Results 1 to 14 of 14
Thread: Teensy 4.0 Audio Shield - SD Card not initialising
    Jul 2022
    13
    I am working to make an audio guest book and struggling to get the SD card initialized. Please refer to the following pictures with hardware connections and errors I have been encountering. Any help to fix this would be highly appreciated.
Name:	SD ERRORS.JPG
    Aug 2018
    Brisbane, Australia
    129
    The Rev C Audio Shield in your photos is not compatible with Teensy 4.x
    See here
    4,279
    Quote Originally Posted by thebigg View Post
    See here
    In particular, with regard to just the SD drive and flash memory if you've soldered it on, the 3.x Teensys needed to use the alternate SPI ports because the I2S ports for the audio stuff overlapped with some of the SPI pins. Unfortunately the Teensy 4.x systems don't support the alternate SPI pins that the Teensy 3.x systems did.
    Jul 2022
    13
    Thanks ... I have ordered a Rev D Audio Shield and will try the same again.
    Jul 2022
    13
    Hello, I have changed the board and cards but now getting only "Initializing SD card.." message with no further progress..
    using codes form "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\exa mples\listfiles" etc. but similar results
    // change this to match your SD shield or module;
    // Teensy 2.0: pin 0
    // Teensy++ 2.0: pin 20
    // Wiz820+SD board: pin 4
    // Teensy audio board: pin 10
    // Teensy 3.5 & 3.6 & 4.1 on-board: BUILTIN_SDCARD
    const int chipSelect = 10;
    //Uncomment these lines for Teensy 3.x Audio Shield (Rev C)
    SPI.setMOSI(11); // Audio shield has MOSI on pin 7
    SPI.setSCK(13); // Audio shield has SCK on pin 14
    while (!Serial) {
    ; // wait for serial port to connect.
    Serial.print("Initializing SD card...");
    if (!SD.begin(chipSelect)) {
    Serial.println("initialization failed!");
    return;
    Serial.println("initialization done.");
    File root = SD.open("/");
    printDirectory(root, 0);
    Serial.println("done!");
    // nothing happens after setup finishes.
    void printDirectory(File dir, int numSpaces) {
    while(true) {
    File entry = dir.openNextFile();
    if (! entry) {
    //Serial.println("** no more files **");
    printSpaces(numSpaces);
    Serial.print(entry.name());
    if (entry.isDirectory()) {
    Serial.println("/");
    printDirectory(entry, numSpaces+2);
    // files have sizes, directories do not
    unsigned int n = log10(entry.size());
    if (n > 10) n = 10;
    printSpaces(50 - numSpaces - strlen(entry.name()) - n);
    Serial.print(" ");
    Serial.print(entry.size(), DEC);
    DateTimeFields datetime;
    if (entry.getModifyTime(datetime)) {
    printSpaces(4);
    printTime(datetime);
    entry.close();
    void printSpaces(int num) {
    for (int i=0; i < num; i++) {
    Serial.print(" ");
    void printTime(const DateTimeFields tm) {
    const char *months[12] = {
    "January","February","March","April","May","Ju ne",
    "July","August","September","October","November"," December"
    if (tm.hour < 10) Serial.print('0');
    Serial.print(tm.hour);
    Serial.print(':');
    if (tm.min < 10) Serial.print('0');
    Serial.print(tm.min);
    Serial.print(" ");
    Serial.print(tm.mon < 12 ? months[tm.mon] : "???");
    Serial.print(" ");
    Serial.print(tm.mday);
    Serial.print(", ");
    Serial.print(tm.year + 1900);
    Cheltenham, UK
    869
    	while (!Serial) {
    		return;
    	while (true) {
    		if (!entry) {
    			printDirectory(entry, numSpaces + 2);
    		else {
    			if (n > 10) n = 10;
    			Serial.print(" ");
    				printSpaces(4);
    		entry.close();
    	for (int i = 0; i < num; i++) {
    		Serial.print(" ");
    	const char* months[12] = {
    	Serial.print(':');
    	Serial.print(" ");
    	Serial.print(" ");
    	Serial.print(", ");
    In future could you enclose your posted code between code tags using the # button, I think you will agree that it makes your code much easier to understand. This will make it more likely that someone will be able to help you.
    Unfortunately I have no experience using the Audio card so I do not fall into that group.
    New York
    8,429
    I can't be 100% sure but don't think your pins are not aligned correctly between the T4 and the audio shield. See audio shield pinout vs your picture:
    Particularly note pins on the audio shield versus what's on the T4. YOu have the 5v/G/3.3v pins going to GND/0/1 pins on the audio shield. See this page for some mounting ideas:https://www.pjrc.com/store/teensy3_audio.html
    10,976
    I think you are right. My quick look was that the Headphone jack was on the same side as USB connection. But did not notice that the board was logically upside down so The left hand side pins are on the right hand side...
    Jul 2022
    13
    Thanks - will try again connecting pins properly as suggested above.
    Jul 2022
    13
    Thanks for the help... I made those changes as suggested ... now it works, I can play the greeting.wav and record *.raw files and play back. However, while compiling I am receiving the following. Can anyone please suggest if the following indicating as errors? If so, how can I resolve?
    C:\Users\dasau\OneDrive\80 AURICA\NICOLA\audio-guestbook\audio-guestbook.ino: In function 'void loop()':
    C:\Users\dasau\OneDrive\80 AURICA\NICOLA\audio-guestbook\audio-guestbook.ino:131:9: warning: enumeration value 'Initialising' not handled in switch [-Wswitch]
    switch(mode){
    C:\Users\dasau\OneDrive\80 AURICA\NICOLA\audio-guestbook\audio-guestbook.ino: In function 'void playAllRecordings()':
    C:\Users\dasau\OneDrive\80 AURICA\NICOLA\audio-guestbook\audio-guestbook.ino:265:36: warning: invalid conversion from 'const char*' to 'char*' [-fpermissive]
    if (strstr(strlwr(entry.name() + (len - 4)), ".raw")) {
    In file included from c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\stdlib.h:11:0,
    from C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/WProgram.h:34,
    from C:\Users\dasau\AppData\Local\Temp\arduino_build_78 0846\pch\Arduino.h:6:
    c:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\string.h:150:7: note: initializing argument 1 of 'char* strlwr(char*)'
    char *_EXFUN(strlwr,(char *));
    Opening Teensy Loader...
    Memory Usage on Teensy 4.0:
    FLASH: code:77604, data:10376, headers:8272 free for files:1935364
    RAM1: variables:14688, code:75240, padding:23064 free for local variables:411296
    RAM2: variables:29024 free for malloc/new:495264
     * Audio Guestbook, Copyright (c) 2022 Playful Technology
     * Tested using a Teensy 4.0 with Teensy Audio Shield, although should work
     * with minor modifications on other similar hardware
     * When handset is lifted, a pre-recorded greeting message is played, followed by a tone.
     * Then, recording starts, and continues until the handset is replaced.
     * Playback button allows all messages currently saved on SD card through earpiece
     * Files are saved on SD card as 44.1kHz, 16-bit, mono signed integer RAW audio format
     * These can be loaded directly into Audacity (https://www.audacityteam.org/). Or else, converted to WAV/MP3 format using SOX (https://sourceforge.net/projects/sox/)
    // INCLUDES
    // The default "sketchbook" location in which Arduino IDE installs libraries is:
    // C:\Users\alast\Documents\Arduino
    // However, the TeensyDuino installer installs libraries in:
    // C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries
    // To ensure the correct libraries are used when targetting Teensy platform in Arduino IDE, go File->Preferences and change the sketchbook location to avoid conflicts with Arduino libraries.
    // When targetting Arduino boards, change it back again to default
    #include <Bounce.h>
    #include <TimeLib.h>
    // DEFINES
    // Define pins used by Teensy Audio Shield
    #define SDCARD_CS_PIN    10
    #define SDCARD_MOSI_PIN  7
    #define SDCARD_SCK_PIN   14
    // And those used for inputs
    #define HOOK_PIN 0
    #define PLAYBACK_BUTTON_PIN 1
    // GLOBALS
    // Audio initialisation code can be generated using the GUI interface at https://www.pjrc.com/teensy/gui/
    // Inputs
    AudioSynthWaveform      waveform1; // To create the "beep" sfx
    AudioInputI2S           i2s2; // I2S input from microphone on audio shield
    AudioPlaySdRaw          playRaw1; // Play .RAW audio files saved on SD card
    AudioPlaySdWav          playWav1; // Play 44.1kHz 16-bit PCM greeting WAV file
    // Outputs
    AudioRecordQueue         queue1; // Creating an audio buffer in memory before saving to SD
    AudioMixer4              mixer; // Allows merging several inputs to same output
    AudioOutputI2S           i2s1; // I2S interface to Speaker/Line Out on Audio shield
    // Connections
    AudioConnection patchCord1(waveform1, 0, mixer, 0); // wave to mixer
    AudioConnection patchCord2(playRaw1, 0, mixer, 1); // raw audio to mixer
    AudioConnection patchCord3(playWav1, 0, mixer, 2); // wav file playback mixer
    AudioConnection patchCord4(mixer, 0, i2s1, 0); // mixer output to speaker (L)
    AudioConnection patchCord5(i2s2, 0, queue1, 0); // mic input to queue (L)
    AudioControlSGTL5000     sgtl5000_1;
    // Filename to save audio recording on SD card
    char filename[15];
    // The file object itself
    File frec;
    // Use long 40ms debounce time on hook switch
    Bounce buttonRecord = Bounce(HOOK_PIN, 40);
    Bounce buttonPlay = Bounce(PLAYBACK_BUTTON_PIN, 8);
    // Keep track of current state of the device
    enum Mode {Initialising, Ready, Prompting, Recording, Playing};
    Mode mode = Mode::Initialising;
      // Note that Serial.begin() is not required for Teensy -
      // by default it initialises serial communication at full USB speed
      // See https://www.pjrc.com/teensy/td_serial.html
      // Serial.begin()
      Serial.println(__FILE__ __DATE__);
      // Configure the input pins
      pinMode(HOOK_PIN, INPUT_PULLUP);
      pinMode(PLAYBACK_BUTTON_PIN, INPUT_PULLUP);
      AudioMemory(60);
      sgtl5000_1.enable();
      // Define which input on the audio shield to use (AUDIO_INPUT_LINEIN / AUDIO_INPUT_MIC)
      sgtl5000_1.volume(0.5);
      // Play a beep to indicate system is online
      waveform1.frequency(440);
      waveform1.amplitude(0.9);
      wait(250);
      waveform1.amplitude(0);
      // Initialize the SD card
      SPI.setMOSI(SDCARD_MOSI_PIN);
      SPI.setSCK(SDCARD_SCK_PIN);
        while (1) {
      // Value in dB
      sgtl5000_1.micGain(15);
      // Synchronise the Time object used in the program code with the RTC time provider.
      // See https://github.com/PaulStoffregen/Time
      // Define a callback that will assign the correct datetime for any file system operations
      // (i.e. saving a new audio recording onto the SD card)
      FsDateTime::setCallback(dateTime);
      mode = Mode::Ready;
      // First, read the buttons
      buttonRecord.update();
      buttonPlay.update();
      switch(mode){
        case Mode::Ready:
          // Rising edge occurs when the handset is lifted
          if (buttonRecord.fallingEdge()) {
            Serial.println("Handset lifted");
            mode = Mode::Prompting;
          else if(buttonPlay.risingEdge()) {
            playAllRecordings();
        case Mode::Prompting:
          // Wait a second for users to put the handset to their ear
          wait(1000);
          // Play the greeting inviting them to record their message
          playWav1.play("greeting.wav");
          // Wait until the  message has finished playing
          while (playWav1.isPlaying()) {
            // Check whether the handset is replaced
            //  Serial.println("greeting playing");
            // Handset is replaced
            if(buttonRecord.risingEdge()) {
              playWav1.stop();
              mode = Mode::Ready;
              return;
          // Debug message
          Serial.println("Starting Recording");
          // Play the tone sound effect
          wait(250);
          // Start the recording function
          startRecording();
        case Mode::Recording:
          if(buttonRecord.risingEdge()){
            // Debug log
            Serial.println("Stopping Recording");
            // Stop recording
            stopRecording();
            // Play audio tone to confirm recording has ended
            waveform1.frequency(523.25);
            wait(50);
            wait(50);
            wait(50);
          else {
            continueRecording();
        case Mode::Playing:
    void startRecording() {
      // Find the first available file number
      for (uint8_t i=0; i<9999; i++) {
        // Format the counter as a five-digit number with leading zeroes, followed by file extension
        snprintf(filename, 11, " %05d.RAW", i);
        // Create if does not exist, do not open existing, write, sync after write
        if (!SD.exists(filename)) {
      frec = SD.open(filename, FILE_WRITE);
      if(frec) {
        Serial.print("Recording to ");
        Serial.println(filename);
        queue1.begin();
        mode = Mode::Recording;
      else {
        Serial.println("Couldn't open file to record!");
    void continueRecording() {
      // Check if there is data in the queue
      if (queue1.available() >= 2) {
        byte buffer[512];
        // into a 512 byte buffer.  The Arduino SD library
        // writes are used.
        memcpy(buffer, queue1.readBuffer(), 256);
        queue1.freeBuffer();
        memcpy(buffer+256, queue1.readBuffer(), 256);
        // Write all 512 bytes to the SD card
        frec.write(buffer, 512);
    void stopRecording() {
      // Stop adding any new data to the queue
      queue1.end();
      // Flush all existing remaining data from the queue
        // Save to open file
        frec.write((byte*)queue1.readBuffer(), 256);
      // Close the file
      frec.close();
      mode = Mode::Ready;
    void playAllRecordings() {
      // Recording files are saved in the root directory
      File dir = SD.open("/");
      while (true) {
        if (!entry) {
          // no more files
          entry.close();
        int8_t len = strlen(entry.name());
          Serial.print("Now playing ");
          Serial.println(entry.name());
          // Play a short beep before each message
          waveform1.amplitude(0.5);
          wait(250);
          // Play the file
          playRaw1.play(entry.name());
          mode = Mode::Playing;
        entry.close();
        while (playRaw1.isPlaying()) {
          // Button is pressed again
          if(buttonPlay.fallingEdge() || buttonRecord.risingEdge()) {
            playRaw1.stop();
            mode = Mode::Ready;
            return;
      // All files have been played
      mode = Mode::Ready;
    // Retrieve the current time from Teensy built-in RTC
    time_t getTeensy3Time(){
      return Teensy3Clock.get();
    // Callback to assign timestamps for file system operations
    void dateTime(uint16_t* date, uint16_t* time, uint8_t* ms10) {
      // Return date using FS_DATE macro to format fields.
      *date = FS_DATE(year(), month(), day());
      // Return time using FS_TIME macro to format fields.
      *time = FS_TIME(hour(), minute(), second());
      // Return low time bits in units of 10 ms.
      *ms10 = second() & 1 ? 100 : 0;
    // Non-blocking delay, which pauses execution of main program logic,
    // but while still listening for input
    void wait(unsigned int milliseconds) {
      elapsedMillis msec=0;
      while (msec <= milliseconds) {
        if (buttonRecord.risingEdge()) Serial.println("Button (pin 0) Press");
        if (buttonPlay.risingEdge()) Serial.println("Button (pin 1) Press");
        if (buttonRecord.fallingEdge()) Serial.println("Button (pin 0) Release");
        if (buttonPlay.fallingEdge()) Serial.println("Button (pin 1) Release");
    Jul 2022
    7
    Hi, as far as i understand, there's 2 warning and 1 note, no errors, if theres an "opening teensy loader" line in your output, it usually means compiling went fine and you can upload the sketch. if it doesn't do so by itself, press the button on the teensy.
    That said, i'm a bloody neewb myself, so take it with a grain of salt :-)
    10,976
    Quote Originally Posted by UjjalD View Post
    As mentioned these are just compiler warnings. As to are they going to impact the program? Hard to say without looking at them.
    switch(mode){
    This one is saying: You are doing a switch on mode
    Which is defined to have the following possible values: enum Mode {Initialising, Ready, Prompting, Recording, Playing};
    And it is saying that you did not say anything about the possible state: Initialising
    Ways around it: add case for it or add default:
    These could be simply to then do: break;
    So the compiler knows that it is handled...
    This one is saying that you are passing entry.name() which is a (const char *) plus some offset to the function strlwr which takes a (char *)
    Which is complaining that that function might try to change something that is marked const.
    Two fixes: strlwr should really be marked as taking: const char * But that is library function so...
    Or you tell the compiler that you want to pass it as char *
    if (strstr(strlwr((char*)entry.name() + (len - 4)), ".raw")) {
    Apr 2021
    Cambridgeshire, UK
    445
    This isn't quite correct, and could cause problems...
    You are passing the result of a call to the function entry.name(), which returns a const char*: this tells you that you must not attempt to modify the data pointed to. Calling strlwr() with it as a parameter is such an attempt, because if there are upper-case characters in the filename then it will try to modify them in place, which is why strlwr() takes a char* parameter, and should absolutely not be "marked as taking const char*", because it doesn't!
    EDIT: A better choice by the original author would have been to use strcasecmp(const char*, const char *), which does exactly what's wanted at this point...
    I assume you've seen this thread, which addresses some of the other problems that this particular piece of code has.
    Last edited by h4yn0nnym0u5e; 07-24-2022 at 02:02 PM. Reason: Added note about strcasecmp()
    10,976
    Yep - I should have looked at the function
    And yes better choice!
