash, block=4, bs=1024, auto=1
20:17:55.084 (loader): flash, block=5, bs=1024, auto=1
20:17:55.087 (loader): flash, block=6, bs=1024, auto=1
20:17:55.090 (loader): flash, block=7, bs=1024, auto=1
20:17:55.093 (loader): flash, block=8, bs=1024, auto=1
20:17:55.095 (loader): flash, block=9, bs=1024, auto=1
20:17:55.097 (loader): flash, block=10, bs=1024, auto=1
20:17:55.103 (loader): flash, block=11, bs=1024, auto=1
20:17:55.105 (loader): flash, block=12, bs=1024, auto=1
20:17:55.106 (loader): flash, block=13, bs=1024, auto=1
20:17:55.108 (loader): flash, block=14, bs=1024, auto=1
20:17:55.109 (loader): flash, block=15, bs=1024, auto=1
20:17:55.110 (loader): flash, block=16, bs=1024, auto=1
20:17:55.112 (loader): flash, block=17, bs=1024, auto=1
20:17:55.113 (loader): flash, block=18, bs=1024, auto=1
20:17:55.115 (loader): flash, block=19, bs=1024, auto=1
20:17:55.116 (loader): flash, block=20, bs=1024, auto=1
20:17:55.117 (loader): flash, block=21, bs=1024, auto=1
20:17:55.118 (loader): flash, block=22, bs=1024, auto=1
20:17:55.120 (loader): flash, block=23, bs=1024, auto=1
20:17:55.121 (loader): flash, block=24, bs=1024, auto=1
20:17:55.138 (loader): remote cmd from 1564: "status"
20:17:55.139 (reboot 10): Status: 1, 1, 1, 2, 0, 1, C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\, Part_1_02_Hardware_Test.ino.hex
20:17:55.139 (loader): flash, block=25, bs=1024, auto=1
20:17:55.140 (loader): flash, block=26, bs=1024, auto=1
20:17:55.142 (loader): flash, block=27, bs=1024, auto=1
20:17:55.143 (loader): flash, block=28, bs=1024, auto=1
20:17:55.145 (loader): flash, block=29, bs=1024, auto=1
20:17:55.147 (loader): flash, block=30, bs=1024, auto=1
20:17:55.148 (loader): flash, block=31, bs=1024, auto=1
20:17:55.150 (loader): flash, block=32, bs=1024, auto=1
20:17:55.151 (loader): flash, block=33, bs=1024, auto=1
20:17:55.152 (loader): flash, block=34, bs=1024, auto=1
20:17:55.153 (loader): flash, block=35, bs=1024, auto=1
20:17:55.154 (loader): flash, block=36, bs=1024, auto=1
20:17:55.156 (loader): flash, block=37, bs=1024, auto=1
20:17:55.173 (loader): flash, block=38, bs=1024, auto=1
20:17:55.174 (loader): flash, block=39, bs=1024, auto=1
20:17:55.176 (loader): flash, block=40, bs=1024, auto=1
20:17:55.176 (loader): flash, block=41, bs=1024, auto=1
20:17:55.178 (loader): flash, block=42, bs=1024, auto=1
20:17:55.179 (loader): flash, block=43, bs=1024, auto=1
20:17:55.181 (loader): flash, block=44, bs=1024, auto=1
20:17:55.182 (loader): flash, block=45, bs=1024, auto=1
20:17:55.183 (loader): flash, block=46, bs=1024, auto=1
20:17:55.184 (loader): flash, block=47, bs=1024, auto=1
20:17:55.203 (loader): remote cmd from 1564: "status"
20:17:55.203 (loader): flash, block=48, bs=1024, auto=1
20:17:55.203 (reboot 10): Status: 1, 1, 1, 2, 0, 1, C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\, Part_1_02_Hardware_Test.ino.hex
20:17:55.204 (loader): flash, block=49, bs=1024, auto=1
20:17:55.206 (loader): flash, block=50, bs=1024, auto=1
20:17:55.207 (loader): flash, block=51, bs=1024, auto=1
20:17:55.209 (loader): flash, block=52, bs=1024, auto=1
20:17:55.210 (loader): flash, block=53, bs=1024, auto=1
20:17:55.212 (loader): flash, block=54, bs=1024, auto=1
20:17:55.214 (loader): flash, block=55, bs=1024, auto=1
20:17:55.216 (loader): flash, block=56, bs=1024, auto=1
20:17:55.218 (loader): flash, block=57, bs=1024, auto=1
20:17:55.219 (loader): flash, block=58, bs=1024, auto=1
20:17:55.220 (loader): flash, block=59, bs=1024, auto=1
20:17:55.221 (loader): flash, block=60, bs=1024, auto=1
20:17:55.223 (loader): flash, block=61, bs=1024, auto=1
20:17:55.225 (loader): flash, block=62, bs=1024, auto=1
20:17:55.227 (loader): flash, block=63, bs=1024, auto=1
20:17:55.229 (loader): flash, block=64, bs=1024, auto=1
20:17:55.230 (loader): flash, block=65, bs=1024, auto=1
20:17:55.231 (loader): flash, block=66, bs=1024, auto=1
20:17:55.232 (loader): flash, block=67, bs=1024, auto=1
20:17:55.234 (loader): flash, block=68, bs=1024, auto=1
20:17:55.236 (loader): flash, block=69, bs=1024, auto=1
20:17:55.238 (loader): flash, block=70, bs=1024, auto=1
20:17:55.240 (loader): flash, block=71, bs=1024, auto=1
20:17:55.261 (loader): remote cmd from 1564: "status"
20:17:55.261 (reboot 10): Status: 1, 1, 1, 2, 0, 2, C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\, Part_1_02_Hardware_Test.ino.hex
20:17:55.262 (loader): sending reboot
20:17:55.263 (loader): begin wait_until_offline
20:17:55.278 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
20:17:55.278 (ports 5): remove: loc=usb:0/140000/0/2
20:17:55.278 (ports 5): usb_remove: usb:0/140000/0/2
20:17:55.278 (ports 5): nothing new, skipping HID & Ports enum
20:17:55.321 (loader): offline, waited 1
20:17:55.321 (loader): end operation, total time = 0.419 seconds
20:17:55.322 (loader): set background IMG_REBOOT_OK
20:17:55.324 (loader): redraw timer set, image 14 to show for 1200 ms
20:17:55.324 (loader): remote cmd from 1564: "status"
20:17:55.325 (loader): HID/win32: vid:056A pid:51C5 ver:0002 usb:150001/1
20:17:55.326 (loader): HID/win32: vid:056A pid:51C5 ver:0002 usb:150001/1
20:17:55.326 (loader): HID/win32: vid:06CB pid:7F28 ver:0003 usb:150000/1
20:17:55.326 (reboot 10): Status: 1, 1, 0, 2, 0, 0, C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\, Part_1_02_Hardware_Test.ino.hex
20:17:55.326 (reboot 10): status read, retry 3
20:17:55.326 (reboot 10): Success
20:17:55.326 (reboot 10): Disconnect
20:17:55.328 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
20:17:55.328 (ports 5): nothing new, skipping HID & Ports enum
20:17:55.349 (loader): remote connection 1564 closed
20:17:55.351 (loader): remote connection 1728 closed
20:17:56.537 (loader): redraw, image 9
20:17:56.897 (ports 5): purge, name=hid#vid_16c0&pid_0478 (Teensy 4.0) Bootloader, loc=usb:0/140000/0/2, age=1.619 sec
20:18:05.544 (loader): Verbose Info event
20:18:25.852 (ports 5): WM_DEVICECHANGE DBT_DEVICEARRIVAL
20:18:25.855 (ports 5): found_usb_device, id=\\?\usb#vid_16c0&pid_0478#0011a9ee#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:18:25.855 (ports 5): found_usb_device, loc=usb:0/140000/0/2 Port_#0002.Hub_#0001
20:18:25.855 (ports 5): found_usb_device, hwid=USB\VID_16C0&PID_0478&REV_0107
20:18:25.855 (ports 5): found_usb_device, devinst=00000003
20:18:25.855 (ports 5): add: loc=usb:0/140000/0/2, class=HID, vid=16C0, pid=0478, ver=0107, serial=0011a9ee, dev=\\?\usb#vid_16c0&pid_0478#0011a9ee#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
20:18:25.858 (ports 5): hiddev_from_devinst_list: iface=0
20:18:25.859 (ports 5): found_usb_device complete
20:18:25.861 (ports 5): usb_add: usb:0/140000/0/2 [no_device] (Teensy) Bootloader
20:18:25.874 (loader): secure mode can not be locked: this is Standard Teensy
20:18:25.874 (loader): encryption is possible on this Teensy, but not yet configured
20:18:25.874 (loader): but without secure mode locked, encryption will NOT be secure!
20:18:25.875 (loader): Device came online, code_size = 2031616
20:18:25.875 (loader): Board is: Teensy 4.0 (IMXRT1062), version 1.07
20:18:25.890 (loader): File "C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\Part_1_02_Hardware_Test.ino.hex", 73728 bytes
20:18:25.890 (loader): File "Part_1_02_Hardware_Test.ino.hex". 73728 bytes, 4% used
20:18:25.938 (loader): set background IMG_ONLINE
20:18:25.955 (loader): File "C:\Users\dasau\AppData\Local\Temp\arduino_build_740553\Part_1_02_Hardware_Test.ino.hex", 73728 bytes
20:18:25.955 (loader): File "Part_1_02_Hardware_Test.ino.hex". 73728 bytes, 4% used
20:18:26.002 (loader): elf appears to be for Teensy 4.0 (IMXRT1062) (2031616 bytes)
20:18:26.003 (loader): elf binary data matches hex file
20:18:26.003 (loader): elf file is for Teensy 4.0 (IMXRT1062)
20:18:26.003 (loader): using hex file
20:18:26.047 (loader): begin operation
20:18:26.067 (loader): flash, block=0, bs=1024, auto=1
20:18:26.068 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
20:18:26.068 (loader): flash, block=1, bs=1024, auto=1
20:18:26.069 (ports 5): update_usb_device, devinst list change, old had 1, new has 2
20:18:26.069 (ports 5): hiddev_from_devinst_list: iface=0
20:18:26.069 (loader): flash, block=2, bs=1024, auto=1
20:18:26.070 (ports 5): hid, found devinst=00000007
20:18:26.070 (ports 5): hid, path=\\?\hid#vid_16c0&pid_0478#6&2bc5e7a5&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
20:18:26.070 (ports 5): hid, opened handle
20:18:26.070 (ports 5): devinst=00000007, location=usb:0/140000/0/2
20:18:26.070 (ports 5): vid=16C0, pid=0478, ver=0107, usepage=FF9C, use=0024
20:18:26.070 (ports 5): devpath=\\?\hid#vid_16c0&pid_0478#6&2bc5e7a5&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
20:18:26.070 (ports 5): usb_add: usb:0/140000/0/2 hid#vid_16c0&pid_0478 (Teensy 4.0) Bootloader
20:18:26.388 (loader): flash, block=3, bs=1024, auto=1
20:18:26.388 (loader): flash, block=4, bs=1024, auto=1
20:18:26.398 (loader): flash, block=5, bs=1024, auto=1
20:18:26.400 (loader): flash, block=6, bs=1024, auto=1
20:18:26.402 (loader): flash, block=7, bs=1024, auto=1
20:18:26.403 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
20:18:26.404 (ports 5): nothing new, skipping HID & Ports enum
20:18:26.404 (loader): flash, block=8, bs=1024, auto=1
20:18:26.406 (loader): flash, block=9, bs=1024, auto=1
20:18:26.408 (loader): flash, block=10, bs=1024, auto=1
20:18:26.409 (loader): flash, block=11, bs=1024, auto=1
20:18:26.411 (loader): flash, block=12, bs=1024, auto=1
20:18:26.413 (loader): flash, block=13, bs=1024, auto=1
20:18:26.414 (loader): flash, block=14, bs=1024, auto=1
20:18:26.417 (loader): flash, block=15, bs=1024, auto=1
20:18:26.419 (loader): flash, block=16, bs=1024, auto=1
20:18:26.420 (loader): flash, block=17, bs=1024, auto=1
20:18:26.422 (loader): flash, block=18, bs=1024, auto=1
20:18:26.423 (loader): flash, block=19, bs=1024, auto=1
20:18:26.424 (loader): flash, block=20, bs=1024, auto=1
20:18:26.426 (loader): flash, block=21, bs=1024, auto=1
20:18:26.428 (loader): flash, block=22, bs=1024, auto=1
20:18:26.430 (loader): flash, block=23, bs=1024, auto=1
20:18:26.431 (loader): flash, block=24, bs=1024, auto=1
20:18:26.433 (loader): flash, block=25, bs=1024, auto=1
20:18:26.435 (loader): flash, block=26, bs=1024, auto=1
20:18:26.437 (loader): flash, block=27, bs=1024, auto=1
20:18:26.438 (loader): flash, block=28, bs=1024, auto=1
20:18:26.440 (loader): flash, block=29, bs=1024, auto=1
20:18:26.442 (loader): flash, block=30, bs=1024, auto=1
20:18:26.444 (loader): flash, block=31, bs=1024, auto=1
20:18:26.447 (loader): flash, block=32, bs=1024, auto=1
20:18:26.448 (loader): flash, block=33, bs=1024, auto=1
20:18:26.450 (loader): flash, block=34, bs=1024, auto=1
20:18:26.452 (loader): flash, block=35, bs=1024, auto=1
20:18:26.453 (loader): flash, block=36, bs=1024, auto=1
20:18:26.455 (loader): flash, block=37, bs=1024, auto=1
20:18:26.457 (loader): flash, block=38, bs=1024, auto=1
20:18:26.459 (loader): flash, block=39, bs=1024, auto=1
20:18:26.461 (loader): flash, block=40, bs=1024, auto=1
20:18:26.463 (loader): flash, block=41, bs=1024, auto=1
20:18:26.464 (loader): flash, block=42, bs=1024, auto=1
20:18:26.466 (loader): flash, block=43, bs=1024, auto=1
20:18:26.468 (loader): flash, block=44, bs=1024, auto=1
20:18:26.470 (loader): flash, block=45, bs=1024, auto=1
20:18:26.471 (loader): flash, block=46, bs=1024, auto=1
20:18:26.475 (loader): flash, block=47, bs=1024, auto=1
20:18:26.476 (loader): flash, block=48, bs=1024, auto=1
20:18:26.478 (loader): flash, block=49, bs=1024, auto=1
20:18:26.480 (loader): flash, block=50, bs=1024, auto=1
20:18:26.482 (loader): flash, block=51, bs=1024, auto=1
20:18:26.484 (loader): flash, block=52, bs=1024, auto=1
20:18:26.485 (loader): flash, block=53, bs=1024, auto=1
20:18:26.487 (loader): flash, block=54, bs=1024, auto=1
20:18:26.489 (loader): flash, block=55, bs=1024, auto=1
20:18:26.491 (loader): flash, block=56, bs=1024, auto=1
20:18:26.493 (loader): flash, block=57, bs=1024, auto=1
20:18:26.495 (loader): flash, block=58, bs=1024, auto=1
20:18:26.497 (loader): flash, block=59, bs=1024, auto=1
20:18:26.499 (loader): flash, block=60, bs=1024, auto=1
20:18:26.500 (loader): flash, block=61, bs=1024, auto=1
20:18:26.502 (loader): flash, block=62, bs=1024, auto=1
20:18:26.504 (loader): flash, block=63, bs=1024, auto=1
20:18:26.506 (loader): flash, block=64, bs=1024, auto=1
20:18:26.508 (loader): flash, block=65, bs=1024, auto=1
20:18:26.509 (loader): flash, block=66, bs=1024, auto=1
20:18:26.511 (loader): flash, block=67, bs=1024, auto=1
20:18:26.513 (loader): flash, block=68, bs=1024, auto=1
20:18:26.515 (loader): flash, block=69, bs=1024, auto=1
20:18:26.517 (loader): flash, block=70, bs=1024, auto=1
20:18:26.519 (loader): flash, block=71, bs=1024, auto=1
20:18:26.531 (loader): sending reboot
20:18:26.531 (loader): begin wait_until_offline
20:18:26.541 (ports 5): WM_DEVICECHANGE DBT_DEVICEREMOVECOMPLETE
20:18:26.541 (ports 5): remove: loc=usb:0/140000/0/2
20:18:26.541 (ports 5): usb_remove: usb:0/140000/0/2
20:18:26.541 (ports 5): nothing new, skipping HID & Ports enum
20:18:26.592 (loader): offline, waited 1
20:18:26.592 (loader): end operation, total time = 0.545 seconds
20:18:26.594 (loader): set background IMG_REBOOT_OK
20:18:26.598 (loader): redraw timer set, image 14 to show for 1200 ms
20:18:26.606 (ports 5): WM_DEVICECHANGE DBT_DEVNODES_CHANGED
20:18:26.606 (ports 5): nothing new, skipping HID & Ports enum
20:18:26.623 (loader): HID/win32: vid:056A pid:51C5 ver:0002 usb:150001/1
20:18:26.624 (loader): HID/win32: vid:056A pid:51C5 ver:0002 usb:150001/1
20:18:26.624 (loader): HID/win32: vid:06CB pid:7F28 ver:0003 usb:150000/1
20:18:27.798 (loader): redraw, image 9
20:18:28.177 (ports 5): purge, name=hid#vid_16c0&pid_0478 (Teensy 4.0) Bootloader, loc=usb:0/140000/0/2, age=1.635 sec
20:18:31.904 (loader): Verbose Info event
But i want to increase the volume of the speaker, the greeting message is to quiet.
sgtl5000_1.micGain(8);
sgtl5000_1.volume(0.85);
Hi all, are there any advantages to going with the teensy 4.0 vs 4.1? The 4.1 already has a SD slot so an audio adapter would not be necessary.
#include <MTP_Teensy.h>
Same here, theis not in orange.Code:#include <MTP_Teensy.h>
But if you can compile the code, everything is fine with that lib.
Did you set Tools --> USB type --> Serial & MTP Disk (Experimental) ? You have to do that before compiling. However, if not, you should have received an error message.
If you connect the Teensy to the PC, wait for a minute or so. Open the explorer and look for a small sign labeled "Teensy", if you click on that, the drive with the name you assigned ("Audio guest book" or similar) will appear and you can access the files.
Okay I’ll give it a go this afternoon. Thank you so much for the reply and all of your work!! I’ll see how I get on a little later. Thanks again.
Arduino: 1.8.19 (Windows 10), TD: 1.57-beta1, Board: "Teensy LC, MTP Disk (Experimental), 48 MHz, Smallest Code, US English"
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src\MTP_Teensy.cpp: In member function 'void MTP_class::loop()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src\MTP_Teensy.cpp:246:26: error: 'usb_mtp_status' was not declared in this scope
if (return_code && usb_mtp_status == 0x01) {
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src\MTP_Teensy.cpp:278:7: error: 'usb_mtp_status' was not declared in this scope
if (usb_mtp_status != 0x01) {
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src\MTP_Teensy.cpp: In member function 'uint32_t MTP_class::GetObject(MTP_class::MTPContainer&)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src\MTP_Teensy.cpp:578:9: error: 'usb_mtp_status' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src\MTP_Teensy.cpp: In member function 'uint32_t MTP_class::GetPartialObject(MTP_class::MTPContainer&)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main\src\MTP_Teensy.cpp:618:9: error: 'usb_mtp_status' was not declared in this scope
Multiple libraries were found for "MTP_Teensy.h"
Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\MTP_Teensy-main
Not used: C:\Program Files (x86)\Arduino\libraries\MTP_Teensy-main
Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
Not used: C:\Program Files (x86)\Arduino\libraries\SD
Error compiling for board Teensy LC.
* Audio Guestbook, Copyright (c) 2022 Playful Technology
* Tested using a Teensy 4.0 with Teensy Audio Shield, although should work
* with minor modifications on other similar hardware
* When handset is lifted, a pre-recorded greeting message is played, followed by a tone.
* Then, recording starts, and continues until the handset is replaced.
* Playback button allows all messages currently saved on SD card through earpiece
* follow the detailed instructions here:
* https://github.com/DD4WH/audio-guestbook/blob/main/README.md
* the sketch only works with the latest Teensyduino 1.57 version, so please update your Arduino IDE AND your Teensyduino to Arduino version 1.8.19 and the latest Teensyduino version 1.57
* download the following library, unzip it and put it into your local Arduino folder (on my computer, the local Arduino folder is: "C:/Users/DD4WH/Documents/Arduino/libraries/"): https://github.com/KurtE/MTP_Teensy
* compile with option: "Serial + MTP Disk (Experimental)"" and with option "CPU speed: 150MHz" (this can save about 70% of battery power)
* Modifications by Frank DD4WH, August 2022
* - now uses a Teensy 4.1 with built-in SD card (faster via SDIO), if you want to use a Teensy 4.0, uncomment in the USER CONFIGURATION below
* - Files are saved on SD card as 44.1kHz, 16-bit mono WAV audio files
* - if you plug in the telephones´ USB cable into your computer, the telephone is mounted as a drive and you can acess the recordings
* - if there is no "greeting.wav" message on the SD card, the telephone automatically plays an invitation to record this message and then you can record the greeting message
* - if you want to record the greeting message again, just delete it from the telephone and lift the handheld again to record the greeting message
* --> if your handheld contact switch opens on lifting, simply uncomment in the USER CONFIGURATION below, everything else is done by the software
* GNU GPL v3.0 license
#include <Bounce.h>
#include <TimeLib.h>
#include <MTP_Teensy.h> // this library has to be downloaded separately (https://github.com/KurtE/MTP_Teensy)
// unzip the downloaded file and its content into your local Arduino folder (on my computer, the local Arduino folder is: "C:/Users/DD4WH/Documents/Arduino/libraries/")
/**USER CONFIGURATION ******************************************************************************************************************************/
/**COMMENT / UNCOMMENT ACCORDING TO YOUR HARDWARE **************************************************************************************************/
// comment this out, if your handheld OPENS the contact on lift
// use a digital voltmeter to find out
#define HANDHELD_CLOSES_ON_LIFT
// comment this out, if you want to record your greeting message with an external recorder
// leave as-is if you want to have the telephone automatically switch to recording the greeting message, in case there is no "greeting.wav" on the SD card
#define AUTO_GREETING_MESSAGE
// comment out, if you use a Teensy 4.0 (and thus the SD card slot on the audio board)
// if you leave this as-is, you have to use the built-in SD card slot on the Teensy 4.1, NOT the SD card slot on the audio board
// I have commmented this out.
//#define TEENSY_LC
/**END OF USER CONFIGURATION ***********************************************************************************************************************/
// Define pins used by Teensy Audio Shield
#ifdef TEENSY_LC
#define SDCARD_CS_PIN BUILTIN_SDCARD
#else
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
// And those used for inputs
// You can choose the pins you use here:
#define HOOK_PIN 40
#define PLAYBACK_BUTTON_PIN 41
//#define HOOK_PIN 0 // this is the default
//#define PLAYBACK_BUTTON_PIN 1 // this is the default
// GLOBALS
// Audio initialisation code can be generated using the GUI interface at https://www.pjrc.com/teensy/gui/
// Inputs
AudioSynthWaveform waveform1; // To create the "beep" sfx
AudioInputI2S i2s2; // I2S input from microphone on audio shield
AudioPlaySdWav playWav1; // Play 44.1kHz 16-bit PCM greeting WAV file
AudioRecordQueue queue1; // Creating an audio buffer in memory before saving to SD
AudioMixer4 mixer; // Allows merging several inputs to same output
AudioOutputI2S i2s1; // I2S interface to Speaker/Line Out on Audio shield
AudioConnection patchCord1(waveform1, 0, mixer, 0); // wave to mixer
AudioConnection patchCord3(playWav1, 0, mixer, 1); // wav file playback mixer
AudioConnection patchCord4(mixer, 0, i2s1, 0); // mixer output to speaker (L)
AudioConnection patchCord6(mixer, 0, i2s1, 1); // mixer output to speaker (R)
AudioConnection patchCord5(i2s2, 0, queue1, 0); // mic input to queue (L)
// Filename to save audio recording on SD card
char filename[15];
// The file object itself
File frec;
// Use long 40ms debounce time on both switches
Bounce buttonRecord = Bounce(HOOK_PIN, 40);
Bounce buttonPlay = Bounce(PLAYBACK_BUTTON_PIN, 40);
// Keep track of current state of the device
enum Mode {Initialising, Ready, Prompting, Recording, Playing, Recording_Greeting};
Mode mode = Mode::Initialising;
float beep_volume = 0.04f; // not too loud :-)
// variables for writing to WAV file
unsigned long ChunkSize = 0L;
unsigned long Subchunk1Size = 16;
unsigned int AudioFormat = 1;
unsigned int numChannels = 1;
unsigned long sampleRate = 44100;
unsigned int bitsPerSample = 16;
unsigned long byteRate = sampleRate*numChannels*(bitsPerSample/8);// samplerate x channels x (bitspersample / 8)
unsigned int blockAlign = numChannels*bitsPerSample/8;
unsigned long Subchunk2Size = 0L;
unsigned long recByteSaved = 0L;
unsigned long NumSamples = 0L;
byte byte1, byte2, byte3, byte4;
while (!Serial && millis() < 5000) {
// wait for serial port to connect.
Serial.println("Serial set up correctly");
print_mode();
// Configure the input pins
pinMode(HOOK_PIN, INPUT_PULLUP);
pinMode(PLAYBACK_BUTTON_PIN, INPUT_PULLUP);
AudioMemory(60);
sgtl5000_1.enable();
// Define which input on the audio shield to use (AUDIO_INPUT_LINEIN / AUDIO_INPUT_MIC)
sgtl5000_1.adcHighPassFilterDisable(); //
mixer.gain(0, 1.0f);
mixer.gain(1, 1.0f);
// Play a beep to indicate system is online
waveform1.begin(beep_volume, 440, WAVEFORM_SINE);
wait(1000);
waveform1.amplitude(0);
// Initialize the SD card
#ifndef TEENSY_LC // assumes that you are using the SD card slot of the AUDIO BOARD
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
if (!(SD.begin(SDCARD_CS_PIN)))
while (1) {
else Serial.println("SD card correctly initialized");
// mandatory to begin the MTP session.
MTP.begin();
// Add SD Card
MTP.addFilesystem(SD, "Gruenkohls Audio guestbook"); // choose a nice name for the SD card volume to appear in your file explorer
Serial.println("Added SD card via MTP");
// Value in dB
// sgtl5000_1.micGain(15);
sgtl5000_1.micGain(8); // much lower gain is required for the AOM5024 electret capsule
// Synchronise the Time object used in the program code with the RTC time provider.
// See https://github.com/PaulStoffregen/Time
// Define a callback that will assign the correct datetime for any file system operations
// (i.e. saving a new audio recording onto the SD card)
FsDateTime::setCallback(dateTime);
mode = Mode::Ready; print_mode();
void loop() { //1
// First, read the buttons
buttonRecord.update();
buttonPlay.update();
switch(mode)
{ //2
case Mode::Ready:
// Falling edge occurs when the handset is lifted --> 611 telephone
#if defined(HANDHELD_CLOSES_ON_LIFT)
if (buttonRecord.fallingEdge())
#else
if (buttonRecord.risingEdge())
Serial.println("Handset lifted");
mode = Mode::Prompting; print_mode();
} //3
else if(buttonPlay.fallingEdge())
{ //4
//playAllRecordings();
playLastRecording();
} //4
case Mode::Prompting:
// Wait a second for users to put the handset to their ear
wait(1000);
#if defined(AUTO_GREETING_MESSAGE)
if (!SD.exists("greeting.wav"))
{ //5
mode = Mode::Recording_Greeting;
} //5
// Play the greeting inviting them to record their message
playWav1.play("greeting.wav");
// Wait until the message has finished playing
// while (playWav1.isPlaying()) {
while (!playWav1.isStopped())
{ //6
// Check whether the handset is replaced
// Handset is replaced
#else
playWav1.stop();
return;
} //7
{ //8
playWav1.stop();
return;
} //8
// Debug message
Serial.println("Starting Recording");
// Play the tone sound effect
wait(1250);
// Start the recording function
startRecording();
case Mode::Recording:
#else
{ //9
// Debug log
Serial.println("Stopping Recording");
// Stop recording
stopRecording();
// Play audio tone to confirm recording has ended
end_Beep();
} //9
{ //10
continueRecording();
} // 10
case Mode::Playing: // to make compiler happy
case Mode::Initialising: // to make compiler happy
case Mode::Recording_Greeting: // to make compiler happy
startRecordingGreeting();
mode = Mode::Recording;
} // 2 end switch
MTP.loop(); //This is mandatory to be placed in the loop code.
} // 1 end loop
void startRecordingGreeting() {
if (SD.exists("greeting.wav")) {
return;
// play message "Please record Greeting message now !"
playWav1.play("invitation_greeting.wav");
while (!playWav1.isStopped()) { // this works for playWav
// Button is pressed again
if(buttonPlay.fallingEdge() || buttonRecord.risingEdge())
#else
if(buttonPlay.fallingEdge() || buttonRecord.fallingEdge())
playWav1.stop();
return;
// play beep
two_tone_Beep();
frec = SD.open("greeting.wav", FILE_WRITE);
Serial.println("Opened Greeting file !");
if(frec) {
Serial.print("Recording to greeting.wav");
queue1.begin();
mode = Mode::Recording; print_mode();
recByteSaved = 0L;
else {
Serial.println("Couldn't open file to record!");
void startRecording() {
// Find the first available file number
// for (uint8_t i=0; i<9999; i++) { // BUGFIX uint8_t overflows if it reaches 255
for (uint16_t i=0; i<9999; i++) {
// Format the counter as a five-digit number with leading zeroes, followed by file extension
snprintf(filename, 11, " %05d.wav", i);
// Create if does not exist, do not open existing, write, sync after write
if (!SD.exists(filename)) {
frec = SD.open(filename, FILE_WRITE);
Serial.println("Opened file !");
if(frec) {
Serial.print("Recording to ");
Serial.println(filename);
queue1.begin();
recByteSaved = 0L;
else {
void continueRecording() {
// Check if there is data in the queue
if (queue1.available() >= 2) {
byte buffer[512];
// into a 512 byte buffer. The Arduino SD library
// writes are used.
memcpy(buffer, queue1.readBuffer(), 256);
queue1.freeBuffer();
memcpy(buffer+256, queue1.readBuffer(), 256);
// Write all 512 bytes to the SD card
frec.write(buffer, 512);
recByteSaved += 512;
void stopRecording() {
// Stop adding any new data to the queue
queue1.end();
// Flush all existing remaining data from the queue
// Save to open file
frec.write((byte*)queue1.readBuffer(), 256);
recByteSaved += 256;
writeOutHeader();
// Close the file
frec.close();
Serial.println("Closed file");
void playAllRecordings() {
// Recording files are saved in the root directory
File dir = SD.open("/");
while (true) {
File entry = dir.openNextFile();
if (strstr(entry.name(), "greeting"))
if (!entry) {
// no more files
entry.close();
end_Beep();
//int8_t len = strlen(entry.name()) - 4;
// if (strstr(strlwr(entry.name() + (len - 4)), ".raw")) {
// if (strstr(strlwr(entry.name() + (len - 4)), ".wav")) {
// the lines above throw a warning, so I replace them with this (which is also easier to read):
if (strstr(entry.name(), ".wav") || strstr(entry.name(), ".WAV")) {
Serial.print("Now playing ");
Serial.println(entry.name());
// Play a short beep before each message
waveform1.amplitude(beep_volume);
wait(750);
// Play the file
playWav1.play(entry.name());
mode = Mode::Playing; print_mode();
entry.close();
// while (playWav1.isPlaying()) { // strangely enough, this works for playRaw, but it does not work properly for playWav
#else
playWav1.stop();
return;
// All files have been played
void playLastRecording() { // 1
uint16_t idx = 0;
for (uint16_t i=0; i<9999; i++) { // 2
// check, if file with index i exists
if (!SD.exists(filename)) { // 3
idx = i - 1;
} // 3
} // 2
// now play file with index idx == last recorded file
snprintf(filename, 11, " %05d.wav", idx);
playWav1.play(filename);
{ // 5 // this works for playWav
#else
playWav1.stop();
return;
} //4
} // 5 end while
// file has been played
end_Beep();
} // 1 end playLastRecording
// Retrieve the current time from Teensy built-in RTC
time_t getTeensy3Time(){
return Teensy3Clock.get();
// Callback to assign timestamps for file system operations
void dateTime(uint16_t* date, uint16_t* time, uint8_t* ms10) {
// Return date using FS_DATE macro to format fields.
*date = FS_DATE(year(), month(), day());
// Return time using FS_TIME macro to format fields.
*time = FS_TIME(hour(), minute(), second());
// Return low time bits in units of 10 ms.
*ms10 = second() & 1 ? 100 : 0;
// Non-blocking delay, which pauses execution of main program logic,
// but while still listening for input
void wait(unsigned int milliseconds) {
elapsedMillis msec=0;
while (msec <= milliseconds) {
if (buttonRecord.fallingEdge()) Serial.println("Button (pin 0) Press");
if (buttonPlay.fallingEdge()) Serial.println("Button (pin 1) Press");
if (buttonRecord.risingEdge()) Serial.println("Button (pin 0) Release");
if (buttonPlay.risingEdge()) Serial.println("Button (pin 1) Release");
void writeOutHeader() { // update WAV header with final filesize/datasize
// NumSamples = (recByteSaved*8)/bitsPerSample/numChannels;
// Subchunk2Size = NumSamples*numChannels*bitsPerSample/8; // number of samples x number of channels x number of bytes per sample
Subchunk2Size = recByteSaved;
ChunkSize = Subchunk2Size + 36;
frec.seek(0);
frec.write("RIFF");
byte1 = ChunkSize & 0xff;
byte2 = (ChunkSize >> 8) & 0xff;
byte3 = (ChunkSize >> 16) & 0xff;
byte4 = (ChunkSize >> 24) & 0xff;
frec.write(byte1); frec.write(byte2); frec.write(byte3); frec.write(byte4);
frec.write("WAVE");
frec.write("fmt ");
byte1 = Subchunk1Size & 0xff;
byte2 = (Subchunk1Size >> 8) & 0xff;
byte3 = (Subchunk1Size >> 16) & 0xff;
byte4 = (Subchunk1Size >> 24) & 0xff;
byte1 = AudioFormat & 0xff;
byte2 = (AudioFormat >> 8) & 0xff;
byte1 = numChannels & 0xff;
byte2 = (numChannels >> 8) & 0xff;
byte1 = sampleRate & 0xff;
byte2 = (sampleRate >> 8) & 0xff;
byte3 = (sampleRate >> 16) & 0xff;
byte4 = (sampleRate >> 24) & 0xff;
byte1 = byteRate & 0xff;
byte2 = (byteRate >> 8) & 0xff;
byte3 = (byteRate >> 16) & 0xff;
byte4 = (byteRate >> 24) & 0xff;
byte1 = blockAlign & 0xff;
byte2 = (blockAlign >> 8) & 0xff;
byte1 = bitsPerSample & 0xff;
byte2 = (bitsPerSample >> 8) & 0xff;
frec.write("data");
byte1 = Subchunk2Size & 0xff;
byte2 = (Subchunk2Size >> 8) & 0xff;
byte3 = (Subchunk2Size >> 16) & 0xff;
byte4 = (Subchunk2Size >> 24) & 0xff;
frec.close();
Serial.println("header written");
Serial.print("Subchunk2: ");
Serial.println(Subchunk2Size);
void end_Beep(void) {
waveform1.frequency(523.25);
wait(250);
wait(250);
wait(250);
wait(250);
wait(250);
wait(250);
wait(250);
void two_tone_Beep(void) {
wait(250);
waveform1.frequency(375.0);
wait(250);
wait(250);
wait(250);
wait(250);
wait(250);
wait(250);
void print_mode(void) { // only for debugging
Serial.print("Mode switched to: ");
// Initialising, Ready, Prompting, Recording, Playing
if(mode == Mode::Ready) Serial.println(" Ready");
else if(mode == Mode::Prompting) Serial.println(" Prompting");
else if(mode == Mode::Recording) Serial.println(" Recording");
else if(mode == Mode::Playing) Serial.println(" Playing");
else if(mode == Mode::Initialising) Serial.println(" Initialising");
else if(mode == Mode::Recording_Greeting) Serial.println(" Recording Greeting");
else Serial.println(" Undefined");
The code you use, is not the code from my github. There are several #ifdef for Teensy LC.
I have only tried T4 and I doubt the code will run on Teensy LC
Hi, I'm new here, and new to all of this. And first of all, I really appreciate the open source code for this as well as this community that is willing to help people out!
I built one of these yesterday and I am having good success - the greeting is working, the recording is working, and so on (I decided to not worry about the playback button, but may wire it in later on).
The only think I have not been able to get to happen is plugging the usb cord to a computer and being able to see the files on the computer. I have it set to "Serial + MTP (experimental)". I am using a mac. Is this just not possible on a mac? Would love to not have to open the phone anytime I want to access the files! I am using the code from github, and have installed the MTP-Teensy.h library in the /Applications/Teensyduino.app/Contents/Java/libraries/MTP_Teensy
Any help will be appreciated! I am not getting any errors when I compile. Don't know what's going on. Thanks in advance!
