AntiDysentery
New member
Hi there,
I'm running a teensy 4.1 with APA102 addressable LEDs, FastLed Library, and level shifters.
The problem is I cannot get FastLed to recognize pins 26 and 27 as Hardware SPI. Is this a PJRC issue or a FastLed issue??
300fps on pins 11 and 13 (MOSI, CLK) 15Mhz updates
90 fps on pins 26 and 27 (MOSI1, CLK1) bitbanged speeds
Thanks, I really need the speeds to be equal as they are running two sides of the same LED strip.
