Hi!
I am trying to interface the MAX98089 audio codec with Teensy 4.1. Mainly I am interested in this codec, as it has integrated speaker amp and some more interfacing options compared to SGTL5000.
I have a custom board based on the evaluation board reference design of the MAX98089. I have managed to establish I2C connection between the Teensy and the audio codec. I can successfully read and write registers with the Wire library. Even the jack detection works correctly.
However, I am having trouble getting the i2S connection to work. When reading the status register from the audio codec it says: "Either digital audio interface is configured incorrectly or receiving invalid clocks."
This leads me to believe that I have not managed to configure the codec correctly so that it would interface with the Teensy as the master.
The connections should be correct MCLK, BCLK, LRCLK, DIN and DOUT.
I have found this project, which also interfaces Teensy with MAX98089, but here the Teensy is a slave, so it is not much of help for my issue.
https://gitlab.com/amesser-group/electronic-devices/radio-shield/-/tree/master
On page 85 of the datasheet of the MAX98089 it describes the process of setting up the clock source etc:
https://datasheets.maximintegrated.com/en/ds/MAX98089.pdf
Here are some of my settings related to the audio input:
0x10 (MCLK prescaler) -> 01 (as Teensy MCLK is 11.29MHz)
0x11 (Sample rate) -> 0x7(44.1KHz)
0x12 I have tried to enable PLL mode, but not exactly sure about the settings on this one.
Here is the full code where I setup all the registers: (For now, I am just trying to get output on headphones.)
Now, I am not very proficient with I2S standard yet. Maybe there are some more experienced heads here on the forums that can spot some obvious mistakes right away?
Best,
Miro
AudioSynthWaveformSine sine1; //xy=411,453
AudioOutputI2S i2s1; //xy=596,455
AudioConnection patchCord1(sine1, 0, i2s1, 0);
AudioConnection patchCord2(sine1, 0, i2s1, 1);
int chordnum=0;
AudioMemory(15);
sine1.amplitude(1.0);
sine1.frequency(400);
Wire.begin();
delay(700);
beginMAX98089();
// Serial.print("Max CPU Usage = ");
// Serial.print(AudioProcessorUsageMax(), 1);
// Serial.println("%");
// maxRead(0x00);
void beginMAX98089() {
// Check that MAX98089 is connected by checking the revision number, should always be 0x40
Wire.beginTransmission(0x10);
Wire.write(0xFF);
Wire.endTransmission(false);
int n = Wire.requestFrom( 0x10, byte(1));
if( n != 1) {
Serial.println( "requestFrom failed");
else {
while(Wire.available()) { // slave may send less than requested
byte c = Wire.read(); // receive a byte as character
Serial.print("0x");
Serial.print(c, HEX); // print the character
Serial.print(" "); // print the character
Wire.endTransmission();
/* Proper Startup sequence
1 Ensure SHDN = 0 0x51
2 Configure Clocks 0x10 to 0x13, 0x19 to 0x1B
3 Configure digital audio interface 0x14 to 0x17, 0x1C to 0x1F
4 Configure digital signal processing 0x18, 0x20, 0x3F to 0x46
5 Load coefficients 0x52 to 0xC9
6 Configure mixers 0x22 to 0x2D
7 Configure gain and volume controls 0x2E to 0x3E
8 Configure miscellaneous functions 0x47 to 0x4B
9 Enable desired functions 0x4C, 0x50
10 Set SHDN = 1 0x51
// Ensure SHDN = 0
if(maxWrite(0x51, 0x00)) { Serial.println("Device disabled"); };
// Configure clocks
if(maxWrite(0x10, 0x10)) { Serial.println("MCLK Prescaler set"); };
if(maxWrite(0x11, 0x70)) { Serial.println("Sample rate set to 44.1 KHz"); };
if(maxWrite(0x12, 0x80)) { Serial.println("Clock mode set"); };
if(maxWrite(0x1A, 0x80)) { Serial.println("Clock mode set"); };
if(maxWrite(0x13, 0x00)) { Serial.println("Clock mode set"); };
if(maxWrite(0x1B, 0x00)) { Serial.println("Clock mode set"); };
// Configure digital audio interface
if(maxWrite(0x14, 0x10)) { Serial.println("DA1 Format set to I2S"); };
if(maxWrite(0x15, 0x00)) { Serial.println("DA1 clock just in case"); };
if(maxWrite(0x16, 0x41)) { Serial.println("S1 routed to DA1"); };
if(maxWrite(0x17, 0x00)) { Serial.println("DA1 TDM Slots"); };
if(maxWrite(0x1C, 0x10)) { Serial.println("DA2 Format set to I2S"); };
// Configure digital signal processing
if(maxWrite(0x18, 0x80)) { Serial.println("Set music mode"); };
// Configure mixers
if(maxWrite(0x22, 0x84)) { Serial.println("Routed DA1 to Headphones"); };
if(maxWrite(0x27, 0x00)) { Serial.println("Bypass headphone mixer"); };
//Configure gain and volume controls
if(maxWrite(0x2F, 0x00)) { Serial.println("Config DA1 Vol"); };
if(maxWrite(0x30, 0x00)) { Serial.println("Config DA1 EQ"); };
if(maxWrite(0x39, 0x1A)) { Serial.println("Set headphone left output & volume"); };
if(maxWrite(0x3A, 0x1A)) { Serial.println("Set headphone right output & volume"); };
// Configure miscellaneous functions
if(maxWrite(0x49, 0x00)) { Serial.println("DAI 1 EQ config"); };
if(maxWrite(0x4B, 0x80)) { Serial.println("Jack detection enabled"); };
// Enable desired functions
if(maxWrite(0x4D, 0xC3)) { Serial.println("Enabled headphone & DAC output"); };
if(maxWrite(0x4E, 0xF0)) { Serial.println("Top level bias set"); };
if(maxWrite(0x50, 0x0F)) { Serial.println("Enabled DAI clock gen"); };
// Set SHDN = 1
if(maxWrite(0x51, 0xC0)) { Serial.println("Device enabled"); };
delay(1500);
maxRead(0x00);
bool maxWrite(unsigned int reg, unsigned int val) {
// if (reg == CHIP_ANA_CTRL) ana_ctrl = val;
Wire.write(reg);
Wire.write(val);
if (Wire.endTransmission() == 0) return true;
return false;
void maxRead(unsigned int reg) {
Wire.write(reg);
if( n != 1) {
else {
Serial.print("0x");
Best,
Miro
