Results 1 to 8 of 8
Thread: SDR A.M. Transmitter on I Q Mixer board RF harmonic problem
    Junior Member stefanodi's Avatar
    May 2022
    Vicenza Italy
    12
    Hi, after solving the code to generate the amplitude modulation in a radio transmitter (thanks again Bob!), Now I ask for help to solve the problem of the harmonic generated by the 11025Khz oscillator visible in the photo.
    I am attaching the schematic of the Tayloe based mixer board designed by my radio friend Giampietro (IK3MAX) which works great in SSB.
    I tried some filters (FIR), but the problem remains ... Thanks in advance to those who will help me.
    Stefano.
    /* File: AM_TEST_TX-FORUM-1.ino
     * Project's name: "Old Style A.M. RTX"
     * Initial project request by Stefano Homebrew
     * @ https://forum.pjrc.com/forum.php
     * Forum code by BOB LARKIN
     * Developed for Teensy 4.0 https://www.pjrc.com/teensy/
     * Audio shield PCM1808 & PCM5102A
    #include <si5351.h>
    #include <ILI9341_t3.h>
    //****Display ILI9341
    #define TFT_DC    9
    #define TFT_CS    10
    #define TFT_RST   255
    #define TFT_MOSI  11
    #define TFT_SCLK  13
    #define TFT_MISO  12
    #define BLACK    0x0000//My alternative colors
    #define MARRONE  0x5041//My alternative colors
    #define IF_FREQ 11025.0  //15000//****sine gen.
    //****var pll frequency init.
    volatile long freq = 25000000;//test lab. frequency
    volatile uint32_t vfoFreq = 0;//for next implementations
    //****var print frequency
    byte unita,decine,centinaia,migliaia,decinemigliaia,centmigliaia,milioni ;  //variabili stampa freq.
    AudioInputI2S            i2s2;           //xy=151.66675567626953,142.0000286102295
    AudioSynthWaveformDc     dc1;            //xy=307.6666831970215,73.00003051757812
    AudioFilterBiquad        biquad1;        //xy=309.6666831970215,137.00004863739014
    AudioMixer4              mixer1;         //xy=490.2820587158203,85.0000228881836
    AudioSynthWaveform       waveform1;      //xy=493.12828826904297,186.00009155273438
    AudioEffectMultiply      multiply1;      //xy=722.4359931945801,84.15388488769531
    AudioOutputI2S           i2s1;           //xy=1117.6666526794434,77.00004529953003
    AudioConnection          patchCord1(i2s2, 0, biquad1, 0);
    AudioConnection          patchCord2(dc1, 0, mixer1, 0);
    AudioConnection          patchCord3(biquad1, 0, mixer1, 1);
    AudioConnection          patchCord4(mixer1, 0, multiply1, 0);
    AudioConnection          patchCord5(waveform1, 0, multiply1, 1);
    AudioConnection          patchCord6(multiply1, 0, i2s1, 0);
    AudioControlSGTL5000     sgtl5000_1;     //xy=312.6666679382324,200.00005531311035
    ILI9341_t3 tft=ILI9341_t3(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
    Si5351 si5351;
    //****init ILI9341
      tft.begin();
      tft.setRotation(3);
    //*****DISPLAY REM
      tft.setCursor(2, 232);
      tft.setTextColor(ILI9341_GREEN, ILI9341_BLACK);
      tft.setTextSize(1);
      tft.print("AM_TEST_TX-FORUM-1");
    //*****PLL SET
      si5351.init(SI5351_CRYSTAL_LOAD_8PF, 0, 0);
      si5351.set_correction(210000, SI5351_PLL_INPUT_XO);//My XTAL correction
      si5351.set_pll(SI5351_PLL_FIXED, SI5351_PLLA);
      si5351.drive_strength(SI5351_CLK2, SI5351_DRIVE_6MA);
      si5351.set_freq((freq-IF_FREQ) * 400ULL, SI5351_CLK2);
    //*****Audio shield SETUP**************************************************
      AudioNoInterrupts();
      AudioMemory(16);
      sgtl5000_1.enable();
      sgtl5000_1.inputSelect(AUDIO_INPUT_LINEIN);
      sgtl5000_1.volume(1.0);
      waveform1.begin(1.0f,IF_FREQ,WAVEFORM_SINE);
      dc1.amplitude(0.5f);//*****************************livello modulazione
      mixer1.gain(0,1.0f);
      mixer1.gain(1,1.0f);
      biquad1.setLowpass(0,8000,0.7);//passa basso
      biquad1.setHighpass(1,100,0.7);//passa alto
      AudioInterrupts();
        stampafrq();
    //****Setup End
    //***************PRINT @frequency DISPLAY
    void stampafrq()
       vfoFreq=freq; ///////////////////////////////////////////////////
        milioni = int(vfoFreq/1000000);
        centmigliaia = ((vfoFreq/100000)%10);
        decinemigliaia = ((vfoFreq/10000)%10);
        migliaia = ((vfoFreq/1000)%10);
        centinaia = ((vfoFreq/100)%10);
        decine = ((vfoFreq/10)%10);
        unita = ((vfoFreq/1)%10);
        tft.fillRect(112, 44, 169, 32, BLACK);
        tft.setTextSize(3);
        tft.setCursor(121,44);
        tft.setTextColor(ILI9341_WHITE);
        tft.print(milioni);//
        tft.print(".");
        tft.print(centmigliaia);
        tft.print(decinemigliaia);
        tft.print(migliaia);
        tft.print(".");
        tft.print(centinaia);
        tft.print(decine);
    Dec 2016
    198
    I do not understand what the spectrum plot is. Is this an RF spectrum? My computer doesn't show enough resolution to read the schematic, so it is hard to help!! Bob
    May 2022
    Vicenza Italy
    12
    Hi Bob, I'm back online!
    I am attaching the schematic of the RTX card in high resolution.
    The AM modulator works well, only it gives me the problem you see in the second photo, @ RF output, it generates this harmonic: (25Mhz + & - IF_FREQ 11025.0) as you can see.
    Obviously I don't have this problem in SSB because I don't have IF_FREQ 11025.0
    I don't understand if the problem is my card or the software.
    Thanks for your help!
    Stefano
Name:	AM_TX_MIXER_11025 hARMONIC.jpg
    in SSB it generates 25Mhz 50Mhz etc ... of harmonics, with the IF_FREQ 11025.0 it generates the harmonic every 11025
    May 2017
    365
    I think one way you could send AM with your hardware was to have two versions of your AM modulator, one for the I channel and one for the Q channel. The waveform generators would be 90 degrees difference in phase. The I and Q will go through your transmitter the same as a SSB signal. If set up for USB you will have the desired AM at +11025 hz above your master SI5351 oscillator and there will be the suppressed image AM signal at master oscillator -11025 hz. If the balance is good the suppressed image should meet ( FCC for me ) requirements.
    There may be different and better ways, I am not an expert but just experiment with some of the DSP stuff.
    Ron K1URC
    Edit:
    Another way I thought of just now would be to take your existing AM signal at 11025 and run it through a pair of Hilbert filters, +45 degrees for I and -45 degrees for Q. The Hilbert filters will want to pass 11025hz +- your desired AM bandwidth. This approach may be a better fit with your current SSB processing. I think the key point here is that you need an I version and a Q version of your audio.
    May 2022
    Vicenza Italy
    12
    Thanks Ron for the reply (We know you for good QCX SDR!) .
    With my friend Giampietro (IK3MAX, the designer of the RTX mixer board) we are also testing your proposals.
    For the moment we don't have a positive result.
    If you have any other suggestions ... Good!
    Thank you.
    Stefano
    May 2022
    Vicenza Italy
    12
    Quote Originally Posted by rcarr View Post
    Ron K1URC
    Edit:
    Ciao everyone,
    I have attached the photo of the best solution to eliminate the harmonics generated (on I & Q Mixer, Tx out) by the IF_FREQ 11025.0
    If anyone has any better ideas... Great!
    Stefano
Name:	AM MODULATION.png
    Dec 2016
    198
    Quote Originally Posted by stefanodi View Post
    Ciao everyone,
    Stefano
    That looks great Stefano!!
    Not to suggest that you need to change anything, but, if you want to explore this more, there is a library class, RadioIQMixer_F32 that is what you have, after "Mixer1". That includes the two oscillators and multipliers. I mention that because it also includes small amplitude and phase adjustment functions that can compensate for errors in the external hardware. Or, you may choose to ignore that issue altogether!!
    Have fun, Bob
    May 2022
    Vicenza Italy
    12
    Quote Originally Posted by Bob Larkin View Post
    Have fun, Bob
    Very good!
    With this I closed and solved the AM transmission problem with Teensy 4.0, 16 Bit 44.1 Khz audio sampling system.
    Dear Bob, I have tried your 32bit 96Khz system and it works very well! I will open a new post for another request that will concern
    OpenAudio_ArduinoLibrary .
    Now, thanks for the help!
    Best regards
    Stefano
