Help! Analog Signal to Teensy from analog Arcadestick
RabbitRocky
New member
I am trying to read analog signals form a arcade stick.
The joystick I use is the:
MAGENTA Programmable Analog to Digital Joystick
This Joystick uses a Magnet and probably Hallsensors to detect the values and converts them to Digital Signals.
The programmable part is you can choose how much you want to tilt the stick till the joystick can send a "Pressed" signal.
My plan was to figure out where the analog signals are and just solder a wire from the stick direct to the teensy analog pins.
My question is where could I solder the wire (my hunch is probably at the end of all the 8 Sensors) and if it could damage anything since directly connect teensy from a random point of the joystick
I tried to read the serialnumbers of the sensors but could only read alpa on it
thanks in advance
