How to geat PEAK and FFT values from AudioPlaySdWav (always null)
Fuzzy
Hmm, not sure what I am doing wrong... When doing peak.available() or fft.available() its always returning 0
AudioPlaySdWav           playWav1;     //xy=186,294
AudioMixer4              mixer1;         //xy=376,275
AudioAnalyzePeak         peak1;          //xy=563,260
AudioOutputI2S           i2s1;           //xy=572,213
AudioAnalyzeFFT256       fft256_1;       //xy=595,296
AudioConnection          patchCord1(playWav1, 0, mixer1, 0);
AudioConnection          patchCord2(playWav1, 1, mixer1, 1);
AudioConnection          patchCord3(mixer1, peak1);
AudioConnection          patchCord4(mixer1, fft256_1);
AudioConnection          patchCord5(mixer1, 0, i2s1, 0);
AudioConnection          patchCord6(mixer1, 0, i2s1, 1);
AudioControlSGTL5000     sgtl5000_1;     //xy=341,160
#define SDCARD_CS_PIN    BUILTIN_SDCARD
#define SDCARD_MOSI_PIN  11  // not actually used
#define SDCARD_SCK_PIN   13  // not actually used
long loopcounter = 0;
  AudioMemory(64);
  // Comment these out if not using the audio adaptor board.
  // This may wait forever if the SDA & SCL pins lack
  // pullup resistors
  sgtl5000_1.enable();
  sgtl5000_1.volume(0.25);
//  SPI.setMOSI(SDCARD_MOSI_PIN);
//  SPI.setSCK(SDCARD_SCK_PIN);
    // stop here, but print a message repetitively
    while (1) {
  Serial.print("Playing file: ");
  Serial.println(filename);
  // Start playing the file.  This sketch continues to
  // run while the file plays.
  playWav1.play(filename);
  // A brief delay for the library read WAV info
  delay(25);
  if(playWav1.isPlaying()==false){ //loop it
    playFile("LOOP2.WAV");
  loopcounter++;
  if(loopcounter%100==0){
    Serial.print("fft available: ");Serial.println(fft256_1.available());
    Serial.print("peak available: ");Serial.println(peak1.available());
OUTPUT:
Looking at peak in the audio library
bool available(void) {
		__disable_irq();
		bool flag = new_output;
		if (flag) new_output = false;
		__enable_irq();
		return flag;
you can see that the available flag gets reset when you read it. Since you a reading it over and over it clears and you mostly print out a zero for available.
Each 3ms ( approx audio library update time ) you will print out a 1.
