Ambient Temperature Rating of Teensy 4.0 and 4.1?
NewLinuxFan
I was wondering if these calcs are accurate:
3.3V * 100mA (@600Mhz) = 0.33 Watts of heat
Junction-to-Ambient, no heat sink, natural convection: 40.8 C/W
0.33 W * 40.8 C/W = 13.5 C temperature difference
max junction: 95C
95C - 13.5C = 81.5C = 178.7F without heat sink, natural convection
But junction-to-case is listed at 16.8 C/W, meaning case to air is around 24 C/W which seems a bit too optimistic because that's in the range of an actual heat sink. Maybe the copper traces on the bottom dissipate heat as well as pins.
But I also saw somebody measure 83mA in another thread, so that would improve heat tolerance.
Replying to myself again...a quarter of that heatsink is likely lower than 36 C/W, maybe 30 or high 20's because all 4 sides are exposed to fresh air. I'll see if I can find a commercial product that fits...
Junction to ambient "thermal resistance" is not a rigid specification. It's an empirical measurement. Often semiconductor manufacturers will give this sort of info with a footnote about the specific test conditions. Some are more honest than others, who perform the test using an utterly unrealistic PCB having huge copper area without solder mask. Sometimes that footnote about test conditions gets pushed to an app note or just omitted completely. But you really can't expect a single authoritative junction to ambient spec. It's just not realistic. Thermal performance depends on the surrounding environment.
The chip has an internal temperature sensor you can use to measure the actual on-die temperature. Using that sensor to monitor the actual temperature in your application is the proper way.
If the temperature is getting too high, the first step to consider is underclocking to 528 MHz (use the Tools > CPU Speed menu). The CPU voltage used is lower for 528 MHz, so you get a pretty substantial improvement without a huge loss in performance.
Maybe I am missing something. Using Serial.printf("%.2f°C\n", tempmonGetTemp()) to monitor the T4.1 I get Tjunction = 74degrees C. It is a pretty full application using two TDM interfaces, a TFT display and a few leds and pushbuttons. If I assume a very conservative 50 C/W that would mean my power consumption was about 1 watt. That would mean the T4.1 is using about 300 mA of current.
What am I missing regarding the assumption that the T4.x consumes about 100 mA?
