I want to use a teensy 4.1 to be able to monitor the audio signal from the PC obtaining it's approximate FFT.
Since I recently installed liquid cooling for the processor and video card of the PC, I would also like to monitor the temperature of the coolant and some extra components that normally don't have a sensor. I built four temperature sensors with film NTC probes, to get the temperature with the help of the teensy, I connected each sensor as a resistive voltage divider.
I monitor the readings of each signal through an analog pin of the teensy; for this I want to use pins A14, A15, A16 and A17.
This is the routine that generates the FFT using pin A2 as the audio signal input.
Without reading the analog pin the FFT is generated without problems
No matter where I place the reading of pin A14, within the routine, the audio signal is interrupted and the FFT is not produced.
NTC
FFT
Separately the routines work very well, however when joining them in the main program, the reading of the NTC probes prevails and that of pin A2 for FFT is interrupted.
Is it possible to get any analog pin read without affecting the process of obtaining the FFT on the A2 pin?
AudioInputAnalog adc1;
AudioAnalyzeFFT1024 fft1024_2;
AudioOutputI2S i2s1;
AudioConnection patchCord3(adc1, fft1024_2);
#define NUM_BINS 380 // 380-16000 Hz (1 BIN = 42.18 Hz)
double Datos[NUM_BINS];
int Bin_inicial = 3; // 6
double FRuido= 0;
double escalaFFT = 10;
double MultiFFT = 1000;
const int Sensor_3 = A14;
double LecturaS_3=0;
AudioMemory(30);
fft1024_2.windowFunction(AudioWindowTukey1024);
//LecturaS_3=analogRead(Sensor_3);
if (fft1024_2.available())
for (int i=Bin_inicial; i < NUM_BINS; i=i+1)
Datos[i] = (fft1024_2.read(i)*MultiFFT*escalaFFT)-FRuido*escalaFFT;
if(Datos[i]<=0){Datos[i]=1;}
Serial.println(Datos[i]);
NTC
FFT
